[GeoNode-users] LDAP on windows
Franklin, Chris CFranklin at AngloGoldAshanti.com
Thu Sep 8 01:01:37 PDT 2016
Here’s the error log from today with access log attached- nothing stands out to me but I could of easily missed something
[Thu Sep 08 10:30:24.136957 2016] [mpm_winnt:notice] [pid 6492:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 10:30:26.160015 2016] [mpm_winnt:notice] [pid 2732:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 10:30:26.363115 2016] [mpm_winnt:notice] [pid 6492:tid 592] AH00430: Parent: Child process 2732 exited successfully.
[Thu Sep 08 10:30:28.117702 2016] [core:warn] [pid 4512:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:30:28.133343 2016] [wsgi:warn] [pid 4512:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:30:28.133343 2016] [wsgi:warn] [pid 4512:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:30:28.133343 2016] [mpm_winnt:notice] [pid 4512:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 10:30:28.133343 2016] [mpm_winnt:notice] [pid 4512:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 10:30:28.133343 2016] [core:notice] [pid 4512:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 10:30:28.133343 2016] [mpm_winnt:notice] [pid 4512:tid 592] AH00418: Parent: Created child process 7132
[Thu Sep 08 10:30:28.523970 2016] [core:warn] [pid 7132:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:30:28.539596 2016] [core:warn] [pid 7132:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:30:28.555222 2016] [wsgi:warn] [pid 7132:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:30:28.555222 2016] [wsgi:warn] [pid 7132:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:30:28.586480 2016] [mpm_winnt:notice] [pid 7132:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975] mod_wsgi (pid=7132): Exception occurred processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'., referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975] Traceback (most recent call last):, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in __call__, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]     self.load_middleware(), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in load_middleware, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]     for middleware_path in settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in __getattr__, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]     self._setup(name), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]     self._wrapped = Settings(settings_module), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in __init__, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]     mod = importlib.import_module(self.SETTINGS_MODULE), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in import_module, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]     __import__(name), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line 874, in <module>, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]     from local_settings import *  # noqa, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py", line 59, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49975] SyntaxError: Non-ASCII character '\\xe2' in file C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py on line 59, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976] mod_wsgi (pid=7132): Exception occurred processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'.
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976] Traceback (most recent call last):
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in __call__
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]     self.load_middleware()
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in load_middleware
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]     for middleware_path in settings.MIDDLEWARE_CLASSES:
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in __getattr__
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]     self._setup(name)
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]     self._wrapped = Settings(settings_module)
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in __init__
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]     mod = importlib.import_module(self.SETTINGS_MODULE)
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in import_module
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]     __import__(name)
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line 874, in <module>
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]     from local_settings import *  # noqa
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py", line 59
[Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592] [client 172.16.1.176:49976] SyntaxError: Non-ASCII character '\\xe2' in file C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py on line 59, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977] mod_wsgi (pid=7132): Exception occurred processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'.
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977] Traceback (most recent call last):
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in __call__
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]     self.load_middleware()
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in load_middleware
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]     for middleware_path in settings.MIDDLEWARE_CLASSES:
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in __getattr__
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]     self._setup(name)
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]     self._wrapped = Settings(settings_module)
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in __init__
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]     mod = importlib.import_module(self.SETTINGS_MODULE)
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in import_module
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]     __import__(name)
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line 874, in <module>
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]     from local_settings import *  # noqa
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py", line 59
[Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588] [client 172.16.1.176:49977] SyntaxError: Non-ASCII character '\\xe2' in file C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py on line 59, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
[Thu Sep 08 10:31:14.498944 2016] [mpm_winnt:notice] [pid 4512:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 10:31:19.863632 2016] [mpm_winnt:notice] [pid 7132:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 10:31:20.187075 2016] [mpm_winnt:notice] [pid 4512:tid 592] AH00430: Parent: Child process 7132 exited successfully.
