[GeoNode-users] error message geoserver
trocellier estelle trocellier.estelle at gmail.com
Wed Aug 2 02:21:55 PDT 2017
Dear all,
I'm trying to understand the message in the file geoserver.log , but some
help can be useful.
My problem is i can"t see my layers inside geonode when i'm connected
outside of my server (windows server).
It seems i should change something in the parameters of geoserver to
connect to the new url (outside of my server) but i don't know where and
what exactly.
Thank you very much.
You can find the file of geoserver in attachment.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170802/0ecd245a/attachment-0001.html>
2017-08-01 14:59:46,262 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5244191.6358594,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security] - Found GeoNode cookie: 6dmvo8x87xzfte8ezgoqy3ys2paw8p8g
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 14:59:46,278 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 14:59:46,293 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,309 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,325 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 14:59:46,356 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,372 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,387 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 14:59:46,418 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 14:59:46,418 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,418 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,418 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 14:59:46,418 DEBUG [org.geoserver.geofence] - Getting access limits for Layer PN_V2
2017-08-01 14:59:46,418 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PN_V2
2017-08-01 14:59:46,418 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:PN_V2
2017-08-01 14:59:46,418 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PN_V2]
2017-08-01 14:59:46,418 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,418 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,418 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,418 DEBUG [org.geoserver.ows] - establishing PN_V2 style for Gapeau:PN_V2
2017-08-01 14:59:46,418 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,418 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fa4.xml
2017-08-01 14:59:46,434 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 14:59:46,481 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,481 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,481 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,481 DEBUG [org.geoserver.geofence] - Getting access limits for Layer ZPS_N2000
2017-08-01 14:59:46,481 DEBUG [org.geoserver.geofence] - Getting access limits for Resource ZPS_N2000
2017-08-01 14:59:46,481 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:ZPS_N2000
2017-08-01 14:59:46,481 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[ZPS_N2000]
2017-08-01 14:59:46,481 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,481 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,481 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,481 DEBUG [org.geoserver.ows] - establishing ZPS_N2000 style for Gapeau:ZPS_N2000
2017-08-01 14:59:46,481 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,481 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
org.geoserver.ows.HttpErrorCodeException
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:119)
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy142.getMap(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor212.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:850)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 14:59:46,497 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:46,497 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,497 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,497 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,497 DEBUG [org.geoserver.geofence] - Getting access limits for Layer PN_V2
2017-08-01 14:59:46,497 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PN_V2
2017-08-01 14:59:46,497 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:PN_V2
2017-08-01 14:59:46,497 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PN_V2]
2017-08-01 14:59:46,497 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,497 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,497 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,497 DEBUG [org.geoserver.ows] - establishing PN_V2 style for Gapeau:PN_V2
2017-08-01 14:59:46,497 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,543 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,559 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,559 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,559 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,559 DEBUG [org.geoserver.geofence] - Getting access limits for Layer ZPS_N2000
2017-08-01 14:59:46,559 DEBUG [org.geoserver.geofence] - Getting access limits for Resource ZPS_N2000
2017-08-01 14:59:46,559 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:ZPS_N2000
2017-08-01 14:59:46,559 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[ZPS_N2000]
2017-08-01 14:59:46,559 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,559 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,559 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,559 DEBUG [org.geoserver.ows] - establishing ZPS_N2000 style for Gapeau:ZPS_N2000
2017-08-01 14:59:46,559 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,559 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 14:59:46,559 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:46,559 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,575 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,637 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 14:59:46,637 DEBUG [org.geoserver.ows] -
2017-08-01 14:59:46,637 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:46,637 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,637 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,637 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,637 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 14:59:46,637 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 14:59:46,637 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 14:59:46,637 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 14:59:46,637 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,637 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,637 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,637 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 14:59:46,637 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,637 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f2d.xml
2017-08-01 14:59:46,653 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:46,684 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,684 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,684 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,700 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 14:59:46,700 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 14:59:46,700 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 14:59:46,700 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 14:59:46,700 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,700 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,700 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,700 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 14:59:46,700 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,700 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,700 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,700 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,715 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,715 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,715 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,715 DEBUG [org.geoserver.geofence] - Getting access limits for Layer PN_V2
2017-08-01 14:59:46,715 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PN_V2
2017-08-01 14:59:46,715 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:PN_V2
2017-08-01 14:59:46,715 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PN_V2]
2017-08-01 14:59:46,715 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,715 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,715 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,715 DEBUG [org.geoserver.ows] - establishing PN_V2 style for Gapeau:PN_V2
2017-08-01 14:59:46,715 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,715 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 14:59:46,715 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:46,731 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,731 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,731 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,731 DEBUG [org.geoserver.geofence] - Getting access limits for Layer PN_V2
2017-08-01 14:59:46,731 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PN_V2
2017-08-01 14:59:46,731 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:PN_V2
2017-08-01 14:59:46,731 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PN_V2]
2017-08-01 14:59:46,731 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,731 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,731 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,731 DEBUG [org.geoserver.ows] - establishing PN_V2 style for Gapeau:PN_V2
2017-08-01 14:59:46,731 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,747 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 14:59:46,747 DEBUG [org.geoserver.ows] -
2017-08-01 14:59:46,747 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:46,747 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 14:59:46,747 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:46,747 INFO [org.geoserver.wms] -
2017-08-01 14:59:46,747 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 14:59:46,747 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 14:59:46,747 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 14:59:46,747 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 14:59:46,747 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:46,747 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:46,747 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 14:59:46,747 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 14:59:46,747 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:46,856 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 14:59:46,856 DEBUG [org.geoserver.ows] -
2017-08-01 14:59:46,856 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/web/**'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/gwc/rest/web/**'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_security_check'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_security_check/'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_oauth2_geonode_login'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_security_logout'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_security_logout/'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/rest/**'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/gwc/rest/**'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique'; against '/**'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 14:59:47,622 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3Areservoir_biologique with /**
2017-08-01 14:59:47,669 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 14:59:47,669 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 14:59:47,669 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 14:59:47,669 DEBUG [org.geoserver.security] - Found GeoNode cookie: 6dmvo8x87xzfte8ezgoqy3ys2paw8p8g
2017-08-01 14:59:47,700 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 14:59:47,747 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:47,794 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wfs]
2017-08-01 14:59:47,794 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wfs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:47,794 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:47,794 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:47,794 INFO [org.geoserver.wfs] -
2017-08-01 14:59:47,794 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:47,794 DEBUG [org.geoserver.geofence] - Getting access limits for Resource reservoir_biologique
2017-08-01 14:59:47,794 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:reservoir_biologique
2017-08-01 14:59:47,794 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[reservoir_biologique]
Request: describeFeatureType
    service = WFS
    version = 1.1.0
    baseUrl = http://localhost:8080/geoserver/
    typeName[0] = {http://www.gapeau.org/}reservoir_biologique
    outputFormat = text/xml; subtype=gml/3.1.1
2017-08-01 14:59:47,794 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/web/**'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/gwc/rest/web/**'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_check'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_check/'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_login'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_logout'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_logout/'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/rest/**'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/gwc/rest/**'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/**'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 14:59:48,871 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr& with /**
2017-08-01 14:59:48,918 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 14:59:48,918 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 14:59:48,918 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 14:59:48,918 DEBUG [org.geoserver.security] - Found GeoNode cookie: 6dmvo8x87xzfte8ezgoqy3ys2paw8p8g
2017-08-01 14:59:48,949 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 14:59:48,996 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:49,043 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wfs]
2017-08-01 14:59:49,043 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wfs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:49,043 DEBUG [org.vfny.geoserver.requests] - First 4 bytes of XML doc are : 3C ('<') 77 ('w') 66 ('f') 73 ('s')
2017-08-01 14:59:49,043 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 1. Inferred encoding: UTF-8
2017-08-01 14:59:49,043 DEBUG [org.vfny.geoserver.requests] - Invalid(?) XML declaration: <wfs:G.
2017-08-01 14:59:49,043 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 2. Charset in XML declaration is `null`.
2017-08-01 14:59:49,043 DEBUG [org.vfny.geoserver.requests] - Trying to create reader basing on existing charset information: `UTF-8`.
2017-08-01 14:59:49,043 DEBUG [org.geoserver.ows] - Raw XML request: <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" version="1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd" service="WFS" resultType="hits"><wfs:Query typeName="feature:reservoir_biologique" srsName="EPSG:900913" /></wfs:GetFeature>
2017-08-01 14:59:49,043 INFO [org.geoserver.wfs] -
2017-08-01 14:59:49,058 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:49,058 DEBUG [org.geoserver.geofence] - Getting access limits for Resource reservoir_biologique
2017-08-01 14:59:49,058 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:reservoir_biologique
2017-08-01 14:59:49,058 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[reservoir_biologique]
2017-08-01 14:59:49,058 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:49,058 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:49,058 DEBUG [org.vfny.geoserver.requests] - Query is org.geoserver.wfs.request.Query$WFS11 at 439309
 To gt2: Query:
   feature type: reservoir_biologique
   filter: Filter.INCLUDE
   [properties:  ALL ]
2017-08-01 14:59:49,058 INFO [org.geoserver.wfs] -
Request: getFeature
    service = WFS
    version = 1.1.0
    query[0]:
        srsName = EPSG:900913
        typeName[0] = reservoir_biologique
    resultType = hits
2017-08-01 14:59:49,074 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/web/**'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/gwc/rest/web/**'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_check'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_check/'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_login'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_logout'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_security_logout/'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/rest/**'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/gwc/rest/**'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr&'; against '/**'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 14:59:50,136 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wfs, QueryString: access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr& with /**
2017-08-01 14:59:50,198 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 14:59:50,198 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 14:59:50,198 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 14:59:50,198 DEBUG [org.geoserver.security] - Found GeoNode cookie: 6dmvo8x87xzfte8ezgoqy3ys2paw8p8g
2017-08-01 14:59:50,230 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 14:59:50,277 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 14:59:50,324 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wfs]
2017-08-01 14:59:50,324 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wfs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 14:59:50,324 DEBUG [org.vfny.geoserver.requests] - First 4 bytes of XML doc are : 3C ('<') 77 ('w') 66 ('f') 73 ('s')
2017-08-01 14:59:50,324 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 1. Inferred encoding: UTF-8
2017-08-01 14:59:50,324 DEBUG [org.vfny.geoserver.requests] - Invalid(?) XML declaration: <wfs:G.
2017-08-01 14:59:50,324 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 2. Charset in XML declaration is `null`.
2017-08-01 14:59:50,324 DEBUG [org.vfny.geoserver.requests] - Trying to create reader basing on existing charset information: `UTF-8`.
2017-08-01 14:59:50,324 DEBUG [org.geoserver.ows] - Raw XML request: <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" version="1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd" service="WFS" maxFeatures="50"><wfs:Query typeName="feature:reservoir_biologique" srsName="EPSG:900913" /></wfs:GetFeature>
2017-08-01 14:59:50,324 INFO [org.geoserver.wfs] -
2017-08-01 14:59:50,324 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 14:59:50,324 DEBUG [org.geoserver.geofence] - Getting access limits for Resource reservoir_biologique
2017-08-01 14:59:50,324 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:reservoir_biologique
2017-08-01 14:59:50,324 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[reservoir_biologique]
2017-08-01 14:59:50,324 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:50,324 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:50,324 DEBUG [org.vfny.geoserver.requests] - Query is org.geoserver.wfs.request.Query$WFS11 at 64f575
 To gt2: Query:
   [properties:  ALL ]
2017-08-01 14:59:50,339 INFO [org.geoserver.wfs] -
Request: getFeature
    service = WFS
    version = 1.1.0
    query[0]:
    maxFeatures = 50
    resultType = results
2017-08-01 14:59:50,339 DEBUG [org.geoserver.geofence] - Getting access limits for Resource reservoir_biologique
2017-08-01 14:59:50,339 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:reservoir_biologique
2017-08-01 14:59:50,339 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[reservoir_biologique]
2017-08-01 14:59:50,339 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 14:59:50,339 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 14:59:50,339 DEBUG [org.geoserver.wfs] - Unable to find user-defined schema location for: . Using a built schema location by default: http://localhost:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=Gapeau%3Areservoir_biologique&access_token=vNeZAcTI37m1HMDpRrfHVRTZRKlpXr
2017-08-01 14:59:50,402 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:00:19,528 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task running
2017-08-01 15:00:19,528 DEBUG [org.geoserver.security] - Cache entries #: 1
2017-08-01 15:00:19,528 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task completed
2017-08-01 15:00:19,528 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 15:00:28,708 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2fee3c1] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at fdfa8ead]]
2017-08-01 15:01:28,729 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 723d54a] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 21f8036]]
2017-08-01 15:02:28,757 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at b3e92b6] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 63a3da2]]
2017-08-01 15:03:28,779 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f5086f0] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at a4c31dc]]
2017-08-01 15:04:28,795 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 136a5b60] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at e66064c]]
2017-08-01 15:05:28,809 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 178e3b9a] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1289e686]]
2017-08-01 15:06:28,816 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1ba5fadd] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 16a1a5c9]]
2017-08-01 15:07:28,833 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1fc0e992] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1abc947e]]
2017-08-01 15:08:28,851 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 23d1d0f8] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1ecd7be4]]
2017-08-01 15:09:28,862 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 27edf94f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 22e9a43b]]
2017-08-01 15:10:19,615 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task running
2017-08-01 15:10:19,615 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 15:10:19,615 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task completed
2017-08-01 15:10:28,867 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2c1213c8] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 270dbeb4]]
2017-08-01 15:11:28,877 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 302bf12e] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2b279c1a]]
2017-08-01 15:12:28,889 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 34439a0a] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2f3f44f6]]
2017-08-01 15:13:28,895 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 3854b734] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 33506220]]
2017-08-01 15:14:28,903 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 3c6fce3c] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 376b7928]]
2017-08-01 15:15:28,909 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 4094f10e] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 3b909bfa]]
2017-08-01 15:16:28,914 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 44af08b3] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 3faab39f]]
2017-08-01 15:17:28,916 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 48c6cc71] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 43c2775d]]
2017-08-01 15:18:28,929 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 4cd8d712] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 47d481fe]]
2017-08-01 15:19:28,938 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 50f2dccb] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 4bee87b7]]
2017-08-01 15:20:19,623 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task running
2017-08-01 15:20:19,623 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 15:20:19,623 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task completed
2017-08-01 15:20:28,946 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 55180893] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 5013b37f]]
2017-08-01 15:21:28,957 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 5931e17e] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 542d8c6a]]
2017-08-01 15:22:28,961 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 5d441472] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 583fbf5e]]
2017-08-01 15:23:28,985 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 615b878a] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 5c573276]]
2017-08-01 15:24:28,995 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 6576a788] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 60725274]]
2017-08-01 15:25:29,001 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 69998cda] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 649537c6]]
2017-08-01 15:26:29,010 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 6db5d013] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 68b17aff]]
2017-08-01 15:27:29,017 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 71c6c4ea] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 6cc26fd6]]
2017-08-01 15:28:29,025 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 75e1dbf2] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 70dd86de]]
2017-08-01 15:29:29,036 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 79f98949] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 74f53435]]
2017-08-01 15:30:19,634 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task running
2017-08-01 15:30:19,634 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 15:30:19,634 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task completed
2017-08-01 15:30:29,040 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 7e1c897d] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 79183469]]
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/web/**'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/j_spring_security_check'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_logout, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /j_spring_security_logout, QueryString: null with /j_spring_security_logout
2017-08-01 15:31:19,605 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:31:19,636 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: null'; against '/web/**'
2017-08-01 15:31:19,636 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2017-08-01 15:31:19,636 DEBUG [org.geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
java.lang.Exception: Full stack trace for the session creation path
	at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:92)
	at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:70)
	at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:238)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:50)
2017-08-01 15:31:19,715 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:31:19,715 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 15:31:19,715 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:31:19,715 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 15:31:19,730 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 15:31:20,402 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 15:31:20,402 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:31:29,055 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 8238b1d4] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 7d345cc0]]
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/web/**'
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/'
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/j_spring_security_check'
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /j_spring_security_check, QueryString: null with /j_spring_security_check
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Request is to process authentication
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Authentication success. Updating SecurityContextHolder to contain: org.springframework.security.authentication.UsernamePasswordAuthenticationToken at 6923e9d6: Principal: Username: admin; Password: [PROTECTED]; Enabled: true; AccountNonExpired: true; CredentialsNonExpired: true; AccountNonLocked: true;  [ ADMIN,ROLE_ADMINISTRATOR ] ; Credentials: [PROTECTED]; Authenticated: true; Details: org.geoserver.security.filter.GeoServerWebAuthenticationDetails at ffff10d0: RemoteIpAddress: 10.33.10.141; SessionId: 342BAF7CD54C1E14BE93CC68859A53B3; Granted Authorities: ADMIN, ROLE_ADMINISTRATOR, ROLE_AUTHENTICATED
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Added remember-me cookie for user 'admin at default', expiry: 'Tue Aug 15 15:31:36 GMT 2017'
2017-08-01 15:31:36,921 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:31:37,030 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web, QueryString: null'; against '/web/**'
2017-08-01 15:31:37,030 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web, QueryString: null with /web/**
2017-08-01 15:31:37,030 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:31:37,030 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:31:37,030 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:31:37,030 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web]
2017-08-01 15:31:37,030 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:31:37,124 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: null'; against '/web/**'
2017-08-01 15:31:37,124 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2017-08-01 15:31:37,124 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:31:37,124 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:31:37,124 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:31:37,124 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 15:31:37,265 DEBUG [org.geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
	at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:229)
	at org.apache.wicket.session.HttpSessionStore.getHttpSession(HttpSessionStore.java:95)
	at org.apache.wicket.session.HttpSessionStore.getSessionId(HttpSessionStore.java:166)
	at org.apache.wicket.Session.bind(Session.java:267)
	at org.apache.wicket.Session.replaceSession(Session.java:519)
	at org.geoserver.web.GeoServerApplication.onApplicationEvent(GeoServerApplication.java:417)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:163)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:136)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:381)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:335)
	at org.springframework.security.authentication.DefaultAuthenticationEventPublisher.publishAuthenticationSuccess(DefaultAuthenticationEventPublisher.java:84)
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:213)
	at org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1492)
	at org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.<init>(SecurityHomePageContentProvider.java:105)
	at org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:47)
	at org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:129)
	at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
	at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
	at org.apache.wicket.Component.internalBeforeRender(Component.java:949)
	at org.apache.wicket.Component.beforeRender(Component.java:1017)
	at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1568)
	at org.apache.wicket.Component.onBeforeRender(Component.java:3877)
	at org.apache.wicket.Page.onBeforeRender(Page.java:801)
	at org.apache.wicket.Component.internalPrepareForRender(Component.java:2215)
	at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
	at org.apache.wicket.Component.render(Component.java:2304)
	at org.apache.wicket.Page.renderPage(Page.java:1018)
	at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
	at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
	at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
	at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
	at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
	at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 15:31:37,436 WARN [org.geoserver.security] - Strong cryptography is NOT available
Download and installation the of unlimted length policy files is recommended
2017-08-01 15:31:37,833 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:31:38,036 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: 1'; against '/web/**'
2017-08-01 15:31:38,036 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: 1 with /web/**
2017-08-01 15:31:38,052 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:31:38,052 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:31:38,052 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:31:38,052 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 15:31:38,052 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 15:31:38,052 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:32:29,057 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 864adbd2] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 814686be]]
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Did not send remember-me cookie (principal did not set parameter '_spring_security_remember_me')
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Remember-me login not requested.
