[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Mon Apr 24 06:21:52 PDT 2017
If I set <proxyBaseUrl>http://localhost:8001/geoserver
<http://localhost/geoserver></proxyBaseUrl> geoserver *preview works* but
I'm *unable to load layers*
If I set <proxyBaseUrl>http://localhost:8080/geoserver
<http://localhost/geoserver></proxyBaseUrl> geoserver preview don'tworks
but I'm able to load layers
If I set <proxyBaseUrl>http://localhost:80/geoserver
2017-04-24 8:07 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Giuseppe,
> just give a try with
> <proxyBaseUrl>http://localhost:8001/geoserver <http://localhost/geoserver></proxyBaseUrl>
>  instead.
> Let us know
> 2017-04-22 16:08 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Giuseppe,
>> In your last error you were trying to open the wrong port in the browser.
>> The correct has to be 8001.
>> Thanks,
>> Francesco
>> 22 apr 2017, 14:59 +0200, giuseppe musumeci <musumeci.giuseppe at gmail.com>,
>> ha scritto:
>> I checked all steps of your tutorial. I have yet the errors I posted in
>> the last mail.
>> 2017-04-21 12:54 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Giuseppe,
>>> Please review all the updated configurations of the workshop. They are
>>> fully working now. In case try to restart the vagrant vm from scratch.
>>> Thanks,
>>> Francesco
>>> 21 apr 2017, 12:18 +0200, giuseppe musumeci <musumeci.giuseppe at gmail.com>,
>>> ha scritto:
>>> Hi francesco.
>>> I'm having problem with this configuration.
>>> 1.from geoserver if i want a preview I get this error:
>>> Impossibile trovare la pagina localhost
>>> Nessuna pagina web trovata per l'indirizzo web:*http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers
>>> <http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers>*
>>> HTTP ERROR 404
>>> 2. pOSTGRESQL
>>> i'M UNABLE TO CONNECT PGADMIN RUNNING IN WINDOWS TO GEONODE DATABASE
>>> RUNNING IN vm
>>> i'VE SPENT LAST TWO DAYS
>>> 2017-04-21 0:07 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Hi Giuseppe,
>>>> I have to adjust my previous hints. To recap the required
>>>> configurations for geoserver are:
>>>> /usr/share/geoserver/data/security/role/geonode\ REST\ role\ service/config.
>>>> <baseUrl>http://localhost:80/</baseUrl>
>>>> /usr/share/geoserver/data/security/filter/geonode-oauth2/config.xml
>>>> <accessTokenUri>http://localhost/o/token/</accessTokenUri>
>>>> <userAuthorizationUri>http://localhost:8001/o/authorize/</userAuthorizationUri>
>>>> <redirectUri>http://localhost:8001/geoserver</redirectUri>
>>>> <checkTokenEndpointUrl>http://localhost/api/o/v4/tokeninfo/</checkTokenEndpointUrl>
>>>> <logoutUri>http://localhost:8001/account/logout/</logoutUri>
>>>> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>>>> <baseUrl>http://localhost:8001/</baseUrl>
>>>> /usr/share/geoserver/data/global.xml
>>>> <proxyBaseUrl>http://localhost:80/geoserver</proxyBaseUrl>
>>>> I have updated the workshop, also figuring out that this configuration
>>>> is a GeoNode full proxied use case where the internal port 8080 is not
>>>> forwarded to the host machine.
>>>> Thanks for reporting your initial issues.
>>>> Hope this definitively clarifies,
>>>> Francesco
>>>> Il giorno 12/apr/2017, alle ore 21:34, giuseppe musumeci <
>>>> musumeci.giuseppe at gmail.com> ha scritto:
>>>> Leaving <proxyBaseUrl> unaltered. I'm able to load layer but I'm not
>>>> able to preview it in geoserver:
>>>> The port changes from 8001 to 8080 and I have the error
>>>>  "The requested URL /geoserver/geonode/wms was not found on this
>>>> server."
>>>> 2017-04-11 12:28 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> Thanks Simone you are right. I will update the slide, it was my fault.
>>>>>  @Giuseppe you have to leave <proxyBaseUrl> unaltered.
>>>>> Sent from Nylas Pro
>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-070d2acb-91ee/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>> the most powerful email app for work
>>>>> On apr 11 2017, at 7:23 am, Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>> wrote:
>>>>>> Dears, just a not.
>>>>>> In the vagrant installation we made at the workshop, there's no need
>>>>>> to forward geoserver to the host as the apache proxy will take care of
>>>>>> serving under localhost:8001/geoserver.
>>>>>> Best
>>>>>> 2017-04-10 23:35 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> See inline
>>>>>> Il giorno 10/apr/2017, alle ore 21:14, giuseppe musumeci <
>>>>>> I followed your instructions.
>>>>>> There are few differences:
>>>>>> in order the system works I must set
>>>>>> *<proxyBaseUrl>http://localhost:8001/geoserver
>>>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> /</proxyBaseUrl>*
>>>>>> instead of
>>>>>> <http://localhost:8001/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> /</proxyBaseUrl>*
>>>>>> This is not required if the settings are configured fine. During an
>>>>>> installation with apt-get this is done automatically while executing the
>>>>>> command geonode-updateip
>>>>>> I cannot edit vagrant file with *config.vm.network "forwarded_port",
>>>>>> guest: 8080, host:* *8080*
>>>>>> infact I get the error
>>>>>> "Vagrant cannot forward the specified ports on this VM, since they
>>>>>> would collide with some other application that is already listening on
>>>>>> these ports. The forwarded port to 8080 is already in use on the host
>>>>>> machine.”
