[GeoNode-users] 'geonode' command on Ubuntu throws "Unknown command" when called without arguments
Benjamin Ducke benducke at fastmail.fm
Wed May 11 04:37:50 PDT 2016
Hi Simone --
On 11/05/16 13:28, Simone Dalmasso wrote:
> Hi,
> yes those steps are for when you installed geonode using apt-get.
Right, that's what I did.
> They can be issued as they are
But then 'geonode' will throw an error
message, as I described. I find that
a little disconcerting.
> and the geonode theme will be installed
> systemwide as geonode is and you need to have geonode installed before
> doing that.
> You don't have to use django-admin except for the template creation. The
> commands as they are using manage.py work fine. If you installed geonode
> manually then it depends on your configuration but still is very similar.
> The geonode command is not used anymore to do collectstatic because the
> manage.py will take care of it.
So do I understand correctly, that I can just
skip running 'geonode'?
Then maybe that step should be removed from
the instructions on the Web?
Cheers and Thanks for your quick reply!
Ben
> 2016-05-11 12:57 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> <mailto:benducke at fastmail.fm>>:
>> Dear GeoNoders,
>> I am currently setting up my first GeoNode installation, and trying to
>> follow
>> the official  documentation on customization and theming.
>> I would appreciate some help/feedback with the 'geonode' command.
>> My OS is Ubuntu 14.04 and I have installed GeoNode 2.4. from the
>> official
>> packages.
>> On this page:
> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
>> There is a sequence of commands that includes a call to 'geonode' (step
>> 4):
>> 1 $ cd /home/geonode/my_geonode
>> 2 $ python manage.py collectstatic
>> 3 $ python manage.py syncdb
>> 4 $ /home/geonode/geonode
>> 5 $ sudo pip install -e .
>> 6 $ sudo service apache2 restart
>> I am assuming that this refers to '/usr/sbin/geonode' when installed
>> from
>> the Ubuntu packages, correct? Said executable is a simple shell script
>> wrapper for 'django-admin', which just determines whether to use
>> 'django-admin' or 'django-admin.py' (right choice for my OS). So far so
>> good. However, when just calling 'geonode' without any arguments, I get:
>>   Unknown command: '--settings=geonode.settings'
>> Apparently, this is because the arguments placeholder '$@' in
>> '/usr/sbin/geonode'
>> stays empty in this case, but 'django-admin.py' really wants to have the
>> name
>> of a subcommand.
>> So my question is: Did 'django-admin.py' use to have a default
>> subcommand in
>> the past, but no longer? Or are the instructions on the web page above
>> incomplete?
>> Which django-admin subcommand should run in line 4 above?
>> Many thanks for any pointers,
>> Benjamin
>> Benjamin Ducke
>> {*} Geospatial Consultant
>> {*} GIS Developer
>>   benducke AT fastmail.fm <http://fastmail.fm>
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Dr. Benjamin Ducke
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
More information about the geonode-users mailing list
