[GeoNode-users] Valid backup GeoNode 2.4
LEOPOLDO JAVIER NUNEZ DE SANTIAGO . lnunezde at guanajuato.gob.mx
Mon Oct 17 08:05:50 PDT 2016
Excellent thank
2016-10-17 9:14 GMT-05:00 Daniel Berry <dberry at boundlessgeo.com>:
> Also you will need to backup any Django media files e.g. thumbnails and
> avatars.  There was an addition recently in master that includes a backup
> and restore command.  You may want to look at trying that out if you are
> able to update.  If not soon we will have a 2.6 release that will include
> it.
> Dan
> On Oct 17, 2016 09:11, "Paolo Corti" <pcorti at gmail.com> wrote:
>> Hi
>> I am not familiar with the directories where the package installer put
>> things, but yes, these are all the things that you need to backup.
>> Make sure to backup the data PostgreSQL database (together with the
>> Django one) in case you are using PostgreSQL as a data store.
>> p
>> On Mon, Oct 17, 2016 at 10:06 AM, LEOPOLDO JAVIER NUNEZ DE SANTIAGO .
>> <lnunezde at guanajuato.gob.mx> wrote:
>> > Hi, It is still validates this configuration to create a backup of your
>> > entire system GeoNode 2.4:
>> > Creating a backup
>> > #. Make a backup of the GeoNode database (PostgreSQL needs to be
>> running)::
>> >     sudo -u postgres -i pg_dump -c -Fc geonode > geonodedb.backup
>> > #. Stop all services::
>> >     sudo /etc/init.d/apache2 stop
>> >     sudo /etc/init.d/tomcat6 stop
>> >     sudo /etc/init.d/postgresql-8.4 stop
>> > #. Backup Geonode config & GeoServer data directory::
>> >     tar -cvzf geonodeConfigBackup.tgz /etc/geonode
>> >     tar -cvzf geonodeDataBackup.tgz  /var/lib/geoserver/geonode-data/
>> > #. In addition, any templates, design changes, and/or CSS files will
>> also
>> > need to be captured.
>> > #. Restart all services::
>> >     sudo /etc/init.d/apache2 start
>> >     sudo /etc/init.d/tomcat6 start
>> >     sudo /etc/init.d/postgresql-8.4 start
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
123 probando
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161017/9b09862d/attachment.html>
More information about the geonode-users mailing list
