[GeoNode-users] Edit layer no CATALOG
Liyuneh Gebre liyenew at gmail.com
Wed Nov 2 08:51:22 PDT 2016
Dear Alessio
finally ...It worked and i can see some Json files in info.json and* NO 404
EROR*
but i can't get the menu tools to *Map, Print ,Identify ,save and other
options in MAPS *
thanks
On Wed, Nov 2, 2016 at 6:04 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear Liyuneh,
> maybe some passage on the installation tutorial is wrong. As I said before
> the GeoServer 2.7 version you are using on your setup is missing the
> printing plugin.
> If you have just some time to do a quick test, please replace your
> GeoServer version with the following one:
> 1) Stop Tomcat
> 2) Delete the GeoServer folder and WAR inside Tomcat webapps (*do a
> backup first*)
> 3) Put a new GeoServer WAR on webapps from here: http://build.geonode.org/
> geoserver/latest/geoserver.war
> 4) Restart Tomcat
> In order to perform a test you should be able to see a correct JSON
> document from the address
> http://<your_host>/geoserver/pdf/info.json
> Please, let me know how the test goes.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Wed, Nov 2, 2016 at 3:57 PM, Liyuneh Gebre <liyenew at gmail.com> wrote:
>> Dear Alessio
>> Thanks in advance i will wait about  30min in office if it is going to be
>> tomorrow every options are possible,
>> bless u brother
>> On Wed, Nov 2, 2016 at 5:51 PM, Alessio Fabiani <
>>> Dear Liyuneh,
>>> after the private webex session I'm going to reply you on the public
>>> mailing list too.
>>> The issue is related to GeoServer, basically the version you are using
>>> is missing the "Print Plugin". Please give me some time to check if the
>>> public GeoServer WARs also have the same issue. I'll provide you the link
>>> to the GeoServer WAR as soon as possible.
>>> Regards,
>>> Alessio Fabiani.
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Wed, Nov 2, 2016 at 3:01 PM, Liyuneh Gebre <liyenew at gmail.com> wrote:
>>>> Dear Alessio
>>>> if you have time am now available for WebEx meeting
>>>> greetings
>>>> On Wed, Nov 2, 2016 at 2:09 PM, Alessio Fabiani <
>>>>> I can setup a WebEx meeting, you will need just to install a plugin
>>>>> from CISCO.
>>>>> Just let me know your time availability.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Wed, Nov 2, 2016 at 11:56 AM, Liyuneh Gebre <liyenew at gmail.com>
>>>>> wrote:
>>>>>> k after couple of hours if u are available i can install teamviewer
>>>>>> best regards
>>>>>> On Wed, Nov 2, 2016 at 1:53 PM, Liyuneh Gebre <liyenew at gmail.com>
>>>>>> wrote:
>>>>>>> on *Creat New Map*  it creates this error
>>>>>>> On Wed, Nov 2, 2016 at 1:39 PM, Alessio Fabiani <
>>>>>>>> Sorry Liyuneh,
>>>>>>>> is this one the correct screenshot of the error you are
>>>>>>>> experiencing?
>>>>>>>> [image: Inline image 1]
>>>>>>>> if so I need the URL of the failing window *not *of the main URL.
>>>>>>>> From you screenshot the /maps/new is working correctly (I can see
>>>>>>>> the map tool on the background).
>>>>>>>> I need to know exactly *when* you are getting this error (which
>>>>>>>> are the operation you are actually doing) and the URL of the modal windows
>>>>>>>> throwing the error. You can find this also by enabling the browser debug
>>>>>>>> options on the *net tab*. Please, let me know if you are able to
>>>>>>>> find those information.
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>> On Wed, Nov 2, 2016 at 11:22 AM, Liyuneh Gebre <liyenew at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> i don' have any other  this is the only one and geonde.conf file
>>>>>>>>> is all the same.
>>>>>>>>> On Wed, Nov 2, 2016 at 1:12 PM, Alessio Fabiani <
>>>>>>>>>> Is your geonode.conf file comliant with the following one?
>>>>>>>>>> http://training.geonode.geo-solutions.it/_downloads/geonode.conf
>>>>>>>>>> Do you have any other apache2 conf file or Proxy configuration on
>>>>>>>>>> your system?
>>>>>>>>>> Best Regards,
>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Italy
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> On Wed, Nov 2, 2016 at 11:09 AM, Liyuneh Gebre <liyenew at gmail.com
>>>>>>>>>> > wrote:
>>>>>>>>>>> *Cenots 7 with xfs partion stand alone machine not virtual*
>>>>>>>>>>> tomcat installation followed the document
>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>>>>>>>>> n/setup_on_centos/install_base_tomcat.html
>>>>>>>>>>> with java 1.7
>>>>>>>>>>> *Appache*
>>>>>>>>>>> http://training.geonode.geo-solutions.it/002_install_and_adm
>>>>>>>>>>> in/003_setup_on_centos/install_base_httpd.html
>>>>>>>>>>> *Geoserver*
>>>>>>>>>>> downloaded 2.7 and moved to /var/lib/tomcats/geoserver/webapps/
>>>>>>>>>>> for deployment
>>>>>>>>>>> On Wed, Nov 2, 2016 at 12:56 PM, Alessio Fabiani <
>>>>>>>>>>>> Well the troubleshooting is not trivial.
