[GeoNode-users] Geonode - Error on uploading layer
Francesco Bartoli xbartolone at gmail.com
Mon Apr 10 04:18:51 PDT 2017
Giuseppe,
if you set "<proxyBaseUrl>http://localhost:8080/geoserver/</proxyBaseUrl>" then you have to make that url reachable from your host. That means
the configuration "config.vm.network "forwarded_port", guest: 8080, host: 8080” is required otherwise you get the 404 error.
Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
> To be able to upload layers I must set
> into  usr/share/geoserver/data/global.xml
> If I open geoserver from the admin panel the address is
> http://localhost:8001/geoserver/web/?1
> but If i want for example a layer preview
> address change to
> http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto
> with error The requested URL /geoserver/geonode/wms was not found on this server.
> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> is simply redundant. It has been added to access geoserver out of the scope of oauth2.
> What url are you going to call in the browser for geoserver?
> Sent from Nylas Pro, the most powerful email app for work
> On apr 10 2017, at 10:49 am, giuseppe musumeci <musumeci.giuseppe at gmail.com> wrote:
> I ran the installation of Geonode using the instructions at the link http://geonode.org/geonode-workshop/foss4git2017/#/4/2
> I think there are problems in the instructions about geoserver configuration:
> $ Sudo vi usr / share / geoserver / data / global.xml
> I changed the default settings with those specified:
> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
> But geoserver don't works: I then set the value to
> moreover i Think that to configure vagrantfile as suggested:
> is not correct.
> Could someone tell me the correct settings values for geoserver and vagrantfile?
> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Dear Giuseppe,
> as already replied on the italian gfoss list you should check to follow from scratch the workshop http://geonode.org/geonode-workshop/foss4git2017/#/4/2 we did during foss4g-it. If the error is still happening please let me know as probably in this case the beta release is also affected and you can help us with your feedback.
> Thanks,
> Francesco
> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
>> Dear list
>> I'm working with Geonode that I installed on a VM set via Vagrant
>> When I try to load the shape file, I get this error:
>> failed to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777
>> In the Apache error log is as follows:
>> ERROR: geonode.layers.views: failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778
>> Trying to google around I found that in the settings.py file should add the line:
>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode'
>> Finally I verified that the www-data user has all permissions on the www / folder geonode
>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode
>> The fact remains that I can't upload.
>> Does anyone know help me?
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/65e47d0c/attachment.html>
More information about the geonode-users mailing list
