[GeoNode-users] windows ldap
Jeffrey Johnson ortelius at gmail.com
Mon Sep 19 09:04:01 PDT 2016
do that inside a python shell.
On Sun, Sep 18, 2016 at 7:55 PM, Dan Erklauer <derklauer at oceaneering.com> wrote:
> Chris the ldap library is not a prerequisite for geonode.  I'm assuming your
> following there documentation.  That error is telling you don't have it
> installed.  You will need to install the library use pip or easy install
> whichever you have on your windows box.
> Dan
> On Sep 18, 2016, at 9:48 PM, Franklin, Chris
> <CFranklin at anglogoldashanti.com> wrote:
> Dan,
> I can't run 'import ldap'
> <image002.png>
> What am I doing wrong?
> Regards.
> Chris
> Today's Topics:
>    1. windows ldap (Erklauer, Dan)
> Message: 1
> Date: Thu, 8 Sep 2016 08:40:59 -0500
> From: "Erklauer, Dan" <derklauer at oceaneering.com>
> To: geonode-users at lists.osgeo.org
> Subject: [GeoNode-users] windows ldap
> Message-ID:
> <CAGHmGXNBAnx_KQ1X9AiqbSE663UkK7KxR5Pw139B3kTPCQyzsw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Chris, I connected yesterday to an LDAP with geonode, it was linux but I
> doubt this is an OS issue.  There are a couple of things I would
> recommend.  First check and make sure your dependencies are all there and
> available to the user running geonode. On your geonode server enter the
> python command line and do 'import ldap' and 'from django_auth_ldap.config
> import LDAPSearch'.  Make sure that works.  Then make sure you can connect
> to your ldap server, test this via command line here is an article on how
> you do that
> <http://serverfault.com/questions/452935/how-to-test-a-ldap-connection-from-a-client>
> make
> sure you use the same parameters you are using in the django app, it looks
> to me that some of your ldap variables are incorrect (formatting).   After
> you confirm that you can connect to your directory and your dependencies
> are there test using the django installed server (python manage.py
> runserver). The code below is how I connected and has some error flags that
> will clearly tell, if there is an error and what it is.  In my case I had
> an ssl issue which I resolved with the ldap.set_option().
> DEBUG=True
> import ldap
> from django_auth_ldap.config import LDAPSearch
> ldap.set_option(ldap.OPT_X_TLS_CACERTFILE,'directory/that/has/cert/mycert.crt')
> AUTHENTICATION_BACKENDS = (
>     'django_auth_ldap.backend.LDAPBackend',
>     'django.contrib.auth.backends.ModelBackend',
>     'guardian.backends.ObjectPermissionBackend',
> AUTH_LDAP_SERVER_URI = 'ldaps://xxxx'
> LDAP_SEARCH_DN = 'CN=users,dc=xxx,dc=xxx'
> AUTH_LDAP_USER = '(cn=%(user)s)'
> AUTH_LDAP_BIND_DN = 'CN=xxx,CN=Users,DC=xxx,DC=xxx'
> AUTH_LDAP_BIND_PASSWORD = 'xxxx'
> AUTH_LDAP_USER_ATTR_MAP = {
>     'first_name': 'givenName', 'last_name': 'sn',
> AUTH_LDAP_USER_DN_TEMPLATE = "cn=%(user)s,cn=users,dc=xxx,dc=xxx"
> AUTH_LDAP_CONNECTION_OPTIONS = {
>         ldap.OPT_DEBUG_LEVEL: 0,
>         ldap.OPT_REFERRALS: 0,
> LOGGING = {
>     'version': 1,
>     'disable_existing_loggers': False,
>     'handlers': {
>         'mail_admins': {
>             'level': 'ERROR',
>             'class': 'django.utils.log.AdminEmailHandler'
>         'stream_to_console': {
>             'level': 'DEBUG',
>             'class': 'logging.StreamHandler'
>     'loggers': {
>         'django.request': {
>             'handlers': ['mail_admins'],
>             'level': 'ERROR',
>             'propagate': True,
>         'django_auth_ldap': {
>             'handlers': ['stream_to_console'],
>             'level': 'DEBUG',
>             'propagate': True,
> On Thu, Sep 8, 2016 at 6:18 AM, <geonode-users-request at lists.osgeo.org>
> wrote:
>> Send geonode-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.osgeo.org/mailman/listinfo/geonode-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         geonode-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of geonode-users digest..."
>> Today's Topics:
>>    1. Re: LDAP on windows (Alessio Fabiani)
>> Message: 1
>> Date: Thu, 8 Sep 2016 13:18:09 +0200
>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>> To: "Franklin, Chris" <CFranklin at anglogoldashanti.com>
>> Cc: Jeffrey Johnson <ortelius at gmail.com>,
>>         "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>> Subject: Re: [GeoNode-users] LDAP on windows
>> Message-ID:
>>         <CAM7ZvLK+LHLnZjwg8x2AJ0onFm60RDhU5FWJoR
>> 3nppDErWmLJQ at mail.gmail.com>
>> Well the most evident and latest one visible from the logs is the
>> following
>> one:
>> URLError: <urlopen error [Errno 10060] A connection attempt failed because
>> the connected party did not properly respond after a period of time, or
>> established connection failed because connected host has failed to
>> respond>
>> but is quite difficult to understand which is the cause... are you sure
>> the
>> LDAP settings are all correct?