>>>>>>>>>>>> Lets try to identify the issue first.
>>>>>>>>>>>> 1) How did you installed your system?
>>>>>>>>>>>> 2) Are you using Apache2 HTTPD server? (I guess so) If YES how
>>>>>>>>>>>> did you configured your virtualhosts?
>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Italy
>>>>>>>>>>>> On Wed, Nov 2, 2016 at 10:37 AM, Liyuneh Gebre <
>>>>>>>>>>>>> so is there any fix  am waiting? or should i have to configure
>>>>>>>>>>>>> on Debian package
>>>>>>>>>>>>> best regards
>>>>>>>>>>>>> On Wed, Nov 2, 2016 at 12:01 PM, Alessio Fabiani <
>>>>>>>>>>>>>> Mmm,
>>>>>>>>>>>>>> "/maps/new" is a standard GeoNode endpoint, if you see a 404
>>>>>>>>>>>>>> error thrown by Tomcat that means that there is a mapping/proxying issue on
>>>>>>>>>>>>>> you HTTP Server configuration.
>>>>>>>>>>>>>> Somehow this URL is redirected to the Tomcat instance, but it
>>>>>>>>>>>>>> should not.
>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>>> On Wed, Nov 2, 2016 at 9:57 AM, Liyuneh Gebre <
>>>>>>>>>>>>>>> Dear Alessio
>>>>>>>>>>>>>>> thanks for your concern
>>>>>>>>>>>>>>> http://172.28.202.28/maps/new
>>>>>>>>>>>>>>> On Wed, Nov 2, 2016 at 11:47 AM, Alessio Fabiani <
>>>>>>>>>>>>>>>> Dear Liyuneh,
>>>>>>>>>>>>>>>> can you please send the link of the window showing the 404
>>>>>>>>>>>>>>>> error please? Just copy and paste the link of the page.
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Alessio.
>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>> On Tue, Nov 1, 2016 at 12:26 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>>>> Dear Alessio
>>>>>>>>>>>>>>>>> 1) PUBLIC_URL configured in setting.py and
>>>>>>>>>>>>>>>>> local_setting.py as well in web.xml for geoserver integration and it works
>>>>>>>>>>>>>>>>> fine from remote pc's can access it .*.thank you *in
>>>>>>>>>>>>>>>>> advance
>>>>>>>>>>>>>>>>> 2) I deleted all the layers and maps and to update any
>>>>>>>>>>>>>>>>> files in DB there is only one table BASE_LINK related with uploaded link
>>>>>>>>>>>>>>>>> and after deletion nothing left there.
>>>>>>>>>>>>>>>>>  but still the Error 404 exists
>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 6:42 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>>>> Ohh, I see ... most probably you changed the URL of
>>>>>>>>>>>>>>>>>> GeoServer.
>>>>>>>>>>>>>>>>>> GeoNode stores the server URL of the maps on DB. Maybe it
>>>>>>>>>>>>>>>>>> is trying to access a wrong GeoServer or WMS URL.
>>>>>>>>>>>>>>>>>> Try to get the whole WMS URL or the one related to that
>>>>>>>>>>>>>>>>>> 404 error (which is a Resource not found by the way).
>>>>>>>>>>>>>>>>>> In case it refers to a wrong URL you have only two
>>>>>>>>>>>>>>>>>> options I guess (at least I'm aware of):
>>>>>>>>>>>>>>>>>> 1. Manually update the maps JSON on DB by updating the
>>>>>>>>>>>>>>>>>> wrong GeoServer address with the new one
>>>>>>>>>>>>>>>>>> 2. Delete the maps and rebuild them from scratch
>>>>>>>>>>>>>>>>>> In any case please make sure the "PUBLIC_URL" of
>>>>>>>>>>>>>>>>>> GeoServer is correct on your settings.py file.
>>>>>>>>>>>>>>>>>> Try to ask on mailing list if there exist a management
>>>>>>>>>>>>>>>>>> command to do that automatically, but I'm afraid it is not.
>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 4:36 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>>>>>> i tried to truncate the log file
>>>>>>>>>>>>>>>>>>> /var/log/httpd/error.log  and reboot the machine
>>>>>>>>>>>>>>>>>>> and invoke the 404 error but no error was logged on
>>>>>>>>>>>>>>>>>>> error.log even the python related
>>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 5:35 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>>>>>> Ok, so you should be able to see the detailed error on
>>>>>>>>>>>>>>>>>>>> /var/log/apache/error.log
>>>>>>>>>>>>>>>>>>>> P.S.: I kindly suggest you to *not *send the log on
>>>>>>>>>>>>>>>>>>>> the public mailing list, it could contain information you wouldn't share
>>>>>>>>>>>>>>>>>>>> with people about your server and system setup. Try to find and cut just
>>>>>>>>>>>>>>>>>>>> the Python exception if possible.
