[GeoNode-users] Failure to connect to postgres store in geonode 2.5
Francesco Bartoli xbartolone at gmail.com
Thu Sep 29 06:30:43 PDT 2016
I see the error is claiming a missing pg_hba.conf configuration but I don’t have time to look into that now. If you are using docker containers from geonode organization can you please file an issue and report the error?
Thanks,
Francesco
Il giorno 29/set/2016, alle ore 11:54, admire <addloe at gmail.com> ha scritto:
> Hi
> I have installed docker geonode 2.5 but I am however failing to create a postgis store in geonode geoserver.
> The containers are linked fine but when you exec into the container looking at the /etc/hosts shows that no entry for the linked containers is visible.
> When I do a docker inspect on the geoserver container I can see the containers are linked but I cannot publish a postgis store in geonode geoserver
> docker-compose -p gfdrr_oondra exec django django-admin.py migrate account --noinput
> Traceback (most recent call last):
>  File "/usr/local/bin/django-admin.py", line 5, in <module>
>    management.execute_from_command_line()
>  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
>    utility.execute()
>  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 346, in execute
>    self.fetch_command(subcommand).run_from_argv(self.argv)
>  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 394, in run_from_argv
>    self.execute(*args, **cmd_options)
>  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 445, in execute
>    output = self.handle(*args, **options)
>  File "/usr/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py", line 93, in handle
>    executor = MigrationExecutor(connection, self.migration_progress_callback)
>  File "/usr/local/lib/python2.7/site-packages/django/db/migrations/executor.py", line 19, in __init__
>    self.loader = MigrationLoader(self.connection)
>  File "/usr/local/lib/python2.7/site-packages/django/db/migrations/loader.py", line 47, in __init__
>    self.build_graph()
>  File "/usr/local/lib/python2.7/site-packages/django/db/migrations/loader.py", line 191, in build_graph
>    self.applied_migrations = recorder.applied_migrations()
>  File "/usr/local/lib/python2.7/site-packages/django/db/migrations/recorder.py", line 59, in applied_migrations
>    self.ensure_schema()
>  File "/usr/local/lib/python2.7/site-packages/django/db/migrations/recorder.py", line 49, in ensure_schema
>    if self.Migration._meta.db_table in self.connection.introspection.table_names(self.connection.cursor()):
>  File "/usr/local/lib/python2.7/site-packages/django/db/backends/base/base.py", line 162, in cursor
>    cursor = self.make_debug_cursor(self._cursor())
>  File "/usr/local/lib/python2.7/site-packages/django/db/backends/base/base.py", line 135, in _cursor
>    self.ensure_connection()
>  File "/usr/local/lib/python2.7/site-packages/django/db/backends/base/base.py", line 130, in ensure_connection
>    self.connect()
>  File "/usr/local/lib/python2.7/site-packages/django/db/utils.py", line 98, in __exit__
>    six.reraise(dj_exc_type, dj_exc_value, traceback)
>    self.connect()
>  File "/usr/local/lib/python2.7/site-packages/django/db/backends/base/base.py", line 119, in connect
>    self.connection = self.get_new_connection(conn_params)
>  File "/usr/local/lib/python2.7/site-packages/django/db/backends/postgresql_psycopg2/base.py", line 176, in get_new_connection
>    connection = Database.connect(**conn_params)
>  File "/usr/local/lib/python2.7/site-packages/psycopg2/__init__.py", line 164, in connect
>    conn = _connect(dsn, connection_factory=connection_factory, async=async)
> django.db.utils.OperationalError: FATAL:  no pg_hba.conf entry for host "172.19.0.7", user "postgres", database "postgres", SSL on
> FATAL:  no pg_hba.conf entry for host "172.19.0.7", user "postgres", database "postgres", SSL off
> Regards
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160929/ef663444/attachment.html>
More information about the geonode-users mailing list
