[GeoNode-users] How to increase the size of GeoExplorer component in Layers section?
Benjamin Ducke benducke at fastmail.fm
Tue May 24 03:11:09 PDT 2016
On 24/05/16 09:09, Simone Dalmasso wrote:
> The portalConfig is part of the Boundless gxp (GeoNode ships it as it is
> more or less) so you may find docs
> there. http://suite.opengeo.org/opengeo-docs/geoexplorer/
> hope this helps
Unfortunately, these pages are too vague
and don't provide enough detail. I have
filed an "issue" with the OpenGeoSuite
guys. As soon as I have something like a
comprehensive list of "portalConfig"
settings, I will share it on this list.
Thanks and best,
Ben
> 2016-05-24 8:55 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> <mailto:benducke at fastmail.fm>>:
>     Hi Simone,
>     Thanks for you advice.
>     I also suspect that there is something going
>     wrong with the Apache config or browser cache.
>     I am a bit frustrated that I cannot seem to
>     dig up any documentation on "portalConfig",
>     because I think that is a powerful configuration
>     mechanism which could provide a lot of the
>     features I am looking for (incl. the layer tree
>     mentioned in my other email).
>     I will investigate this further and then report
>     back to this list once I figured it out.
>     Cheers,
>     Ben
>     On 24/05/16 07:52, Simone Dalmasso wrote:
>     > Hi, that "height" is the correct place. No need to restart apache
>     > because is just a template. If the change id not take effect then
>     could
>     > it be that your template is not the one served by apache? if you
>     inspect
>     > the page can you see your height in there?
>     > 2016-05-23 19:38 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
>     > <mailto:benducke at fastmail.fm <mailto:benducke at fastmail.fm>>>:
>     >     Thanks for the pointer.
>     >     I assume you refer to this config object:
>     >       portalConfig: {
>     >                         renderTo: "preview_map",
>     >                         height: 400
>     >     I have changed "height" and restarted Apache but no effect.
>     >     Do I have to add something to "portalConfig"?
>     >     Actually, I have not been able to find any documentation on
>     >     the possible contents of "portalConfig". Do you have a URL
>     >     for the official docs?
>     >     Thanks,
>     >     Ben
>     >     Benjamin Ducke
>     >     {*} Geospatial Consultant
>     >     {*} GIS Developer
>     >       benducke AT fastmail.fm <http://fastmail.fm>
>     >     On Mon, May 23, 2016, at 18:34, Jeffrey Johnson wrote:
>      https://github.com/GeoNode/geonode/blob/master/geonode/layers/templates/layers/layer_geoext_map.html
>     >     > On Mon, May 23, 2016 at 9:29 AM, Benjamin Ducke
>     >     <benducke at fastmail.fm <mailto:benducke at fastmail.fm>
>     >     > wrote:
>     >     > > Hi All --
>     >     > > Is there an easy way to increase the size of the embedded
>     >     > > GeoExplorer layer viewer?
>     >     > > I suppose it must be done in some template, but I cannot
>     >     > > seem to find the right one.
>     >     > > Any hints much appreciated.
>     >     > > Best,
>     >     > > Ben
>     >     > > _______________________________________________
>     >     > > geonode-users mailing list
>     >     > > geonode-users at lists.osgeo.org
>     <mailto:geonode-users at lists.osgeo.org>
>     <mailto:geonode-users at lists.osgeo.org>>
>     >     > > http://lists.osgeo.org/mailman/listinfo/geonode-users
>     > Simone
>     Dr. Benjamin Ducke
>     {*} GIS Developer
>     Spatial technology for the masses, not the classes:
>     experience free and open source GIS at http://gvsigce.org
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> Simone
Dr. Benjamin Ducke
{*} GIS Developer
More information about the geonode-users mailing list