[Thu Sep 08 10:31:21.047950 2016] [core:warn] [pid 7844:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:31:21.063577 2016] [wsgi:warn] [pid 7844:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:31:21.063577 2016] [wsgi:warn] [pid 7844:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:31:21.063577 2016] [mpm_winnt:notice] [pid 7844:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 10:31:21.063577 2016] [mpm_winnt:notice] [pid 7844:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 10:31:21.063577 2016] [core:notice] [pid 7844:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 10:31:21.063577 2016] [mpm_winnt:notice] [pid 7844:tid 592] AH00418: Parent: Created child process 2460
[Thu Sep 08 10:31:21.485472 2016] [core:warn] [pid 2460:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:31:21.501101 2016] [core:warn] [pid 2460:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:31:21.516725 2016] [wsgi:warn] [pid 2460:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:31:21.516725 2016] [wsgi:warn] [pid 2460:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:31:21.547984 2016] [mpm_winnt:notice] [pid 2460:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 10:31:29.775250 2016] [wsgi:error] [pid 2460:tid 2592] Not enabling BingMaps base layer as a BING_API_KEY is not defined in local_settings.py file.
[Thu Sep 08 10:54:30.903346 2016] [mpm_winnt:notice] [pid 7844:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 10:54:32.934649 2016] [mpm_winnt:notice] [pid 2460:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 10:54:33.122107 2016] [mpm_winnt:notice] [pid 7844:tid 592] AH00430: Parent: Child process 2460 exited successfully.
[Thu Sep 08 10:54:34.028352 2016] [core:warn] [pid 512:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:54:34.043977 2016] [wsgi:warn] [pid 512:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:54:34.043977 2016] [wsgi:warn] [pid 512:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:54:34.043977 2016] [mpm_winnt:notice] [pid 512:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 10:54:34.043977 2016] [mpm_winnt:notice] [pid 512:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 10:54:34.043977 2016] [core:notice] [pid 512:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 10:54:34.043977 2016] [mpm_winnt:notice] [pid 512:tid 592] AH00418: Parent: Created child process 3380
[Thu Sep 08 10:54:34.434603 2016] [core:warn] [pid 3380:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:54:34.465853 2016] [core:warn] [pid 3380:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:54:34.465853 2016] [wsgi:warn] [pid 3380:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:54:34.465853 2016] [wsgi:warn] [pid 3380:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:54:34.497103 2016] [mpm_winnt:notice] [pid 3380:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268] mod_wsgi (pid=3380): Exception occurred processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'., referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268] Traceback (most recent call last):, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in __call__, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]     self.load_middleware(), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in load_middleware, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]     for middleware_path in settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in __getattr__, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]     self._setup(name), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]     self._wrapped = Settings(settings_module), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in __init__, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]     mod = importlib.import_module(self.SETTINGS_MODULE), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in import_module, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]     __import__(name), referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line 874, in <module>, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]     from local_settings import *  # noqa, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py", line 59, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592] [client 172.16.1.176:50268] SyntaxError: Non-ASCII character '\\xe2' in file C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py on line 59, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details, referer: http://aupegis03/layers/?limit=100&offset=0
[Thu Sep 08 10:55:00.872156 2016] [mpm_winnt:notice] [pid 512:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 10:55:03.622159 2016] [mpm_winnt:notice] [pid 3380:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 10:55:05.028413 2016] [mpm_winnt:notice] [pid 512:tid 592] AH00430: Parent: Child process 3380 exited successfully.
[Thu Sep 08 10:55:07.856544 2016] [core:warn] [pid 6624:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:55:08.262793 2016] [wsgi:warn] [pid 6624:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:55:08.262793 2016] [wsgi:warn] [pid 6624:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:55:08.262793 2016] [mpm_winnt:notice] [pid 6624:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 10:55:08.262793 2016] [mpm_winnt:notice] [pid 6624:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 10:55:08.262793 2016] [core:notice] [pid 6624:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 10:55:08.278419 2016] [mpm_winnt:notice] [pid 6624:tid 592] AH00418: Parent: Created child process 4352
[Thu Sep 08 10:55:08.997173 2016] [core:warn] [pid 4352:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:55:09.028421 2016] [core:warn] [pid 4352:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:55:09.090921 2016] [wsgi:warn] [pid 4352:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:55:09.090921 2016] [wsgi:warn] [pid 4352:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:55:09.122173 2016] [mpm_winnt:notice] [pid 4352:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 10:55:17.325312 2016] [wsgi:error] [pid 4352:tid 2592] Not enabling BingMaps base layer as a BING_API_KEY is not defined in local_settings.py file.
