[GeoNode-users] Geosites installation error
Simone Dalmasso simone.dalmasso at gmail.com
Mon Apr 24 09:07:15 PDT 2017
geonode-project is just a template, all you may need you can copy into it.
In this case just copy the site-template either from githiub or your
geonode installation (you can search for it and copy) and rename
accordingly.
2017-04-24 16:52 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
> Hi Simone,
> I am trying to use geonode-project as base template. For single site it
> works fine but I do not understand how to set it as a multisite. In
> geonode-project template there are not all files mentioned in the geosites
> guides.
> For example in this Eugenio's comment https://github.com/
> GeoNode/geonode/commit/740af85ab5654cee3d27b6611b74c3
> 9687a4187c#commitcomment-21731291 I need site_template in contrib
> directory but in geonode-project template there isn't.
> How can I do?
> Thanks.
> Fosco
> 2017-04-21 12:41 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> No don't need to checkout another geonode or delete the settings in etc.
>> I suggest you to start from here https://github.com/GeoNod
>> e/geonode-project and once you have it set up then you can create your
>> own settings with geosites enabled and make your own geosites in it.
>> 2017-04-21 12:31 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>> Ok, I have installed geonode 2.6 like quick installation tells, then I
>>> deleted /etc/geonode to replace it with *git
>>> clone https://github.com/GeoNode/geonode
>>> <https://github.com/GeoNode/geonode>*, is it right?
>>> I have duplicated /geonode/geonode/contrib/geosites/site_template whit
>>> a new name.
>>> Now I would like to have:
>>> - www.example.com/site1
>>> - www.example.com/site2
>>> so I go to www.example.com/admin/sites/site/ and add site1 and site2
>>> Now have I to edit /etc/apache2/sites-enabled/geonode.conf? In which
>>> way?
>>> I did:
>>> WSGIDaemonProcess new_name_site_template user=www-data threads=15
>>> processes=2
>>> <VirtualHost *:80>
>>>    DocumentRoot /etc/geonode/geonode/contrib/geosites/
>>>    WSGIProcessGroup fosco_geosites
>>>    WSGIScriptAlias / /etc/geonode/geonode/contrib/g
>>> eosites/new_name_site_template/wsgi.py
>>> but doesn't work.
>>> Where am I wrong?
>>> Thanks.
>>> Fosco
>>> 2017-04-19 17:43 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Hi,
>>>> no you don't need a development installation, you can achieve the same
>>>> using a standard apt geonode installation or a geonode-project.
>>>> Unfortunately the documentation for geosites is a bit outdated but you
>>>> can make it work even without any automatic script. I suggest you to take a
>>>> look at the geonode repo as geosites is now part of it as a contrib app
>>>> (optional and less maintained) https://github.com
>>>> /GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites and the geonode
>>>> homepage and docs for the installation http://www.geonode.org.
>>>> In order to use geosites you will have to understand the basics of
>>>> django projects, nothing too tricky though.
>>>> Recently Eugenio made some interesting comments on the geosites doc
>>>> that could help you, see here https://github.com/GeoNod
>>>> e/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c#co
>>>> mmitcomment-21731038
>>>> hope this helps
>>>> 2017-04-19 17:23 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>>> Hi, I'm trying to install geosites.
>>>>> I followed this guide for ubuntu development installation:
>>>>> https://github.com/simod/geonode#ubuntu
>>>>> and then this guide for geosites: https://github.com/t
>>>>> erranodo/geosites-project/blob/master/GEOSITES-README.md
>>>>> I realized that to have geosites I have to do development
>>>>> installation, is it true?
>>>>> When I give *bash ./setup.sh example.org <http://example.org>* I have
>>>>> this error:
>>>>> *Command "python setup.py egg_info" failed with error code 1 in
>>>>> /tmp/pip-build-8XOXyi/Paver**/*
>>>>> I looked for directory pip-build-8XOXyi but doesn't exist.
>>>>> Is this command the same of geonode-updateip for standard
>>>>> installation? Can I give *bash ./setup.sh IP* instead of example.org?
>>>>> Thanks
>>>>> Fosco
>>>>> Fosco
>>>>> http://studiotypo.it/
>>>>> http://www.studiotypo.it/fosco/
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>>> Fosco
>> Simone
> Fosco
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/f7283672/attachment-0001.html>
More information about the geonode-users mailing list