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure,
>> reproduction,
>> copying, distribution, or either dissemination, either whole or partial,
>> is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Thu, Sep 8, 2016 at 1:11 PM, Franklin, Chris <
>> > Think that was from trying to get google basemaps working.....nothing
>> else
>> > in the error file?
>> > Chris Franklin
>> > GIS & DB Co-ordinator
>> > On 8 Sep 2016, at 16:06, Alessio Fabiani <alessio.fabiani at geo-
>> solutions.it>
>> > wrote:
>> > It looks like a syntax error on the settings.py
>> >  File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line
>> 902,
>> > referer: http://aupegis03/maps/?limit=100&offset=0
>> > [Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592]
>> [client
>> > 172.16.1.176:50471]     "name": "SATELLITE",, referer: http://aupegis03/
>> [client
>> > 172.16.1.176:50471]           ^, referer: http://aupegis03/
>> [client
>> > 172.16.1.176:50471] SyntaxError: invalid syntax, referer:
>> > Best Regards,
>> > Alessio Fabiani.
>> > @alfa7691
>> > GeoSolutions S.A.S.
>> > Italy
>> > stesso,
>> for
>> or
>> reproduction,
>> is
>> or
>> > On Thu, Sep 8, 2016 at 10:01 AM, Franklin, Chris <
>> >> Here’s the error log from today with access log attached- nothing
>> >> stands
>> >> out to me but I could of easily missed something
>> >> [Thu Sep 08 10:30:24.136957 2016] [mpm_winnt:notice] [pid 6492:tid 592]
>> >> AH00422: Parent: Received shutdown signal -- Shutting down the server.
>> >> [Thu Sep 08 10:30:26.160015 2016] [mpm_winnt:notice] [pid 2732:tid 492]
>> >> AH00364: Child: All worker threads have exited.
>> >> [Thu Sep 08 10:30:26.363115 2016] [mpm_winnt:notice] [pid 6492:tid 592]
>> >> AH00430: Parent: Child process 2732 exited successfully.
>> >> [Thu Sep 08 10:30:28.117702 2016] [core:warn] [pid 4512:tid 592]
>> AH00117:
>> >> Ignoring deprecated use of DefaultType in line 424 of
>> >> C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
>> >> [Thu Sep 08 10:30:28.133343 2016] [wsgi:warn] [pid 4512:tid 592]
>> >> mod_wsgi: Compiled for Python/2.7.10+.
>> >> mod_wsgi: Runtime using Python/2.7.10.
>> >> [Thu Sep 08 10:30:28.133343 2016] [mpm_winnt:notice] [pid 4512:tid 592]
>> >> AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured
>> >> resuming normal operations
>> >> AH00456: Server built: Dec  9 2015 12:21:09
>> >> [Thu Sep 08 10:30:28.133343 2016] [core:notice] [pid 4512:tid 592]
>> >> AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d
>> >> C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
>> >> AH00418: Parent: Created child process 7132
>> >> [Thu Sep 08 10:30:28.523970 2016] [core:warn] [pid 7132:tid 492]
>> AH00117:
>> >> [Thu Sep 08 10:30:28.539596 2016] [core:warn] [pid 7132:tid 492]
>> AH00117:
>> >> [Thu Sep 08 10:30:28.555222 2016] [wsgi:warn] [pid 7132:tid 492]
>> >> [Thu Sep 08 10:30:28.586480 2016] [mpm_winnt:notice] [pid 7132:tid 492]
>> >> AH00354: Child: Starting 250 worker threads.
>> >> [Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592]
>> >> [client 172.16.1.176:49975] mod_wsgi (pid=7132): Exception occurred
>> >> processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.
>> x/geonode/wsgi.py'.,
>> >> referer: http://aupegis03/layers/?limit=100&offset=0
>> >> [client 172.16.1.176:49975] Traceback (most recent call last):,
>> referer:
>> >> [client 172.16.1.176:49975]   File "C:\\GeoNode-2.4.x\\geonode-2.
>> >> 4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in
>> >> __call__, referer: http://aupegis03/layers/?limit=100&offset=0
>> >> [client 172.16.1.176:49975]     self.load_middleware(), referer:
>> >> 4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in
>> >> load_middleware, referer: http://aupegis03/layers/?limit=100&offset=0
>> >> [client 172.16.1.176:49975]     for middleware_path in
>> >> settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/layers/?limit
>> >> =100&offset=0
>> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in
>> >> __getattr__, referer: http://aupegis03/layers/?limit=100&offset=0
>> >> [client 172.16.1.176:49975]     self._setup(name), referer:
>> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in
>> _setup,
>> >> [client 172.16.1.176:49975]     self._wrapped =
>> >> Settings(settings_module), referer: http://aupegis03/layers/?limit
>> >> =100&offset=0
>> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in
>> >> __init__, referer: http://aupegis03/layers/?limit=100&offset=0
>> >> [client 172.16.1.176:49975]     mod = importlib.import_module(self.
