[GeoNode-users] Geonode - Error on uploading layer
Simone Dalmasso simone.dalmasso at gmail.com
Mon Apr 24 06:22:40 PDT 2017
what about not setting it at all? :)
2017-04-24 15:21 GMT+02:00 giuseppe musumeci <musumeci.giuseppe at gmail.com>:
> If I set <proxyBaseUrl>http://localhost:8001/geoserver
> <http://localhost/geoserver></proxyBaseUrl> geoserver *preview works* but
> I'm *unable to load layers*
> If I set <proxyBaseUrl>http://localhost:8080/geoserver
> <http://localhost/geoserver></proxyBaseUrl> geoserver preview don'tworks
> but I'm able to load layers
> If I set <proxyBaseUrl>http://localhost:80/geoserver
> 2017-04-24 8:07 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Giuseppe,
>> just give a try with
>> <proxyBaseUrl>http://localhost:8001/geoserver <http://localhost/geoserver></proxyBaseUrl>
>>  instead.
>> Let us know
>> 2017-04-22 16:08 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Giuseppe,
>>> In your last error you were trying to open the wrong port in the
>>> browser. The correct has to be 8001.
>>> Thanks,
>>> Francesco
>>> 22 apr 2017, 14:59 +0200, giuseppe musumeci <musumeci.giuseppe at gmail.com>,
>>> ha scritto:
>>> I checked all steps of your tutorial. I have yet the errors I posted in
>>> the last mail.
>>> 2017-04-21 12:54 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Giuseppe,
>>>> Please review all the updated configurations of the workshop. They are
>>>> fully working now. In case try to restart the vagrant vm from scratch.
>>>> Thanks,
>>>> Francesco
>>>> 21 apr 2017, 12:18 +0200, giuseppe musumeci <
>>>> musumeci.giuseppe at gmail.com>, ha scritto:
>>>> Hi francesco.
>>>> I'm having problem with this configuration.
>>>> 1.from geoserver if i want a preview I get this error:
>>>> Impossibile trovare la pagina localhost
>>>> Nessuna pagina web trovata per l'indirizzo web:*http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers
>>>> <http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers>*
>>>> HTTP ERROR 404
>>>> 2. pOSTGRESQL
>>>> i'M UNABLE TO CONNECT PGADMIN RUNNING IN WINDOWS TO GEONODE DATABASE
>>>> RUNNING IN vm
>>>> i'VE SPENT LAST TWO DAYS
>>>> 2017-04-21 0:07 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> Hi Giuseppe,
>>>>> I have to adjust my previous hints. To recap the required
>>>>> configurations for geoserver are:
>>>>> /usr/share/geoserver/data/security/role/geonode\ REST\ role\ service/config.
>>>>> <baseUrl>http://localhost:80/</baseUrl>
>>>>> /usr/share/geoserver/data/security/filter/geonode-oauth2/config.xml
>>>>> <accessTokenUri>http://localhost/o/token/</accessTokenUri>
>>>>> <userAuthorizationUri>http://localhost:8001/o/authorize/</userAuthorizationUri>
>>>>> <redirectUri>http://localhost:8001/geoserver</redirectUri>
>>>>> <checkTokenEndpointUrl>http://localhost/api/o/v4/tokeninfo/</checkTokenEndpointUrl>
>>>>> <logoutUri>http://localhost:8001/account/logout/</logoutUri>
>>>>> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>>>>> <baseUrl>http://localhost:8001/</baseUrl>
>>>>> /usr/share/geoserver/data/global.xml
>>>>> <proxyBaseUrl>http://localhost:80/geoserver</proxyBaseUrl>
>>>>> I have updated the workshop, also figuring out that this configuration
>>>>> is a GeoNode full proxied use case where the internal port 8080 is not
>>>>> forwarded to the host machine.
>>>>> Thanks for reporting your initial issues.
>>>>> Hope this definitively clarifies,
>>>>> Francesco
>>>>> Il giorno 12/apr/2017, alle ore 21:34, giuseppe musumeci <
>>>>> musumeci.giuseppe at gmail.com> ha scritto:
>>>>> Leaving <proxyBaseUrl> unaltered. I'm able to load layer but I'm not
>>>>> able to preview it in geoserver:
>>>>> The port changes from 8001 to 8080 and I have the error
>>>>>  "The requested URL /geoserver/geonode/wms was not found on this
>>>>> server."
>>>>> 2017-04-11 12:28 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Thanks Simone you are right. I will update the slide, it was my
>>>>>> fault.
>>>>>>  @Giuseppe you have to leave <proxyBaseUrl> unaltered.
>>>>>> Sent from Nylas Pro
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-070d2acb-91ee/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>> the most powerful email app for work
>>>>>> On apr 11 2017, at 7:23 am, Simone Dalmasso <
>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>> Dears, just a not.
>>>>>>> In the vagrant installation we made at the workshop, there's no need
>>>>>>> to forward geoserver to the host as the apache proxy will take care of
>>>>>>> serving under localhost:8001/geoserver.
>>>>>>> Best
>>>>>>> 2017-04-10 23:35 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> See inline
>>>>>>> Il giorno 10/apr/2017, alle ore 21:14, giuseppe musumeci <
>>>>>>> I followed your instructions.