>>>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 3:32 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>>>>>>>> Apache 2.4.6
>>>>>>>>>>>>>>>>>>>>> tomcat 7
>>>>>>>>>>>>>>>>>>>>> java 7
>>>>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 5:26 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>>>>>>>> Mmm, is there a chance to take a look at a more
>>>>>>>>>>>>>>>>>>>>>> detailed log? Are you running GeoNode through an Apache2 Web Server or
>>>>>>>>>>>>>>>>>>>>>> something?
>>>>>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>>>>>>> posta elettronica e/o nel/i file/s allegato/i sono da considerarsi
>>>>>>>>>>>>>>>>>>>>>> strettamente riservate. Il loro utilizzo è consentito esclusivamente al
>>>>>>>>>>>>>>>>>>>>>> destinatario del messaggio, per le finalità indicate nel messaggio stesso.
>>>>>>>>>>>>>>>>>>>>>> Qualora riceviate questo messaggio senza esserne il destinatario, Vi
>>>>>>>>>>>>>>>>>>>>>> preghiamo cortesemente di darcene notizia via e-mail e di procedere alla
>>>>>>>>>>>>>>>>>>>>>> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
>>>>>>>>>>>>>>>>>>>>>> Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad
>>>>>>>>>>>>>>>>>>>>>> altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce
>>>>>>>>>>>>>>>>>>>>>> comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>>>>>>>>>>>>>> is intended solely for the attention and use of the named addressee(s) and
>>>>>>>>>>>>>>>>>>>>>> may be confidential or proprietary in nature or covered by the provisions
>>>>>>>>>>>>>>>>>>>>>> of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 3:24 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>>>>>>>>>> Dear Alessio
>>>>>>>>>>>>>>>>>>>>>>> thanks it works after running
>>>>>>>>>>>>>>>>>>>>>>> "python manage.py loaddata initial_data.json"
>>>>>>>>>>>>>>>>>>>>>>> but am still can't figure out the *Create New Map
>>>>>>>>>>>>>>>>>>>>>>> Error throwing 404*
>>>>>>>>>>>>>>>>>>>>>>> since i can access my geoserver and all the uploaded
>>>>>>>>>>>>>>>>>>>>>>> layers exist in geoserver.
>>>>>>>>>>>>>>>>>>>>>>> best regards
>>>>>>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 5:04 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>>>>>>>>>> The problem is caused by the fact that the new
>>>>>>>>>>>>>>>>>>>>>>>> versions of GeoNode are (at least for the moment) no more initialized.
>>>>>>>>>>>>>>>>>>>>>>>> You need to import manually the "initial_data.json"
>>>>>>>>>>>>>>>>>>>>>>>> fixtures in order to let it work correctly.
>>>>>>>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 2:40 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>>>>>>>>>>>> on Edit layer the catalog is not activated shown
>>>>>>>>>>>>>>>>>>>>>>>>> in the attached png   and to update the other info
>>>>>>>>>>>>>>>>>>>>>>>>> it returns "Category is required"
>>>>>>>>>>>>>>>>>>>>>>>>> centos 7 geoserver 2.8.5 geonode 2.5.4
>>>>>>>>>>>>>>>>>>>>>>>>> P.S still the creating map returns 404
>>>>>>>>>>>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>>>>>>>>>>>> *Geospatial Database Administrator and Researcher *
>>>>>>>>>>>>>>>>>>>>>>>>> *Ethiopian Institute of Agricultural Research *
>>>>>>>>>>>>>>>>>>>>>>>>> *Climate and Geospatial Directorate *
>>>>>>>>>>>>>>>>>>>>>>>>> *Office Phone: +251 -116-460380*
>>>>>>>>>>>>>>>>>>>>>>>>> *Cell Phone:    +251-911- 858155*
>>>>>>>>>>>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman
>>>>>>>>>>>>>>>>>>>>>>>>> /listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>> *Ethiopia*
>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>> *Addis Ababa *
>>>>>>>>> *Ethiopia*
>>>>>>> *Liyuneh Gebre*
>>>>>>> *P.O.Box: 2003*
>>>>>>> *Addis Ababa *
>>>>>>> *Ethiopia*
>>>>>> *Liyuneh Gebre*
>>>>>> *P.O.Box: 2003*
>>>>>> *Addis Ababa *
>>>>>> *Ethiopia*
>>>> *Liyuneh Gebre*
>>>> *P.O.Box: 2003*
>>>> *Addis Ababa *
>>>> *Ethiopia*
>> *Liyuneh Gebre*
>> *P.O.Box: 2003*
>> *Addis Ababa *
>> *Ethiopia*
*Liyuneh Gebre*
*P.O.Box: 2003*
*Addis Ababa *
*Ethiopia*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161102/522c4e90/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161102/522c4e90/attachment-0001.png>
More information about the geonode-users mailing list