>> SETTINGS_MODULE),
>> >> 4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in
>> >> import_module, referer: http://aupegis03/layers/?limit=100&offset=0
>> >> [client 172.16.1.176:49975]     __import__(name), referer:
>> >> line 874, in <module>, referer: http://aupegis03/layers/?limit
>> >> =100&offset=0
>> >> [client 172.16.1.176:49975]     from local_settings import *  # noqa,
>> >> 4.x\\geonode\\local_settings.py", line 59, referer:
>> >> [client 172.16.1.176:49975] SyntaxError: Non-ASCII character '\\xe2' in
>> >> file C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py on
>> >> line 59, but no encoding declared; see http://python.org/dev/peps/pep
>> >> -0263/ for details, referer: http://aupegis03/layers/?
>> limit=100&offset=0
>> >> [Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592]
>> >> [client 172.16.1.176:49976] mod_wsgi (pid=7132): Exception occurred
>> x/geonode/wsgi.py'.
>> >> [client 172.16.1.176:49976] Traceback (most recent call last):
>> >> [client 172.16.1.176:49976]   File "C:\\GeoNode-2.4.x\\geonode-2.
>> >> __call__
>> >> [client 172.16.1.176:49976]     self.load_middleware()
>> >> load_middleware
>> >> [client 172.16.1.176:49976]     for middleware_path in
>> >> __getattr__
>> >> [client 172.16.1.176:49976]     self._setup(name)
>> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup
>> >> [client 172.16.1.176:49976]     self._wrapped =
>> >> __init__
>> >> [client 172.16.1.176:49976]     mod = importlib.import_module(self.S
>> >> ETTINGS_MODULE)
>> >> import_module
>> >> [client 172.16.1.176:49976]     __import__(name)
>> >> [client 172.16.1.176:49976]     from local_settings import *  # noqa
>> >> [client 172.16.1.176:49976] SyntaxError: Non-ASCII character '\\xe2' in
>> >> -0263/ for details
>> >> [Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588]
>> >> [client 172.16.1.176:49977] mod_wsgi (pid=7132): Exception occurred
>> x/geonode/wsgi.py'.
>> >> [client 172.16.1.176:49977] Traceback (most recent call last):
>> >> [client 172.16.1.176:49977]   File "C:\\GeoNode-2.4.x\\geonode-2.
>> >> __call__
>> >> [client 172.16.1.176:49977]     self.load_middleware()
>> >> load_middleware
>> >> [client 172.16.1.176:49977]     for middleware_path in
>> >> __getattr__
>> >> [client 172.16.1.176:49977]     self._setup(name)
>> >> [client 172.16.1.176:49977]     self._wrapped =
>> >> __init__
>> >> [client 172.16.1.176:49977]     mod = importlib.import_module(self.S
>> >> ETTINGS_MODULE)
>> >> import_module
>> >> [client 172.16.1.176:49977]     __import__(name)
>> >> [client 172.16.1.176:49977]     from local_settings import *  # noqa
>> >> [client 172.16.1.176:49977] SyntaxError: Non-ASCII character '\\xe2' in
>> >> -0263/ for details
>> >> [Thu Sep 08 10:31:14.498944 2016] [mpm_winnt:notice] [pid 4512:tid 592]
>> >> [Thu Sep 08 10:31:19.863632 2016] [mpm_winnt:notice] [pid 7132:tid 492]
>> >> [Thu Sep 08 10:31:20.187075 2016] [mpm_winnt:notice] [pid 4512:tid 592]
>> >> AH00430: Parent: Child process 7132 exited successfully.
>> >> [Thu Sep 08 10:31:21.047950 2016] [core:warn] [pid 7844:tid 592]
>> AH00117:
>> >> [Thu Sep 08 10:31:21.063577 2016] [wsgi:warn] [pid 7844:tid 592]
>> >> [Thu Sep 08 10:31:21.063577 2016] [mpm_winnt:notice] [pid 7844:tid 592]
>> >> [Thu Sep 08 10:31:21.063577 2016] [core:notice] [pid 7844:tid 592]
>> >> AH00418: Parent: Created child process 2460
>> >> [Thu Sep 08 10:31:21.485472 2016] [core:warn] [pid 2460:tid 492]
>> AH00117:
>> >> [Thu Sep 08 10:31:21.501101 2016] [core:warn] [pid 2460:tid 492]
>> AH00117:
>> >> [Thu Sep 08 10:31:21.516725 2016] [wsgi:warn] [pid 2460:tid 492]
>> >> [Thu Sep 08 10:31:21.547984 2016] [mpm_winnt:notice] [pid 2460:tid 492]
>> >> [Thu Sep 08 10:31:29.775250 2016] [wsgi:error] [pid 2460:tid 2592] Not
>> >> enabling BingMaps base layer as a BING_API_KEY is not defined in
>> >> local_settings.py file.