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security] - AuthenticationCache adding new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security] - AuthenticationCache added new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 15:32:49,207 DEBUG [org.geoserver.security] - Cache entries #: 1
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-zones-inondables_26.xml'; to: '/rest/layergroups/les-zones-inondables_26.xml'  and httpMethod= GET
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 15:32:49,222 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-zones-inondables_26.xml]
2017-08-01 15:32:49,222 DEBUG [org.geoserver] - Thread 271 locking in mode READ
2017-08-01 15:32:49,222 DEBUG [org.geoserver] - Thread 271 got the lock in mode READ
2017-08-01 15:32:49,222 DEBUG [org.geoserver] - Thread 271 releasing the lock in mode READ
2017-08-01 15:32:49,222 ERROR [org.geoserver.rest] - No such layer group les-zones-inondables_26
2017-08-01 15:32:49,222 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
org.geoserver.rest.RestletException
	at org.geoserver.catalog.rest.LayerGroupFinder.findTarget(LayerGroupFinder.java:49)
	at org.restlet.Finder.handle(Finder.java:268)
	at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
	at org.restlet.Filter.doHandle(Filter.java:105)
	at org.restlet.Filter.handle(Filter.java:134)
	at org.restlet.Router.handle(Router.java:444)
	at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
	at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
	at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:213)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 15:32:49,222 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-zones-inondables_26.xml'; to: '/rest/layergroups/les-zones-inondables_26.xml'  and httpMethod= GET
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 15:32:49,238 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-zones-inondables_26.xml]
2017-08-01 15:32:49,238 DEBUG [org.geoserver] - Thread 62 locking in mode READ
2017-08-01 15:32:49,238 DEBUG [org.geoserver] - Thread 62 got the lock in mode READ
2017-08-01 15:32:49,238 DEBUG [org.geoserver] - Thread 62 releasing the lock in mode READ
2017-08-01 15:32:49,238 ERROR [org.geoserver.rest] - No such layer group les-zones-inondables_26
2017-08-01 15:32:49,238 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 15:32:49,238 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 15:32:49,254 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-zones-inondables_26.xml'; to: '/rest/layergroups/les-zones-inondables_26.xml'  and httpMethod= GET
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 15:32:49,269 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-zones-inondables_26.xml]
2017-08-01 15:32:49,269 DEBUG [org.geoserver] - Thread 61 locking in mode READ
2017-08-01 15:32:49,269 DEBUG [org.geoserver] - Thread 61 got the lock in mode READ
2017-08-01 15:32:49,269 DEBUG [org.geoserver] - Thread 61 releasing the lock in mode READ
2017-08-01 15:32:49,269 ERROR [org.geoserver.rest] - No such layer group les-zones-inondables_26
2017-08-01 15:32:49,269 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 15:32:49,269 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/web/**'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/rest/**'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/**'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/**'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 15:33:10,003 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /pdf/info.json, QueryString: null with /**
2017-08-01 15:33:10,019 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:33:10,019 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 15:33:10,019 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 15:33:10,019 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/pdf/info.json]
2017-08-01 15:33:10,019 WARN [org.ho.yaml.CustomBeanWrapper] - MetaData: unknown field 'footer' with value '{items=[org.mapfish.print.config.layout.ColumnsBlock at 38e108], height=30}'
2017-08-01 15:33:10,034 WARN [org.ho.yaml.CustomBeanWrapper] - MainPage: Error while writing '{items=[org.mapfish.print.config.layout.ColumnsBlock at 38e108], height=30}' to footer: java.lang.IllegalArgumentException: argument type mismatch
2017-08-01 15:33:10,034 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/web/**'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/web/**'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check/'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout/'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/rest/**'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/**'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/**'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 15:33:12,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer with /**
2017-08-01 15:33:12,522 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 15:33:12,522 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:33:12,522 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 15:33:12,569 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 15:33:12,616 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 15:33:12,678 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 15:33:12,678 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 15:33:12,678 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 15:33:12,678 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 15:33:12,678 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 15:33:12,678 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 15:33:12,678 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 15:33:12,678 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 15:33:12,678 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 15:33:12,678 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
Request: describeLayer
	Layers = [org.geoserver.wms.MapLayerInfo at cb36b54c]
	OutputFormat = application/vnd.ogc.wms_xml
	GetMapRequest = null
	ExeptionFormat = application/vnd.ogc.se_xml
	Version = 1.1.1
	Request = DescribeLayer
	Get = false
	BaseUrl = http://localhost:80/geoserver/
	RawKvp = {REQUEST=DescribeLayer, ACCESS_TOKEN=DpruYgZACfBII27s9S8qrsqbTIHiyY, VERSION=1.1.1, SERVICE=WMS, LAYERS=Gapeau:Reseau_hydrographique_lim_SAGE}
	RequestCharset = null
2017-08-01 15:33:12,678 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/web/**'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/rest/**'
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/styles, QueryString: null with /rest/**
2017-08-01 15:33:20,131 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/styles'; to: '/rest/styles'  and httpMethod= PUT
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=false
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=false
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=false
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ROLE_ADMINISTRATOR
2017-08-01 15:33:20,147 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/styles]
2017-08-01 15:33:20,147 DEBUG [org.geoserver] - Thread 67 locking in mode WRITE
2017-08-01 15:33:20,147 DEBUG [org.geoserver] - Thread 67 got the lock in mode WRITE
2017-08-01 15:33:20,147 DEBUG [org.geoserver] - Thread 67 releasing the lock in mode WRITE
2017-08-01 15:33:20,147 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:33:29,067 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 8a64dd10] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 856087fc]]
2017-08-01 15:34:29,072 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 8e7c935d] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 89783e49]]
2017-08-01 15:35:29,085 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 929f6b3e] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 8d9b162a]]
2017-08-01 15:36:29,095 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 96ba8b3c] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 91b63628]]
2017-08-01 15:37:29,102 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 9acdcf7f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 95c97a6b]]
2017-08-01 15:38:29,123 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 9ee8ac48] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 99e45734]]
2017-08-01 15:39:29,134 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at a30b8d1f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 9e07380b]]
2017-08-01 15:40:19,640 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task running
2017-08-01 15:40:19,640 DEBUG [org.geoserver.security] - Cache entries #: 1
2017-08-01 15:40:19,640 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task completed
2017-08-01 15:40:19,640 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 15:40:29,143 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at a723436c] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at a21eee58]]
2017-08-01 15:41:29,147 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at ab3d4da0] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at a638f88c]]
2017-08-01 15:42:29,154 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at af4f7323] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at aa4b1e0f]]
2017-08-01 15:43:22,706 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: null'; against '/web/**'
2017-08-01 15:43:22,706 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: null with /web/**
2017-08-01 15:43:22,706 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:22,706 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:22,706 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:22,800 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofencePage]
2017-08-01 15:43:22,800 DEBUG [org.geoserver] - Thread 65 locking in mode WRITE
2017-08-01 15:43:22,800 DEBUG [org.geoserver] - Thread 65 got the lock in mode WRITE
2017-08-01 15:43:22,972 DEBUG [org.geoserver] - Thread 65 locking in mode WRITE
2017-08-01 15:43:22,972 DEBUG [org.geoserver] - Thread 65 releasing the lock in mode WRITE
2017-08-01 15:43:22,972 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:23,144 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: 4'; against '/web/**'
2017-08-01 15:43:23,144 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: 4 with /web/**
2017-08-01 15:43:23,144 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:23,144 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:23,144 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:23,160 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofencePage]
2017-08-01 15:43:23,160 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 15:43:23,160 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:29,171 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at b36b8098] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at ae672b84]]
2017-08-01 15:43:49,787 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserverpage, QueryString: null'; against '/web/**'
2017-08-01 15:43:49,787 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserverpage, QueryString: null with /web/**
2017-08-01 15:43:49,787 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:49,787 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:49,787 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:49,787 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofenceServerPage]
2017-08-01 15:43:49,787 DEBUG [org.geoserver] - Thread 61 locking in mode WRITE
2017-08-01 15:43:49,787 DEBUG [org.geoserver] - Thread 61 got the lock in mode WRITE
2017-08-01 15:43:51,037 DEBUG [org.geoserver] - Thread 61 locking in mode WRITE
2017-08-01 15:43:51,037 DEBUG [org.geoserver] - Thread 61 releasing the lock in mode WRITE
2017-08-01 15:43:51,100 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:51,193 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserverpage, QueryString: 5'; against '/web/**'
2017-08-01 15:43:51,193 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserverpage, QueryString: 5 with /web/**
2017-08-01 15:43:51,193 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:51,193 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:51,193 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:51,193 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofenceServerPage]
2017-08-01 15:43:51,193 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 15:43:51,209 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:52,869 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/wicketdnd.theme.windowstheme/web/theme-ver-ed7b4bbd2e85d4f36617eca68e4b12d2.css, QueryString: null'; against '/web/**'
2017-08-01 15:43:52,869 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/wicketdnd.theme.windowstheme/web/theme-ver-ed7b4bbd2e85d4f36617eca68e4b12d2.css, QueryString: null with /web/**
2017-08-01 15:43:52,869 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:52,869 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:52,869 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:52,869 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/wicketdnd.theme.WindowsTheme/web/theme-ver-ED7B4BBD2E85D4F36617ECA68E4B12D2.css]
2017-08-01 15:43:52,885 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/css
2017-08-01 15:43:52,885 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:52,948 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/wicketdnd.transfer/wicket-dnd-ver-a9d21ebf7484d913880490dc2b85c578.js, QueryString: null'; against '/web/**'
2017-08-01 15:43:52,948 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/wicketdnd.transfer/wicket-dnd-ver-a9d21ebf7484d913880490dc2b85c578.js, QueryString: null with /web/**
2017-08-01 15:43:52,948 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:52,948 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:52,948 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:52,948 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/wicketdnd.Transfer/wicket-dnd-ver-A9D21EBF7484D913880490DC2B85C578.js]
2017-08-01 15:43:52,948 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: application/javascript
2017-08-01 15:43:52,948 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:53,401 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage$buttonpanel/img/arrow_up-ver-34ced99097002e9a7783ada1f2d84d1b.png, QueryString: null'; against '/web/**'
2017-08-01 15:43:53,401 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage$buttonpanel/img/arrow_up-ver-34ced99097002e9a7783ada1f2d84d1b.png, QueryString: null with /web/**
2017-08-01 15:43:53,401 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:53,401 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:53,401 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:53,401 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.geofence.web.GeofenceServerPage$ButtonPanel/img/arrow_up-ver-34CED99097002E9A7783ADA1F2D84D1B.png]
2017-08-01 15:43:53,417 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 15:43:53,417 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:53,807 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage$buttonpanel/img/arrow_down-ver-60c7def42fe4a9f7be6857ace5e016e4.png, QueryString: null'; against '/web/**'
2017-08-01 15:43:53,807 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage$buttonpanel/img/arrow_down-ver-60c7def42fe4a9f7be6857ace5e016e4.png, QueryString: null with /web/**
2017-08-01 15:43:53,807 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:53,807 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:53,807 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:53,823 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.geofence.web.GeofenceServerPage$ButtonPanel/img/arrow_down-ver-60C7DEF42FE4A9F7BE6857ACE5E016E4.png]
2017-08-01 15:43:53,823 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 15:43:53,823 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:43:53,839 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage$buttonpanel/img/edit-ver-b1f5c08af54a8efabcdf782ac18cedd8.png, QueryString: null'; against '/web/**'
2017-08-01 15:43:53,839 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage$buttonpanel/img/edit-ver-b1f5c08af54a8efabcdf782ac18cedd8.png, QueryString: null with /web/**
2017-08-01 15:43:53,839 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:43:53,839 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:43:53,839 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:43:53,839 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.geofence.web.GeofenceServerPage$ButtonPanel/img/edit-ver-B1F5C08AF54A8EFABCDF782AC18CEDD8.png]
2017-08-01 15:43:53,839 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 15:43:53,839 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:44:00,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserveradminpage, QueryString: null'; against '/web/**'
2017-08-01 15:44:00,460 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserveradminpage, QueryString: null with /web/**
2017-08-01 15:44:00,460 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:44:00,460 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:44:00,460 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:44:00,460 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofenceServerAdminPage]
2017-08-01 15:44:00,460 DEBUG [org.geoserver] - Thread 271 locking in mode WRITE
2017-08-01 15:44:00,460 DEBUG [org.geoserver] - Thread 271 got the lock in mode WRITE
2017-08-01 15:44:00,585 DEBUG [org.geoserver] - Thread 271 locking in mode WRITE
2017-08-01 15:44:00,585 DEBUG [org.geoserver] - Thread 271 releasing the lock in mode WRITE
2017-08-01 15:44:00,585 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:44:01,022 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserveradminpage, QueryString: 6'; against '/web/**'
2017-08-01 15:44:01,022 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofenceserveradminpage, QueryString: 6 with /web/**
2017-08-01 15:44:01,022 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:44:01,022 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:44:01,022 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:44:01,022 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofenceServerAdminPage]
2017-08-01 15:44:01,022 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 15:44:01,022 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:44:29,188 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at b78f5361] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at b28afe4d]]
2017-08-01 15:45:28,698 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: null'; against '/web/**'
2017-08-01 15:45:28,698 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: null with /web/**
2017-08-01 15:45:28,698 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:45:28,698 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:45:28,698 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:45:28,698 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofencePage]
2017-08-01 15:45:28,698 DEBUG [org.geoserver] - Thread 66 locking in mode WRITE
2017-08-01 15:45:28,698 DEBUG [org.geoserver] - Thread 66 got the lock in mode WRITE
2017-08-01 15:45:28,729 DEBUG [org.geoserver] - Thread 66 locking in mode WRITE
2017-08-01 15:45:28,729 DEBUG [org.geoserver] - Thread 66 releasing the lock in mode WRITE
2017-08-01 15:45:28,729 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:45:28,917 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: 7'; against '/web/**'
2017-08-01 15:45:28,917 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: 7 with /web/**
2017-08-01 15:45:28,917 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:45:28,917 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:45:28,917 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:45:28,917 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofencePage]
2017-08-01 15:45:28,917 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 15:45:28,917 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:45:29,198 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at bba9549f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at b6a4ff8b]]
2017-08-01 15:46:29,214 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at bfc0eb8f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at babc967b]]
2017-08-01 15:47:29,230 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at c3d2e8bf] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at bece93ab]]
2017-08-01 15:48:29,236 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at c7ecd811] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at c2e882fd]]
2017-08-01 15:48:31,551 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: 7-1.IBehaviorListener.0-form-test'; against '/web/**'
2017-08-01 15:48:31,551 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.geofence.web.geofencepage, QueryString: 7-1.IBehaviorListener.0-form-test with /web/**
2017-08-01 15:48:31,551 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:48:31,551 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:48:31,551 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:48:31,551 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.geofence.web.GeofencePage]
2017-08-01 15:48:31,613 DEBUG [org.geoserver] - Thread 59 locking in mode WRITE
2017-08-01 15:48:31,613 DEBUG [org.geoserver] - Thread 59 got the lock in mode WRITE
2017-08-01 15:48:31,692 DEBUG [org.geoserver] - Thread 59 locking in mode WRITE
2017-08-01 15:48:31,692 DEBUG [org.geoserver] - Thread 59 releasing the lock in mode WRITE
2017-08-01 15:48:31,692 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2017-08-01 15:48:31,692 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:49:29,245 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at cc11ff5e] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at c70daa4a]]
2017-08-01 15:50:19,642 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task running
2017-08-01 15:50:19,642 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 15:50:19,642 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task completed
2017-08-01 15:50:29,261 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at d02cf28e] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at cb289d7a]]
2017-08-01 15:51:29,264 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at d43e0b3d] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at cf39b629]]
2017-08-01 15:52:29,278 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at d855bd0f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at d35167fb]]
2017-08-01 15:53:29,280 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at dc70dd0d] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at d76c87f9]]
2017-08-01 15:54:29,283 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at e093f3a8] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at db8f9e94]]
2017-08-01 15:55:29,296 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at e4b0011d] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at dfabac09]]
2017-08-01 15:56:29,306 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at e8c10c5b] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at e3bcb747]]
2017-08-01 15:57:29,317 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at ecdc0406] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at e7d7aef2]]
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/web/**'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/gwc/rest/web/**'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_security_check'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_security_check/'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_oauth2_geonode_login'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_security_logout'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_security_logout/'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/rest/**'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/gwc/rest/**'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG'; against '/**'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 15:57:45,210 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG with /**
2017-08-01 15:57:45,272 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:57:45,272 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 15:57:45,272 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 15:57:45,272 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/ows]
2017-08-01 15:57:45,272 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/ows] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 1851722] and 1 interceptor
2017-08-01 15:57:45,288 INFO [org.geoserver.wms] -
2017-08-01 15:57:45,288 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: No such operation wms 1.3.0 GetCapabilities?access_token=T6lJbcf6eYgjFmHxlBLnJxrrhy5TiG
	at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:639)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:258)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 15:57:45,288 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:58:15,118 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: null'; against '/web/**'
2017-08-01 15:58:15,118 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2017-08-01 15:58:15,118 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:58:15,118 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:58:15,118 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:58:15,118 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 15:58:15,228 DEBUG [org.geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
java.lang.Exception: Full stack trace for the session creation path
	at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:92)
	at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:229)
	at org.apache.wicket.session.HttpSessionStore.getHttpSession(HttpSessionStore.java:95)
	at org.apache.wicket.session.HttpSessionStore.getSessionId(HttpSessionStore.java:166)
	at org.apache.wicket.Session.bind(Session.java:267)
	at org.apache.wicket.Session.replaceSession(Session.java:519)
	at org.geoserver.web.GeoServerApplication.onApplicationEvent(GeoServerApplication.java:417)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:163)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:136)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:381)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:335)
	at org.springframework.security.authentication.DefaultAuthenticationEventPublisher.publishAuthenticationSuccess(DefaultAuthenticationEventPublisher.java:84)
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:213)
	at org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1492)
	at org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.<init>(SecurityHomePageContentProvider.java:105)
	at org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:47)
	at org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:129)
	at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
	at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
	at org.apache.wicket.Component.internalBeforeRender(Component.java:949)
	at org.apache.wicket.Component.beforeRender(Component.java:1017)
	at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1568)
	at org.apache.wicket.Component.onBeforeRender(Component.java:3877)
	at org.apache.wicket.Page.onBeforeRender(Page.java:801)
	at org.apache.wicket.Component.internalPrepareForRender(Component.java:2215)
	at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
	at org.apache.wicket.Component.render(Component.java:2304)
	at org.apache.wicket.Page.renderPage(Page.java:1018)
	at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
	at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
	at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
	at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
	at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
	at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
2017-08-01 15:58:15,275 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:58:15,290 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: 8'; against '/web/**'
2017-08-01 15:58:15,290 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: 8 with /web/**
2017-08-01 15:58:15,306 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 15:58:15,306 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 15:58:15,306 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 15:58:15,306 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 15:58:15,306 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 15:58:15,306 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 15:58:29,328 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f0f3b15d] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at ebef5c49]]
2017-08-01 15:59:29,331 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f516c7f8] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f01272e4]]
2017-08-01 15:59:51,279 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f02.xml
2017-08-01 15:59:51,279 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e8d.xml
2017-08-01 15:59:51,279 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb0.xml
2017-08-01 15:59:51,279 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f21.xml
2017-08-01 15:59:51,279 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f60.xml
2017-08-01 15:59:51,279 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f27.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ef5.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f66.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f9e.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f48.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7efc.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fec.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fd5.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fce.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f15.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f54.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fe3.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f36.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fda.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fbc.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f42.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e3e.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e21.xml
2017-08-01 15:59:51,294 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7f03.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f7e.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f98.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7faa.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe0.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe6.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7835.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc8.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fed.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f2d.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f08.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f6c.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f0f.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f4e.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e1a.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f84.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb6.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f8b.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f92.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f1b.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f5a.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7eef.xml
2017-08-01 15:59:51,310 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f3c.xml
2017-08-01 15:59:51,326 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ff3.xml
2017-08-01 15:59:51,326 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerGroupInfoImpl--1a844f6e_15d78d339f9_-7ecf.xml
2017-08-01 15:59:51,326 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e9f.xml
2017-08-01 15:59:51,326 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc2.xml
2017-08-01 15:59:51,326 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f72.xml
2017-08-01 15:59:51,326 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f78.xml
2017-08-01 15:59:51,326 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fa4.xml
2017-08-01 15:59:51,388 WARN [org.springframework.beans.factory.support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'geoGigGeoServerLifeCycleListener': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2017-08-01 16:00:05,117 DEBUG [org.geoserver.logging] - Logging output to file 'C:\GeoNode-2.6.x\data\logs\geoserver.log'
2017-08-01 16:00:05,117 DEBUG [org.geoserver.logging] - FINISHED CONFIGURING GEOSERVER LOGGING -------------------------
2017-08-01 16:00:07,523 TRACE [org.geoserver.platform] - No resourceStoreImpl beans found, falling back to DataDirectoryResourceStore
2017-08-01 16:00:07,554 WARN [org.geoserver.config] - Error reading resource URL [jar:file:/C:/GeoNode-2.6.x/apache-tomcat-7.0.65/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.9-SNAPSHOT.jar!/geofence-default-override.properties]
java.io.FileNotFoundException: URL [jar:file:/C:/GeoNode-2.6.x/apache-tomcat-7.0.65/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.9-SNAPSHOT.jar!/geofence-default-override.properties] cannot be resolved to absolute file path because it does not reside in the file system: jar:file:/C:/GeoNode-2.6.x/apache-tomcat-7.0.65/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.9-SNAPSHOT.jar!/geofence-default-override.properties
	at org.springframework.util.ResourceUtils.getFile(ResourceUtils.java:218)
	at org.springframework.core.io.AbstractFileResolvingResource.getFile(AbstractFileResolvingResource.java:52)
	at org.springframework.core.io.UrlResource.getFile(UrlResource.java:212)
	at org.geoserver.config.SpringResourceAdaptor.relative(SpringResourceAdaptor.java:40)
	at org.geoserver.config.GeoServerPropertyOverrideConfigurer.setLocations(GeoServerPropertyOverrideConfigurer.java:52)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.springframework.beans.BeanWrapperImpl$BeanPropertyHandler.setValue(BeanWrapperImpl.java:346)
	at org.springframework.beans.AbstractNestablePropertyAccessor.setPropertyValue(AbstractNestablePropertyAccessor.java:454)
	at org.springframework.beans.AbstractNestablePropertyAccessor.setPropertyValue(AbstractNestablePropertyAccessor.java:280)
	at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:95)
	at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:75)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1514)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1226)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:543)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202)
	at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:154)
	at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:678)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:520)
	at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
