[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Mon Apr 10 04:44:15 PDT 2017
>From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
GEOSERVER_LOCATION = os.getenv(
    'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
GEOSERVER_PUBLIC_LOCATION = os.getenv(
    'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/'
>From /etc/geonode/local_settings.py
GEOSERVER_URL = SITEURL + 'geoserver/'
2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Can you double check what you have in the settings for the
> geoserver configurations?
> Sent from Nylas Pro
> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
> the most powerful email app for work
> On apr 10 2017, at 1:28 pm, giuseppe musumeci <musumeci.giuseppe at gmail.com>
> wrote:
>> Dear Francesco,
>> I followed the tutorial
>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>> </proxyBaseUrl>
>> and not <proxyBaseUrl>http://localhost:8001/
>> </proxyBaseUrl>
>> In this way geoserver seems to work fine.
>> The problem is I'm not able to upload layers from geonode menu
>> [Errno 111] Connection refused
>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Giuseppe,
>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>> </proxyBaseUrl>" then you have to make that url reachable from your
>> host. That means
>> the configuration "config.vm.network
>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise you
>> get the 404 error.
>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>> musumeci.giuseppe at gmail.com> ha scritto:
>> To be able to upload layers I must set
>> </proxyBaseUrl>
>> into usr/share/geoserver/data/global.xml
>> If I open geoserver from the admin panel the address is
>> http://localhost:8001/geoserver/web/?1
>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>> but If i want for example a layer preview
>> address change to
>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geo
>> node:fiora_amianto
>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>> with error The requested URL /geoserver/geonode/wms was not found on
>> this server.
>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> config.vm.network
>> is simply redundant. It has been added to access geoserver out of the
>> scope of oauth2.
>> What url are you going to call in the browser for geoserver?
>> Sent from Nylas Pro
>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>> musumeci.giuseppe at gmail.com> wrote:
>> I ran the installation of Geonode using the instructions at the link
>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>> I think there are problems in the instructions about geoserver
>> configuration:
>> $ Sudo vi usr / share / geoserver / data / global.xml
>> I changed the default settings with those specified:
>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>> But geoserver don't works: I then set the value to
>> moreover i Think that to configure vagrantfile as suggested:
>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>> is not correct.
>> Could someone tell me the correct settings values for geoserver and
>> vagrantfile?
>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Dear Giuseppe,
>> as already replied on the italian gfoss list you should check to follow
>> from scratch the workshop http://geonode.org/ge
>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>> did during foss4g-it. If the error is still happening please let me know as
>> probably in this case the beta release is also affected and you can help us
>> with your feedback.
>> Thanks,
>> Francesco
>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>> Dear list I'm working with Geonode that I installed on a VM set via
>> Vagrant When I try to load the shape file, I get this error: *failed to
>> create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the Apache
>> error log is as follows: *ERROR: geonode.layers.views: failed to create
>> /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to google around
>> I found that in the settings.py file should add the line:
>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>> that the www-data user has all permissions on the www / folder geonode
>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>> that I can't upload. Does anyone know help me?
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/6dc126fa/attachment-0001.html>
More information about the geonode-users mailing list
