[GeoNode-users] geoserver authentication in multi-geosites
Eugenio Trumpy frippe12573 at hotmail.com
Thu Apr 6 03:08:09 PDT 2017
Unfortunately I have to come back again on this topic, that seemed to be almost solved yesterday, because this morning I realized that in my running configuration I cannot view any layer (i.e. in the info page I see the pink tiles) if I'm not logged in geoserver as admin, and since the authentication via geonode dosen't currently work fine that is a problem.
This happen both from the master and from geosites.
I think there still is some problem on geoserver configuration.
No useful info on logs.
Da: Simone Dalmasso <simone.dalmasso at gmail.com>
Inviato: mercoledì 5 aprile 2017 15.39
A: Eugenio Trumpy
Cc: geonode-users at lists.osgeo.org
Oggetto: Re: geoserver authentication in multi-geosites
Eugenio, I don't see wrong config. It is ok I guess to leave the master site host in the gs config as well as I think it is ok that you cannot log in directly into gs from a child site. That said, when geosites was developed, the geoserver ext was modified to make sure that geoserver pings the same host that made the http request for authentication instead of relying on the base url parameter. So ideally it should work as you would expect.
2017-04-05 14:39 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>>:
I'm working on geonode 2.4 in a Ubuntu server 14.04LTS (tomcat7, java8).
I had to upgrade geoserver from 2.7.x version up to 2.9.x.
In the system I configured geonode to work as multi-geosites.
The master site is the normal geonode site, I mean it use the local_setting.py I have in /geonode/geonode
The geosites are in /geonode/geonode/contrib/geosites, and they use the relative config files.
The documentation: https://github.com/terranodo/geosites-project/blob/master/GEOSITES-README.md
indicates to leave empty <baseurl> in config.xml in security/auth/geonodeauthprovider/
In that way I have this error:
java.lang.IllegalArgumentException: host parameter is null
        org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:206)
        org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:155)
        org.apache.commons.httpclient.SimpleHttpConnectionManager.getConnectionWithTimeout(SimpleHttpConnectionManager.java:175)
        org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:153)
        org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
        org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
        org.geonode.security.HTTPClient.sendGET(HTTPClient.java:89)
        org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
        org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
        org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
        org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
        org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
        org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:323)
        org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:94)
        org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
        org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
        org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
        org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
        org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
        org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
        org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
        org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
        org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
        org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
        org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
        org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
        org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
        org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
        org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
        org.springframework.web.filter.CharacterEncodingFilter.doFilterIntaernal(CharacterEncodingFilter.java:121)
        org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
both if I use the geoserver link in the menu (once logged in) and if I call geoserver by using the geoserver url in the browser address bar.
If set the doman name of the master site in <baseurl> in config.xml in security/auth/geonodeauthprovider/
I'm able to enter in geoserver as admin from the menu, by the way doing the same operation from a geosite
I got the geoserverage but not logged.
The master site virtualhost as well as those of the geosites have the proxypass and reverse pointing to http://localhost:8080/geoserver
The same in /geonode/geonode/contrib/geosites/local_setting.py and pre-setting.py I have http://localhost:8080/geoserver
Is there a wrong configuration?
Any hints?
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170406/21eea4d9/attachment-0001.html>
More information about the geonode-users mailing list