	at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5003)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5517)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
	at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1095)
	at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1960)
	at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
	at java.util.concurrent.FutureTask.run(Unknown Source)
2017-08-01 16:00:07,554 INFO [org.geoserver.geofence.config.GeoFencePropertyPlaceholderConfigurer] - Loading properties file from org.geoserver.config.SpringResourceAdaptor at 1e58e45
2017-08-01 16:00:07,570 WARN [org.springframework.beans.factory.config.PropertyOverrideConfigurer] - Could not load properties from URL [file:${geofence.dir}/geofence-datasource-ovr.properties]: ${geofence.dir}\geofence-datasource-ovr.properties (Le chemin d��cc���sp���fi���st introuvable)
2017-08-01 16:00:07,570 INFO [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Loading properties file from URL [jar:file:/C:/GeoNode-2.6.x/apache-tomcat-7.0.65/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.9-SNAPSHOT.jar!/geofence-default-override.properties]
2017-08-01 16:00:07,570 INFO [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Loading properties file from org.geoserver.config.SpringResourceAdaptor at 1981625
2017-08-01 16:00:07,570 INFO [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Loading properties file from org.geoserver.config.SpringResourceAdaptor at 170373c
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceEntityManagerFactory.jpaPropertyMap[hibernate.validator.autoregister_listeners]' set to value [false  ]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceConfigurationManager.configuration.servicesUrl' set to value [internal:/]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceEntityManagerFactory.jpaPropertyMap[javax.persistence.validation.mode]' set to value [none]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceEntityManagerFactory.jpaPropertyMap[hibernate.hbm2ddl.auto]' set to value [update]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceDataSource.driverClassName' set to value [org.h2.Driver]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceEntityManagerFactory.jpaPropertyMap[hibernate.default_schema]' set to value [public]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceDataSource.url' set to value [jdbc:h2:C:\GeoNode-2.6.x\data/geofence/geofence_db/geofence]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceDataSource.username' set to value [sa]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceEntityManagerFactory.jpaPropertyMap[hibernate.validator.apply_to_ddl]' set to value [false]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceDataSource.password' set to value [sa]
2017-08-01 16:00:07,570 DEBUG [org.geoserver.config.GeoServerPropertyOverrideConfigurer] - Property 'geofenceVendorAdapter.databasePlatform' set to value [org.hibernatespatial.geodb.GeoDBDialect]
2017-08-01 16:00:07,929 INFO [org.geoserver.geofence] - GeoFence configuration: instance name is default-gs
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'alea'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'Alea_residuel_fedb9d6a'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'arrete_protection_biotope'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'Baignade_Bilan'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'Bassin_versants_limite'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'Biocenose'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'Biocenose_7c262b4b'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'Captages_AEP_AERMC'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'centre_equestre'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'commune_contour_sage'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'commune_contour_sage_6dcf60ee'
2017-08-01 16:00:10,383 INFO [org.geoserver] - Loaded style 'commune_contour_sage_6e4e3f52'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'Corridor'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'Decharge_Bilan'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'ENS'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'flore_invasives'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'generic'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'ICPE'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'Intercommunalites'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'line'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'Masse_eau'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'masse_eau_souterraine_carmen_bv'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'navettes'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'N_ENJEU_PPRI_P_21'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'N_ENJEU_PPRI_P_21_96432a31'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'N_ENJEU_PPRI_S_21'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'Ouvrage_SCP'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'PARCELLES_DGI_NOUVELLE_VERSION_MAI2014'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'Plages'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'Plages_0b101a31'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'pnr_sainte_baume'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'PN_CT_CM'
2017-08-01 16:00:10,399 INFO [org.geoserver] - Loaded style 'PN_V2'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'point'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'polygon'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'Polygone_alea_q100_v4_avec_AleaResiduel'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'port_plaisance'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'PPRI'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'Ramsar'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'raster'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'Reseau_hydrographique_lim_SAGE'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'Reseau_hydrographique_SAGE'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'Reseau_SCP'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'reservoir_biologique'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'san_andres_y_providencia_administrative'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'san_andres_y_providencia_coastline'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'san_andres_y_providencia_highway'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'san_andres_y_providencia_location'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'san_andres_y_providencia_natural'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'san_andres_y_providencia_poi'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'san_andres_y_providencia_water'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'single_point'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'sites_plongees'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'SRCE_Cours_eau'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'STEU'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'troncon_hydro_sage'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'Veg_rase'
2017-08-01 16:00:10,415 INFO [org.geoserver] - Loaded style 'Vouge_Polygone_alea_q100_v4_avec%20AleaResiduel'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'Zones_agri'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'Zones_boisee'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'Zones_Expansion_Crue'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'Zones_humides'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'zones_inondables_PACA'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'Zones_urb'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'Zone_mouillage'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'zone_strategique'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'ZPS_N2000'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded style 'ZSC_N2000'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded default workspace Gapeau
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded workspace 'Gapeau'
2017-08-01 16:00:10,430 INFO [org.geoserver] - Loaded workspace 'geonode'
2017-08-01 16:00:10,899 INFO [org.geoserver] - Loaded store 'datastore', enabled
2017-08-01 16:00:10,915 INFO [org.geoserver] - Loaded data store 'datastore'
2017-08-01 16:00:12,071 INFO [org.geoserver] - Loaded feature type 'flore_invasives', enabled
2017-08-01 16:00:12,087 INFO [org.geoserver] - Loaded feature type 'datastore'
2017-08-01 16:00:12,102 INFO [org.geoserver] - Loaded layer 'flore_invasives'
2017-08-01 16:00:12,196 INFO [org.geoserver] - Loaded store 'gapeau', enabled
2017-08-01 16:00:12,196 INFO [org.geoserver] - Loaded data store 'gapeau'
2017-08-01 16:00:12,430 INFO [org.geoserver] - Loaded feature type 'Alluvions_Gapeau', enabled
2017-08-01 16:00:12,430 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded layer 'Alluvions_Gapeau'
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded feature type 'arrete_protection_biotope', enabled
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded layer 'arrete_protection_biotope'
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded feature type 'Baignade_Bilan', enabled
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded layer 'Baignade_Bilan'
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded feature type 'Bassin_versants_limite', enabled
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded layer 'Bassin_versants_limite'
2017-08-01 16:00:12,446 INFO [org.geoserver] - Loaded feature type 'Biocenose', enabled
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded layer 'Biocenose'
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded feature type 'Captages_AEP_AERMC', enabled
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded layer 'Captages_AEP_AERMC'
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded feature type 'centre_equestre', enabled
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded layer 'centre_equestre'
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded feature type 'commune_contour_sage', enabled
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded layer 'commune_contour_sage'
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded feature type 'Corridor', enabled
2017-08-01 16:00:12,461 INFO [org.geoserver] - Loaded layer 'Corridor'
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded feature type 'Decharge_Bilan', enabled
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded layer 'Decharge_Bilan'
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded feature type 'ENS', enabled
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded layer 'ENS'
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded feature type 'ICPE', enabled
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded layer 'ICPE'
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded feature type 'Intercommunalites', enabled
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded layer 'Intercommunalites'
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded feature type 'Masse_eau', enabled
2017-08-01 16:00:12,477 INFO [org.geoserver] - Loaded layer 'Masse_eau'
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded feature type 'masse_eau_souterraine_carmen_bv', enabled
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded layer 'masse_eau_souterraine_carmen_bv'
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded feature type 'navettes', enabled
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded layer 'navettes'
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded feature type 'Ouvrage_SCP', enabled
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded layer 'Ouvrage_SCP'
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded feature type 'Plages', enabled
2017-08-01 16:00:12,493 INFO [org.geoserver] - Loaded layer 'Plages'
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded feature type 'pnr_sainte_baume', enabled
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded layer 'pnr_sainte_baume'
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded feature type 'PN_CT_CM', enabled
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded layer 'PN_CT_CM'
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded feature type 'PN_V2', enabled
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded layer 'PN_V2'
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded feature type 'port_plaisance', enabled
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded layer 'port_plaisance'
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded feature type 'PPRI', enabled
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded layer 'PPRI'
2017-08-01 16:00:12,508 INFO [org.geoserver] - Loaded feature type 'Ramsar', enabled
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded layer 'Ramsar'
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded feature type 'Reseau_hydrographique_lim_SAGE', enabled
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded layer 'Reseau_hydrographique_lim_SAGE'
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded feature type 'Reseau_SCP', enabled
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded layer 'Reseau_SCP'
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded feature type 'reservoir_biologique', enabled
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded layer 'reservoir_biologique'
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded feature type 'sites_plongees', enabled
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded layer 'sites_plongees'
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded feature type 'SRCE_Cours_eau', enabled
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded layer 'SRCE_Cours_eau'
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded feature type 'STEU', enabled
2017-08-01 16:00:12,524 INFO [org.geoserver] - Loaded layer 'STEU'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'troncon_hydro_sage', enabled
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded layer 'troncon_hydro_sage'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'Veg_rase', enabled
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded layer 'Veg_rase'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'Zones_agri', enabled
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded layer 'Zones_agri'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'Zones_boisee', enabled
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded layer 'Zones_boisee'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'Zones_Expansion_Crue', enabled
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded layer 'Zones_Expansion_Crue'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'Zones_humides', enabled
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded layer 'Zones_humides'
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded feature type 'zones_inondables_PACA', enabled
2017-08-01 16:00:12,540 INFO [org.geoserver] - Loaded layer 'zones_inondables_PACA'
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded feature type 'Zones_urb', enabled
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded feature type 'gapeau'
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded layer 'Zones_urb'
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded feature type 'Zone_mouillage', enabled
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded layer 'Zone_mouillage'
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded feature type 'zone_strategique', enabled
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded layer 'zone_strategique'
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded feature type 'ZPS_N2000', enabled
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded layer 'ZPS_N2000'
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded feature type 'ZSC_N2000', enabled
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded layer 'ZSC_N2000'
2017-08-01 16:00:12,555 INFO [org.geoserver] - Loaded store 'Ortho 2014', enabled
2017-08-01 16:00:12,571 INFO [org.geoserver] - Loaded coverage store 'Ortho 2014'
2017-08-01 16:00:12,586 INFO [org.geoserver] - Loaded coverage 'Ortho2012_WGS84', enabled
2017-08-01 16:00:12,586 INFO [org.geoserver] - Loaded coverage 'Ortho 2014'
2017-08-01 16:00:12,821 INFO [org.geoserver] - Loaded layer 'Ortho2012_WGS84'
2017-08-01 16:00:12,836 INFO [org.geoserver] - Loaded layer group 'Occupation du sol'
2017-08-01 16:00:12,930 INFO [org.geoserver] - Loaded store 'datastore', enabled
2017-08-01 16:00:12,930 INFO [org.geoserver] - Loaded data store 'datastore'
2017-08-01 16:00:13,149 INFO [org.geoserver] - Loaded feature type 'san_andres_y_providencia_administrative', enabled
2017-08-01 16:00:13,149 INFO [org.geoserver] - Loaded feature type 'datastore'
2017-08-01 16:00:13,149 INFO [org.geoserver] - Loaded layer 'san_andres_y_providencia_administrative'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'san_andres_y_providencia_coastline', enabled
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'datastore'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded layer 'san_andres_y_providencia_coastline'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'san_andres_y_providencia_highway', enabled
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded layer 'san_andres_y_providencia_highway'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'san_andres_y_providencia_location', enabled
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded layer 'san_andres_y_providencia_location'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'san_andres_y_providencia_natural', enabled
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded layer 'san_andres_y_providencia_natural'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'san_andres_y_providencia_poi', enabled
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded layer 'san_andres_y_providencia_poi'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'san_andres_y_providencia_water', enabled
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded layer 'san_andres_y_providencia_water'
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded feature type 'single_point', enabled
2017-08-01 16:00:13,165 INFO [org.geoserver] - Loaded layer 'single_point'
2017-08-01 16:00:13,446 INFO [org.geoserver] - GeoServer configuration lock is enabled
2017-08-01 16:00:13,633 DEBUG [org.geoserver.config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id 'WMTSInfoImpl--3351f7fa:15766bb3594:-8000', available services were []
2017-08-01 16:00:13,633 INFO [org.geoserver] - Loaded service 'WMTSInfoImpl--3351f7fa:15766bb3594:-8000', enabled
2017-08-01 16:00:13,633 DEBUG [org.geoserver.config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id 'wcs', available services were [WMTSInfoImpl[WMTS]]
2017-08-01 16:00:13,633 INFO [org.geoserver] - Loaded service 'wcs', enabled
2017-08-01 16:00:13,633 DEBUG [org.geoserver.config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id 'wfs', available services were [WMTSInfoImpl[WMTS], WCSInfoImpl[My GeoServer WCS]]
2017-08-01 16:00:13,633 INFO [org.geoserver] - Loaded service 'wfs', enabled
2017-08-01 16:00:13,649 DEBUG [org.geoserver.config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id 'wms', available services were [WMTSInfoImpl[WMTS], WCSInfoImpl[My GeoServer WCS], WFSInfoImpl[My GeoServer WFS]]
2017-08-01 16:00:13,649 INFO [org.geoserver] - Loaded service 'wms', enabled
2017-08-01 16:00:13,665 DEBUG [org.geoserver.config.impl] - Could not locate service of type interface org.geoserver.config.ServiceInfo and id 'WPSInfoImpl-5af2e37b:155c5279975:-7ffe', available services were [WMTSInfoImpl[WMTS], WCSInfoImpl[My GeoServer WCS], WFSInfoImpl[My GeoServer WFS], WMSInfoImpl[My GeoServer WMS]]
2017-08-01 16:00:13,665 INFO [org.geoserver] - Loaded service 'WPSInfoImpl-5af2e37b:155c5279975:-7ffe', enabled
2017-08-01 16:00:13,743 INFO [org.geoserver.gwc.config.GeoserverXMLResourceProvider] - Will look for 'geowebcache.xml' in directory 'C:\GeoNode-2.6.x\data\gwc'.
2017-08-01 16:00:13,743 INFO [org.geoserver.gwc.config.GeoserverXMLResourceProvider] - Found configuration file in gwc
2017-08-01 16:00:13,790 WARN [org.geowebcache.config.XMLConfiguration] - ********************************************************************************
2017-08-01 16:00:13,790 WARN [org.geowebcache.config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1.a: Cannot find the declaration of element 'gwcConfiguration'.
2017-08-01 16:00:13,790 WARN [org.geowebcache.config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
2017-08-01 16:00:13,899 INFO [org.geoserver.gwc.layer] - Initializing GWC configuration based on GeoServer's Catalog
2017-08-01 16:00:13,899 INFO [org.geoserver.gwc.layer] - GeoServer TileLayer store base directory is: gwc-layers
2017-08-01 16:00:13,899 INFO [org.geoserver.gwc.layer] - Loading tile layers from gwc-layers
2017-08-01 16:00:13,899 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerGroupInfoImpl--1a844f6e_15d78d339f9_-7ecf.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Occupation du sol'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7835.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:flore_invasives'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7eef.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Ortho2012_WGS84'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ef5.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:zones_inondables_PACA'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7efc.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:zone_strategique'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f02.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:troncon_hydro_sage'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f08.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:sites_plongees'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f0f.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:reservoir_biologique'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f15.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:port_plaisance'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f1b.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:pnr_sainte_baume'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f21.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:navettes'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f27.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:masse_eau_souterraine_carmen_bv'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f2d.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:commune_contour_sage'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f36.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:centre_equestre'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f3c.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:arrete_protection_biotope'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f42.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Zones_urb'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f48.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Zones_humides'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f4e.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Zones_boisee'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f54.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Zones_agri'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f5a.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Zones_Expansion_Crue'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f60.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Zone_mouillage'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f66.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:ZSC_N2000'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f6c.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:ZPS_N2000'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f72.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Veg_rase'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f78.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:STEU'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f7e.xml
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:SRCE_Cours_eau'
2017-08-01 16:00:13,915 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f84.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Reseau_hydrographique_lim_SAGE'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f8b.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Reseau_SCP'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f92.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Ramsar'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f98.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Plages'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f9e.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:PPRI'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fa4.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:PN_V2'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7faa.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:PN_CT_CM'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb0.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Ouvrage_SCP'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb6.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Masse_eau'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fbc.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Intercommunalites'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc2.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:ICPE'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc8.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:ENS'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fce.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Decharge_Bilan'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fd5.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Corridor'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fda.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Captages_AEP_AERMC'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe0.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Biocenose'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe6.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Bassin_versants_limite'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fec.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Baignade_Bilan'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ff3.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'Gapeau:Alluvions_Gapeau'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e1a.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:single_point'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e21.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:san_andres_y_providencia_water'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e3e.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:san_andres_y_providencia_poi'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e8d.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:san_andres_y_providencia_natural'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e9f.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:san_andres_y_providencia_location'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7f03.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:san_andres_y_providencia_highway'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fe3.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:san_andres_y_providencia_coastline'
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fed.xml
2017-08-01 16:00:13,930 DEBUG [org.geoserver.gwc.layer] - Loaded tile layer 'geonode:san_andres_y_providencia_administrative'
2017-08-01 16:00:13,961 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f02.xml
2017-08-01 16:00:13,961 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e8d.xml
2017-08-01 16:00:13,961 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb0.xml
2017-08-01 16:00:13,961 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f21.xml
2017-08-01 16:00:13,961 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f60.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f27.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ef5.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f66.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f9e.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f48.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7efc.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fec.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fd5.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fce.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f15.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f54.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fe3.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f36.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fda.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fbc.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f42.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e3e.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e21.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7f03.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f7e.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f98.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7faa.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe0.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe6.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7835.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc8.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fed.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f2d.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f08.xml
2017-08-01 16:00:13,977 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f6c.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f0f.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f4e.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e1a.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f84.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb6.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f8b.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f92.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f1b.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f5a.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7eef.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f3c.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ff3.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerGroupInfoImpl--1a844f6e_15d78d339f9_-7ecf.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e9f.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc2.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f72.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f78.xml
2017-08-01 16:00:13,993 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fa4.xml
2017-08-01 16:00:13,993 INFO [org.geoserver.gwc.layer] - GWC configuration based on GeoServer's Catalog loaded successfuly
2017-08-01 16:00:14,102 INFO [org.geoserver.gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.config] - GWC GeoServer specific configuration loaded from gwc-gs.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7835.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ff3.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f3c.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fec.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe6.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fe0.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fda.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f36.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f2d.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fd5.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fce.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc8.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fc2.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fbc.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb6.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f27.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f21.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fb0.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f98.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f1b.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7faa.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7fa4.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f15.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f9e.xml
2017-08-01 16:00:14,102 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f92.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f84.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f8b.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f0f.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f08.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f7e.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f78.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f02.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f72.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f54.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f4e.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f5a.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f48.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7ef5.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f42.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f60.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7efc.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f6c.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7f66.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl--1a844f6e_15d78d339f9_-7eef.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fed.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7fe3.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7f03.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e9f.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e8d.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e3e.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e21.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerInfoImpl-39ff2488_15d3c42393a_-7e1a.xml
2017-08-01 16:00:14,118 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from gwc-layers/LayerGroupInfoImpl--1a844f6e_15d78d339f9_-7ecf.xml
2017-08-01 16:00:14,212 WARN [org.geoserver.platform.resource] - There is code leaving resource input streams open, locks around them might not be cleared! Add -Dfalse=true to your JVM options to get a full stack trace of the code that acquired the input stream
2017-08-01 16:00:15,524 INFO [org.geoserver.gwc.config.GeoserverXMLResourceProvider] - Will look for 'geowebcache-diskquota.xml' in directory 'C:\GeoNode-2.6.x\data\gwc'.
