[GeoNode-users] Geonode - Error on uploading layer
Francesco Bartoli xbartolone at gmail.com
Mon Apr 10 05:33:32 PDT 2017
How did you perform the installation?
You were originally receive that error because GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
'http://localhost:8001/geoserver'
Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
> GEOSERVER_LOCATION = os.getenv(
>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/'
> From /etc/geonode/local_settings.py
> GEOSERVER_URL = SITEURL + 'geoserver/'
> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Can you double check what you have in the settings for the geoserver configurations?
> Sent from Nylas Pro, the most powerful email app for work
> On apr 10 2017, at 1:28 pm, giuseppe musumeci <musumeci.giuseppe at gmail.com> wrote:
> Dear Francesco,
> I followed the tutorial
> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/</proxyBaseUrl>
> and not <proxyBaseUrl>http://localhost:8001/</proxyBaseUrl>
> In this way geoserver seems to work fine.
> The problem is I'm not able to upload layers from geonode menu
> [Errno 111] Connection refused
> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Giuseppe,
> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/</proxyBaseUrl>" then you have to make that url reachable from your host. That means
> the configuration "config.vm.network "forwarded_port", guest: 8080, host: 8080” is required otherwise you get the 404 error.
> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
>> To be able to upload layers I must set
>> into  usr/share/geoserver/data/global.xml
>> If I open geoserver from the admin panel the address is
>> http://localhost:8001/geoserver/web/?1
>> but If i want for example a layer preview
>> address change to
>> http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto
>> with error The requested URL /geoserver/geonode/wms was not found on this server.
>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> is simply redundant. It has been added to access geoserver out of the scope of oauth2.
>> What url are you going to call in the browser for geoserver?
>> On apr 10 2017, at 10:49 am, giuseppe musumeci <musumeci.giuseppe at gmail.com> wrote:
>> I ran the installation of Geonode using the instructions at the link http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>> I think there are problems in the instructions about geoserver configuration:
>> $ Sudo vi usr / share / geoserver / data / global.xml
>> I changed the default settings with those specified:
>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>> But geoserver don't works: I then set the value to
>> moreover i Think that to configure vagrantfile as suggested:
>> is not correct.
>> Could someone tell me the correct settings values for geoserver and vagrantfile?
>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Dear Giuseppe,
>> as already replied on the italian gfoss list you should check to follow from scratch the workshop http://geonode.org/geonode-workshop/foss4git2017/#/4/2 we did during foss4g-it. If the error is still happening please let me know as probably in this case the beta release is also affected and you can help us with your feedback.
>> Thanks,
>> Francesco
>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
>>> Dear list
>>> I'm working with Geonode that I installed on a VM set via Vagrant
>>> When I try to load the shape file, I get this error:
>>> failed to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777
>>> In the Apache error log is as follows:
>>> ERROR: geonode.layers.views: failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778
>>> Trying to google around I found that in the settings.py file should add the line:
>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode'
>>> Finally I verified that the www-data user has all permissions on the www / folder geonode
>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode
>>> The fact remains that I can't upload.
>>> Does anyone know help me?
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/21cf4e7c/attachment.html>
More information about the geonode-users mailing list