>>>>>>> There are few differences:
>>>>>>> in order the system works I must set
>>>>>>> *<proxyBaseUrl>http://localhost:8001/geoserver
>>>>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> /</proxyBaseUrl>*
>>>>>>> instead of
>>>>>>> <http://localhost:8001/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> /</proxyBaseUrl>*
>>>>>>> This is not required if the settings are configured fine. During an
>>>>>>> installation with apt-get this is done automatically while executing the
>>>>>>> command geonode-updateip
>>>>>>> I cannot edit vagrant file with *config.vm.network
>>>>>>> "forwarded_port", guest: 8080, host:* *8080*
>>>>>>> infact I get the error
>>>>>>> "Vagrant cannot forward the specified ports on this VM, since they
>>>>>>> would collide with some other application that is already listening on
>>>>>>> these ports. The forwarded port to 8080 is already in use on the host
>>>>>>> machine.”
>>>>>>> You have another process which is running on port 8080 in your host
>>>>>>> machine. Please shutdown that.
>>>>>>> If I try to upload a layer I get this error [Errno 111] Connection
>>>>>>> refused
>>>>>>> but if I access geoserver on http://localhost:8001/geoserver/web
>>>>>>> <http://localhost:8001/geoserver/web&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> Apparently some geoserver configurations in your settings are still
>>>>>>> wrong. Are you sure you started a new installation after a vagrant destroy?
>>>>>>> I see that layers have been uploaded into geoserver.
>>>>>>> Nevethless If I watch into geonode I see that "No content created
>>>>>>> yet"
>>>>>>> 2017-04-10 16:09 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> If you have run “sudo geonode-updateip localhost:8001” then the next
>>>>>>> thing to do is to check again the configuration of geoserver in settings
>>>>>>> file and for the security in the data directory.
>>>>>>> Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci <
>>>>>>> I've already done it in this attempt
>>>>>>> Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com> ha
>>>>>>> scritto:
>>>>>>> Can you please repeat all the commands from scratch? You can do it
>>>>>>> by running “vagrant destroy”
>>>>>>> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <
>>>>>>> I installed again geonode according the tutorial
>>>>>>> I run the command geonode-updateip
>>>>>>> I have problem to load layers:[Errno 111] Connection refused
>>>>>>> Where I'm wrong?
>>>>>>> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> Yes, absolutely. It looks like you missed this one
>>>>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/6
>>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/6&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
>>>>>>> I followed all the istructions in the tutorial you send me.
>>>>>>> Is there a way to correct these errors using a command (i.e sudo
>>>>>>> geonode-updateip localhost:8001)?
>>>>>>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> How did you perform the installation?
>>>>>>> You were originally receive that error because
>>>>>>> GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
>>>>>>> 'http://localhost:8001/geoserver'
>>>>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t'>
>>>>>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>>>>>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>>>>>> GEOSERVER_LOCATION = os.getenv(
>>>>>>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/
>>>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>>>>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/
>>>>>>> From /etc/geonode/local_settings.py
>>>>>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>>>>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> Can you double check what you have in the settings for the
>>>>>>> geoserver configurations?
>>>>>>> Sent from Nylas Pro
>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>>>>>> musumeci.giuseppe at gmail.com> wrote:
>>>>>>> Dear Francesco,
>>>>>>> I followed the tutorial
>>>>>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> </proxyBaseUrl>
>>>>>>> and not <proxyBaseUrl>http://localhost:8001/
>>>>>>> </proxyBaseUrl>
>>>>>>> In this way geoserver seems to work fine.
>>>>>>> The problem is I'm not able to upload layers from geonode menu
>>>>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> Giuseppe,
>>>>>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>>>>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>>>>>> host. That means
>>>>>>> the configuration "config.vm.network
>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise
>>>>>>> you get the 404 error.
>>>>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>>>>>> To be able to upload layers I must set
>>>>>>> </proxyBaseUrl>
>>>>>>> into usr/share/geoserver/data/global.xml
>>>>>>> If I open geoserver from the admin panel the address is
>>>>>>> http://localhost:8001/geoserver/web/?1
>>>>>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> but If i want for example a layer preview
>>>>>>> address change to
>>>>>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>>>>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>>>>>> de:fiora_amianto
>>>>>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> with error The requested URL /geoserver/geonode/wms was not found
>>>>>>> on this server.
>>>>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> config.vm.network
>>>>>>> is simply redundant. It has been added to access geoserver out of
>>>>>>> the scope of oauth2.
>>>>>>> What url are you going to call in the browser for geoserver?
>>>>>>> Sent from Nylas Pro
>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>>>>>> I ran the installation of Geonode using the instructions at the link
>>>>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> I think there are problems in the instructions about geoserver
>>>>>>> configuration:
>>>>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>>>>> I changed the default settings with those specified:
>>>>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>>>>> But geoserver don't works: I then set the value to
>>>>>>> moreover i Think that to configure vagrantfile as suggested:
>>>>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>>>>> is not correct.
>>>>>>> Could someone tell me the correct settings values for geoserver and
>>>>>>> vagrantfile?
>>>>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> Dear Giuseppe,
>>>>>>> as already replied on the italian gfoss list you should check to
>>>>>>> follow from scratch the workshop http://geonode.org/ge
>>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>>>>>> did during foss4g-it. If the error is still happening please let me know as
>>>>>>> probably in this case the beta release is also affected and you can help us
>>>>>>> with your feedback.
>>>>>>> Thanks,
>>>>>>> Francesco
>>>>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>>>>>> Dear list I'm working with Geonode that I installed on a VM set via
>>>>>>> Vagrant When I try to load the shape file, I get this error: *failed
>>>>>>> to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the
>>>>>>> Apache error log is as follows: *ERROR: geonode.layers.views:
>>>>>>> failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying
>>>>>>> to google around I found that in the settings.py file should add the line:
>>>>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>>>>>> that the www-data user has all permissions on the www / folder geonode
>>>>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>>>>>> that I can't upload. Does anyone know help me?
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/52e2f0b2/attachment-0001.html>
More information about the geonode-users mailing list