2017-08-01 16:00:15,540 INFO [org.geoserver.gwc.config.GeoserverXMLResourceProvider] - Will look for 'geowebcache-diskquota-jdbc.xml' in directory 'C:\GeoNode-2.6.x\data\gwc'.
2017-08-01 16:00:21,243 DEBUG [org.geoserver.config] - Cache control for capabilities requests and 304 support is enabled: true
2017-08-01 16:00:21,352 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler 'dispatcher'
2017-08-01 16:00:22,415 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler 'dispatcher'
2017-08-01 16:00:22,415 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler 'dispatcher'
2017-08-01 16:00:22,415 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/kml/icon/**/*] onto handler 'kmlIconService'
2017-08-01 16:00:22,571 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
2017-08-01 16:00:22,571 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
2017-08-01 16:00:22,884 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
2017-08-01 16:00:22,884 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
2017-08-01 16:00:23,759 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler 'wfsTestServlet'
2017-08-01 16:00:23,759 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler 'dispatcher'
2017-08-01 16:00:23,759 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler 'dispatcher'
2017-08-01 16:00:26,024 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler 'dispatcher'
2017-08-01 16:00:26,024 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler 'dispatcher'
2017-08-01 16:00:26,134 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler 'dispatcher'
2017-08-01 16:00:26,134 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler 'dispatcher'
2017-08-01 16:00:26,165 DEBUG [org.geoserver.geofence] - Not limiting styles
2017-08-01 16:00:26,243 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wps] onto handler 'dispatcher'
2017-08-01 16:00:26,243 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/wps/*] onto handler 'dispatcher'
2017-08-01 16:00:26,368 INFO [org.geoserver.ows.OWSHandlerMapping] - Mapped URL path [/temp/**] onto handler 'filePublisher'
2017-08-01 16:00:26,368 INFO [org.geoserver.wps] - Blacklisting process geonode:BatchDownload as the input LAYERS of type class org.geonode.process.batchdownload.LayerReference cannot be handled
2017-08-01 16:00:26,368 INFO [org.geoserver.wps] - Blacklisting process geonode:BatchDownload as the input map of type class org.geonode.process.batchdownload.MapMetadata cannot be handled
2017-08-01 16:00:26,368 INFO [org.geoserver.wps] - Blacklisting process geonode:BatchDownload as the output ZippedFile of type interface org.geonode.process.storage.Resource cannot be handled
2017-08-01 16:00:26,368 INFO [org.geoserver.wps] - Found 0 bindable processes in Batch Downloader
2017-08-01 16:00:26,446 INFO [org.geoserver.wps] - Found 30 bindable processes in Vector processes
2017-08-01 16:00:26,446 INFO [org.geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the input zones of type class java.lang.Object cannot be handled
2017-08-01 16:00:26,446 INFO [org.geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the input nodata of type class it.geosolutions.jaiext.range.Range cannot be handled
2017-08-01 16:00:26,446 INFO [org.geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the input rangeData of type class java.lang.Object cannot be handled
2017-08-01 16:00:26,446 INFO [org.geoserver.wps] - Blacklisting process ras:RasterZonalStatistics2 as the output zonal statistics of type interface java.util.List cannot be handled
2017-08-01 16:00:26,446 INFO [org.geoserver.wps] - Found 16 bindable processes in Raster processes
2017-08-01 16:00:26,446 INFO [org.geoserver.wps] - Found 5 bindable processes in GeoServer specific processes
2017-08-01 16:00:26,462 INFO [org.geoserver.wps] - Found 48 bindable processes in Geometry processes
2017-08-01 16:00:26,477 INFO [org.geoserver.wps] - Found 89 bindable processes in Deprecated processes
2017-08-01 16:00:26,790 INFO [org.geoserver.importer] - Enabling import store: memory
2017-08-01 16:00:26,790 WARN [org.geoserver.security] - security/masterpw.info is a security risk. Please read this file and remove it afterward
2017-08-01 16:00:27,071 INFO [org.geoserver.security] - Start reloading user/groups for service named default
2017-08-01 16:00:27,071 INFO [org.geoserver.security] - Reloading user/groups successful for service named default
2017-08-01 16:00:27,102 WARN [org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider] - INIT FROM CONFIG
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - Line 1: /rest/process/batchdownload/download/*:GET=IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /rest/process/batchdownload/download/*:GET firstColonIndex= 38
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /rest/process/batchdownload/download/*:GET antPath= /rest/process/batchdownload/download/* methods= GET
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - methodList = [GET]
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /rest/process/batchdownload/download/*; attributes: [IS_AUTHENTICATED_ANONYMOUSLY], httpMethods: [GET]
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - Line 1: /rest/printing/*:GET,POST=IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /rest/printing/*:GET,POST firstColonIndex= 16
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /rest/printing/*:GET,POST antPath= /rest/printing/* methods= GET,POST
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - methodList = [GET, POST]
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /rest/printing/*; attributes: [IS_AUTHENTICATED_ANONYMOUSLY], httpMethods: [GET, POST]
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - Line 1: /**:GET=IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:GET firstColonIndex= 3
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:GET antPath= /** methods= GET
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [IS_AUTHENTICATED_ANONYMOUSLY], httpMethods: [GET]
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - Line 1: /**:POST,DELETE,PUT=ROLE_ADMINISTRATOR
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:POST,DELETE,PUT firstColonIndex= 3
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - ~~~~~~~~~~ name= /**:POST,DELETE,PUT antPath= /** methods= POST,DELETE,PUT
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulDefinitionSource] - methodList = [POST, DELETE, PUT]
2017-08-01 16:00:27,196 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Added Ant path: /**; attributes: [ROLE_ADMINISTRATOR], httpMethods: [POST, DELETE, PUT]
2017-08-01 16:00:27,212 INFO [org.geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
2017-08-01 16:00:27,212 INFO [org.geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
2017-08-01 16:00:27,212 DEBUG [org.geoserver.security] - AuthenticationCache removing all entries
2017-08-01 16:00:27,212 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 16:00:27,212 DEBUG [org.geoserver.security] - AuthenticationCache removed all entries
2017-08-01 16:00:27,759 WARN [org.mapfish.print.servlet.BaseMapServlet] - Cannot delete file:C:\GeoNode-2.6.x\apache-tomcat-7.0.65\work\Catalina\localhost\geoserver\wicket-filestore
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/web/**'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:00:27,993 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null with /rest/**
2017-08-01 16:00:28,009 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:28,040 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Did not send remember-me cookie (principal did not set parameter '_spring_security_remember_me')
2017-08-01 16:00:28,040 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Remember-me login not requested.
2017-08-01 16:00:28,040 DEBUG [org.geoserver.security] - AuthenticationCache adding new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:28,040 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 16:00:28,040 DEBUG [org.geoserver.security] - AuthenticationCache added new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:28,040 DEBUG [org.geoserver.security] - Cache entries #: 1
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-pressions-qualitatives_38.xml'; to: '/rest/layergroups/les-pressions-qualitatives_38.xml'  and httpMethod= GET
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:00:28,134 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:28,149 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-pressions-qualitatives_38.xml]
2017-08-01 16:00:28,196 DEBUG [org.geoserver] - Thread 56 locking in mode READ
2017-08-01 16:00:28,196 DEBUG [org.geoserver] - Thread 56 got the lock in mode READ
2017-08-01 16:00:28,227 DEBUG [org.geoserver] - Thread 56 locking in mode READ
2017-08-01 16:00:28,227 DEBUG [org.geoserver] - Thread 56 releasing the lock in mode READ
2017-08-01 16:00:28,227 ERROR [org.geoserver.rest] - No such layer group les-pressions-qualitatives_38
2017-08-01 16:00:28,227 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
org.geoserver.rest.RestletException
	at org.geoserver.catalog.rest.LayerGroupFinder.findTarget(LayerGroupFinder.java:49)
	at org.restlet.Finder.handle(Finder.java:268)
	at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
	at org.restlet.Filter.doHandle(Filter.java:105)
	at org.restlet.Filter.handle(Filter.java:134)
	at org.restlet.Router.handle(Router.java:444)
	at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
	at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
	at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:213)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/web/**'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null with /rest/**
2017-08-01 16:00:28,243 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-pressions-qualitatives_38.xml'; to: '/rest/layergroups/les-pressions-qualitatives_38.xml'  and httpMethod= GET
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:00:28,259 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:28,259 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-pressions-qualitatives_38.xml]
2017-08-01 16:00:28,274 DEBUG [org.geoserver] - Thread 61 locking in mode READ
2017-08-01 16:00:28,274 DEBUG [org.geoserver] - Thread 61 got the lock in mode READ
2017-08-01 16:00:28,274 DEBUG [org.geoserver] - Thread 61 releasing the lock in mode READ
2017-08-01 16:00:28,274 ERROR [org.geoserver.rest] - No such layer group les-pressions-qualitatives_38
2017-08-01 16:00:28,274 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/web/**'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null with /rest/**
2017-08-01 16:00:28,274 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-pressions-qualitatives_38.xml'; to: '/rest/layergroups/les-pressions-qualitatives_38.xml'  and httpMethod= GET
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:00:28,290 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:28,290 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-pressions-qualitatives_38.xml]
2017-08-01 16:00:28,305 DEBUG [org.geoserver] - Thread 62 locking in mode READ
2017-08-01 16:00:28,305 DEBUG [org.geoserver] - Thread 62 got the lock in mode READ
2017-08-01 16:00:28,305 DEBUG [org.geoserver] - Thread 62 releasing the lock in mode READ
2017-08-01 16:00:28,305 ERROR [org.geoserver.rest] - No such layer group les-pressions-qualitatives_38
2017-08-01 16:00:28,305 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 16:00:28,305 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:36,371 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f9ea44bf] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f4e5efab]]
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/web/**'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/rest/**'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/**'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/**'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:00:46,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /pdf/info.json, QueryString: null with /**
2017-08-01 16:00:46,065 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:46,065 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:46,065 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:00:46,065 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/pdf/info.json]
2017-08-01 16:00:46,331 WARN [org.ho.yaml.CustomBeanWrapper] - MetaData: unknown field 'footer' with value '{items=[org.mapfish.print.config.layout.ColumnsBlock at b6c92d], height=30}'
2017-08-01 16:00:46,347 WARN [org.ho.yaml.CustomBeanWrapper] - MainPage: Error while writing '{items=[org.mapfish.print.config.layout.ColumnsBlock at b6c92d], height=30}' to footer: java.lang.IllegalArgumentException: argument type mismatch
2017-08-01 16:00:46,362 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/web/**'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/gwc/rest/web/**'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_security_check'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_security_check/'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_security_logout'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_security_logout/'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/rest/**'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/gwc/rest/**'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l'; against '/**'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:00:47,269 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l with /**
2017-08-01 16:00:47,284 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:47,284 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:47,284 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:00:47,284 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/ows]
2017-08-01 16:00:47,284 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/ows] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:00:47,300 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:00:47,300 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: No such operation wms 1.3.0 GetCapabilities?access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l
	at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:639)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:258)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
2017-08-01 16:00:47,300 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/web/**'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/web/**'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check/'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout/'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/rest/**'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/**'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/**'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:00:55,755 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer with /**
2017-08-01 16:00:55,991 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:00:55,991 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:55,991 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:56,053 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:00:56,477 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:00:56,524 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:00:56,524 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:00:56,524 INFO [org.geoserver.wms] -
2017-08-01 16:00:56,555 DEBUG [org.geoserver.geofence] - Getting access limits for Layer STEU
2017-08-01 16:00:56,555 DEBUG [org.geoserver.geofence] - Getting access limits for Resource STEU
2017-08-01 16:00:56,555 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:STEU
2017-08-01 16:00:56,555 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[STEU]
2017-08-01 16:00:56,555 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:00:56,555 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:00:56,555 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:00:56,555 INFO [org.geoserver.wms] -
Request: describeLayer
	Layers = [org.geoserver.wms.MapLayerInfo at dd4ae9b9]
	OutputFormat = application/vnd.ogc.wms_xml
	GetMapRequest = null
	ExeptionFormat = application/vnd.ogc.se_xml
	Version = 1.1.1
	Request = DescribeLayer
	Get = false
	BaseUrl = http://localhost:80/geoserver/
	RawKvp = {REQUEST=DescribeLayer, ACCESS_TOKEN=DpruYgZACfBII27s9S8qrsqbTIHiyY, VERSION=1.1.1, SERVICE=WMS, LAYERS=Gapeau:STEU}
	RequestCharset = null
2017-08-01 16:00:56,680 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 16:00:58,571 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-zones-inondables_26.xml'; to: '/rest/layergroups/les-zones-inondables_26.xml'  and httpMethod= GET
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:58,586 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-zones-inondables_26.xml]
2017-08-01 16:00:58,586 DEBUG [org.geoserver] - Thread 55 locking in mode READ
2017-08-01 16:00:58,586 DEBUG [org.geoserver] - Thread 55 got the lock in mode READ
2017-08-01 16:00:58,586 DEBUG [org.geoserver] - Thread 55 releasing the lock in mode READ
2017-08-01 16:00:58,586 ERROR [org.geoserver.rest] - No such layer group les-zones-inondables_26
2017-08-01 16:00:58,586 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 16:00:58,586 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-zones-inondables_26.xml'; to: '/rest/layergroups/les-zones-inondables_26.xml'  and httpMethod= GET
2017-08-01 16:00:58,602 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:00:58,617 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:58,617 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:00:58,617 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:58,617 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:00:58,617 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:00:58,617 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:58,617 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-zones-inondables_26.xml]
2017-08-01 16:00:58,617 DEBUG [org.geoserver] - Thread 56 locking in mode READ
2017-08-01 16:00:58,617 DEBUG [org.geoserver] - Thread 56 got the lock in mode READ
2017-08-01 16:00:58,617 DEBUG [org.geoserver] - Thread 56 releasing the lock in mode READ
2017-08-01 16:00:58,617 ERROR [org.geoserver.rest] - No such layer group les-zones-inondables_26
2017-08-01 16:00:58,617 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 16:00:58,617 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 16:00:58,633 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-zones-inondables_26.xml'; to: '/rest/layergroups/les-zones-inondables_26.xml'  and httpMethod= GET
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:00:58,649 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-zones-inondables_26.xml]
2017-08-01 16:00:58,649 DEBUG [org.geoserver] - Thread 61 locking in mode READ
2017-08-01 16:00:58,649 DEBUG [org.geoserver] - Thread 61 got the lock in mode READ
2017-08-01 16:00:58,649 DEBUG [org.geoserver] - Thread 61 releasing the lock in mode READ
2017-08-01 16:00:58,649 ERROR [org.geoserver.rest] - No such layer group les-zones-inondables_26
2017-08-01 16:00:58,649 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 16:00:58,649 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/web/**'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/rest/**'
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/styles, QueryString: null with /rest/**
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/styles'; to: '/rest/styles'  and httpMethod= PUT
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=false
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=false
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=false
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:00:58,805 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ROLE_ADMINISTRATOR
2017-08-01 16:00:58,821 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/styles]
2017-08-01 16:00:58,821 DEBUG [org.geoserver] - Thread 63 locking in mode WRITE
2017-08-01 16:00:58,821 DEBUG [org.geoserver] - Thread 63 got the lock in mode WRITE
2017-08-01 16:00:58,821 DEBUG [org.geoserver] - Thread 63 releasing the lock in mode WRITE
2017-08-01 16:00:58,836 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:00:59,635 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:00:59,643 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:00:59,775 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:00:59,775 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:59,775 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:00:59,775 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:00:59,779 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:00:59,779 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:00:59,779 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:00:59,779 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:00:59,823 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:00:59,891 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:00:59,947 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:00:59,947 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:00:59,951 INFO [org.geoserver.wms] -
2017-08-01 16:00:59,963 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:00:59,963 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:00:59,963 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:00:59,963 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:00:59,963 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:00:59,963 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:00:59,967 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:00:59,979 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:00:59,979 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:00:59,979 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:00:59,979 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:00:59,979 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:00:59,979 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:00:59,979 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:00,159 DEBUG [org.geoserver.ows] - establishing Reseau_hydrographique_SAGE style for Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:00,159 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:00,191 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:00,191 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:00,191 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	Layers = [org.geoserver.wms.MapLayerInfo at cb36b54c]
	MaxFeatures = null
	FeatureVersion = null
	SRS = EPSG:900913
	Tiled = true
	Styles = [StyleImpl[ name=Reseau_hydrographique_SAGE, DEFAULT]]
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	RemoteOwsType = null
	SldBody = null
	Crs = PROJCS["WGS84 / Google Mercator",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
    AXIS["Latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Mercator_1SP"],
  PARAMETER["semi_minor", 6378137.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["central_meridian", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","900913"]]
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	BgColor = java.awt.Color[r=255,g=255,b=255]
	ValidateSchema = false
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Reseau_hydrographique_lim_SAGE, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
	RequestCharset = UTF-8
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Reseau_hydrographique_lim_SAGE, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:00,195 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:00,195 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,199 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,279 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:00,279 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:00,279 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:00,279 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:00,283 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:00,283 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:00,283 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:00,331 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:00,391 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:00,451 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:00,451 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:00,451 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:00,455 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:00,455 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:00,455 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:00,455 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:00,455 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:00,455 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:00,455 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:00,455 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:00,455 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:00,455 INFO [org.geoserver.wms] -
2017-08-01 16:01:00,479 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:00,479 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:00,483 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:00,483 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:00,483 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	Layers = [org.geoserver.wms.MapLayerInfo at 7eb47a7b]
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Styles = [StyleImpl[ name=zones_inondables_PACA, DEFAULT]]
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5283327.3943359 : 5322463.1528125]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	BaseUrl = http://localhost:80/geoserver/
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:00,483 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:00,487 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,491 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,553 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:00,553 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:00,553 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:00,553 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:00,600 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:00,616 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,647 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:00,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,694 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:00,866 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,882 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:00,882 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:00,882 INFO [org.geoserver.wms] -
2017-08-01 16:01:00,882 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:00,882 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:00,882 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:00,882 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:00,882 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:00,882 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:00,882 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:00,882 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:00,882 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:00,882 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:00,882 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	FeatureVersion = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	RemoteOwsType = null
	SldBody = null
	Crs = PROJCS["WGS84 / Google Mercator",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
    AXIS["Latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Mercator_1SP"],
  PARAMETER["semi_minor", 6378137.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["central_meridian", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","900913"]]
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	BgColor = java.awt.Color[r=255,g=255,b=255]
	ValidateSchema = false
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
	RequestCharset = UTF-8
2017-08-01 16:01:00,882 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:00,882 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:00,897 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:00,928 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:00,928 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:00,928 INFO [org.geoserver.wms] -
2017-08-01 16:01:00,928 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:00,928 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:00,928 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:00,928 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:00,928 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:00,928 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:00,928 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:00,928 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:00,928 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:00,928 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:00,928 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:00,928 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:00,928 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:00,928 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:00,928 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:00,928 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:00,928 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:00,944 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:00,960 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:00,991 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,007 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,007 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,007 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,007 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,007 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,022 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,053 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,053 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,053 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,053 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,053 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,069 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,069 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,100 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,100 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,116 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,116 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,116 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:01,116 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:01,116 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:01,116 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,116 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:01,116 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,116 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,116 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,116 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,116 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,116 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,116 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	Layers = [org.geoserver.wms.MapLayerInfo at 7eb47a7b]
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Styles = [StyleImpl[ name=zones_inondables_PACA, DEFAULT]]
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	BaseUrl = http://localhost:80/geoserver/
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,132 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,132 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,132 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,147 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,163 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,163 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,163 INFO [org.geoserver.wms] -
2017-08-01 16:01:01,163 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:01,163 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:01,163 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:01,163 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:01,163 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,163 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,178 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,178 DEBUG [org.geoserver.ows] - establishing Reseau_hydrographique_SAGE style for Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:01,178 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,178 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,178 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:01,178 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	Layers = [org.geoserver.wms.MapLayerInfo at cb36b54c]
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Styles = [StyleImpl[ name=Reseau_hydrographique_SAGE, DEFAULT]]
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Reseau_hydrographique_lim_SAGE, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,178 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,178 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,194 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,194 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,194 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,210 INFO [org.geoserver.wms] -
2017-08-01 16:01:01,210 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:01,210 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:01,210 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,210 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:01,210 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,210 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,210 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,210 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,210 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,210 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,210 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,210 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,210 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,210 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,225 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,241 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,241 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,241 INFO [org.geoserver.wms] -
2017-08-01 16:01:01,241 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:01,241 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:01,241 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,241 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:01,241 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,241 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,241 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,241 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,241 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,241 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,241 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:01,257 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5283327.3943359 : 5322463.1528125]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,257 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,257 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,257 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,257 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,257 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,257 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,288 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,288 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,288 INFO [org.geoserver.wms] -
2017-08-01 16:01:01,288 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:01,288 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:01,288 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,288 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:01,288 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,288 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,288 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,288 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,288 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,288 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,288 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,288 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,288 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,288 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,288 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	FeatureVersion = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	RemoteOwsType = null
	SldBody = null
	Crs = PROJCS["WGS84 / Google Mercator",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
    AXIS["Latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Mercator_1SP"],
  PARAMETER["semi_minor", 6378137.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["central_meridian", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","900913"]]
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5283327.3943359 : 5322463.1528125]
	Env = {}
	Angle = 0.0
	Sld = null
	BgColor = java.awt.Color[r=255,g=255,b=255]
	ValidateSchema = false
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
	RequestCharset = UTF-8
2017-08-01 16:01:01,288 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,288 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,319 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,319 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,319 INFO [org.geoserver.wms] -
2017-08-01 16:01:01,319 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:01,319 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:01,319 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,319 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:01,319 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,319 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,319 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,319 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:01,319 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,319 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,319 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:zones_inondables_PACA, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,319 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,319 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,335 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,350 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,366 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,366 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,366 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,366 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,382 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,382 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,382 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,382 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,382 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,413 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,428 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,428 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,428 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,428 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,428 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,444 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,460 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,475 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,507 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,522 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,522 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,522 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:01,522 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:01,522 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:01,522 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:01,522 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:01,522 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,522 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,522 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,553 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,553 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:01,553 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,553 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,553 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:01,553 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	Layers = [org.geoserver.wms.MapLayerInfo at 612aff33]
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Styles = [StyleImpl[ name=Zones_Expansion_Crue, DEFAULT]]
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	BaseUrl = http://localhost:80/geoserver/
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Zones_Expansion_Crue, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,553 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,553 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,553 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,553 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,553 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:01,553 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:01,553 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:01,553 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:01,553 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,553 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,553 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,569 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,569 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:01,569 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Zones_Expansion_Crue, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,569 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,569 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,600 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,616 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,632 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,632 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,647 INFO [org.geoserver.wms] -
2017-08-01 16:01:01,647 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:01,647 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:01,647 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:01,647 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:01,647 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,647 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,647 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,647 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:01,647 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,647 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,647 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Zones_Expansion_Crue, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,647 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,647 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,647 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,647 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,663 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,663 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:01,663 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Zones_Expansion_Crue, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,663 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Zones_Expansion_Crue, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,663 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,678 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,710 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,710 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,710 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,710 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,725 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,725 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,725 INFO [org.geoserver.wms] -
2017-08-01 16:01:01,725 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:01,725 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:01,725 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:01,725 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:01,725 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,725 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,725 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,725 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:01,725 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,725 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,725 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	FeatureVersion = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	RemoteOwsType = null
	SldBody = null
	Crs = PROJCS["WGS84 / Google Mercator",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
    AXIS["Latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Mercator_1SP"],
  PARAMETER["semi_minor", 6378137.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["central_meridian", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","900913"]]
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	BgColor = java.awt.Color[r=255,g=255,b=255]
	ValidateSchema = false
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:Zones_Expansion_Crue, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
	RequestCharset = UTF-8
2017-08-01 16:01:01,725 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,725 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,741 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,772 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,772 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,772 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,772 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,803 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,835 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,850 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:01,850 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:01,850 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:01,850 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:01,866 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,913 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,928 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:01,928 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:01,928 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:01,928 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:01,928 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:01,928 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:01,928 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:01,928 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:01,928 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:01,928 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:01,944 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:01,960 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:01,960 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:01,960 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:01,960 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:01,960 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	Layers = [org.geoserver.wms.MapLayerInfo at 3184d8fa]