>> >> [Thu Sep 08 10:54:30.903346 2016] [mpm_winnt:notice] [pid 7844:tid 592]
>> >> [Thu Sep 08 10:54:32.934649 2016] [mpm_winnt:notice] [pid 2460:tid 492]
>> >> [Thu Sep 08 10:54:33.122107 2016] [mpm_winnt:notice] [pid 7844:tid 592]
>> >> AH00430: Parent: Child process 2460 exited successfully.
>> >> [Thu Sep 08 10:54:34.028352 2016] [core:warn] [pid 512:tid 592]
>> >> AH00117:
>> >> [Thu Sep 08 10:54:34.043977 2016] [wsgi:warn] [pid 512:tid 592]
>> mod_wsgi:
>> mod_wsgi:
>> >> [Thu Sep 08 10:54:34.043977 2016] [mpm_winnt:notice] [pid 512:tid 592]
>> >> [Thu Sep 08 10:54:34.043977 2016] [core:notice] [pid 512:tid 592]
>> >> AH00418: Parent: Created child process 3380
>> >> [Thu Sep 08 10:54:34.434603 2016] [core:warn] [pid 3380:tid 492]
>> AH00117:
>> >> [Thu Sep 08 10:54:34.465853 2016] [core:warn] [pid 3380:tid 492]
>> AH00117:
>> >> [Thu Sep 08 10:54:34.465853 2016] [wsgi:warn] [pid 3380:tid 492]
>> >> [Thu Sep 08 10:54:34.497103 2016] [mpm_winnt:notice] [pid 3380:tid 492]
>> >> [Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592]
>> >> [client 172.16.1.176:50268] mod_wsgi (pid=3380): Exception occurred
>> >> [client 172.16.1.176:50268] Traceback (most recent call last):,
>> referer:
>> >> [client 172.16.1.176:50268]   File "C:\\GeoNode-2.4.x\\geonode-2.
>> >> [client 172.16.1.176:50268]     self.load_middleware(), referer:
>> >> [client 172.16.1.176:50268]     for middleware_path in
>> >> =100&offset=0
>> >> [client 172.16.1.176:50268]     self._setup(name), referer:
>> _setup,
>> >> [client 172.16.1.176:50268]     self._wrapped =
>> >> =100&offset=0
>> >> [client 172.16.1.176:50268]     mod = importlib.import_module(self.
>> SETTINGS_MODULE),
>> >> [client 172.16.1.176:50268]     __import__(name), referer:
>> >> =100&offset=0
>> >> [client 172.16.1.176:50268]     from local_settings import *  # noqa,
>> >> [client 172.16.1.176:50268] SyntaxError: Non-ASCII character '\\xe2' in
>> limit=100&offset=0
>> >> [Thu Sep 08 10:55:00.872156 2016] [mpm_winnt:notice] [pid 512:tid 592]
>> >> [Thu Sep 08 10:55:03.622159 2016] [mpm_winnt:notice] [pid 3380:tid 492]
>> >> [Thu Sep 08 10:55:05.028413 2016] [mpm_winnt:notice] [pid 512:tid 592]
>> >> AH00430: Parent: Child process 3380 exited successfully.
>> >> [Thu Sep 08 10:55:07.856544 2016] [core:warn] [pid 6624:tid 592]
>> AH00117:
>> >> [Thu Sep 08 10:55:08.262793 2016] [wsgi:warn] [pid 6624:tid 592]
>> >> [Thu Sep 08 10:55:08.262793 2016] [mpm_winnt:notice] [pid 6624:tid 592]
>> >> [Thu Sep 08 10:55:08.262793 2016] [core:notice] [pid 6624:tid 592]
>> >> [Thu Sep 08 10:55:08.278419 2016] [mpm_winnt:notice] [pid 6624:tid 592]
>> >> AH00418: Parent: Created child process 4352
>> >> [Thu Sep 08 10:55:08.997173 2016] [core:warn] [pid 4352:tid 492]
>> AH00117:
>> >> [Thu Sep 08 10:55:09.028421 2016] [core:warn] [pid 4352:tid 492]
>> >> AH00117: Ignoring deprecated use of DefaultType in line 424 of
>> >> [Thu Sep 08 10:55:09.090921 2016] [wsgi:warn] [pid 4352:tid 492]
>> >> [Thu Sep 08 10:55:09.122173 2016] [mpm_winnt:notice] [pid 4352:tid 492]
>> >> [Thu Sep 08 10:55:17.325312 2016] [wsgi:error] [pid 4352:tid 2592] Not
>> >> [Thu Sep 08 10:56:06.997285 2016] [mpm_winnt:notice] [pid 6624:tid 592]
>> >> [Thu Sep 08 10:56:11.731690 2016] [mpm_winnt:notice] [pid 4352:tid 492]
>> >> [Thu Sep 08 10:56:11.887926 2016] [mpm_winnt:notice] [pid 6624:tid 592]
>> >> AH00430: Parent: Child process 4352 exited successfully.
