[GeoNode-users] geoserver authentication in multi-geosites
Simone Dalmasso simone.dalmasso at gmail.com
Wed Apr 5 06:39:50 PDT 2017
Eugenio, I don't see wrong config. It is ok I guess to leave the master
site host in the gs config as well as I think it is ok that you cannot log
in directly into gs from a child site. That said, when geosites was
developed, the geoserver ext was modified to make sure that geoserver pings
the same host that made the http request for authentication instead of
relying on the base url parameter. So ideally it should work as you would
expect.
2017-04-05 14:39 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi,
> I'm working on geonode 2.4 in a Ubuntu server 14.04LTS (tomcat7, java8).
> I had to upgrade geoserver from 2.7.x version up to 2.9.x.
> In the system I configured geonode to work as multi-geosites.
> The master site is the normal geonode site, I mean it use the
> local_setting.py I have in /geonode/geonode
> The geosites are in /geonode/geonode/contrib/geosites, and they use the
> relative config files.
> The documentation: https://github.com/terranodo/geosites-
> project/blob/master/GEOSITES-README.md
> indicates to leave empty <baseurl> in config.xml in security/auth/
> geonodeauthprovider/
> In that way I have this error:
> java.lang.IllegalArgumentException: host parameter is null
> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:206)
> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:155)
> 	org.apache.commons.httpclient.SimpleHttpConnectionManager.getConnectionWithTimeout(SimpleHttpConnectionManager.java:175)
> 	org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:153)
> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
> 	org.geonode.security.HTTPClient.sendGET(HTTPClient.java:89)
> 	org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
> 	org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
> 	org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
> 	org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
> 	org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
> 	org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:323)
> 	org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:94)
> 	org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
> 	org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
> 	org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
> 	org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
> 	org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
> 	org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
> 	org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
> 	org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
> 	org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
> 	org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
> 	org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
> 	org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
> 	org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
> 	org.springframework.web.filter.CharacterEncodingFilter.doFilterIntaernal(CharacterEncodingFilter.java:121)
> 	org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
> both if I use the geoserver link in the menu (once logged in) and if I
> call geoserver by using the geoserver url in the browser address bar.
> If set the doman name of the master site in <baseurl> in config.xml in
> security/auth/geonodeauthprovider/
> I'm able to enter in geoserver as admin from the menu, by the way doing
> the same operation from a geosite
> I got the geoserverage but not logged.
> The master site virtualhost as well as those of the geosites have the
> proxypass and reverse pointing to http://localhost:8080/geoserver
> The same in /geonode/geonode/contrib/geosites/local_setting.py and
> pre-setting.py I have http://localhost:8080/geoserver
> Is there a wrong configuration?
> Any hints?
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170405/9e5d12a1/attachment-0001.html>
More information about the geonode-users mailing list