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Styles = [StyleImpl[ name=commune_contour_sage, DEFAULT]]
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	BaseUrl = http://localhost:80/geoserver/
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:01,960 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:01,960 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:01,960 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:01,975 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:01,991 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:02,038 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:02,038 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,038 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,038 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,038 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:02,038 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:02,038 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:02,038 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:02,038 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,038 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,038 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:02,038 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:02,038 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:02,038 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:02,038 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:02,038 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:02,038 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:02,053 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:02,069 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:02,178 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:02,085 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:02,272 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,272 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:02,303 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,303 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:02,303 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:02,303 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:02,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:02,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:02,303 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:02,303 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,303 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,303 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:02,303 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:02,303 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:02,303 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:02,303 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,303 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,303 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:02,303 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:02,303 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:02,303 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:02,303 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5283327.3943359 : 5322463.1528125]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:02,319 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,366 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,366 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,366 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,366 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:02,366 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:02,366 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:02,366 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5283327.3943359 : 5322463.1528125]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:02,366 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:02,366 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:02,366 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,366 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,366 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:02,366 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:02,366 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:02,366 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:02,366 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[665307.89410156 : 704443.65257813, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/web/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/rest/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /pdf/info.json, QueryString: null with /**
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/web/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/web/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/rest/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/**'
2017-08-01 16:01:02,382 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer with /**
2017-08-01 16:01:02,397 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,397 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,397 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,397 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:02,397 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:02,397 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:02,397 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:02,397 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,397 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,397 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:02,397 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:02,397 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:02,397 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:02,397 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:02,397 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[704443.65257813 : 743579.41105469, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:02,397 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:02,397 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:02,413 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:02,413 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:02,413 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:02,413 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:01:02,413 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/pdf/info.json]
2017-08-01 16:01:02,413 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:02,428 WARN [org.ho.yaml.CustomBeanWrapper] - MetaData: unknown field 'footer' with value '{items=[org.mapfish.print.config.layout.ColumnsBlock at 1612ff2], height=30}'
2017-08-01 16:01:02,428 WARN [org.ho.yaml.CustomBeanWrapper] - MainPage: Error while writing '{items=[org.mapfish.print.config.layout.ColumnsBlock at 1612ff2], height=30}' to footer: java.lang.IllegalArgumentException: argument type mismatch
2017-08-01 16:01:02,428 DEBUG [org.geoserver.filters] - Compressing output for mimetype: application/json;charset=utf-8
2017-08-01 16:01:02,428 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:02,460 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:02,460 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:02,475 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:02,475 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:02,475 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:02,475 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:02,522 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:02,522 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,522 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,522 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,522 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:02,522 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:02,522 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:02,522 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:02,522 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:02,522 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,522 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,522 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:02,522 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:02,522 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:02,522 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:02,522 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	FeatureVersion = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	RemoteOwsType = null
	SldBody = null
	Crs = PROJCS["WGS84 / Google Mercator",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
    AXIS["Latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Mercator_1SP"],
  PARAMETER["semi_minor", 6378137.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["central_meridian", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","900913"]]
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5322463.1528125 : 5361598.9112891]
	Env = {}
	Angle = 0.0
	Sld = null
	BgColor = java.awt.Color[r=255,g=255,b=255]
	ValidateSchema = false
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
	RequestCharset = UTF-8
2017-08-01 16:01:02,522 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:02,522 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:02,538 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:02,569 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,569 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,569 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,569 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:02,569 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:02,569 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:02,585 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:02,585 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,585 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,585 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:02,585 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:02,585 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:02,585 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:02,585 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
2017-08-01 16:01:02,585 INFO [org.geoserver.wms] -
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5283327.3943359 : 5322463.1528125]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:02,585 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:02,585 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:02,585 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:02,600 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:02,632 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,632 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,632 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,632 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:02,632 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:02,632 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:02,632 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:02,632 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,632 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,632 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:02,632 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:02,632 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:02,632 DEBUG [org.geoserver.gwc.wms] - No matching ETag, returning cached tile
2017-08-01 16:01:02,632 DEBUG [org.geoserver.gwc.wms] - Using cacheAgeMax {0}
Request: getMap
	Time = []
	Filter = null
	Format = image/png
	Buffer = 0
	Filters = null
	Height = 256
	Width = 256
	MaxFeatures = null
	SRS = EPSG:900913
	Tiled = true
	Palette = null
	FeatureId = null
	Elevation = []
	StartIndex = null
	FormatOptions = {}
	ViewParams = null
	CQLFilter = null
	RemoteOwsURL = null
	SldBody = null
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
	Bbox = SRSEnvelope[626172.135625 : 665307.89410156, 5361598.9112891 : 5400734.6697656]
	Env = {}
	Angle = 0.0
	Sld = null
	Interpolations = []
	Transparent = true
	StyleFormat = sld
	StyleUrl = null
	TilesOrigin = null
	Exceptions = SE_XML
	StyleBody = null
	SldVersion = null
	StyleVersion = null
	ScaleMethod = null
	Version = 1.1.1
	Request = GetMap
	Get = true
	RawKvp = {FORMAT=image/png, STYLES=, WIDTH=256, HEIGHT=256, LAYERS=Gapeau:commune_contour_sage, TILED=true, REQUEST=GetMap, SRS=EPSG:900913, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=TRUE}
2017-08-01 16:01:02,632 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:01:02,632 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:02,647 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:02,647 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:02,647 INFO [org.geoserver.wms] -
2017-08-01 16:01:02,647 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:02,647 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:02,647 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:02,647 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:02,647 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:02,647 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:02,647 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
Request: describeLayer
	Layers = [org.geoserver.wms.MapLayerInfo at cb36b54c]
	OutputFormat = application/vnd.ogc.wms_xml
	GetMapRequest = null
	ExeptionFormat = application/vnd.ogc.se_xml
	Version = 1.1.1
	Request = DescribeLayer
	Get = false
	RawKvp = {REQUEST=DescribeLayer, ACCESS_TOKEN=YtMVqcqQsTE4UbM158TjjgbuXyjC7l, VERSION=1.1.1, SERVICE=WMS, LAYERS=Gapeau:Reseau_hydrographique_lim_SAGE}
	RequestCharset = null
2017-08-01 16:01:02,663 DEBUG [org.geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.wms_xml
2017-08-01 16:01:02,663 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/web/**'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/rest/**'
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/styles, QueryString: null with /rest/**
2017-08-01 16:01:03,725 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/styles'; to: '/rest/styles'  and httpMethod= PUT
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=false
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=false
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=false
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ROLE_ADMINISTRATOR
2017-08-01 16:01:03,741 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/styles]
2017-08-01 16:01:03,741 DEBUG [org.geoserver] - Thread 64 locking in mode WRITE
2017-08-01 16:01:03,741 DEBUG [org.geoserver] - Thread 64 got the lock in mode WRITE
2017-08-01 16:01:03,741 DEBUG [org.geoserver] - Thread 64 releasing the lock in mode WRITE
2017-08-01 16:01:03,741 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:04,649 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:04,653 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AReseau_hydrographique_lim_SAGE&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:04,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:04,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:04,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:04,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:04,665 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:04,665 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:04,665 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:04,741 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:04,745 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:04,977 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:04,981 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:04,985 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,029 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,037 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,073 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,109 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,113 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,141 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,149 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,149 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,149 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:05,149 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,149 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,149 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,149 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:05,149 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,149 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,149 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,149 DEBUG [org.geoserver.ows] - establishing Reseau_hydrographique_SAGE style for Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,149 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,153 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,153 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,153 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,153 DEBUG [org.geoserver.ows] -
org.geoserver.ows.HttpErrorCodeException
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:119)
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy142.getMap(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:850)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:01:05,153 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,153 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,153 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,153 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,153 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,153 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:05,153 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,153 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,153 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,153 DEBUG [org.geoserver.ows] - establishing Reseau_hydrographique_SAGE style for Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,153 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,161 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,161 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,161 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,165 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,213 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,213 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,213 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,213 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,213 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,213 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,213 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:05,213 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,213 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,213 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,217 DEBUG [org.geoserver.ows] - establishing Reseau_hydrographique_SAGE style for Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:05,217 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,217 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,217 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,221 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,253 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,253 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,253 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,253 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,253 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,253 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,253 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,253 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,253 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,253 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,253 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,253 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,253 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,257 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,269 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,269 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,269 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,269 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,269 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,269 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,269 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,269 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,269 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,269 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,269 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,269 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,273 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,273 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:05,273 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,277 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,277 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,277 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,277 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,277 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,277 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,277 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,281 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,281 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,281 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,281 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,281 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,281 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,281 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,281 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,281 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Azones_inondables_PACA&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,285 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,341 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,393 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,405 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,413 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,425 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,433 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,473 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,505 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,509 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,517 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,525 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,525 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,525 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:05,525 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,525 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,525 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,525 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,525 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,525 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,525 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,525 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,525 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,529 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,529 DEBUG [org.geoserver.ows] -
org.geoserver.ows.HttpErrorCodeException
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:119)
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy142.getMap(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:850)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:01:05,529 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,533 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,537 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,605 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,605 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,605 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,605 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,605 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,605 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,605 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,605 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,605 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,605 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,605 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,605 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,613 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,613 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:05,617 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,617 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,621 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,625 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,625 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,625 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,625 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,625 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,625 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,625 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,625 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,625 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,625 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,625 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,625 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,629 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,629 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:05,629 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,633 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,633 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,633 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,633 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,637 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,637 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,637 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,637 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,637 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,637 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,637 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,637 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,637 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,637 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,637 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,641 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,649 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,649 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,649 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,649 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,649 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,649 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,649 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,649 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,649 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,649 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,653 DEBUG [org.geoserver.ows] - establishing zones_inondables_PACA style for Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,653 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,653 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,653 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,653 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,653 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,653 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,653 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:05,653 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:05,653 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:05,653 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:05,653 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,653 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,653 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,657 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,657 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3AZones_Expansion_Crue&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,661 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,697 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,701 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,717 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,748 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,763 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,795 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,795 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,795 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:05,810 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:05,810 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:05,810 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,810 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:05,810 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,810 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,810 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,810 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,810 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,810 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
org.geoserver.ows.HttpErrorCodeException
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:119)
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy142.getMap(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:850)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:01:05,810 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,810 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5322463.1528125,704443.65257813,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,826 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,842 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,857 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,873 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,888 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:05,904 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,904 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,904 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,904 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:05,904 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:05,904 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,904 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:05,904 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,904 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,904 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,904 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,904 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,904 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,904 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,904 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5322463.1528125,743579.41105469,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,920 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,920 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,920 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,920 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,920 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:05,920 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:05,920 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,920 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:05,920 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,920 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,920 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,935 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,935 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,935 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,935 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5283327.3943359,704443.65257813,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,951 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,951 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,951 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,951 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,951 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:05,951 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:05,951 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,951 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:05,951 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,951 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,951 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,951 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,951 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,967 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,967 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5283327.3943359,743579.41105469,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,967 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,982 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,982 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,982 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,982 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:05,982 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:05,982 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,982 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:05,982 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,982 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,982 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,982 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,982 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:05,982 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:05,982 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:05,982 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=665307.89410156,5361598.9112891,704443.65257813,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:05,998 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:05,998 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:05,998 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:05,998 INFO [org.geoserver.wms] -
2017-08-01 16:01:05,998 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:05,998 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:05,998 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,998 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:05,998 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:05,998 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:05,998 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:05,998 DEBUG [org.geoserver.ows] - establishing Zones_Expansion_Crue style for Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:05,998 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,013 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,013 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:06,013 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,013 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=704443.65257813,5361598.9112891,743579.41105469,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:06,029 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,045 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,060 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:06,060 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:06,060 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:06,060 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,060 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,060 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,060 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,060 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,060 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,060 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,060 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,060 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,076 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,076 DEBUG [org.geoserver.ows] -
org.geoserver.ows.HttpErrorCodeException
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:119)
	at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy142.getMap(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:850)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:01:06,076 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:06,076 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5322463.1528125,665307.89410156,5361598.9112891&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:06,092 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:06,123 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:06,138 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,451 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:06,467 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:06,467 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:06,467 INFO [org.geoserver.wms] -
2017-08-01 16:01:06,467 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,467 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,467 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,467 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,467 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,467 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,467 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,467 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,467 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,467 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:06,467 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,467 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/web/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/web/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_check/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_security_logout/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/rest/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/gwc/rest/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256'; against '/**'
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5283327.3943359,665307.89410156,5322463.1528125&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&LAYERS=Gapeau%3Acommune_contour_sage&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&TILED=true&SRS=EPSG%3A900913&BBOX=626172.135625,5361598.9112891,665307.89410156,5400734.6697656&WIDTH=256&HEIGHT=256 with /**
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:06,482 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,513 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:06,529 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,545 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:06,545 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:06,545 INFO [org.geoserver.wms] -
2017-08-01 16:01:06,545 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,545 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,545 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,545 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,545 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,545 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,545 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,545 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,545 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,560 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,560 DEBUG [org.geoserver.ows] -
2017-08-01 16:01:06,560 INFO [org.geoserver.wms] -
2017-08-01 16:01:06,560 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:06,560 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,560 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,560 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,560 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,560 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,560 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,560 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,560 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,560 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,560 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:06,576 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:06,576 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:06,576 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:06,576 INFO [org.geoserver.wms] -
2017-08-01 16:01:06,576 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,576 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,576 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,576 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,576 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,576 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,576 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,576 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,576 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,576 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,592 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:06,607 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:06,623 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:06,623 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:06,623 INFO [org.geoserver.wms] -
2017-08-01 16:01:06,623 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,623 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,623 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,623 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,623 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,623 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,623 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,623 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,623 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,623 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,623 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:06,623 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:06,654 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:06,654 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:06,654 INFO [org.geoserver.wms] -
2017-08-01 16:01:06,654 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,654 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,654 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,654 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,654 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,654 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,654 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,654 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,654 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,654 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,654 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:06,670 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:06,670 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:06,670 INFO [org.geoserver.wms] -
2017-08-01 16:01:06,670 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:06,670 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:06,670 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:06,670 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:06,670 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:06,670 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:06,670 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
2017-08-01 16:01:06,670 DEBUG [org.geoserver.ows] - establishing commune_contour_sage style for Gapeau:commune_contour_sage
2017-08-01 16:01:06,670 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:06,670 DEBUG [org.geoserver.gwc.wms] - ETag matches, returning 304
2017-08-01 16:01:06,685 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/web/**'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/web/**'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check/'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout/'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/rest/**'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/**'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/**'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:commune_contour_sage&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969 with /**
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:07,592 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/web/**'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/web/**'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check/'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout/'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/rest/**'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/**'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/**'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:PPRI&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969 with /**
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:07,607 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/web/**'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/web/**'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check/'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout/'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/rest/**'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/**'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/**'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Zones_Expansion_Crue&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969 with /**
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:07,623 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:01:07,623 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:07,623 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:07,623 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontAntiAliasing'. Storing as raw string.
2017-08-01 16:01:07,623 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontSize'. Storing as raw string.
2017-08-01 16:01:07,623 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontName'. Storing as raw string.
2017-08-01 16:01:07,623 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence] - Getting access limits for Layer commune_contour_sage
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence] - Setting user for filter:
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence] - ResourceInfo filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"commune_contour_sage"+]
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence.cache] - Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"commune_contour_sage"+]
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"commune_contour_sage"+]
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:07,623 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:07,638 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:07,638 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:07,638 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontAntiAliasing'. Storing as raw string.
2017-08-01 16:01:07,638 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontSize'. Storing as raw string.
