[GeoNode-users] Geonode 2.6c1, admin user is not automatically logged into geoserver
Eric Goddard egoddard1010 at gmail.com
Fri Apr 14 12:13:15 PDT 2017
Thanks Alessio, using the geonode button does work now. I missed that
addition and was expecting it to work the same as in 2.4.
I can authenticate with Geoserver now, however when trying to upload a
layer through geonode it throws an error:
(actual url replaced since it isn't ready yet)
Tried to make a GET request to
https://geonode.example.com/geoserver/rest/workspaces/default.xml but
got a 404 status code:
trying to access the rest endpoints directly gives an error message,
both over http and https so I don't think it is from the nginx/lets
encrypt config. However, When I'm in the geoserver admin,
clicking on any of the sidebar links such as Geoserver logs adds an
extra https// in the link: Even though hovering over the link displays
the correct link in the browser status bar, when you click on it I get
https://https//geonode.example.com/geoserver/web/wicket/bookmarkable/org.geoserver.web.admin.StatusPage?8
Thanks again,
Eric
On Fri, Apr 14, 2017 at 4:01 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> It is normal.
> If you are using OAtuh2, the GeoServer Admin GUI won't be automatically
> logged. You need to authenticate through geonode icon or geoserver
> credentials.
> This is different for access to the layers. GeoNode generates an
> authentication token which is used to keep authentication.
> Alternatively you can get this token from session and use it to be
> automatically authetnicated on GeoServer Admin GUI too.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Apr 13, 2017 at 10:35 PM, Eric Goddard <egoddard1010 at gmail.com>
> wrote:
>> Hi all,
>> I'm running Geonode 2.6c1 on Ubuntu 16.04 installed using Ansible
>> (with geoserver-2.9.x-oauth2). My geonode instance is served over
>> https with a LetsEncrypt certificate.
>> After enabling ssl, I've gone through and changed the URLS for geonode
>> and geoserver everywhere that I can think of so that it uses the https
>> endpoint:
>> /var/lib/tomcat8/webapps/geoserver/data/security/role/geonode REST
>> role service/config.xml
>> /var/lib/tomcat8/webapps/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>> /var/lib/tomcat8/webapps/geoserver/data/security/filter/geonode-oauth2/config.xml
>> /var/lib/tomcat8/webapps/geoserver/data/global.xml
>> GEOSERVER_LOCATION in local_settings.py has also been updated to the
>> https endpoint.
>> I also changed the redirect uris in the GeoServer application entry in
>> the geonode admin panel under Django Oauth2 Toolkit > GeoServer to the
>> https endpoint.
>> The geoserver log after attempting to access geoserver from the logged
>> in admin account:
>> 2017-04-13 15:13:14,757 DEBUG
>> [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] -
>> Checking match of request : 'Path: /, QueryString: null'; against
>> '/web/**'
>> '/gwc/rest/web/**'
>> Checking match of request : 'Path: /, QueryString: null'; against '/'
>> 2017-04-13 15:13:14,758 DEBUG
>> Matched Path: /, QueryString: null with /
>> 2017-04-13 15:13:14,758 DEBUG [org.geoserver.security] - Inspecting
>> the http request looking for the GeoNode Session ID.
>> 2017-04-13 15:13:14,758 DEBUG [org.geoserver.security] - Found 9 cookies!
>> 2017-04-13 15:13:14,759 DEBUG [org.geoserver.security] - Found GeoNode
>> cookie: fgalnbhxuf3ynqazgs3bfm0uqqkk71l0
>> 2017-04-13 15:13:14,761 DEBUG [org.geoserver.security] -
>> preAuthenticatedPrincipal = null, trying to authenticate
>> 2017-04-13 15:13:14,768 TRACE [org.geoserver.ows.OWSHandlerMapping] -
>> No handler mapping found for [/]
>> 2017-04-13 15:13:14,769 DEBUG
>> [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1]
>> - SecurityContextHolder now cleared, as request processing completed
>> 2017-04-13 15:13:14,944 DEBUG
>> Checking match of request : 'Path: /web/, QueryString: null'; against
>> '/web/**'
>> Matched Path: /web/, QueryString: null with /web/**
>> 2017-04-13 15:13:14,944 DEBUG [org.geoserver.security] - Inspecting
>> 2017-04-13 15:13:14,944 DEBUG [org.geoserver.security] - Found 9 cookies!
>> 2017-04-13 15:13:14,945 DEBUG [org.geoserver.security] - Found GeoNode
>> 2017-04-13 15:13:14,946 DEBUG [org.geoserver.security] -
>> 2017-04-13 15:13:14,953 TRACE [org.geoserver.ows.OWSHandlerMapping] -
>> No handler mapping found for [/web/]
>> 2017-04-13 15:13:15,021 DEBUG [org.geoserver.filters] - Compressing
>> output for mimetype: text/html;charset=UTF-8
>> 2017-04-13 15:13:15,028 DEBUG
>> I'm not really sure where go from here with troubleshooting, so any
>> help is greatly appreciated. I've tried to include everything that
>> that would be relevant to this issue, but if there is some other
>> information that's needed please let me know.
>> Thanks!
>> Eric
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
