[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Mon Apr 10 07:05:04 PDT 2017
I've already done it in this attempt
Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com> ha scritto:
> Can you please repeat all the commands from scratch? You can do it by
> running “vagrant destroy”
> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <
> musumeci.giuseppe at gmail.com> ha scritto:
> I installed again geonode according the tutorial
> I run the command geonode-updateip
> I have problem to load layers:[Errno 111] Connection refused
> Where I'm wrong?
> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Yes, absolutely. It looks like you missed this one
>> http://geonode.org/geonode-workshop/foss4git2017/#/4/6
>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
>> I followed all the istructions in the tutorial you send me.
>> Is there a way to correct these errors using a command (i.e sudo
>> geonode-updateip localhost:8001)?
>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> How did you perform the installation?
>>> You were originally receive that error because GEOSERVER_PUBLIC_LOCATION
>>> is wrong. It should be:
>>> 'http://localhost:8001/geoserver'
>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>> GEOSERVER_LOCATION = os.getenv(
>>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/'
>>> From /etc/geonode/local_settings.py
>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Can you double check what you have in the settings for the
>>>> geoserver configurations?
>>>> Sent from Nylas Pro
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>> the most powerful email app for work
>>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>>> musumeci.giuseppe at gmail.com> wrote:
>>>>> Dear Francesco,
>>>>> I followed the tutorial
>>>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>> </proxyBaseUrl>
>>>>> and not <proxyBaseUrl>http://localhost:8001/
>>>>> </proxyBaseUrl>
>>>>> In this way geoserver seems to work fine.
>>>>> The problem is I'm not able to upload layers from geonode menu
>>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> Giuseppe,
>>>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>>>> host. That means
>>>>> the configuration "config.vm.network
>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise you
>>>>> get the 404 error.
>>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>>>> To be able to upload layers I must set
>>>>> </proxyBaseUrl>
>>>>> into usr/share/geoserver/data/global.xml
>>>>> If I open geoserver from the admin panel the address is
>>>>> http://localhost:8001/geoserver/web/?1
>>>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>> but If i want for example a layer preview
>>>>> address change to
>>>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>>>> de:fiora_amianto
>>>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>> with error The requested URL /geoserver/geonode/wms was not found on
>>>>> this server.
>>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> config.vm.network
>>>>> is simply redundant. It has been added to access geoserver out of the
>>>>> scope of oauth2.
>>>>> What url are you going to call in the browser for geoserver?
>>>>> Sent from Nylas Pro
>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>>>> I ran the installation of Geonode using the instructions at the link
>>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>> I think there are problems in the instructions about geoserver
>>>>> configuration:
>>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>>> I changed the default settings with those specified:
>>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>>> But geoserver don't works: I then set the value to
>>>>> moreover i Think that to configure vagrantfile as suggested:
>>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>>> is not correct.
>>>>> Could someone tell me the correct settings values for geoserver and
>>>>> vagrantfile?
>>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> Dear Giuseppe,
>>>>> as already replied on the italian gfoss list you should check to
>>>>> follow from scratch the workshop http://geonode.org/ge
>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>>>> did during foss4g-it. If the error is still happening please let me know as
>>>>> probably in this case the beta release is also affected and you can help us
>>>>> with your feedback.
>>>>> Thanks,
>>>>> Francesco
>>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>>>> Dear list I'm working with Geonode that I installed on a VM set via
>>>>> Vagrant When I try to load the shape file, I get this error: *failed
>>>>> to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the
>>>>> Apache error log is as follows: *ERROR: geonode.layers.views: failed
>>>>> to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to
>>>>> google around I found that in the settings.py file should add the line:
>>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>>>> that the www-data user has all permissions on the www / folder geonode
>>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>>>> that I can't upload. Does anyone know help me?
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/1d56dc51/attachment-0001.html>
More information about the geonode-users mailing list
