[GeoNode-users] How to increase the size of GeoExplorer component in Layers section?
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 24 00:09:08 PDT 2016
The portalConfig is part of the Boundless gxp (GeoNode ships it as it is
more or less) so you may find docs there.
http://suite.opengeo.org/opengeo-docs/geoexplorer/
hope this helps
2016-05-24 8:55 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm>:
> Hi Simone,
> Thanks for you advice.
> I also suspect that there is something going
> wrong with the Apache config or browser cache.
> I am a bit frustrated that I cannot seem to
> dig up any documentation on "portalConfig",
> because I think that is a powerful configuration
> mechanism which could provide a lot of the
> features I am looking for (incl. the layer tree
> mentioned in my other email).
> I will investigate this further and then report
> back to this list once I figured it out.
> Cheers,
> Ben
> On 24/05/16 07:52, Simone Dalmasso wrote:
> > Hi, that "height" is the correct place. No need to restart apache
> > because is just a template. If the change id not take effect then could
> > it be that your template is not the one served by apache? if you inspect
> > the page can you see your height in there?
> > 2016-05-23 19:38 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> > <mailto:benducke at fastmail.fm>>:
> >     Thanks for the pointer.
> >     I assume you refer to this config object:
> >       portalConfig: {
> >                         renderTo: "preview_map",
> >                         height: 400
> >     I have changed "height" and restarted Apache but no effect.
> >     Do I have to add something to "portalConfig"?
> >     Actually, I have not been able to find any documentation on
> >     the possible contents of "portalConfig". Do you have a URL
> >     for the official docs?
> >     Thanks,
> >     Ben
> >     Benjamin Ducke
> >     {*} Geospatial Consultant
> >     {*} GIS Developer
> >       benducke AT fastmail.fm <http://fastmail.fm>
> >     On Mon, May 23, 2016, at 18:34, Jeffrey Johnson wrote:
> https://github.com/GeoNode/geonode/blob/master/geonode/layers/templates/layers/layer_geoext_map.html
> >     > On Mon, May 23, 2016 at 9:29 AM, Benjamin Ducke
> >     <benducke at fastmail.fm <mailto:benducke at fastmail.fm>>
> >     > wrote:
> >     > > Hi All --
> >     > > Is there an easy way to increase the size of the embedded
> >     > > GeoExplorer layer viewer?
> >     > > I suppose it must be done in some template, but I cannot
> >     > > seem to find the right one.
> >     > > Any hints much appreciated.
> >     > > Best,
> >     > > Ben
> >     > > _______________________________________________
> >     > > geonode-users mailing list
> >     > > geonode-users at lists.osgeo.org <mailto:
> geonode-users at lists.osgeo.org>
> >     > > http://lists.osgeo.org/mailman/listinfo/geonode-users
> >     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> > Simone
> Dr. Benjamin Ducke
> {*} GIS Developer
> Spatial technology for the masses, not the classes:
> experience free and open source GIS at http://gvsigce.org
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160524/25476619/attachment-0001.html>
More information about the geonode-users mailing list
