[GeoNode-users] Geonode - Error on uploading layer
Francesco Bartoli xbartolone at gmail.com
Mon Apr 10 04:31:55 PDT 2017
Can you double check what you have in the settings for the geoserver
configurations?
Sent from [Nylas Pro](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-
pro%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the most powerful
email app for work![](https://link.nylas.com/open/43o9gzlmd58gqwkxv3di3wjcc
/local-677d8377-2abb?r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
On apr 10 2017, at 1:28 pm, giuseppe musumeci <musumeci.giuseppe at gmail.com>
wrote:
> Dear Francesco,
> I followed the tutorial
> I need to set <proxyBaseUrl>[http://localhost:8001/geoserver/](http://localh
ost:8080/geoserver/&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)</proxyBaseUrl>
> and not <proxyBaseUrl>[http://localhost:8001/](http://localhost:8080/geoserv
> In this way geoserver seems to work fine.
> The problem is I'm not able to upload layers from geonode menu
> [Errno 111] Connection refused
> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli
<[xbartolone at gmail.com](mailto:xbartolone at gmail.com)>:
>> Giuseppe,
>> if you set "<proxyBaseUrl>[http://localhost:8080/geoserver/](http://localho
st:8080/geoserver/&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)</proxyBaseUrl>"
then you have to make that url reachable from your host. That means
>> the configuration
"[config.vm.network](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ2
1haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) "forwarded_port",
guest: 8080, host: 8080” is required otherwise you get the 404 error.
>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci
<[musumeci.giuseppe at gmail.com](mailto:musumeci.giuseppe at gmail.com)> ha
scritto:
>>> To be able to upload layers I must set
>>> <proxyBaseUrl>[http://localhost:8080/geoserver/](http://localhost:8080/geo
>>> into usr/share/geoserver/data/global.xml
>>> If I open geoserver from the admin panel the address is
>>> [http://localhost:8001/geoserver/web/?1](http://localhost:8001/geoserver/w
eb/?1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
>>> but If i want for example a layer preview
>>> address change to
>>> [http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aN
Wvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto](http://localh
ost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fs
ervice%3DWMS/kml?layers=geonode:fiora_amianto&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2
dlby5vcmc=)
>>> with error The requested URL /geoserver/geonode/wms was not found on this
server.
>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli
>>>> is simply redundant. It has been added to access geoserver out of the
scope of oauth2.
>>>> What url are you going to call in the browser for geoserver?
__Sent from [Nylas Pro](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1
&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5v
cmc=), the most powerful email app for work__
>>>> ![](https://link.nylas.com/open/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-
64f5?r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
On apr 10 2017, at 10:49 am, giuseppe musumeci
<[musumeci.giuseppe at gmail.com](mailto:musumeci.giuseppe at gmail.com)> wrote:
>>>>> I ran the installation of Geonode using the instructions at the link
[http://geonode.org/geonode-workshop/foss4git2017/#/4/2](http://geonode.org
/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=
>>>>> I think there are problems in the instructions about geoserver
configuration:
>>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>>> I changed the default settings with those specified:
>>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>>> But geoserver don't works: I then set the value to
>>>>> moreover i Think that to configure vagrantfile as suggested:
>>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>>> is not correct.
>>>>> Could someone tell me the correct settings values for geoserver and
vagrantfile?
>>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli
>>>>>> Dear Giuseppe,
>>>>>> as already replied on the italian gfoss list you should check to follow
from scratch the workshop [http://geonode.org/geonode-
workshop/foss4git2017/#/4/2](http://geonode.org/geonode-workshop/foss4git2017/
#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2d
lby5vcmc=) we did during foss4g-it. If the error is still happening please let
me know as probably in this case the beta release is also affected and you can
help us with your feedback.
>>>>>> Thanks,
>>>>>> Francesco
>>>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci
scritto:
>>>>>>> Dear list I'm working with Geonode that I installed on a VM set via
Vagrant When I try to load the shape file, I get this error: **failed to
create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777** In the Apache error
log is as follows: **ERROR: geonode.layers.views: failed to create /var/www
/vagrant-ubuntu-trusty-64.Dummy-2-3778** Trying to google around I found that
in the settings.py file should add the line: NOTIFICATION_LOCK_LOCATION = '/
var / www / geonode' Finally I verified that the www-data user has all
permissions on the www / folder geonode drwxr-xr-x 5 www-data root March 21
4096 14:27 geonode The fact remains that I can't upload. Does anyone know help
me?
>>>>>>> _______________________________________________
geonode-users mailing list
[geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/geonode-
users](https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2
l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/f2a03ab1/attachment.html>
More information about the geonode-users mailing list