>> >> [Thu Sep 08 10:56:13.294171 2016] [core:warn] [pid 2676:tid 592]
>> AH00117:
>> >> [Thu Sep 08 10:56:13.669175 2016] [wsgi:warn] [pid 2676:tid 592]
>> >> [Thu Sep 08 10:56:13.669175 2016] [mpm_winnt:notice] [pid 2676:tid 592]
>> >> [Thu Sep 08 10:56:13.669175 2016] [core:notice] [pid 2676:tid 592]
>> >> AH00418: Parent: Created child process 5188
>> >> [Thu Sep 08 10:56:14.075424 2016] [core:warn] [pid 5188:tid 492]
>> >> [Thu Sep 08 10:56:14.091047 2016] [core:warn] [pid 5188:tid 492]
>> >> [Thu Sep 08 10:56:14.137923 2016] [wsgi:warn] [pid 5188:tid 492]
>> >> [Thu Sep 08 10:56:14.169173 2016] [mpm_winnt:notice] [pid 5188:tid 492]
>> >> [Thu Sep 08 11:06:28.357881 2016] [mpm_winnt:notice] [pid 2676:tid 592]
>> >> [Thu Sep 08 11:06:30.420438 2016] [mpm_winnt:notice] [pid 5188:tid 492]
>> >> [Thu Sep 08 11:06:30.670385 2016] [mpm_winnt:notice] [pid 2676:tid 592]
>> >> AH00430: Parent: Child process 5188 exited successfully.
>> >> [Thu Sep 08 11:06:31.764139 2016] [core:warn] [pid 6988:tid 592]
>> AH00117:
>> >> [Thu Sep 08 11:06:31.795381 2016] [wsgi:warn] [pid 6988:tid 592]
>> >> [Thu Sep 08 11:06:31.795381 2016] [mpm_winnt:notice] [pid 6988:tid 592]
>> >> [Thu Sep 08 11:06:31.795381 2016] [core:notice] [pid 6988:tid 592]
>> >> AH00418: Parent: Created child process 4600
>> >> [Thu Sep 08 11:06:32.186008 2016] [core:warn] [pid 4600:tid 492]
>> AH00117:
>> >> [Thu Sep 08 11:06:32.201632 2016] [core:warn] [pid 4600:tid 492]
>> AH00117:
>> >> [Thu Sep 08 11:06:32.217258 2016] [wsgi:warn] [pid 4600:tid 492]
>> >> [Thu Sep 08 11:06:32.248512 2016] [mpm_winnt:notice] [pid 4600:tid 492]
>> >> [Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592]
>> >> [client 172.16.1.176:50465] mod_wsgi (pid=4600): Exception occurred
>> >> [client 172.16.1.176:50465] Traceback (most recent call last):,
>> referer:
>> >> [client 172.16.1.176:50465]   File "C:\\GeoNode-2.4.x\\geonode-2.
>> >> __call__, referer: http://aupegis03/maps/?limit=100&offset=0
>> >> [client 172.16.1.176:50465]     self.load_middleware(), referer:
>> >> load_middleware, referer: http://aupegis03/maps/?limit=100&offset=0
>> >> [client 172.16.1.176:50465]     for middleware_path in
>> >> settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/maps/?limit=1
>> >> 00&offset=0
>> >> __getattr__, referer: http://aupegis03/maps/?limit=100&offset=0
>> >> [client 172.16.1.176:50465]     self._setup(name), referer:
>> _setup,
>> >> [client 172.16.1.176:50465]     self._wrapped =
>> >> Settings(settings_module), referer: http://aupegis03/maps/?limit=1
>> >> 00&offset=0
>> >> __init__, referer: http://aupegis03/maps/?limit=100&offset=0
>> >> [client 172.16.1.176:50465]     mod = importlib.import_module(self.
>> SETTINGS_MODULE),
>> >> import_module, referer: http://aupegis03/maps/?limit=100&offset=0
>> >> [client 172.16.1.176:50465]     __import__(name), referer:
>> >> line 902, referer: http://aupegis03/maps/?limit=100&offset=0
>> >> [client 172.16.1.176:50465]     "name": "SATELLITE",, referer:
>> >> [client 172.16.1.176:50465]           ^, referer:
>> >> [client 172.16.1.176:50465] SyntaxError: invalid syntax, referer:
>> >> [Thu Sep 08 11:06:50.670425 2016] [mpm_winnt:notice] [pid 6988:tid 592]
>> >> [Thu Sep 08 11:06:55.029802 2016] [mpm_winnt:notice] [pid 4600:tid 492]
>> >> [Thu Sep 08 11:06:55.717303 2016] [mpm_winnt:notice] [pid 6988:tid 592]
>> >> AH00430: Parent: Child process 4600 exited successfully.
