[GeoNode-users] How to increase the size of GeoExplorer component in Layers section?
Simone Dalmasso simone.dalmasso at gmail.com
Mon May 23 22:52:37 PDT 2016
Hi, that "height" is the correct place. No need to restart apache because
is just a template. If the change id not take effect then could it be that
your template is not the one served by apache? if you inspect the page can
you see your height in there?
2016-05-23 19:38 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm>:
> Thanks for the pointer.
> I assume you refer to this config object:
>   portalConfig: {
>                     renderTo: "preview_map",
>                     height: 400
> I have changed "height" and restarted Apache but no effect.
> Do I have to add something to "portalConfig"?
> Actually, I have not been able to find any documentation on
> the possible contents of "portalConfig". Do you have a URL
> for the official docs?
> Thanks,
> Ben
> Benjamin Ducke
> {*} Geospatial Consultant
> {*} GIS Developer
>   benducke AT fastmail.fm
> On Mon, May 23, 2016, at 18:34, Jeffrey Johnson wrote:
> https://github.com/GeoNode/geonode/blob/master/geonode/layers/templates/layers/layer_geoext_map.html
> > On Mon, May 23, 2016 at 9:29 AM, Benjamin Ducke <benducke at fastmail.fm>
> > wrote:
> > > Hi All --
> > > Is there an easy way to increase the size of the embedded
> > > GeoExplorer layer viewer?
> > > I suppose it must be done in some template, but I cannot
> > > seem to find the right one.
> > > Any hints much appreciated.
> > > Best,
> > > Ben
> > > _______________________________________________
> > > geonode-users mailing list
> > > geonode-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160524/b54baaff/attachment.html>
More information about the geonode-users mailing list