2017-08-01 16:01:07,638 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontName'. Storing as raw string.
2017-08-01 16:01:07,638 INFO [org.geoserver.wms] -
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence] - Getting access limits for Layer PPRI
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PPRI
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence] - Setting user for filter:
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence] - ResourceInfo filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"PPRI"+]
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence.cache] - Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"PPRI"+]
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"PPRI"+]
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:07,638 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/web/**'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/web/**'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check/'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout/'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/rest/**'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/**'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/**'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Bassin_versants_limite&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969 with /**
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:07,654 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:07,670 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:01:07,670 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:07,670 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:07,670 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontAntiAliasing'. Storing as raw string.
2017-08-01 16:01:07,670 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontSize'. Storing as raw string.
2017-08-01 16:01:07,670 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontName'. Storing as raw string.
2017-08-01 16:01:07,670 INFO [org.geoserver.wms] -
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Zones_Expansion_Crue
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence] - Setting user for filter:
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence] - ResourceInfo filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Zones_Expansion_Crue"+]
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence.cache] - Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Zones_Expansion_Crue"+]
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Zones_Expansion_Crue"+]
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:07,670 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/web/**'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/web/**'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check/'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout/'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/rest/**'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/**'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/**'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:zones_inondables_PACA&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969 with /**
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:07,685 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,701 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/web/**'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/web/**'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check/'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout/'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/rest/**'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/**'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/**'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Reseau_hydrographique_lim_SAGE&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969 with /**
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:07,717 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:01:07,717 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:07,717 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:07,717 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontAntiAliasing'. Storing as raw string.
2017-08-01 16:01:07,717 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontSize'. Storing as raw string.
2017-08-01 16:01:07,717 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontName'. Storing as raw string.
2017-08-01 16:01:07,717 INFO [org.geoserver.wms] -
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Bassin_versants_limite
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Bassin_versants_limite
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence] - Setting user for filter:
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence] - ResourceInfo filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Bassin_versants_limite"+]
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence.cache] - Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Bassin_versants_limite"+]
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Bassin_versants_limite"+]
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:07,717 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:07,748 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:01:07,748 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:07,748 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:07,748 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontAntiAliasing'. Storing as raw string.
2017-08-01 16:01:07,748 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontSize'. Storing as raw string.
2017-08-01 16:01:07,748 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontName'. Storing as raw string.
2017-08-01 16:01:07,748 INFO [org.geoserver.wms] -
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence] - Getting access limits for Layer zones_inondables_PACA
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence] - Setting user for filter:
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence] - ResourceInfo filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"zones_inondables_PACA"+]
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence.cache] - Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"zones_inondables_PACA"+]
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"zones_inondables_PACA"+]
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:07,748 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:07,763 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:01:07,779 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:07,779 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontAntiAliasing'. Storing as raw string.
2017-08-01 16:01:07,779 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontSize'. Storing as raw string.
2017-08-01 16:01:07,779 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontName'. Storing as raw string.
2017-08-01 16:01:07,779 INFO [org.geoserver.wms] -
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence] - Setting user for filter:
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence] - ResourceInfo filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Reseau_hydrographique_lim_SAGE"+]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.cache] - Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Reseau_hydrographique_lim_SAGE"+]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Reseau_hydrographique_lim_SAGE"+]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.internal] - RoleService [geonode REST role service] matching for User []
2017-08-01 16:01:07,779 DEBUG [org.geoserver.geofence.internal] - Matching Roles [[]] for User []
2017-08-01 16:01:07,795 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,795 DEBUG [org.geoserver.geofence.internal] - RoleService [geonode REST role service] matching for User []
2017-08-01 16:01:07,795 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,795 DEBUG [org.geoserver.geofence.internal] - Matching Roles [[]] for User []
2017-08-01 16:01:07,810 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,857 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,857 DEBUG [org.geoserver.geofence.internal] - RoleService [geonode REST role service] matching for User []
2017-08-01 16:01:07,857 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,857 DEBUG [org.geoserver.geofence.internal] - Matching Roles [[]] for User []
2017-08-01 16:01:07,873 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,873 DEBUG [org.geoserver.geofence.internal] - RoleService [geonode REST role service] matching for User []
2017-08-01 16:01:07,873 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,873 DEBUG [org.geoserver.geofence.internal] - Matching Roles [[]] for User []
2017-08-01 16:01:07,920 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:07,920 DEBUG [org.geoserver.geofence.internal] - RoleService [geonode REST role service] matching for User []
2017-08-01 16:01:07,920 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:07,920 DEBUG [org.geoserver.geofence.internal] - Matching Roles [[]] for User []
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Bassin_versants_limite]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning VectorAccessLimits [readAttributes=null, writeAttributes=null, writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer Gapeau:Reseau_hydrographique_lim_SAGE and user
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning VectorAccessLimits [readAttributes=null, writeAttributes=null, writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer Gapeau:commune_contour_sage and user
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning VectorAccessLimits [readAttributes=null, writeAttributes=null, writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer Gapeau:Bassin_versants_limite and user
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Getting admin auth for Workspace Gapeau
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - AdminAuth filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:ANY req:ANY ws:"Gapeau"+ layer:ANY]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning VectorAccessLimits [readAttributes=null, writeAttributes=null, writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer Gapeau:zones_inondables_PACA and user
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence.cache] - AdminAuth Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:ANY req:ANY ws:"Gapeau"+ layer:ANY]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:ANY req:ANY ws:"Gapeau"+ layer:ANY]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PPRI]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning VectorAccessLimits [readAttributes=null, writeAttributes=null, writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer Gapeau:PPRI and user
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence] - Returning VectorAccessLimits [readAttributes=null, writeAttributes=null, writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer Gapeau:Zones_Expansion_Crue and user
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:08,154 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/web/**'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/web/**'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_check/'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_security_logout/'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/rest/**'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/gwc/rest/**'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969'; against '/**'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: request=GetLegendGraphic&width=20&height=20&layer=Gapeau:Ortho2012_WGS84&access_token=X1nk6rEhiR5gvC3IUz6G0FekN8lhHH&transparent=true&format=image%2Fpng&legend_options=fontAntiAliasing%3Atrue%3BfontSize%3A11%3BfontName%3AArial&SCALE=545977.6814319969 with /**
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:01:08,217 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:08,248 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:01:08,248 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:01:08,248 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:08,263 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontAntiAliasing'. Storing as raw string.
2017-08-01 16:01:08,263 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontSize'. Storing as raw string.
2017-08-01 16:01:08,263 DEBUG [org.geoserver.ows] - Could not find kvp parser for: 'fontName'. Storing as raw string.
2017-08-01 16:01:08,263 INFO [org.geoserver.wms] -
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence] - Getting access limits for Layer Ortho2012_WGS84
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Ortho2012_WGS84
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence] - Setting user for filter:
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence] - ResourceInfo filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Ortho2012_WGS84"+]
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.cache] - Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Ortho2012_WGS84"+]
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.cache] - Loading RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:"WMS"+ req:"GETLEGENDGRAPHIC"+ ws:"Gapeau"+ layer:"Ortho2012_WGS84"+]
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.internal] - Getting Roles for User []
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [default]
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.internal] - Checking RoleService [geonode REST role service]
2017-08-01 16:01:08,263 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.internal] - RoleService [geonode REST role service] matching for User []
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence.internal] - Matching Roles [[]] for User []
2017-08-01 16:01:08,263 DEBUG [org.geoserver.geofence] - Admin auth for User: Workspace:Gapeau: false
2017-08-01 16:01:08,263 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Can't obtain the schema for the required layer.
	at org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReader.read(GetLegendGraphicKvpReader.java:181)
	at org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReader.read(GetLegendGraphicKvpReader.java:75)
	at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1498)
	at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:673)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:258)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
Caused by: org.geoserver.platform.ServiceException: Gapeau:commune_contour_sage layer does not exist.
	at org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReader.read(GetLegendGraphicKvpReader.java:172)
	... 98 more
Caused by: org.geoserver.platform.ServiceException: Gapeau:PPRI layer does not exist.
	... 98 more
Caused by: org.geoserver.platform.ServiceException: Gapeau:Zones_Expansion_Crue layer does not exist.
	... 98 more
Caused by: org.geoserver.platform.ServiceException: Gapeau:zones_inondables_PACA layer does not exist.
	... 98 more
Caused by: org.geoserver.platform.ServiceException: Gapeau:Reseau_hydrographique_lim_SAGE layer does not exist.
	... 98 more
2017-08-01 16:01:08,279 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2017-08-01 16:01:08,279 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
Caused by: org.geoserver.platform.ServiceException: Gapeau:Bassin_versants_limite layer does not exist.
	... 98 more
2017-08-01 16:01:08,373 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:08,420 DEBUG [org.geoserver.security] - Setting ROLES for User [] to [ROLE_ANONYMOUS]
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence.internal] - RoleService [geonode REST role service] matching for User []
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence.internal] - Checking UserGroupService [default]
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence.internal] - Matching Roles [[]] for User []
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource CoverageInfoImpl[Ortho2012_WGS84]
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence] - Returning CoverageAccessLimits [params=null, rasterFilter=null, readFilter=Filter.EXCLUDE, mode=HIDE] for layer Gapeau:Ortho2012_WGS84 and user
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence] - Getting admin auth for Workspace Gapeau
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence] - AdminAuth filter: RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:ANY req:ANY ws:"Gapeau"+ layer:ANY]
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence.cache] - AdminAuth Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs ip:"127.0.0.1"+ serv:ANY req:ANY ws:"Gapeau"+ layer:ANY]
2017-08-01 16:01:08,420 DEBUG [org.geoserver.geofence] - Admin auth for User: Workspace:Gapeau: false
2017-08-01 16:01:08,420 ERROR [org.geoserver.ows] -
Caused by: org.geoserver.platform.ServiceException: Gapeau:Ortho2012_WGS84 layer does not exist.
	... 98 more
2017-08-01 16:01:08,420 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2017-08-01 16:01:08,420 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/web/**'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/gwc/rest/web/**'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_security_check'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_security_check/'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_security_logout'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_security_logout/'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/rest/**'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/gwc/rest/**'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE'; against '/**'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:08,451 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=Gapeau%3AReseau_hydrographique_lim_SAGE with /**
2017-08-01 16:01:08,498 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:08,498 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:08,498 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:08,498 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:08,529 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:08,576 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:08,623 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wfs]
2017-08-01 16:01:08,623 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wfs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:08,623 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:08,623 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:08,623 INFO [org.geoserver.wfs] -
Request: getServiceInfo
2017-08-01 16:01:08,842 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:08,842 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:08,842 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:08,842 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:08,842 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:08,842 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:08,842 INFO [org.geoserver.wfs] -
Request: describeFeatureType
    service = WFS
    version = 1.1.0
    baseUrl = http://localhost:8080/geoserver/
    typeName[0] = {http://www.gapeau.org/}Reseau_hydrographique_lim_SAGE
    outputFormat = text/xml; subtype=gml/3.1.1
2017-08-01 16:01:09,295 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/web/**'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/gwc/rest/web/**'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_check'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_check/'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_logout'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_logout/'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/rest/**'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/gwc/rest/**'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/**'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:10,398 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l& with /**
2017-08-01 16:01:10,444 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:10,444 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:10,444 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:10,444 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:10,476 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:10,523 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:10,569 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wfs]
2017-08-01 16:01:10,569 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wfs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:10,585 DEBUG [org.vfny.geoserver.requests] - First 4 bytes of XML doc are : 3C ('<') 77 ('w') 66 ('f') 73 ('s')
2017-08-01 16:01:10,585 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 1. Inferred encoding: UTF-8
2017-08-01 16:01:10,585 DEBUG [org.vfny.geoserver.requests] - Invalid(?) XML declaration: <wfs:G.
2017-08-01 16:01:10,585 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 2. Charset in XML declaration is `null`.
2017-08-01 16:01:10,585 DEBUG [org.vfny.geoserver.requests] - Trying to create reader basing on existing charset information: `UTF-8`.
2017-08-01 16:01:10,585 DEBUG [org.geoserver.ows] - Raw XML request: <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" version="1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd" service="WFS" resultType="hits"><wfs:Query typeName="feature:Reseau_hydrographique_lim_SAGE" srsName="EPSG:900913" /></wfs:GetFeature>
2017-08-01 16:01:10,585 INFO [org.geoserver.wfs] -
2017-08-01 16:01:11,508 INFO [org.geoserver.wfs.xml] - Identified addresses and hostnames for local interfaces: 127.0.0.1 127.0.0.1, 0:0:0:0:0:0:0:1 0:0:0:0:0:0:0:1, 10.1.33.31 GEONODE.brl.intra, fe80:0:0:0:4049:e574:f301:47d2%eth4 GEONODE.brl.intra, fe80:0:0:0:0:5efe:a01:211f%net5 fe80:0:0:0:0:5efe:a01:211f%net5
2017-08-01 16:01:11,508 INFO [org.geoserver.wfs.xml] - Additional aliases for local host: localhost
2017-08-01 16:01:11,773 DEBUG [org.geoserver.geofence] - Getting access limits for Resource flore_invasives
2017-08-01 16:01:11,773 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:flore_invasives
2017-08-01 16:01:11,773 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[flore_invasives]
2017-08-01 16:01:11,773 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,773 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Alluvions_Gapeau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Alluvions_Gapeau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Alluvions_Gapeau]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource arrete_protection_biotope
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:arrete_protection_biotope
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[arrete_protection_biotope]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Baignade_Bilan
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Baignade_Bilan
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Baignade_Bilan]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Bassin_versants_limite
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Bassin_versants_limite
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Bassin_versants_limite]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Biocenose
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Biocenose
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Biocenose]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Captages_AEP_AERMC
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Captages_AEP_AERMC
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Captages_AEP_AERMC]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource centre_equestre
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:centre_equestre
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[centre_equestre]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource commune_contour_sage
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:commune_contour_sage
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[commune_contour_sage]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Corridor
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Corridor
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Corridor]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Decharge_Bilan
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Decharge_Bilan
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Decharge_Bilan]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource ENS
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:ENS
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[ENS]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource ICPE
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:ICPE
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[ICPE]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Intercommunalites
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Intercommunalites
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Intercommunalites]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Masse_eau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Masse_eau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Masse_eau]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource masse_eau_souterraine_carmen_bv
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:masse_eau_souterraine_carmen_bv
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[masse_eau_souterraine_carmen_bv]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource navettes
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:navettes
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[navettes]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Ouvrage_SCP
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Ouvrage_SCP
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Ouvrage_SCP]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Plages
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Plages
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Plages]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource pnr_sainte_baume
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:pnr_sainte_baume
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[pnr_sainte_baume]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PN_CT_CM
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:PN_CT_CM
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PN_CT_CM]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PN_V2
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:PN_V2
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PN_V2]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource port_plaisance
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:port_plaisance
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[port_plaisance]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource PPRI
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:PPRI
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[PPRI]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Ramsar
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Ramsar
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Ramsar]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_SCP
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_SCP
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_SCP]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource reservoir_biologique
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:reservoir_biologique
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[reservoir_biologique]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource sites_plongees
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:sites_plongees
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[sites_plongees]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource SRCE_Cours_eau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:SRCE_Cours_eau
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[SRCE_Cours_eau]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource STEU
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:STEU
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[STEU]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource troncon_hydro_sage
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:troncon_hydro_sage
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[troncon_hydro_sage]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Veg_rase
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Veg_rase
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Veg_rase]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_agri
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_agri
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_agri]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_boisee
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_boisee
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_boisee]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_Expansion_Crue
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_Expansion_Crue
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_Expansion_Crue]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_humides
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_humides
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_humides]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zones_inondables_PACA
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zones_inondables_PACA
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zones_inondables_PACA]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zones_urb
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zones_urb
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zones_urb]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Zone_mouillage
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Zone_mouillage
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Zone_mouillage]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource zone_strategique
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:zone_strategique
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[zone_strategique]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource ZPS_N2000
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:ZPS_N2000
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[ZPS_N2000]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource ZSC_N2000
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:ZSC_N2000
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[ZSC_N2000]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource san_andres_y_providencia_administrative
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:san_andres_y_providencia_administrative
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[san_andres_y_providencia_administrative]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource san_andres_y_providencia_coastline
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:san_andres_y_providencia_coastline
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[san_andres_y_providencia_coastline]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource san_andres_y_providencia_highway
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:san_andres_y_providencia_highway
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[san_andres_y_providencia_highway]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource san_andres_y_providencia_location
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:san_andres_y_providencia_location
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[san_andres_y_providencia_location]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource san_andres_y_providencia_natural
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:san_andres_y_providencia_natural
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[san_andres_y_providencia_natural]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource san_andres_y_providencia_poi
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:san_andres_y_providencia_poi
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[san_andres_y_providencia_poi]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource san_andres_y_providencia_water
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:san_andres_y_providencia_water
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[san_andres_y_providencia_water]
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Getting access limits for Resource single_point
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer geonode:single_point
2017-08-01 16:01:11,789 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[single_point]
2017-08-01 16:01:11,820 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,820 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,852 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,852 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,883 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,883 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,898 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,898 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,930 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,930 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,945 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,945 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:11,977 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:11,977 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,008 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,008 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,023 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,023 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,055 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,055 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,070 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,070 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,086 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,086 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,117 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,117 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,148 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,148 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,164 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,164 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,195 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,195 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,211 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,211 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,227 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,227 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,242 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,242 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,273 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,273 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,289 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,289 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,320 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,320 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,352 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,352 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,367 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,367 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,398 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,398 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,414 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,414 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,523 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,523 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,555 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,555 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,586 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,586 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,602 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,602 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,633 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,633 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,648 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,648 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,680 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,680 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,695 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,695 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,711 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,711 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,727 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,727 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,742 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,742 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,773 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,773 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,789 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:12,789 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:12,820 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,820 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:12,852 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,852 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:12,898 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,898 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:12,914 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,914 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:12,930 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,930 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:12,945 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,945 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:12,961 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,961 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:12,977 DEBUG [org.geoserver.geofence] - Getting access limits for workspace geonode
2017-08-01 16:01:12,977 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace geonode
2017-08-01 16:01:13,039 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:13,070 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:13,070 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:13,070 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:13,070 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:13,070 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:13,117 DEBUG [org.vfny.geoserver.requests] - Query is org.geoserver.wfs.request.Query$WFS11 at e37dbc
 To gt2: Query:
   feature type: Reseau_hydrographique_lim_SAGE
   filter: Filter.INCLUDE
   [properties:  ALL ]
2017-08-01 16:01:13,148 INFO [org.geoserver.wfs] -
Request: getFeature
    service = WFS
    version = 1.1.0
    query[0]:
        srsName = EPSG:900913
        typeName[0] = Reseau_hydrographique_lim_SAGE
    resultType = hits
2017-08-01 16:01:13,180 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/web/**'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/gwc/rest/web/**'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_check'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_check/'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_logout'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_security_logout/'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/rest/**'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/gwc/rest/**'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l&'; against '/**'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:01:14,246 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wfs, QueryString: access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l& with /**
2017-08-01 16:01:14,324 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:01:14,324 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:01:14,324 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:01:14,324 DEBUG [org.geoserver.security] - Found GeoNode cookie: ilpfb31r5gomsrfgilxi6nknzqriya3v
2017-08-01 16:01:14,371 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:01:14,434 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:01:14,481 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wfs]
2017-08-01 16:01:14,481 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wfs] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:01:14,481 DEBUG [org.vfny.geoserver.requests] - First 4 bytes of XML doc are : 3C ('<') 77 ('w') 66 ('f') 73 ('s')
2017-08-01 16:01:14,481 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 1. Inferred encoding: UTF-8
2017-08-01 16:01:14,481 DEBUG [org.vfny.geoserver.requests] - Invalid(?) XML declaration: <wfs:G.
2017-08-01 16:01:14,481 DEBUG [org.vfny.geoserver.requests] - Charset detection phase 2. Charset in XML declaration is `null`.
2017-08-01 16:01:14,481 DEBUG [org.vfny.geoserver.requests] - Trying to create reader basing on existing charset information: `UTF-8`.