[Thu Sep 08 10:56:06.997285 2016] [mpm_winnt:notice] [pid 6624:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 10:56:11.731690 2016] [mpm_winnt:notice] [pid 4352:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 10:56:11.887926 2016] [mpm_winnt:notice] [pid 6624:tid 592] AH00430: Parent: Child process 4352 exited successfully.
[Thu Sep 08 10:56:13.294171 2016] [core:warn] [pid 2676:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:56:13.669175 2016] [wsgi:warn] [pid 2676:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:56:13.669175 2016] [wsgi:warn] [pid 2676:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:56:13.669175 2016] [mpm_winnt:notice] [pid 2676:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 10:56:13.669175 2016] [mpm_winnt:notice] [pid 2676:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 10:56:13.669175 2016] [core:notice] [pid 2676:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 10:56:13.669175 2016] [mpm_winnt:notice] [pid 2676:tid 592] AH00418: Parent: Created child process 5188
[Thu Sep 08 10:56:14.075424 2016] [core:warn] [pid 5188:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:56:14.091047 2016] [core:warn] [pid 5188:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 10:56:14.137923 2016] [wsgi:warn] [pid 5188:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 10:56:14.137923 2016] [wsgi:warn] [pid 5188:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 10:56:14.169173 2016] [mpm_winnt:notice] [pid 5188:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 11:06:28.357881 2016] [mpm_winnt:notice] [pid 2676:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 11:06:30.420438 2016] [mpm_winnt:notice] [pid 5188:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 11:06:30.670385 2016] [mpm_winnt:notice] [pid 2676:tid 592] AH00430: Parent: Child process 5188 exited successfully.
[Thu Sep 08 11:06:31.764139 2016] [core:warn] [pid 6988:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:06:31.795381 2016] [wsgi:warn] [pid 6988:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 11:06:31.795381 2016] [wsgi:warn] [pid 6988:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 11:06:31.795381 2016] [mpm_winnt:notice] [pid 6988:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 11:06:31.795381 2016] [mpm_winnt:notice] [pid 6988:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 11:06:31.795381 2016] [core:notice] [pid 6988:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 11:06:31.795381 2016] [mpm_winnt:notice] [pid 6988:tid 592] AH00418: Parent: Created child process 4600
[Thu Sep 08 11:06:32.186008 2016] [core:warn] [pid 4600:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:06:32.201632 2016] [core:warn] [pid 4600:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:06:32.217258 2016] [wsgi:warn] [pid 4600:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 11:06:32.217258 2016] [wsgi:warn] [pid 4600:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 11:06:32.248512 2016] [mpm_winnt:notice] [pid 4600:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465] mod_wsgi (pid=4600): Exception occurred processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'., referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465] Traceback (most recent call last):, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in __call__, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]     self.load_middleware(), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in load_middleware, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]     for middleware_path in settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in __getattr__, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]     self._setup(name), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]     self._wrapped = Settings(settings_module), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in __init__, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]     mod = importlib.import_module(self.SETTINGS_MODULE), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in import_module, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]     __import__(name), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line 902, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]     "name": "SATELLITE",, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465]           ^, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592] [client 172.16.1.176:50465] SyntaxError: invalid syntax, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:06:50.670425 2016] [mpm_winnt:notice] [pid 6988:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 11:06:55.029802 2016] [mpm_winnt:notice] [pid 4600:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 11:06:55.717303 2016] [mpm_winnt:notice] [pid 6988:tid 592] AH00430: Parent: Child process 4600 exited successfully.
