[GeoNode-users] Customize structure of metadata in geonode 2.4
admire addloe at gmail.com
Tue Nov 22 06:12:55 PST 2016
Hi
I have geonode 2.4 installed via docker and inside the metadata document
I see it is generating url with localhost for the even though I changed
PUBLIC_LOCATION to point to an external ip. How can I ensure that
localhost does not appear in metadata.
I also need to customize the section for supplementary information in my
metadata so that my app can use it. I have changed full_metadata.xml to
     <gmd:supplementalInformation>
          {{ layer.supplemental_information }}
        </gmd:supplementalInformation>
But with this change I cannot update my metadata document as it throws
an error.
Error updating metadata. Please check the following fields:
      o Category is required.
It seems to disable the Category tab.
Regards
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161122/3ab15f62/attachment.html>
More information about the geonode-users mailing list