2017-08-01 16:01:14,481 DEBUG [org.geoserver.ows] - Raw XML request: <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" version="1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd" service="WFS" maxFeatures="50"><wfs:Query typeName="feature:Reseau_hydrographique_lim_SAGE" srsName="EPSG:900913" /></wfs:GetFeature>
2017-08-01 16:01:14,481 INFO [org.geoserver.wfs] -
2017-08-01 16:01:14,497 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
2017-08-01 16:01:14,497 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:14,497 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:14,497 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:14,497 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:14,497 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:14,497 DEBUG [org.vfny.geoserver.requests] - Query is org.geoserver.wfs.request.Query$WFS11 at 1a1e45f
 To gt2: Query:
   [properties:  ALL ]
2017-08-01 16:01:14,591 INFO [org.geoserver.wfs] -
Request: getFeature
    service = WFS
    version = 1.1.0
    query[0]:
    maxFeatures = 50
    resultType = results
2017-08-01 16:01:14,591 DEBUG [org.geoserver.geofence] - Getting access limits for Resource Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:14,591 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:Reseau_hydrographique_lim_SAGE
2017-08-01 16:01:14,591 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[Reseau_hydrographique_lim_SAGE]
2017-08-01 16:01:14,591 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:01:14,591 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:01:14,591 DEBUG [org.geoserver.wfs] - Unable to find user-defined schema location for: . Using a built schema location by default: http://localhost:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=Gapeau%3AReseau_hydrographique_lim_SAGE&access_token=YtMVqcqQsTE4UbM158TjjgbuXyjC7l
2017-08-01 16:01:14,700 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:01:36,385 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at fe052ef9] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f900d9e5]]
2017-08-01 16:02:36,397 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2161f55] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at fd11ca41]]
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/web/**'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/gwc/rest/web/**'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/j_spring_security_check'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/j_spring_security_check/'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/j_spring_security_logout'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/j_spring_security_logout/'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /j_spring_oauth2_geonode_logout, QueryString: access_token=DpruYgZACfBII27s9S8qrsqbTIHiyY with /j_spring_oauth2_geonode_logout
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: null'; against '/web/**'
2017-08-01 16:02:46,828 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2017-08-01 16:02:46,828 DEBUG [org.geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
java.lang.Exception: Full stack trace for the session creation path
	at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:92)
	at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:70)
	at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:238)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:50)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:02:46,844 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:02:46,844 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:02:46,844 DEBUG [org.geoserver.security] - Found GeoNode cookie: cz4e02scb7jcuiijhc48mtaf7dcosr00
2017-08-01 16:02:46,844 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:02:46,844 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 16:02:47,516 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/web/**'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/gwc/rest/web/**'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_security_check'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_security_check/'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_security_logout'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_security_logout/'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/rest/**'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/gwc/rest/**'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW'; against '/**'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:03:18,016 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /ows, QueryString: service=wms&version=1.3.0&request=GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW with /**
2017-08-01 16:03:18,031 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:03:18,031 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:03:18,031 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:03:18,031 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/ows]
2017-08-01 16:03:18,031 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/ows] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:03:18,031 INFO [org.geoserver.wms] -
2017-08-01 16:03:18,031 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: No such operation wms 1.3.0 GetCapabilities?access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW
	at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:639)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:258)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
2017-08-01 16:03:18,031 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:03:36,404 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 62dde98] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1298984]]
2017-08-01 16:04:36,428 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at a48adf0] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 54458dc]]
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/web/**'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null with /rest/**
2017-08-01 16:05:12,705 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-pressions-qualitatives_38.xml'; to: '/rest/layergroups/les-pressions-qualitatives_38.xml'  and httpMethod= GET
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:05:12,721 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-pressions-qualitatives_38.xml]
2017-08-01 16:05:12,721 DEBUG [org.geoserver] - Thread 266 locking in mode READ
2017-08-01 16:05:12,721 DEBUG [org.geoserver] - Thread 266 got the lock in mode READ
2017-08-01 16:05:12,721 DEBUG [org.geoserver] - Thread 266 releasing the lock in mode READ
2017-08-01 16:05:12,721 ERROR [org.geoserver.rest] - No such layer group les-pressions-qualitatives_38
2017-08-01 16:05:12,721 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
org.geoserver.rest.RestletException
	at org.geoserver.catalog.rest.LayerGroupFinder.findTarget(LayerGroupFinder.java:49)
	at org.restlet.Finder.handle(Finder.java:268)
	at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
	at org.restlet.Filter.doHandle(Filter.java:105)
	at org.restlet.Filter.handle(Filter.java:134)
	at org.restlet.Router.handle(Router.java:444)
	at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
	at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
	at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:213)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
2017-08-01 16:05:12,721 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/web/**'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null with /rest/**
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-pressions-qualitatives_38.xml'; to: '/rest/layergroups/les-pressions-qualitatives_38.xml'  and httpMethod= GET
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:05:12,736 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:05:12,752 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-pressions-qualitatives_38.xml]
2017-08-01 16:05:12,752 DEBUG [org.geoserver] - Thread 56 locking in mode READ
2017-08-01 16:05:12,752 DEBUG [org.geoserver] - Thread 56 got the lock in mode READ
2017-08-01 16:05:12,752 DEBUG [org.geoserver] - Thread 56 releasing the lock in mode READ
2017-08-01 16:05:12,752 ERROR [org.geoserver.rest] - No such layer group les-pressions-qualitatives_38
2017-08-01 16:05:12,752 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/web/**'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-pressions-qualitatives_38.xml, QueryString: null with /rest/**
2017-08-01 16:05:12,752 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-pressions-qualitatives_38.xml'; to: '/rest/layergroups/les-pressions-qualitatives_38.xml'  and httpMethod= GET
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-pressions-qualitatives_38.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:05:12,768 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:05:12,768 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-pressions-qualitatives_38.xml]
2017-08-01 16:05:12,768 DEBUG [org.geoserver] - Thread 61 locking in mode READ
2017-08-01 16:05:12,768 DEBUG [org.geoserver] - Thread 61 got the lock in mode READ
2017-08-01 16:05:12,768 DEBUG [org.geoserver] - Thread 61 releasing the lock in mode READ
2017-08-01 16:05:12,768 ERROR [org.geoserver.rest] - No such layer group les-pressions-qualitatives_38
2017-08-01 16:05:12,768 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
2017-08-01 16:05:12,783 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/web/**'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/rest/**'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/gwc/rest/**'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /pdf/info.json, QueryString: null'; against '/**'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:05:15,283 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /pdf/info.json, QueryString: null with /**
2017-08-01 16:05:15,299 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:05:15,299 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:05:15,299 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:05:15,299 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/pdf/info.json]
2017-08-01 16:05:15,299 WARN [org.ho.yaml.CustomBeanWrapper] - MetaData: unknown field 'footer' with value '{items=[org.mapfish.print.config.layout.ColumnsBlock at 1578091], height=30}'
2017-08-01 16:05:15,315 WARN [org.ho.yaml.CustomBeanWrapper] - MainPage: Error while writing '{items=[org.mapfish.print.config.layout.ColumnsBlock at 1578091], height=30}' to footer: java.lang.IllegalArgumentException: argument type mismatch
2017-08-01 16:05:15,315 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/web/**'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/web/**'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_check/'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_security_logout/'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/rest/**'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/gwc/rest/**'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer'; against '/**'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Request matched by universal pattern '/**'
2017-08-01 16:05:15,408 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /wms, QueryString: access_token=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW&LAYERS=Gapeau%3ASTEU&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer with /**
2017-08-01 16:05:15,455 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for geonode-oauth2, admin
2017-08-01 16:05:15,455 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:05:15,455 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:05:15,486 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = admin, trying to authenticate
2017-08-01 16:05:15,549 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:05:15,596 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/wms]
2017-08-01 16:05:15,596 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher at 58002f] and 1 interceptor
2017-08-01 16:05:15,596 INFO [org.geoserver.wms] -
Request: getServiceInfo
2017-08-01 16:05:15,596 DEBUG [org.geoserver.geofence] - Getting access limits for Layer STEU
2017-08-01 16:05:15,596 DEBUG [org.geoserver.geofence] - Getting access limits for Resource STEU
2017-08-01 16:05:15,596 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for layer Gapeau:STEU
2017-08-01 16:05:15,596 DEBUG [org.geoserver.geofence] - Returning mode HIDE for resource FeatureTypeInfoImpl[STEU]
2017-08-01 16:05:15,596 DEBUG [org.geoserver.geofence] - Getting access limits for workspace Gapeau
2017-08-01 16:05:15,596 DEBUG [org.geoserver.geofence] - Admin level access, returning full rights for workspace Gapeau
2017-08-01 16:05:15,596 DEBUG [org.geoserver.geofence] - Admin level access, not applying default style for this request
Request: describeLayer
	Layers = [org.geoserver.wms.MapLayerInfo at dd4ae9b9]
	OutputFormat = application/vnd.ogc.wms_xml
	GetMapRequest = null
	ExeptionFormat = application/vnd.ogc.se_xml
	Version = 1.1.1
	Request = DescribeLayer
	Get = false
	BaseUrl = http://localhost:80/geoserver/
	RawKvp = {REQUEST=DescribeLayer, ACCESS_TOKEN=Z3mdYSub09otgNi6Yn9vqQvFoyiEOW, VERSION=1.1.1, SERVICE=WMS, LAYERS=Gapeau:STEU}
	RequestCharset = null
2017-08-01 16:05:15,596 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/web/**'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/styles, QueryString: null'; against '/rest/**'
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/styles, QueryString: null with /rest/**
2017-08-01 16:05:17,940 DEBUG [org.geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/styles'; to: '/rest/styles'  and httpMethod= PUT
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=false
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=false
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=false
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [POST, DELETE, PUT]
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/styles'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ROLE_ADMINISTRATOR
2017-08-01 16:05:17,955 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/styles]
2017-08-01 16:05:17,955 DEBUG [org.geoserver] - Thread 55 locking in mode WRITE
2017-08-01 16:05:17,955 DEBUG [org.geoserver] - Thread 55 got the lock in mode WRITE
2017-08-01 16:05:17,955 DEBUG [org.geoserver] - Thread 55 releasing the lock in mode WRITE
2017-08-01 16:05:17,955 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:05:36,435 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at e6bb29f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 9675d8b]]
2017-08-01 16:06:36,445 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1287cd85] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at d837871]]
2017-08-01 16:07:36,441 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 16990591] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1194b07d]]
2017-08-01 16:08:36,432 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1ab10c84] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 15acb770]]
2017-08-01 16:08:44,665 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: null'; against '/web/**'
2017-08-01 16:08:44,665 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: null with /web/**
2017-08-01 16:08:44,665 DEBUG [org.geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
2017-08-01 16:08:44,728 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:44,728 DEBUG [org.geoserver.security] - Found 2 cookies!
2017-08-01 16:08:44,728 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:44,728 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:44,728 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:08:44,743 DEBUG [org.geoserver] - Thread 266 locking in mode WRITE
2017-08-01 16:08:44,743 DEBUG [org.geoserver] - Thread 266 got the lock in mode WRITE
2017-08-01 16:08:44,790 DEBUG [org.geoserver] - Thread 266 locking in mode WRITE
2017-08-01 16:08:44,790 DEBUG [org.geoserver] - Thread 266 releasing the lock in mode WRITE
2017-08-01 16:08:44,884 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:44,978 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.web.geoserverloginpage, QueryString: null'; against '/web/**'
2017-08-01 16:08:44,978 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.web.geoserverloginpage, QueryString: null with /web/**
2017-08-01 16:08:44,978 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:44,978 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:44,978 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:44,978 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:44,978 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.web.GeoServerLoginPage]
2017-08-01 16:08:44,978 DEBUG [org.geoserver] - Thread 56 locking in mode READ
2017-08-01 16:08:44,978 DEBUG [org.geoserver] - Thread 56 got the lock in mode READ
2017-08-01 16:08:45,009 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:08:45,009 DEBUG [org.geoserver] - Thread 56 locking in mode READ
2017-08-01 16:08:45,009 DEBUG [org.geoserver] - Thread 56 releasing the lock in mode READ
2017-08-01 16:08:45,009 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.apache.wicket.resource.jqueryresourcereference/jquery/jquery-1.11.3-ver-79582db38c40815251d3924e53495b3d.js, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.apache.wicket.resource.jqueryresourcereference/jquery/jquery-1.11.3-ver-79582db38c40815251d3924e53495b3d.js, QueryString: null with /web/**
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,228 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.apache.wicket.resource.JQueryResourceReference/jquery/jquery-1.11.3-ver-79582DB38C40815251D3924E53495B3D.js]
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/css/blueprint/screen-ver-5e7ba86a4c3bea6b457ac3c7f9adf9b4.css, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,228 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/css/blueprint/screen-ver-5e7ba86a4c3bea6b457ac3c7f9adf9b4.css, QueryString: null with /web/**
2017-08-01 16:08:45,228 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/css/blueprint/screen-ver-5E7BA86A4C3BEA6B457AC3C7F9ADF9B4.css]
2017-08-01 16:08:45,243 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/css
2017-08-01 16:08:45,243 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: application/javascript
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/css/geoserver-ver-3ddd7fba2ea4d6b1582f060cea17df0b.css, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/css/geoserver-ver-3ddd7fba2ea4d6b1582f060cea17df0b.css, QueryString: null with /web/**
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/js/jquery.placeholder-ver-6e6e735ff3a1792243c593d1e48d6ae1.js, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/js/jquery.placeholder-ver-6e6e735ff3a1792243c593d1e48d6ae1.js, QueryString: null with /web/**
2017-08-01 16:08:45,243 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/css/geoserver-ver-3DDD7FBA2EA4D6B1582F060CEA17DF0B.css]
2017-08-01 16:08:45,243 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/js/jquery.placeholder-ver-6E6E735FF3A1792243C593D1E48D6AE1.js]
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.demo.mappreviewpage/mappreview_keyshortcut-ver-53dba8b7b51005f654e624bee0441d3b.js, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,243 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.demo.mappreviewpage/mappreview_keyshortcut-ver-53dba8b7b51005f654e624bee0441d3b.js, QueryString: null with /web/**
2017-08-01 16:08:45,243 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut-ver-53DBA8B7B51005F654E624BEE0441D3B.js]
2017-08-01 16:08:45,259 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: application/javascript
2017-08-01 16:08:45,259 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,337 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.security.oauth2.geonodeoauth2authproviderpanel/geonode-ver-75cfc72f2527d8c938e65cc5e56692d2.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,337 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.security.oauth2.geonodeoauth2authproviderpanel/geonode-ver-75cfc72f2527d8c938e65cc5e56692d2.png, QueryString: null with /web/**
2017-08-01 16:08:45,337 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,337 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,337 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,337 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,337 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.security.oauth2.GeoNodeOAuth2AuthProviderPanel/geonode-ver-75CFC72F2527D8C938E65CC5E56692D2.png]
2017-08-01 16:08:45,337 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,337 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,353 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/door-in-ver-4871ea9656eebf15c2f83bf4e25b0ebb.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,353 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/door-in-ver-4871ea9656eebf15c2f83bf4e25b0ebb.png, QueryString: null with /web/**
2017-08-01 16:08:45,353 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,353 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,353 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,353 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,353 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/door-in-ver-4871EA9656EEBF15C2F83BF4E25B0EBB.png]
2017-08-01 16:08:45,353 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,353 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,399 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.aboutgeoserverpage/img/icons/silk/help-ver-c3812c74bc524179f4ccf5d2db7b3cbf.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,399 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.aboutgeoserverpage/img/icons/silk/help-ver-c3812c74bc524179f4ccf5d2db7b3cbf.png, QueryString: null with /web/**
2017-08-01 16:08:45,399 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,399 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,399 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,399 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,399 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help-ver-C3812C74BC524179F4CCF5D2DB7B3CBF.png]
2017-08-01 16:08:45,399 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,399 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,446 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.demo.mappreviewpage/::/img/icons/geosilk/map-ver-3085230ce03a9a93a074669e4c194432.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,446 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.demo.mappreviewpage/::/img/icons/geosilk/map-ver-3085230ce03a9a93a074669e4c194432.png, QueryString: null with /web/**
2017-08-01 16:08:45,462 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,462 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,462 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,462 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,462 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.demo.MapPreviewPage/::/img/icons/geosilk/map-ver-3085230CE03A9A93A074669E4C194432.png]
2017-08-01 16:08:45,462 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,462 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,524 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/ajax-loader-ver-a51c5608d01acf32df728f299767f82b.gif, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,524 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/ajax-loader-ver-a51c5608d01acf32df728f299767f82b.gif, QueryString: null with /web/**
2017-08-01 16:08:45,524 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,524 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,524 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,524 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,524 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/ajax-loader-ver-A51C5608D01ACF32DF728F299767F82B.gif]
2017-08-01 16:08:45,524 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/gif
2017-08-01 16:08:45,524 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,540 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/css/blueprint/print-ver-bbb913c92fdf844cbad576e7bb0b2a96.css, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,540 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/css/blueprint/print-ver-bbb913c92fdf844cbad576e7bb0b2a96.css, QueryString: null with /web/**
2017-08-01 16:08:45,540 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,540 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,540 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,540 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,540 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/css/blueprint/print-ver-BBB913C92FDF844CBAD576E7BB0B2A96.css]
2017-08-01 16:08:45,540 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/css
2017-08-01 16:08:45,540 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/logo.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/logo.png, QueryString: null with /web/**
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/button-gradient.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/button-gradient.png, QueryString: null with /web/**
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,556 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/logo.png]
2017-08-01 16:08:45,556 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2017-08-01 16:08:45,556 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,556 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/main-bg.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/main-wrap-bg.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/main-wrap-bg.png, QueryString: null with /web/**
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/main-bg.png, QueryString: null with /web/**
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,587 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/main-wrap-bg.png]
2017-08-01 16:08:45,587 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/main-bg.png]
2017-08-01 16:08:45,587 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,587 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/page-bg.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/page-bg.png, QueryString: null with /web/**
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security] - Found 3 cookies!
