[GeoNode-users] Geosites installation error
Fosco Ventura foscone at gmail.com
Mon Apr 24 10:28:21 PDT 2017
And I have to copy site-template in dir/dir/contrib/geosites or only in
dir/dir like in this guide https://github.com/terranodo/landscapeportal ?
2017-04-24 18:07 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi,
> geonode-project is just a template, all you may need you can copy into it.
> In this case just copy the site-template either from githiub or your
> geonode installation (you can search for it and copy) and rename
> accordingly.
> 2017-04-24 16:52 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>> Hi Simone,
>> I am trying to use geonode-project as base template. For single site it
>> works fine but I do not understand how to set it as a multisite. In
>> geonode-project template there are not all files mentioned in the geosites
>> guides.
>> For example in this Eugenio's comment https://github.com/Geo
>> Node/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c
>> #commitcomment-21731291 I need site_template in contrib directory but in
>> geonode-project template there isn't.
>> How can I do?
>> Thanks.
>> Fosco
>> 2017-04-21 12:41 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> No don't need to checkout another geonode or delete the settings in etc.
>>> I suggest you to start from here https://github.com/GeoNod
>>> e/geonode-project and once you have it set up then you can create your
>>> own settings with geosites enabled and make your own geosites in it.
>>> 2017-04-21 12:31 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>> Ok, I have installed geonode 2.6 like quick installation tells, then I
>>>> deleted /etc/geonode to replace it with *git
>>>> clone https://github.com/GeoNode/geonode
>>>> <https://github.com/GeoNode/geonode>*, is it right?
>>>> I have duplicated /geonode/geonode/contrib/geosites/site_template whit
>>>> a new name.
>>>> Now I would like to have:
>>>> - www.example.com/site1
>>>> - www.example.com/site2
>>>> so I go to www.example.com/admin/sites/site/ and add site1 and site2
>>>> Now have I to edit /etc/apache2/sites-enabled/geonode.conf? In which
>>>> way?
>>>> I did:
>>>> WSGIDaemonProcess new_name_site_template user=www-data threads=15
>>>> processes=2
>>>> <VirtualHost *:80>
>>>>    DocumentRoot /etc/geonode/geonode/contrib/geosites/
>>>>    WSGIProcessGroup fosco_geosites
>>>>    WSGIScriptAlias / /etc/geonode/geonode/contrib/g
>>>> eosites/new_name_site_template/wsgi.py
>>>> but doesn't work.
>>>> Where am I wrong?
>>>> Thanks.
>>>> Fosco
>>>> 2017-04-19 17:43 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> Hi,
>>>>> no you don't need a development installation, you can achieve the same
>>>>> using a standard apt geonode installation or a geonode-project.
>>>>> Unfortunately the documentation for geosites is a bit outdated but you
>>>>> can make it work even without any automatic script. I suggest you to take a
>>>>> look at the geonode repo as geosites is now part of it as a contrib app
>>>>> (optional and less maintained) https://github.com
>>>>> /GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites and the geonode
>>>>> homepage and docs for the installation http://www.geonode.org.
>>>>> In order to use geosites you will have to understand the basics of
>>>>> django projects, nothing too tricky though.
>>>>> Recently Eugenio made some interesting comments on the geosites doc
>>>>> that could help you, see here https://github.com/GeoNod
>>>>> e/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c#co
>>>>> mmitcomment-21731038
>>>>> hope this helps
>>>>> 2017-04-19 17:23 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>>>> Hi, I'm trying to install geosites.
>>>>>> I followed this guide for ubuntu development installation:
>>>>>> https://github.com/simod/geonode#ubuntu
>>>>>> and then this guide for geosites: https://github.com/t
>>>>>> erranodo/geosites-project/blob/master/GEOSITES-README.md
>>>>>> I realized that to have geosites I have to do development
>>>>>> installation, is it true?
>>>>>> When I give *bash ./setup.sh example.org <http://example.org>* I
>>>>>> have this error:
>>>>>> *Command "python setup.py egg_info" failed with error code 1 in
>>>>>> /tmp/pip-build-8XOXyi/Paver**/*
>>>>>> I looked for directory pip-build-8XOXyi but doesn't exist.
>>>>>> Is this command the same of geonode-updateip for standard
>>>>>> installation? Can I give *bash ./setup.sh IP* instead of example.org?
>>>>>> Thanks
>>>>>> Fosco
>>>>>> Fosco
>>>>>> http://studiotypo.it/
>>>>>> http://www.studiotypo.it/fosco/
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Simone
>>>> Fosco
>>> Simone
>> Fosco
> Simone
Fosco
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/f8ce8743/attachment.html>
More information about the geonode-users mailing list
