[GeoNode-users] Problem with createsuperuser
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 10 04:55:23 PDT 2016
Hi what version of django are you using?
2016-05-10 13:52 GMT+02:00 Suchakrey Kongpila <suchakreyk at adpc.net>:
> Dear All
> I install Geonode 2.4 by custom install method using this url:
> http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/all_together.html
> When I run the command python manage.py createsuperuser, these error come:
> WARNINGS:
> account.EmailConfirmation.created: (fields.W161) Fixed default value
> provided.
>         HINT: It seems you set a fixed date / time / datetime value as
> default for this field. This may not be what you want. If you want to have
> the current date as default, use `django.utils.timezone.now`
> base.ResourceBase.regions: (fields.W340) null has no effect on
> ManyToManyField.
> dialogos.Comment.ip_address: (fields.W900) IPAddressField has been
> deprecated. Support for it (except in historical migrations) will be
> removed in Django 1.9.
>         HINT: Use GenericIPAddressField instead.
> services.WebServiceHarvestLayersJob.service: (fields.W342) Setting
> unique=True on a ForeignKey has the same effect as using a OneToOneField.
>         HINT: ForeignKey(unique=True) is usually better served by a
> OneToOneField.
> Username: geonode
> Traceback (most recent call last):
>   File "manage.py", line 29, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
>   File
> line 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py",
> line 50, in execute
>     return super(Command, self).execute(*args, **options)
>   File
> line 445, in execute
>     output = self.handle(*args, **options)
>   File
> line 105, in handle
> self.UserModel._default_manager.db_manager(database).get_by_natural_key(username)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/models.py",
> line 162, in get_by_natural_key
>     return self.get(**{self.model.USERNAME_FIELD: username})
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
> 127, in manager_method
>     return getattr(self.get_queryset(), name)(*args, **kwargs)
>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> line 328, in get
>     num = len(clone)
> line 144, in __len__
>     self._fetch_all()
> line 965, in _fetch_all
>     self._result_cache = list(self.iterator())
> line 238, in iterator
>     results = compiler.execute_sql()
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
> line 840, in execute_sql
>     cursor.execute(sql, params)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py", line
> 79, in execute
>     return super(CursorDebugWrapper, self).execute(sql, params)
>   File
> 64, in execute
>     return self.cursor.execute(sql, params)
>   File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line
> 98, in __exit__
>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>   File
> 64, in execute
> django.db.utils.ProgrammingError: relation "people_profile" does not exist
> LINE 1: ...ofile"."zipcode", "people_profile"."country" FROM "people_pr...
> How can I fig this problem? Thanks for your help
> *adpc*
> *Asian Disaster Preparedness Center*
> Mr. Suchakrey Kongpila
> Computer and Network Coordinator
> Tel: +66 2 298 0682-92 *|* Fax: +66 2 298 0012
> Mobile: +66 8 9451 4468 *| *Skype: chakreyk
> www.adpc.net *| **twitter <https://twitter.com/ADPCnet>* *| *facebook
> <https://www.facebook.com/adpc.thailand>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160510/fca5db0d/attachment.html>
More information about the geonode-users mailing list