[Thu Sep 08 11:06:57.967308 2016] [core:warn] [pid 6136:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:06:58.920435 2016] [wsgi:warn] [pid 6136:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 11:06:58.920435 2016] [wsgi:warn] [pid 6136:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 11:06:58.920435 2016] [mpm_winnt:notice] [pid 6136:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 11:06:58.920435 2016] [mpm_winnt:notice] [pid 6136:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 11:06:58.920435 2016] [core:notice] [pid 6136:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 11:06:58.920435 2016] [mpm_winnt:notice] [pid 6136:tid 592] AH00418: Parent: Created child process 7508
[Thu Sep 08 11:06:59.514184 2016] [core:warn] [pid 7508:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:06:59.529809 2016] [core:warn] [pid 7508:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:06:59.748565 2016] [wsgi:warn] [pid 7508:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 11:06:59.748565 2016] [wsgi:warn] [pid 7508:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 11:06:59.764196 2016] [mpm_winnt:notice] [pid 7508:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471] mod_wsgi (pid=7508): Exception occurred processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py'., referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471] Traceback (most recent call last):, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in __call__, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]     self.load_middleware(), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in load_middleware, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]     for middleware_path in settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in __getattr__, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]     self._setup(name), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]     self._wrapped = Settings(settings_module), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in __init__, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]     mod = importlib.import_module(self.SETTINGS_MODULE), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in import_module, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]     __import__(name), referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line 902, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]     "name": "SATELLITE",, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471]           ^, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592] [client 172.16.1.176:50471] SyntaxError: invalid syntax, referer: http://aupegis03/maps/?limit=100&offset=0
[Thu Sep 08 11:07:27.514239 2016] [mpm_winnt:notice] [pid 6136:tid 592] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Thu Sep 08 11:07:37.123649 2016] [mpm_winnt:notice] [pid 7508:tid 492] AH00364: Child: All worker threads have exited.
[Thu Sep 08 11:07:37.154933 2016] [mpm_winnt:notice] [pid 6136:tid 592] AH00430: Parent: Child process 7508 exited successfully.
[Thu Sep 08 11:07:38.951761 2016] [core:warn] [pid 5332:tid 592] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:07:39.373642 2016] [wsgi:warn] [pid 5332:tid 592] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 11:07:39.373642 2016] [wsgi:warn] [pid 5332:tid 592] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 11:07:39.373642 2016] [mpm_winnt:notice] [pid 5332:tid 592] AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured -- resuming normal operations
[Thu Sep 08 11:07:39.373642 2016] [mpm_winnt:notice] [pid 5332:tid 592] AH00456: Server built: Dec  9 2015 12:21:09
[Thu Sep 08 11:07:39.373642 2016] [core:notice] [pid 5332:tid 592] AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
[Thu Sep 08 11:07:39.373642 2016] [mpm_winnt:notice] [pid 5332:tid 592] AH00418: Parent: Created child process 8172
[Thu Sep 08 11:07:40.154890 2016] [core:warn] [pid 8172:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:07:40.170516 2016] [core:warn] [pid 8172:tid 492] AH00117: Ignoring deprecated use of DefaultType in line 424 of C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
[Thu Sep 08 11:07:40.404889 2016] [wsgi:warn] [pid 8172:tid 492] mod_wsgi: Compiled for Python/2.7.10+.
[Thu Sep 08 11:07:40.404889 2016] [wsgi:warn] [pid 8172:tid 492] mod_wsgi: Runtime using Python/2.7.10.
[Thu Sep 08 11:07:40.436140 2016] [mpm_winnt:notice] [pid 8172:tid 492] AH00354: Child: Starting 250 worker threads.
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584] Internal Server Error: /services/register/
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584] Traceback (most recent call last):
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 112, in get_response
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     response = wrapped_callback(request, *callback_args, **callback_kwargs)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\contrib\\auth\\decorators.py", line 22, in _wrapped_view
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     return view_func(request, *args, **kwargs)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\services\\views.py", line 110, in register_service
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     type, server = _verify_service_type(url)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\services\\views.py", line 239, in _verify_service_type
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     service.services
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\arcrest\\server.py", line 480, in services
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     in self._json_struct.get('services', [])]
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\arcrest\\server.py", line 266, in _json_struct
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     if self._contents is not Ellipsis:
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\arcrest\\server.py", line 243, in _contents
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     handle = compat.urllib2.urlopen(request)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 154, in urlopen
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     return opener.open(url, data, timeout)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 431, in open
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     response = self._open(req, data)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 449, in _open
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     '_open', req)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 409, in _call_chain
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     result = func(*args)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 1227, in http_open
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     return self.do_open(httplib.HTTPConnection, req)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]   File "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 1197, in do_open
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]     raise URLError(err)
[Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584] URLError: <urlopen error [Errno 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond>
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576] Internal Server Error: /maps/58/thumbnail
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576] Traceback (most recent call last):
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 105, in get_response
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     response = middleware_method(request, callback, callback_args, callback_kwargs)
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\middleware\\csrf.py", line 170, in process_view
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     request_csrf_token = request.POST.get('csrfmiddlewaretoken', '')
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 146, in _get_post
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     self._load_post_and_files()
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\http\\request.py", line 227, in _load_post_and_files
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     self._post, self._files = QueryDict(self.body, encoding=self._encoding), MultiValueDict()
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\http\\request.py", line 190, in body
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     six.reraise(UnreadablePostError, UnreadablePostError(*e.args), sys.exc_info()[2])
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\http\\request.py", line 188, in body
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     self._body = self.read()
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\http\\request.py", line 244, in read
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\http\\request.py", line 242, in read
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     return self._stream.read(*args, **kwargs)
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 45, in read
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     result = self.buffer + self._read_limited()
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]   File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 39, in _read_limited
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]     result = self.stream.read(size)
[Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576] UnreadablePostError: Apache/mod_wsgi request data read error: Partial results are valid but processing is incomplete.
