[GeoNode-users] Geosites installation error
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 21 03:41:33 PDT 2017
No don't need to checkout another geonode or delete the settings in etc. I
suggest you to start from here https://github.com/GeoNode/geonode-project and
once you have it set up then you can create your own settings with geosites
enabled and make your own geosites in it.
2017-04-21 12:31 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
> Ok, I have installed geonode 2.6 like quick installation tells, then I
> deleted /etc/geonode to replace it with *git
> clone https://github.com/GeoNode/geonode
> <https://github.com/GeoNode/geonode>*, is it right?
> I have duplicated /geonode/geonode/contrib/geosites/site_template whit a
> new name.
> Now I would like to have:
> - www.example.com/site1
> - www.example.com/site2
> so I go to www.example.com/admin/sites/site/ and add site1 and site2
> Now have I to edit /etc/apache2/sites-enabled/geonode.conf? In which way?
> I did:
> WSGIDaemonProcess new_name_site_template user=www-data threads=15
> processes=2
> <VirtualHost *:80>
>    DocumentRoot /etc/geonode/geonode/contrib/geosites/
>    WSGIProcessGroup fosco_geosites
>    WSGIScriptAlias / /etc/geonode/geonode/contrib/geosites/new_name_site_
> template/wsgi.py
> but doesn't work.
> Where am I wrong?
> Thanks.
> Fosco
> 2017-04-19 17:43 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi,
>> no you don't need a development installation, you can achieve the same
>> using a standard apt geonode installation or a geonode-project.
>> Unfortunately the documentation for geosites is a bit outdated but you
>> can make it work even without any automatic script. I suggest you to take a
>> look at the geonode repo as geosites is now part of it as a contrib app
>> (optional and less maintained) https://github.com
>> /GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites and the geonode
>> homepage and docs for the installation http://www.geonode.org.
>> In order to use geosites you will have to understand the basics of django
>> projects, nothing too tricky though.
>> Recently Eugenio made some interesting comments on the geosites doc that
>> could help you, see here https://github.com/GeoNod
>> e/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c#co
>> mmitcomment-21731038
>> hope this helps
>> 2017-04-19 17:23 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>> Hi, I'm trying to install geosites.
>>> I followed this guide for ubuntu development installation:
>>> https://github.com/simod/geonode#ubuntu
>>> and then this guide for geosites: https://github.com/t
>>> erranodo/geosites-project/blob/master/GEOSITES-README.md
>>> I realized that to have geosites I have to do development installation,
>>> is it true?
>>> When I give *bash ./setup.sh example.org <http://example.org>* I have
>>> this error:
>>> *Command "python setup.py egg_info" failed with error code 1 in
>>> /tmp/pip-build-8XOXyi/Paver**/*
>>> I looked for directory pip-build-8XOXyi but doesn't exist.
>>> Is this command the same of geonode-updateip for standard installation?
>>> Can I give *bash ./setup.sh IP* instead of example.org?
>>> Thanks
>>> Fosco
>>> Fosco
>>> http://studiotypo.it/
>>> http://www.studiotypo.it/fosco/
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Fosco
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170421/373e0534/attachment.html>
More information about the geonode-users mailing list