>>>>>> You have another process which is running on port 8080 in your host
>>>>>> machine. Please shutdown that.
>>>>>> If I try to upload a layer I get this error [Errno 111] Connection
>>>>>> refused
>>>>>> but if I access geoserver on http://localhost:8001/geoserver/web
>>>>>> <http://localhost:8001/geoserver/web&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> Apparently some geoserver configurations in your settings are still
>>>>>> wrong. Are you sure you started a new installation after a vagrant destroy?
>>>>>> I see that layers have been uploaded into geoserver.
>>>>>> Nevethless If I watch into geonode I see that "No content created
>>>>>> yet"
>>>>>> 2017-04-10 16:09 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> If you have run “sudo geonode-updateip localhost:8001” then the next
>>>>>> thing to do is to check again the configuration of geoserver in settings
>>>>>> file and for the security in the data directory.
>>>>>> Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci <
>>>>>> I've already done it in this attempt
>>>>>> Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com> ha
>>>>>> scritto:
>>>>>> Can you please repeat all the commands from scratch? You can do it by
>>>>>> running “vagrant destroy”
>>>>>> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <
>>>>>> I installed again geonode according the tutorial
>>>>>> I run the command geonode-updateip
>>>>>> I have problem to load layers:[Errno 111] Connection refused
>>>>>> Where I'm wrong?
>>>>>> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Yes, absolutely. It looks like you missed this one
>>>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/6
>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/6&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
>>>>>> I followed all the istructions in the tutorial you send me.
>>>>>> Is there a way to correct these errors using a command (i.e sudo
>>>>>> geonode-updateip localhost:8001)?
>>>>>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> How did you perform the installation?
>>>>>> You were originally receive that error because
>>>>>> GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
>>>>>> 'http://localhost:8001/geoserver'
>>>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t'>
>>>>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>>>>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>>>>> GEOSERVER_LOCATION = os.getenv(
>>>>>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/
>>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>>>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/
>>>>>> From /etc/geonode/local_settings.py
>>>>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>>>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Can you double check what you have in the settings for the
>>>>>> geoserver configurations?
>>>>>> Sent from Nylas Pro
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>>>>> musumeci.giuseppe at gmail.com> wrote:
>>>>>> Dear Francesco,
>>>>>> I followed the tutorial
>>>>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> </proxyBaseUrl>
>>>>>> and not <proxyBaseUrl>http://localhost:8001/
>>>>>> </proxyBaseUrl>
>>>>>> In this way geoserver seems to work fine.
>>>>>> The problem is I'm not able to upload layers from geonode menu
>>>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Giuseppe,
>>>>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>>>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>>>>> host. That means
>>>>>> the configuration "config.vm.network
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise
>>>>>> you get the 404 error.
>>>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>>>>> To be able to upload layers I must set
>>>>>> </proxyBaseUrl>
>>>>>> into usr/share/geoserver/data/global.xml
>>>>>> If I open geoserver from the admin panel the address is
>>>>>> http://localhost:8001/geoserver/web/?1
>>>>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> but If i want for example a layer preview
>>>>>> address change to
>>>>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>>>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>>>>> de:fiora_amianto
>>>>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> with error The requested URL /geoserver/geonode/wms was not found on
>>>>>> this server.
>>>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> config.vm.network
>>>>>> is simply redundant. It has been added to access geoserver out of the
>>>>>> scope of oauth2.
>>>>>> What url are you going to call in the browser for geoserver?
>>>>>> Sent from Nylas Pro
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>>>>> I ran the installation of Geonode using the instructions at the link
>>>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> I think there are problems in the instructions about geoserver
>>>>>> configuration:
>>>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>>>> I changed the default settings with those specified:
>>>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>>>> But geoserver don't works: I then set the value to
>>>>>> moreover i Think that to configure vagrantfile as suggested:
>>>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>>>> is not correct.
>>>>>> Could someone tell me the correct settings values for geoserver and
>>>>>> vagrantfile?
>>>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Dear Giuseppe,
>>>>>> as already replied on the italian gfoss list you should check to
>>>>>> follow from scratch the workshop http://geonode.org/ge
>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>>>>> did during foss4g-it. If the error is still happening please let me know as
>>>>>> probably in this case the beta release is also affected and you can help us
>>>>>> with your feedback.
>>>>>> Thanks,
>>>>>> Francesco
>>>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>>>>> Dear list I'm working with Geonode that I installed on a VM set via
>>>>>> Vagrant When I try to load the shape file, I get this error: *failed
>>>>>> to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the
>>>>>> Apache error log is as follows: *ERROR: geonode.layers.views: failed
>>>>>> to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to
>>>>>> google around I found that in the settings.py file should add the line:
>>>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>>>>> that the www-data user has all permissions on the www / folder geonode
>>>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>>>>> that I can't upload. Does anyone know help me?
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/7af35ab3/attachment-0001.html>
More information about the geonode-users mailing list
