[GeoNode-users] How to synchronize GWC configuration
Toni Schönbuchner toni.schoenbuchner at csgis.de
Mon Nov 21 22:34:39 PST 2016
Hi Francesco,
thanks a lot for your reply. I am quite new to Geonode thus I would double check if
I understand everything correctly.
Would this be the way you have in mind:
Delete the layer
curl -v -u admin:geoserver -XDELETE "http://localhost:8080/geoserver/gwc/rest/layers/coral_reef.xml"
(I cannot access Geoservers GWC Gui. )
After that, check if I can access the GUI again and rebuild the Cache? I´m unsure how to do this
correctly. I´ve found this three methods:
1. delete or rename the layers
2. via interface: 'demo' page --> 'Seed this layer' ---> 'Type of operation' select 'Reseed - regenerate all tiles'
3. Let the user do  it: expire them using the geowebcache.xml
http://osgeo-org.1560.x6.nabble.com/Rebuild-GWC-td5093241.html <http://osgeo-org.1560.x6.nabble.com/Rebuild-GWC-td5093241.html>
Which one would you suggest?
Cheers,
Toni
> Am 22.11.2016 um 00:56 schrieb Francesco Bartoli <xbartolone at gmail.com>:
> Hi Toni,
> you might try to clearing out the gwc configuration for that layer and then rebuild the tile caching.
> Hope this helps
> Francesco
> Il giorno 21/nov/2016, alle ore 22:08, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> ha scritto:
>> Hello,
>> a Geonode 2.4 installation is not showing layers in Geoexplorer anymore.
>> I´ve recognized that the wms request response with an error saying.
>> „Could not locate a layer or layer group with id LayerInfoImpl--484e05d9:1460aec6751:-137f within GeoServer configuration
>> the GWC configuration seems to be out of synch“
>> Indeed I found a xml file within /usr/share/geoserver/data/gwc-layers/ which refers to a layer which
>> cannot be found in geonode, geoserver or postgresql.
>> after that I´ve tried
>> $ geonode updatelayers --remove-deleted
>> in hope it will remove leftovers but it failed with:
>> "'Failed to process coral_reef', AttributeError(\"'NoneType' object has no attribute 'default_style'\",)" <Exception:>
>> My question is which steps are needed to synchronize GWC configuration again?
>> Thanks!
>> Toni
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161122/34378167/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161122/34378167/attachment.sig>
More information about the geonode-users mailing list