>> >> [Thu Sep 08 11:06:57.967308 2016] [core:warn] [pid 6136:tid 592]
>> AH00117:
>> >> [Thu Sep 08 11:06:58.920435 2016] [wsgi:warn] [pid 6136:tid 592]
>> >> [Thu Sep 08 11:06:58.920435 2016] [mpm_winnt:notice] [pid 6136:tid 592]
>> >> [Thu Sep 08 11:06:58.920435 2016] [core:notice] [pid 6136:tid 592]
>> >> AH00418: Parent: Created child process 7508
>> >> [Thu Sep 08 11:06:59.514184 2016] [core:warn] [pid 7508:tid 492]
>> AH00117:
>> >> [Thu Sep 08 11:06:59.529809 2016] [core:warn] [pid 7508:tid 492]
>> AH00117:
>> >> [Thu Sep 08 11:06:59.748565 2016] [wsgi:warn] [pid 7508:tid 492]
>> >> [Thu Sep 08 11:06:59.764196 2016] [mpm_winnt:notice] [pid 7508:tid 492]
>> >> [client 172.16.1.176:50471] mod_wsgi (pid=7508): Exception occurred
>> >> [client 172.16.1.176:50471] Traceback (most recent call last):,
>> referer:
>> >> [client 172.16.1.176:50471]   File "C:\\GeoNode-2.4.x\\geonode-2.
>> >> [client 172.16.1.176:50471]     self.load_middleware(), referer:
>> >> [client 172.16.1.176:50471]     for middleware_path in
>> >> 00&offset=0
>> >> [client 172.16.1.176:50471]     self._setup(name), referer:
>> _setup,
>> >> [client 172.16.1.176:50471]     self._wrapped =
>> >> 00&offset=0
>> >> [client 172.16.1.176:50471]     mod = importlib.import_module(self.
>> SETTINGS_MODULE),
>> >> [client 172.16.1.176:50471]     __import__(name), referer:
>> >> [client 172.16.1.176:50471]     "name": "SATELLITE",, referer:
>> >> [client 172.16.1.176:50471]           ^, referer:
>> >> [client 172.16.1.176:50471] SyntaxError: invalid syntax, referer:
>> >> [Thu Sep 08 11:07:27.514239 2016] [mpm_winnt:notice] [pid 6136:tid 592]
>> >> [Thu Sep 08 11:07:37.123649 2016] [mpm_winnt:notice] [pid 7508:tid 492]
>> >> [Thu Sep 08 11:07:37.154933 2016] [mpm_winnt:notice] [pid 6136:tid 592]
>> >> AH00430: Parent: Child process 7508 exited successfully.
>> >> [Thu Sep 08 11:07:38.951761 2016] [core:warn] [pid 5332:tid 592]
>> AH00117:
>> >> [Thu Sep 08 11:07:39.373642 2016] [wsgi:warn] [pid 5332:tid 592]
>> >> [Thu Sep 08 11:07:39.373642 2016] [mpm_winnt:notice] [pid 5332:tid 592]
>> >> [Thu Sep 08 11:07:39.373642 2016] [core:notice] [pid 5332:tid 592]
>> >> AH00418: Parent: Created child process 8172
>> >> [Thu Sep 08 11:07:40.154890 2016] [core:warn] [pid 8172:tid 492]
>> AH00117:
>> >> [Thu Sep 08 11:07:40.170516 2016] [core:warn] [pid 8172:tid 492]
>> AH00117:
>> >> [Thu Sep 08 11:07:40.404889 2016] [wsgi:warn] [pid 8172:tid 492]
>> >> [Thu Sep 08 11:07:40.436140 2016] [mpm_winnt:notice] [pid 8172:tid 492]
>> >> [Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]
>> >> Internal Server Error: /services/register/
>>  File
>> >> "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\
>> >> line 112, in get_response
>> >> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>  File
>> >> "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\djang
>> >> o\\contrib\\auth\\decorators.py", line 22, in _wrapped_view
>> >> return view_func(request, *args, **kwargs)
>>  File
>> >> "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\services\\views.py", line
>> >> 110, in register_service
>> >> type, server = _verify_service_type(url)
>>  File
>> >> 239, in _verify_service_type
>> >> service.services
>>  File
>> arcrest\\server.py",
>> >> line 480, in services
>>  in
>> >> self._json_struct.get('services', [])]
>>  File
>> >> line 266, in _json_struct
>>  if
>> >> self._contents is not Ellipsis:
>>  File
>> >> line 243, in _contents
>> >> handle = compat.urllib2.urlopen(request)
>>  File
>> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 154, in urlopen
>> >> return opener.open(url, data, timeout)
>>  File
>> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 431, in open
>> >> response = self._open(req, data)
>>  File
>> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 449, in _open
>> >> '_open', req)
>>  File
>> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 409, in
>> _call_chain
>> >> result = func(*args)
>>  File
>> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 1227, in http_open
>> >> return self.do_open(httplib.HTTPConnection, req)
>>  File
>> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 1197, in do_open
>> >> raise URLError(err)
>> because
>> respond>
>> >> [Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]
>> >> Internal Server Error: /maps/58/thumbnail
>>  File
>> >> line 105, in get_response
>> >> response = middleware_method(request, callback, callback_args,
>> >> callback_kwargs)
>>  File
>> django\\middleware\\csrf.py",
>> >> line 170, in process_view
>> >> request_csrf_token = request.POST.get('csrfmiddlewaretoken', '')
>>  File
>> >> line 146, in _get_post
>> >> self._load_post_and_files()
>>  File
>> django\\http\\request.py",
>> >> line 227, in _load_post_and_files
>> >> self._post, self._files = QueryDict(self.body,
>> >> encoding=self._encoding),
>> >> MultiValueDict()
>>  File
>> >> line 190, in body
>> >> six.reraise(UnreadablePostError, UnreadablePostError(*e.args),
>> >> sys.exc_info()[2])
>>  File
>> >> line 188, in body
>> >> self._body = self.read()
>>  File
>> >> line 244, in read
>> >> sys.exc_info()[2])
>>  File
>> >> line 242, in read
>> >> return self._stream.read(*args, **kwargs)
>>  File
>> >> line 45, in read
>> >> result = self.buffer + self._read_limited()
>>  File
>> >> line 39, in _read_limited
>> >> result = self.stream.read(size)
>> >> UnreadablePostError: Apache/mod_wsgi request data read error: Partial
>> >> results are valid but processing is incomplete.
>> >> *Chris Franklin*
>> >> GIS and Database Co-ordinator
>> >> Exploration Australia
>> >> <image001.jpg>
>> >> Tel:         +61 08 9425 4719
>> >> Fax:        +61 08 9425 4650
>> >> Email:      cfranklin at anglogoldashanti.com
>> >> Consider the environment. Think before you print.
>> >> *From:* alessio.fabiani at gmail.com [mailto:alessio.fabiani at gmail.com]
>> *On
>> >> Behalf Of *Alessio Fabiani
>> >> *Sent:* Thursday, 8 September 2016 3:47 PM
>> >> *To:* Franklin, Chris
>> >> *Cc:* Jeffrey Johnson; geonode-users at lists.osgeo.org
>> >> *Subject:* Re: [GeoNode-users] LDAP on windows
>> >> Do you see some specific line on the geonode-2.4.x/apache/logs/
>> error.log
>> >> or other log files?
>> >> Best Regards,
>> >> Alessio Fabiani.
>> >> @alfa7691
>> >> GeoSolutions S.A.S.
>> >> Italy
>> >> messaggio,
>> >> messaggio
>> stesso,
>> >> ai
>> >> for the attention and use of the named addressee(s) and may be
>> confidential
>> >> or proprietary in nature or covered by the provisions of privacy act
>> reproduction,
>> partial, is
>> or
>> >> changes
>> >> On Thu, Sep 8, 2016 at 4:39 AM, Franklin, Chris <
>> >> Ok, im getting closer:
>> >> I set the virtualenv first – ran
>> >> <image006.png>
>> >> Then ran :
>> >> <image009.png>
>> >> Added:
>> >> *#LDAP*
>> >> *import ldap*
>> >> *from django_auth_ldap.config import LDAPSearch*
>> >> *AUTHENTICATION_BACKENDS = (*
>> >> *    'django_auth_ldap.backend.LDAPBackend',*
>> >> *    'django.contrib.auth.backends.ModelBackend',*
>> >> *    'guardian.backends.ObjectPermissionBackend',*
>> >> *AUTH_LDAP_SERVER_URI = ‘ldap://ag.ad.local' *
>> >> *LDAP_SEARCH_DN = 'OU=AUSTRALIA,OU=AUSTRALASIA,DC=ag,DC=ad,DC=local' *
>> >> *AUTH_LDAP_USER = '(uid=%(user)s)'*
>> >> *AUTH_LDAP_BIND_DN = '{ADD_BIND_DN_IF_REQUIRED}'*
>> >> *AUTH_LDAP_BIND_PASSWORD = '{ADD_BIND_PASSWORD_IF_REQUIRED}'*
>> >> *AUTH_LDAP_USER_ATTR_MAP = {*
>> >> *    'first_name': 'givenName', 'last_name': 'sn', 'email': 'mail',*
>> >> *AUTH_LDAP_USER_SEARCH = LDAPSearch(LDAP_SEARCH_DN,*
>> >> *                                   ldap.SCOPE_SUBTREE,
>> >> AUTH_LDAP_USER)*
>> >> to my local_settings.py file like so:
>> >> <image010.png>
>> >> Restarted Apache but Geonode had a 500 error – what did I do wrong?