Chris Franklin
GIS and Database Co-ordinator
Exploration Australia
[cid:image001.jpg at 01D209EA.2F3F71D0]
Tel:         +61 08 9425 4719
Fax:        +61 08 9425 4650
Email:      cfranklin at anglogoldashanti.com<mailto:cfranklin at anglogoldashanti.com>
Consider the environment. Think before you print.
From: alessio.fabiani at gmail.com [mailto:alessio.fabiani at gmail.com] On Behalf Of Alessio Fabiani
Sent: Thursday, 8 September 2016 3:47 PM
To: Franklin, Chris
Cc: Jeffrey Johnson; geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] LDAP on windows
Do you see some specific line on the geonode-2.4.x/apache/logs/error.log or other log files?
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Thu, Sep 8, 2016 at 4:39 AM, Franklin, Chris <CFranklin at anglogoldashanti.com<mailto:CFranklin at anglogoldashanti.com>> wrote:
Ok, im getting closer:
I set the virtualenv first – ran
[cid:image006.png at 01D209EA.2F2225D0]
Then ran :
[cid:image009.png at 01D209EA.2F2225D0]
Added:
#LDAP
import ldap
from django_auth_ldap.config import LDAPSearch
AUTHENTICATION_BACKENDS = (
    'django_auth_ldap.backend.LDAPBackend',
    'django.contrib.auth.backends.ModelBackend',
    'guardian.backends.ObjectPermissionBackend',
AUTH_LDAP_SERVER_URI = ‘ldap://ag.ad.local'
LDAP_SEARCH_DN = 'OU=AUSTRALIA,OU=AUSTRALASIA,DC=ag,DC=ad,DC=local'
AUTH_LDAP_USER = '(uid=%(user)s)'
AUTH_LDAP_BIND_DN = '{ADD_BIND_DN_IF_REQUIRED}'
AUTH_LDAP_BIND_PASSWORD = '{ADD_BIND_PASSWORD_IF_REQUIRED}'
AUTH_LDAP_USER_ATTR_MAP = {
    'first_name': 'givenName', 'last_name': 'sn', 'email': 'mail',
AUTH_LDAP_USER_SEARCH = LDAPSearch(LDAP_SEARCH_DN,
                                   ldap.SCOPE_SUBTREE, AUTH_LDAP_USER)
to my local_settings.py file like so:
[cid:image010.png at 01D209EA.2F2225D0]
Restarted Apache but Geonode had a 500 error – what did I do wrong?
Thanks
Chris Franklin
[cid:image011.jpg at 01D209EA.2F2225D0]
Tel:         +61 08 9425 4719<tel:%2B61%2008%209425%204719>
Fax:        +61 08 9425 4650<tel:%2B61%2008%209425%204650>
From: alessio.fabiani at gmail.com<mailto:alessio.fabiani at gmail.com> [mailto:alessio.fabiani at gmail.com<mailto:alessio.fabiani at gmail.com>] On Behalf Of Alessio Fabiani
Sent: Wednesday, 7 September 2016 4:18 PM
To: Jeffrey Johnson
Cc: Franklin, Chris; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Jeffrey is right, you need to use pip, but first of all you need to:
1. go to the windows prompt
2. go to the geonode installation folder
3. activate the virtual env with the batch command :
cd C:\GeoNode-2.4.x\geonode-2.4.x
python_env.bat
Scripts\activate.bat
Regards,
-A.
Best Regards,
Alessio Fabiani.
@alfa7691
GeoSolutions S.A.S.
