[GeoNode-users] Geonode - Error on uploading layer
Francesco Bartoli xbartolone at gmail.com
Mon Apr 10 01:58:04 PDT 2017
[config.vm.network](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-eec0852c-
64f5/0?redirect=config.vm.network&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
"forwarded_port", guest: 8080, host: 8080
is simply redundant. It has been added to access geoserver out of the scope of
oauth2.
What url are you going to call in the browser for geoserver?
Sent from [Nylas Pro](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-
pro%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the most powerful
email app for work
![](https://link.nylas.com/open/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-
64f5?r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
On apr 10 2017, at 10:49 am, giuseppe musumeci <musumeci.giuseppe at gmail.com>
wrote:
> I ran the installation of Geonode using the instructions at the link
[http://geonode.org/geonode-workshop/foss4git2017/#/4/2](http://geonode.org
/geonode-
workshop/foss4git2017/#/4/2&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
> I think there are problems in the instructions about geoserver
configuration:
> $ Sudo vi usr / share / geoserver / data / global.xml
> I changed the default settings with those specified:
> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
> But geoserver don't works: I then set the value to
> moreover i Think that to configure vagrantfile as suggested:
> config.vm.network "forwarded_port", guest: 8080, host: 8080
> is not correct.
> Could someone tell me the correct settings values for geoserver and
vagrantfile?
> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli
<[xbartolone at gmail.com](mailto:xbartolone at gmail.com)>:
>> Dear Giuseppe,
>> as already replied on the italian gfoss list you should check to follow
from scratch the workshop [http://geonode.org/geonode-
workshop/foss4git2017/#/4/2](http://geonode.org/geonode-
workshop/foss4git2017/#/4/2&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) we did
during foss4g-it. If the error is still happening please let me know as
probably in this case the beta release is also affected and you can help us
with your feedback.
>> Thanks,
>> Francesco
>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci
<[musumeci.giuseppe at gmail.com](mailto:musumeci.giuseppe at gmail.com)> ha
scritto:
>>> Dear list I'm working with Geonode that I installed on a VM set via
Vagrant When I try to load the shape file, I get this error: **failed to
create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777** In the Apache error
log is as follows: **ERROR: geonode.layers.views: failed to create /var/www
/vagrant-ubuntu-trusty-64.Dummy-2-3778** Trying to google around I found that
in the settings.py file should add the line: NOTIFICATION_LOCK_LOCATION = '/
var / www / geonode' Finally I verified that the www-data user has all
permissions on the www / folder geonode drwxr-xr-x 5 www-data root March 21
4096 14:27 geonode The fact remains that I can't upload. Does anyone know help
me?
geonode-users mailing list
[geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/geonode-
users](https://lists.osgeo.org/mailman/listinfo/geonode-
users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/8d907be7/attachment.html>
More information about the geonode-users mailing list