>> >> Thanks
>> >> *Chris Franklin*
>> >> <image011.jpg>
>> *On
>> >> *Sent:* Wednesday, 7 September 2016 4:18 PM
>> >> *To:* Jeffrey Johnson
>> >> *Cc:* Franklin, Chris; geonode-users at lists.osgeo.org
>> >> Jeffrey is right, you need to use pip, but first of all you need to:
>> >> 1. go to the windows prompt
>> >> 2. go to the geonode installation folder
>> >> 3. activate the virtual env with the batch command :
>> >> cd C:\GeoNode-2.4.x\geonode-2.4.x
>> >> python_env.bat
>> >> Scripts\activate.bat
>> >> Regards,
>> >> -A.
>> >> Best Regards,
>> >> Alessio Fabiani.
>> >> @alfa7691
>> >> GeoSolutions S.A.S.
>> >> Italy
>> >> messaggio,
>> >> messaggio
>> stesso,
>> >> ai
>> confidential
>> reproduction,
>> partial, is
>> or
>> >> changes
>> >> On Tue, Sep 6, 2016 at 6:42 PM, Jeffrey Johnson <ortelius at gmail.com>
>> >> wrote:
>> >> Chris, you need to use pip. Im not sure how the virtualenvironment is
>> >> setup. Alessio, can you give us some insight here?
>> >> https://pip.pypa.io/en/stable/user_guide/#installing-from-wheels (on
>> >> windows you need to use the command prompt)
>> >> On Mon, Sep 5, 2016 at 9:19 PM, Franklin, Chris <
>> >> Thanks dan,
>> >> Have been trying to see how I can install the .whl file but can’t find
>> >> any info on it, can someone out there help?
>> >> Regards
>> >> *Chris Franklin*
>> >> <image012.jpg>
>> >> Mob:       +61 04 4818 2351
>> >> *From:* Daniel Berry [mailto:dberry at boundlessgeo.com]
>> >> *Sent:* Wednesday, 31 August 2016 8:29 PM
>> >> *To:* Franklin, Chris <CFranklin at AngloGoldAshanti.com>
>> >> *Cc:* Jeffrey Johnson <ortelius at gmail.com>;
>> >> Chris,
>> >> It looks like for windows you could use one of these wheel files to
>> >> install python-ldap. Just match the wheel to your OS.
>> >> http://www.lfd.uci.edu/~gohlke/pythonlibs/#python-ldap
>> >> These have already been pre built and include the `.pyd` file, which is
>> a
>> >> `.dll` file - https://docs.python.org/3/faq/windows.html#is-a-pyd-file-
>> >> the-same-as-a-dll. This should alleviate you having to install devel
>> >> libs and compile the source from pypi using pip.
>> >> Good luck!
>> >> Dan
>> >> On Wed, Aug 31, 2016 at 1:57 AM, Franklin, Chris <
>> >> Ok I added this to my local setting file :
>> >> import ldap
>> >>                                    ldap.SCOPE_SUBTREE, AUTH_LDAP_USER)
>> >> But was unsure on installing the ldap devel lib – who do I do that on
>> >> windows?
>> >> http://docs.geonode.org/en/master/tutorials/admin/ldap/
>> >> Cheers
>> >> *Chris Franklin*
>> >> <image013.jpg>
>> >> *From:* Jeffrey Johnson [mailto:ortelius at gmail.com]
>> >> *Sent:* Thursday, 25 August 2016 2:24 PM
>> >> *Cc:* geonode-users at lists.osgeo.org
>> >> I dont think there should be any difference in how it works on windows.
>> >> Let us know how it goes.
>> >> On Thu, Aug 25, 2016 at 6:45 AM, Franklin, Chris <
>> >> Hi,
>> >> Im looking to link my Geonode 2.4 windows into the corp LDAP, is this
>> >> possible in windows?
>> >> http://docs.geonode.org/en/master/tutorials/admin/ldap/index.html
>> >> Regards
>> >> *Chris Franklin*
>> >> <image012.jpg>
>> >> This email, and its attachments, is subject to important warnings and
>> >> disclaimers which are legally incorporated into this email in terms of
>> >> Section 11(3) of the South African Electronic Communications and
>> >> Transactions Act, 25 of 2002. The full text of the warnings and
>> >> disclaimers, together with the company details and directors is
>> available
>> >> by clicking on http://www.anglogoldashanti.com/en/Pages/legal.aspx
>> >> _______________________________________________
>> available
>> >> *Daniel Berry*
>> >> Senior Software Engineer | Boundless
>> >> 512-468-3946 (cell)
>> >> @boundlessgeo
>> available
>> available
>> available
>> > available
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <http://lists.osgeo.org/pipermail/geonode-users/
>> attachments/20160908/c07fa5a7/attachment.html>
>> Subject: Digest Footer
>> End of geonode-users Digest, Vol 20, Issue 17
> URL:
> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/135bb64c/attachment.html>
> End of geonode-users Digest, Vol 20, Issue 18
> Transactions Act, 25 of 2002. The full text of the warnings and disclaimers,
> together with the company details and directors is available by clicking on
More information about the geonode-users mailing list
