[GeoNode-users] Geosites installation error
Fosco Ventura foscone at gmail.com
Mon Apr 24 07:52:46 PDT 2017
Hi Simone,
I am trying to use geonode-project as base template. For single site it
works fine but I do not understand how to set it as a multisite. In
geonode-project template there are not all files mentioned in the geosites
guides.
For example in this Eugenio's comment
https://github.com/GeoNode/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c#commitcomment-21731291
I need site_template in contrib directory but in geonode-project template
there isn't.
How can I do?
Thanks.
Fosco
2017-04-21 12:41 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> No don't need to checkout another geonode or delete the settings in etc. I
> suggest you to start from here https://github.com/GeoNode/geonode-project and
> once you have it set up then you can create your own settings with geosites
> enabled and make your own geosites in it.
> 2017-04-21 12:31 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>> Ok, I have installed geonode 2.6 like quick installation tells, then I
>> deleted /etc/geonode to replace it with *git
>> clone https://github.com/GeoNode/geonode
>> <https://github.com/GeoNode/geonode>*, is it right?
>> I have duplicated /geonode/geonode/contrib/geosites/site_template whit a
>> new name.
>> Now I would like to have:
>> - www.example.com/site1
>> - www.example.com/site2
>> so I go to www.example.com/admin/sites/site/ and add site1 and site2
>> Now have I to edit /etc/apache2/sites-enabled/geonode.conf? In which way?
>> I did:
>> WSGIDaemonProcess new_name_site_template user=www-data threads=15
>> processes=2
>> <VirtualHost *:80>
>>    DocumentRoot /etc/geonode/geonode/contrib/geosites/
>>    WSGIProcessGroup fosco_geosites
>>    WSGIScriptAlias / /etc/geonode/geonode/contrib/g
>> eosites/new_name_site_template/wsgi.py
>> but doesn't work.
>> Where am I wrong?
>> Thanks.
>> Fosco
>> 2017-04-19 17:43 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi,
>>> no you don't need a development installation, you can achieve the same
>>> using a standard apt geonode installation or a geonode-project.
>>> Unfortunately the documentation for geosites is a bit outdated but you
>>> can make it work even without any automatic script. I suggest you to take a
>>> look at the geonode repo as geosites is now part of it as a contrib app
>>> (optional and less maintained) https://github.com
>>> /GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites and the geonode
>>> homepage and docs for the installation http://www.geonode.org.
>>> In order to use geosites you will have to understand the basics of
>>> django projects, nothing too tricky though.
>>> Recently Eugenio made some interesting comments on the geosites doc that
>>> could help you, see here https://github.com/GeoNod
>>> mmitcomment-21731038
>>> hope this helps
>>> 2017-04-19 17:23 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>> Hi, I'm trying to install geosites.
>>>> I followed this guide for ubuntu development installation:
>>>> https://github.com/simod/geonode#ubuntu
>>>> and then this guide for geosites: https://github.com/t
>>>> erranodo/geosites-project/blob/master/GEOSITES-README.md
>>>> I realized that to have geosites I have to do development installation,
>>>> is it true?
>>>> When I give *bash ./setup.sh example.org <http://example.org>* I have
>>>> this error:
>>>> *Command "python setup.py egg_info" failed with error code 1 in
>>>> /tmp/pip-build-8XOXyi/Paver**/*
>>>> I looked for directory pip-build-8XOXyi but doesn't exist.
>>>> Is this command the same of geonode-updateip for standard installation?
>>>> Can I give *bash ./setup.sh IP* instead of example.org?
>>>> Thanks
>>>> Fosco
>>>> Fosco
>>>> http://studiotypo.it/
>>>> http://www.studiotypo.it/fosco/
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>> Fosco
> Simone
Fosco
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/3e457be6/attachment.html>
More information about the geonode-users mailing list