Italy
phone: +39 0584 962313<tel:%2B39%200584%20962313>
fax:     +39 0584 1660272<tel:%2B39%200584%201660272>
mob:   +39 331 6233686<tel:%2B39%20331%206233686>
On Tue, Sep 6, 2016 at 6:42 PM, Jeffrey Johnson <ortelius at gmail.com<mailto:ortelius at gmail.com>> wrote:
Chris, you need to use pip. Im not sure how the virtualenvironment is setup. Alessio, can you give us some insight here?
https://pip.pypa.io/en/stable/user_guide/#installing-from-wheels (on windows you need to use the command prompt)
On Mon, Sep 5, 2016 at 9:19 PM, Franklin, Chris <CFranklin at anglogoldashanti.com<mailto:CFranklin at anglogoldashanti.com>> wrote:
Thanks dan,
Have been trying to see how I can install the .whl file but can’t find any info on it, can someone out there help?
Regards
Chris Franklin
[cid:image012.jpg at 01D209EA.2F2225D0]
Mob:       +61 04 4818 2351
Email:      cfranklin at anglogoldashanti.com<http://cfranklin@anglogoldashanti.com>
From: Daniel Berry [mailto:dberry at boundlessgeo.com<mailto:dberry at boundlessgeo.com>]
Sent: Wednesday, 31 August 2016 8:29 PM
To: Franklin, Chris <CFranklin at AngloGoldAshanti.com<mailto:CFranklin at AngloGoldAshanti.com>>
Cc: Jeffrey Johnson <ortelius at gmail.com<mailto:ortelius at gmail.com>>; geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Chris,
It looks like for windows you could use one of these wheel files to install python-ldap. Just match the wheel to your OS.
http://www.lfd.uci.edu/~gohlke/pythonlibs/#python-ldap
These have already been pre built and include the `.pyd` file, which is a `.dll` file - https://docs.python.org/3/faq/windows.html#is-a-pyd-file-the-same-as-a-dll. This should alleviate you having to install devel libs and compile the source from pypi using pip.
Good luck!
Dan
On Wed, Aug 31, 2016 at 1:57 AM, Franklin, Chris <CFranklin at anglogoldashanti.com<mailto:CFranklin at anglogoldashanti.com>> wrote:
Ok I added this to my local setting file :
import ldap
But was unsure on installing the ldap devel lib – who do I do that on windows?
http://docs.geonode.org/en/master/tutorials/admin/ldap/
Cheers
Chris Franklin
[cid:image013.jpg at 01D209EA.2F2225D0]
From: Jeffrey Johnson [mailto:ortelius at gmail.com<mailto:ortelius at gmail.com>]
Sent: Thursday, 25 August 2016 2:24 PM
To: Franklin, Chris
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
I dont think there should be any difference in how it works on windows. Let us know how it goes.
On Thu, Aug 25, 2016 at 6:45 AM, Franklin, Chris <CFranklin at anglogoldashanti.com<mailto:CFranklin at anglogoldashanti.com>> wrote:
Im looking to link my Geonode 2.4 windows into the corp LDAP, is this possible in windows?
http://docs.geonode.org/en/master/tutorials/admin/ldap/index.html
Regards
Chris Franklin
This email, and its attachments, is subject to important warnings and disclaimers which are legally incorporated into this email in terms of Section 11(3) of the South African Electronic Communications and Transactions Act, 25 of 2002. The full text of the warnings and disclaimers, together with the company details and directors is available by clicking on http://www.anglogoldashanti.com/en/Pages/legal.aspx
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Daniel Berry
Senior Software Engineer | Boundless
512-468-3946<tel:512-468-3946> (cell)
@boundlessgeo
[https://docs.google.com/a/boundlessgeo.com/uc?id=0B_qVH4CJ8mXOa3E1YUNySzN2d00&export=download]
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0001.html>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0003.png>
Type: image/png
Desc: image009.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0004.png>
Type: image/png
Desc: image010.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0005.png>
Type: image/jpeg
Desc: image011.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0004.jpg>
Type: image/jpeg
Desc: image012.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0005.jpg>
Type: image/jpeg
Desc: image013.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0006.jpg>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0007.jpg>
Type: application/x-zip-compressed
Desc: access.zip
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/b783e227/attachment-0001.bin>
More information about the geonode-users mailing list