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security] - preAuthenticatedPrincipal = null, trying to authenticate
2017-08-01 16:08:45,603 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/page-bg.png]
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/page-header-bg.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/page-header-bg.png, QueryString: null with /web/**
2017-08-01 16:08:45,603 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,603 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:45,603 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/page-header-bg.png]
2017-08-01 16:08:45,618 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:45,618 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/web/**'
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/'
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /j_spring_security_check, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /j_spring_security_check, QueryString: null with /j_spring_security_check
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Request is to process authentication
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter$1] - Authentication success. Updating SecurityContextHolder to contain: org.springframework.security.authentication.UsernamePasswordAuthenticationToken at 6923b59a: Principal: Username: admin; Password: [PROTECTED]; Enabled: true; AccountNonExpired: true; CredentialsNonExpired: true; AccountNonLocked: true;  [ ADMIN,ROLE_ADMINISTRATOR ] ; Credentials: [PROTECTED]; Authenticated: true; Details: org.geoserver.security.filter.GeoServerWebAuthenticationDetails at ffff4c9c: RemoteIpAddress: 10.33.10.141; SessionId: DDCFCEB7F313FC2F157884EF144E621C; Granted Authorities: ADMIN, ROLE_ADMINISTRATOR, ROLE_AUTHENTICATED
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Added remember-me cookie for user 'admin at default', expiry: 'Tue Aug 15 16:08:57 GMT 2017'
2017-08-01 16:08:57,188 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:57,204 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web, QueryString: null'; against '/web/**'
2017-08-01 16:08:57,204 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web, QueryString: null with /web/**
2017-08-01 16:08:57,204 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:57,204 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:57,204 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:57,204 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web]
2017-08-01 16:08:57,204 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:57,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: null'; against '/web/**'
2017-08-01 16:08:57,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2017-08-01 16:08:57,219 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:57,219 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:57,219 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:57,219 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 16:08:57,344 DEBUG [org.geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
java.lang.Exception: Full stack trace for the session creation path
	at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:92)
	at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:229)
	at org.apache.wicket.session.HttpSessionStore.getHttpSession(HttpSessionStore.java:95)
	at org.apache.wicket.session.HttpSessionStore.getSessionId(HttpSessionStore.java:166)
	at org.apache.wicket.Session.bind(Session.java:267)
	at org.apache.wicket.Session.replaceSession(Session.java:519)
	at org.geoserver.web.GeoServerApplication.onApplicationEvent(GeoServerApplication.java:417)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:163)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:136)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:381)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:335)
	at org.springframework.security.authentication.DefaultAuthenticationEventPublisher.publishAuthenticationSuccess(DefaultAuthenticationEventPublisher.java:84)
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:213)
	at org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1492)
	at org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.<init>(SecurityHomePageContentProvider.java:105)
	at org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:47)
	at org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:129)
	at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
	at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
	at org.apache.wicket.Component.internalBeforeRender(Component.java:949)
	at org.apache.wicket.Component.beforeRender(Component.java:1017)
	at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1568)
	at org.apache.wicket.Component.onBeforeRender(Component.java:3877)
	at org.apache.wicket.Page.onBeforeRender(Page.java:801)
	at org.apache.wicket.Component.internalPrepareForRender(Component.java:2215)
	at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
	at org.apache.wicket.Component.render(Component.java:2304)
	at org.apache.wicket.Page.renderPage(Page.java:1018)
	at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
	at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
	at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
	at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
	at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
	at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:08:57,688 WARN [org.geoserver.security] - Strong cryptography is NOT available
Download and installation the of unlimted length policy files is recommended
2017-08-01 16:08:57,969 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:57,985 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: 2'; against '/web/**'
2017-08-01 16:08:57,985 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: 2 with /web/**
2017-08-01 16:08:58,001 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,001 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,001 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,001 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 16:08:58,001 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:08:58,001 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,094 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/door-out-ver-af08348c0718b2b414cf6c19d798234b.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,094 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/door-out-ver-af08348c0718b2b414cf6c19d798234b.png, QueryString: null with /web/**
2017-08-01 16:08:58,094 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,094 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,094 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,094 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/door-out-ver-AF08348C0718B2B414CF6C19D798234B.png]
2017-08-01 16:08:58,094 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,094 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,110 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.admin.statuspage/::/img/icons/silk/server_error-ver-102a2cf17440c6924efad1b6540701cb.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,110 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.admin.statuspage/::/img/icons/silk/server_error-ver-102a2cf17440c6924efad1b6540701cb.png, QueryString: null with /web/**
2017-08-01 16:08:58,110 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,110 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,110 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,110 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.admin.StatusPage/::/img/icons/silk/server_error-ver-102A2CF17440C6924EFAD1B6540701CB.png]
2017-08-01 16:08:58,110 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,110 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,157 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.admin.logpage/::/img/icons/silk/page_white_text-ver-0da66bdb013f9a9d12ce7219e642bc25.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,173 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.admin.logpage/::/img/icons/silk/page_white_text-ver-0da66bdb013f9a9d12ce7219e642bc25.png, QueryString: null with /web/**
2017-08-01 16:08:58,173 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,173 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,173 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,173 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.admin.LogPage/::/img/icons/silk/page_white_text-ver-0DA66BDB013F9A9D12CE7219E642BC25.png]
2017-08-01 16:08:58,173 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,173 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.wps.web.processstatuspage/::/::/web/img/icons/silk/cog-ver-30a18063ef42b090194a7e936086960f.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.admin.contactpage/::/img/icons/silk/vcard-ver-151823b90ad370105db8ffdbaaabf39f.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.admin.contactpage/::/img/icons/silk/vcard-ver-151823b90ad370105db8ffdbaaabf39f.png, QueryString: null with /web/**
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.wps.web.processstatuspage/::/::/web/img/icons/silk/cog-ver-30a18063ef42b090194a7e936086960f.png, QueryString: null with /web/**
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.importer.web.importdatapage/map_add-ver-3845cf673929eecc4739eae658e3f4c8.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.importer.web.importdatapage/map_add-ver-3845cf673929eecc4739eae658e3f4c8.png, QueryString: null with /web/**
2017-08-01 16:08:58,188 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.admin.ContactPage/::/img/icons/silk/vcard-ver-151823B90AD370105DB8FFDBAAABF39F.png]
2017-08-01 16:08:58,188 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.wps.web.ProcessStatusPage/::/::/web/img/icons/silk/cog-ver-30A18063EF42B090194A7E936086960F.png]
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.data.store.storepage/::/::/img/icons/silk/database-ver-d698a5e9a755a97b51e657256881bbde.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.data.store.storepage/::/::/img/icons/silk/database-ver-d698a5e9a755a97b51e657256881bbde.png, QueryString: null with /web/**
2017-08-01 16:08:58,188 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.importer.web.ImportDataPage/map_add-ver-3845CF673929EECC4739EAE658E3F4C8.png]
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.data.workspace.workspacepage/::/::/img/icons/silk/folder-ver-fbd3929a893b147ae0940d48d533e023.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,188 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,188 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.data.store.StorePage/::/::/img/icons/silk/database-ver-D698A5E9A755A97B51E657256881BBDE.png]
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,188 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.data.workspace.workspacepage/::/::/img/icons/silk/folder-ver-fbd3929a893b147ae0940d48d533e023.png, QueryString: null with /web/**
2017-08-01 16:08:58,188 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.data.workspace.WorkspacePage/::/::/img/icons/silk/folder-ver-FBD3929A893B147AE0940D48D533E023.png]
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.data.layer.layerpage/::/::/img/icons/silk/picture_empty-ver-7c42dae5239115350ca4f2557cf0f015.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.data.layer.layerpage/::/::/img/icons/silk/picture_empty-ver-7c42dae5239115350ca4f2557cf0f015.png, QueryString: null with /web/**
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.data.layergroup.layergrouppage/::/::/img/icons/silk/layers-ver-a13de972b638ec78f2a83894515ff4e7.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.data.layergroup.layergrouppage/::/::/img/icons/silk/layers-ver-a13de972b638ec78f2a83894515ff4e7.png, QueryString: null with /web/**
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.wms.web.data.stylepage/palette-ver-184b77b5020909bed079c417e8f6bb9f.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.wms.web.data.stylepage/palette-ver-184b77b5020909bed079c417e8f6bb9f.png, QueryString: null with /web/**
2017-08-01 16:08:58,219 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.data.layer.LayerPage/::/::/img/icons/silk/picture_empty-ver-7C42DAE5239115350CA4F2557CF0F015.png]
2017-08-01 16:08:58,219 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.data.layergroup.LayerGroupPage/::/::/img/icons/silk/layers-ver-A13DE972B638EC78F2A83894515FF4E7.png]
2017-08-01 16:08:58,219 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.wms.web.data.StylePage/palette-ver-184B77B5020909BED079C417E8F6BB9F.png]
2017-08-01 16:08:58,219 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,219 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.gwc.web.wmts.wmtsadminpage/server_tile_map-ver-23b59d4ee5eada27cd2bde0f7b292392.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.gwc.web.wmts.wmtsadminpage/server_tile_map-ver-23b59d4ee5eada27cd2bde0f7b292392.png, QueryString: null with /web/**
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,235 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.gwc.web.wmts.WMTSAdminPage/server_tile_map-ver-23B59D4EE5EADA27CD2BDE0F7B292392.png]
2017-08-01 16:08:58,235 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.security.web.auth.authenticationpage/::/img/icons/silk/shield-ver-807cdfb63d846a7e57f43cbdd59317ce.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.security.web.auth.authenticationpage/::/img/icons/silk/shield-ver-807cdfb63d846a7e57f43cbdd59317ce.png, QueryString: null with /web/**
2017-08-01 16:08:58,235 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,235 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.security.web.auth.AuthenticationPage/::/img/icons/silk/shield-ver-807CDFB63D846A7E57F43CBDD59317CE.png]
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.security.web.usergrouproleservicespage/img/icons/silk/group-ver-3afbbb77c13a366898f9088f7ae086a0.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.security.web.usergrouproleservicespage/img/icons/silk/group-ver-3afbbb77c13a366898f9088f7ae086a0.png, QueryString: null with /web/**
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.gwc.web.layer.cachedlayerspage/::/tilelayer-ver-a4e41e9a105008cea7f89e5529a5cc04.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.gwc.web.layer.cachedlayerspage/::/tilelayer-ver-a4e41e9a105008cea7f89e5529a5cc04.png, QueryString: null with /web/**
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.admin.coverageaccesspage/::/img/icons/silk/cog_photo-ver-717de401b9156ecac0dde3752f8c5095.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.admin.coverageaccesspage/::/img/icons/silk/cog_photo-ver-717de401b9156ecac0dde3752f8c5095.png, QueryString: null with /web/**
2017-08-01 16:08:58,266 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group-ver-3AFBBB77C13A366898F9088F7AE086A0.png]
2017-08-01 16:08:58,266 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.gwc.web.layer.CachedLayersPage/::/tilelayer-ver-A4E41E9A105008CEA7F89E5529A5CC04.png]
2017-08-01 16:08:58,266 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.admin.CoverageAccessPage/::/img/icons/silk/cog_photo-ver-717DE401B9156ECAC0DDE3752F8C5095.png]
2017-08-01 16:08:58,266 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,266 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.wms.web.wmsadminpage/server_map-ver-bd9f5588df2cad48a10c7d90bd6c9de7.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.wms.web.wmsadminpage/server_map-ver-bd9f5588df2cad48a10c7d90bd6c9de7.png, QueryString: null with /web/**
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.gwc.web.diskquota.diskquotasettingspage/::/diskquota-ver-952051985214488bb370ecd21db44c74.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.gwc.web.diskquota.diskquotasettingspage/::/diskquota-ver-952051985214488bb370ecd21db44c74.png, QueryString: null with /web/**
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,282 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.wms.web.WMSAdminPage/server_map-ver-BD9F5588DF2CAD48A10C7D90BD6C9DE7.png]
2017-08-01 16:08:58,282 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/::/diskquota-ver-952051985214488BB370ECD21DB44C74.png]
2017-08-01 16:08:58,282 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.wfs.web.wfsadminpage/server_vector-ver-abcfc9bdf3237f2799fed1b0e4679a21.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,282 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.wfs.web.wfsadminpage/server_vector-ver-abcfc9bdf3237f2799fed1b0e4679a21.png, QueryString: null with /web/**
2017-08-01 16:08:58,282 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.wfs.web.WFSAdminPage/server_vector-ver-ABCFC9BDF3237F2799FED1B0E4679A21.png]
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.admin.globalsettingspage/::/img/icons/silk/server-ver-b0b38dc2e3593f7363de77ed20fd7897.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.admin.globalsettingspage/::/img/icons/silk/server-ver-b0b38dc2e3593f7363de77ed20fd7897.png, QueryString: null with /web/**
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.backuprestore.web.backuprestoredatapage/database_save-ver-8303213a3c95654e14d5afd4e72ed4c2.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.backuprestore.web.backuprestoredatapage/database_save-ver-8303213a3c95654e14d5afd4e72ed4c2.png, QueryString: null with /web/**
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,313 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.admin.GlobalSettingsPage/::/img/icons/silk/server-ver-B0B38DC2E3593F7363DE77ED20FD7897.png]
2017-08-01 16:08:58,313 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.backuprestore.web.BackupRestoreDataPage/database_save-ver-8303213A3C95654E14D5AFD4E72ED4C2.png]
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.gwc.web.blob.blobstorespage/::/blobstores-ver-d698a5e9a755a97b51e657256881bbde.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.gwc.web.blob.blobstorespage/::/blobstores-ver-d698a5e9a755a97b51e657256881bbde.png, QueryString: null with /web/**
2017-08-01 16:08:58,313 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,313 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.gwc.web.blob.BlobStoresPage/::/blobstores-ver-D698A5E9A755A97B51E657256881BBDE.png]
2017-08-01 16:08:58,313 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,329 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.security.web.passwd.passwordpage/::/img/icons/silk/lock-ver-b508411bb915ecf32b1a995644f67fd1.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,329 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.security.web.passwd.passwordpage/::/img/icons/silk/lock-ver-b508411bb915ecf32b1a995644f67fd1.png, QueryString: null with /web/**
2017-08-01 16:08:58,329 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,329 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,329 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,329 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.security.web.passwd.PasswordPage/::/img/icons/silk/lock-ver-B508411BB915ECF32B1A995644F67FD1.png]
2017-08-01 16:08:58,329 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,329 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geogig.geoserver.web.remotespage/geogig_16x16_darkblue-ver-bdb3ea46b8723b8f130e3d0801750d62.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geogig.geoserver.web.repositoriespage/geogig_16x16_darkblue-ver-bdb3ea46b8723b8f130e3d0801750d62.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geogig.geoserver.web.remotespage/geogig_16x16_darkblue-ver-bdb3ea46b8723b8f130e3d0801750d62.png, QueryString: null with /web/**
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geogig.geoserver.web.repositoriespage/geogig_16x16_darkblue-ver-bdb3ea46b8723b8f130e3d0801750d62.png, QueryString: null with /web/**
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,344 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue-ver-BDB3EA46B8723B8F130E3D0801750D62.png]
2017-08-01 16:08:58,344 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue-ver-BDB3EA46B8723B8F130E3D0801750D62.png]
2017-08-01 16:08:58,344 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,344 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.admin.jaipage/::/img/icons/silk/cog_photo-ver-717de401b9156ecac0dde3752f8c5095.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.admin.jaipage/::/img/icons/silk/cog_photo-ver-717de401b9156ecac0dde3752f8c5095.png, QueryString: null with /web/**
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.wcs.web.wcsadminpage/server_raster-ver-24a0b07b2e1ce3a44aab292b4aa5567b.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.wcs.web.wcsadminpage/server_raster-ver-24a0b07b2e1ce3a44aab292b4aa5567b.png, QueryString: null with /web/**
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.wps.web.wpsadminpage/server_gear-ver-d3e4e668c526960f9bbb166f1c758467.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.wps.web.wpsadminpage/server_gear-ver-d3e4e668c526960f9bbb166f1c758467.png, QueryString: null with /web/**
2017-08-01 16:08:58,360 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.wcs.web.WCSAdminPage/server_raster-ver-24A0B07B2E1CE3A44AAB292B4AA5567B.png]
2017-08-01 16:08:58,360 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.admin.JAIPage/::/img/icons/silk/cog_photo-ver-717DE401B9156ECAC0DDE3752F8C5095.png]
2017-08-01 16:08:58,360 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.wps.web.WPSAdminPage/server_gear-ver-D3E4E668C526960F9BBB166F1C758467.png]
2017-08-01 16:08:58,360 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,360 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.gwc.web.gwcsettingspage/geowebcache-16-ver-a2cc77bec866639f3454064ae0e3ae2c.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.gwc.web.gwcsettingspage/geowebcache-16-ver-a2cc77bec866639f3454064ae0e3ae2c.png, QueryString: null with /web/**
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,376 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16-ver-A2CC77BEC866639F3454064AE0E3AE2C.png]
2017-08-01 16:08:58,376 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.gwc.web.gridset.gridsetspage/::/gridset-ver-618e101d6ea16710a07144904f301f58.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,376 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.gwc.web.gridset.gridsetspage/::/gridset-ver-618e101d6ea16710a07144904f301f58.png, QueryString: null with /web/**
2017-08-01 16:08:58,376 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.gwc.web.gridset.GridSetsPage/::/gridset-ver-618E101D6EA16710A07144904F301F58.png]
2017-08-01 16:08:58,391 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.gwc.web.gridset.GridSetsPage/::/gridset-ver-618E101D6EA16710A07144904F301F58.png]
2017-08-01 16:08:58,391 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,391 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,391 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/wrench-ver-a137eb4441860564ce1655357af26de8.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,391 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/wrench-ver-a137eb4441860564ce1655357af26de8.png, QueryString: null with /web/**
2017-08-01 16:08:58,391 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,391 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,391 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,391 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench-ver-A137EB4441860564CE1655357AF26DE8.png]
2017-08-01 16:08:58,407 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.security.web.data.datasecuritypage/::/img/icons/silk/database_key-ver-b5213a0964c48368586607d76a55a83b.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.security.web.data.datasecuritypage/::/img/icons/silk/database_key-ver-b5213a0964c48368586607d76a55a83b.png, QueryString: null with /web/**
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.security.web.service.serviceaccessrulepage/::/img/icons/silk/shape_square_key-ver-48019bbc44223e249d1e0b48dd79e1fd.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,407 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.security.web.service.serviceaccessrulepage/::/img/icons/silk/shape_square_key-ver-48019bbc44223e249d1e0b48dd79e1fd.png, QueryString: null with /web/**
2017-08-01 16:08:58,407 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.security.web.data.DataSecurityPage/::/img/icons/silk/database_key-ver-B5213A0964C48368586607D76A55A83B.png]
2017-08-01 16:08:58,407 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.security.web.service.ServiceAccessRulePage/::/img/icons/silk/shape_square_key-ver-48019BBC44223E249D1E0B48DD79E1FD.png]
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,423 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.wps.web.wpsaccessrulepage/server_key-ver-d3e4e668c526960f9bbb166f1c758467.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.wps.web.wpsaccessrulepage/server_key-ver-d3e4e668c526960f9bbb166f1c758467.png, QueryString: null with /web/**
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,423 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.wps.web.WPSAccessRulePage/server_key-ver-D3E4E668C526960F9BBB166F1C758467.png]
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.geofence.web.geofencepage/img/icons/geofence-ver-7aa84e8ae641d93e0b886a29a6a7983f.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,423 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.geofence.web.geofencepage/img/icons/geofence-ver-7aa84e8ae641d93e0b886a29a6a7983f.png, QueryString: null with /web/**
2017-08-01 16:08:58,423 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.geofence.web.GeofencePage/img/icons/geofence-ver-7AA84E8AE641D93E0B886A29A6A7983F.png]
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage/img/icons/geofence-ver-7aa84e8ae641d93e0b886a29a6a7983f.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserverpage/img/icons/geofence-ver-7aa84e8ae641d93e0b886a29a6a7983f.png, QueryString: null with /web/**
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,438 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.geofence.web.GeofenceServerPage/img/icons/geofence-ver-7AA84E8AE641D93E0B886A29A6A7983F.png]
2017-08-01 16:08:58,438 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserveradminpage/img/icons/geofence-ver-7aa84e8ae641d93e0b886a29a6a7983f.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,438 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.geofence.web.geofenceserveradminpage/img/icons/geofence-ver-7aa84e8ae641d93e0b886a29a6a7983f.png, QueryString: null with /web/**
2017-08-01 16:08:58,438 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.geofence.web.GeofenceServerAdminPage/img/icons/geofence-ver-7AA84E8AE641D93E0B886A29A6A7983F.png]
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/add.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/add.png, QueryString: null with /web/**
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/error.png, QueryString: null'; against '/web/**'
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/error.png, QueryString: null with /web/**
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:08:58,469 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/add.png]
2017-08-01 16:08:58,469 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/error.png]
2017-08-01 16:08:58,469 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:08:58,469 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:01,691 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: null'; against '/web/**'
2017-08-01 16:09:01,691 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: null with /web/**
2017-08-01 16:09:01,691 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:01,691 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:01,691 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:01,707 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:01,707 DEBUG [org.geoserver] - Thread 62 locking in mode WRITE
2017-08-01 16:09:01,707 DEBUG [org.geoserver] - Thread 62 got the lock in mode WRITE
2017-08-01 16:09:03,050 DEBUG [org.geoserver] - Thread 62 locking in mode WRITE
2017-08-01 16:09:03,050 DEBUG [org.geoserver] - Thread 62 releasing the lock in mode WRITE
2017-08-01 16:09:03,097 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:03,191 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 5'; against '/web/**'
2017-08-01 16:09:03,191 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 5 with /web/**
2017-08-01 16:09:03,191 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:03,191 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:03,191 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:03,191 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:03,191 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:09:03,207 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.apache.wicket.ajax.abstractdefaultajaxbehavior/res/js/wicket-event-jquery-ver-6fa1ed3529e8b208ab6e9dfd7d57d908.js, QueryString: null'; against '/web/**'
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.apache.wicket.ajax.abstractdefaultajaxbehavior/res/js/wicket-event-jquery-ver-6fa1ed3529e8b208ab6e9dfd7d57d908.js, QueryString: null with /web/**
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:04,628 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.apache.wicket.ajax.AbstractDefaultAjaxBehavior/res/js/wicket-event-jquery-ver-6FA1ED3529E8B208AB6E9DFD7D57D908.js]
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.apache.wicket.ajax.abstractdefaultajaxbehavior/res/js/wicket-ajax-jquery-ver-f7b616a06388d870481a2120080172d3.js, QueryString: null'; against '/web/**'
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.apache.wicket.ajax.abstractdefaultajaxbehavior/res/js/wicket-ajax-jquery-ver-f7b616a06388d870481a2120080172d3.js, QueryString: null with /web/**
2017-08-01 16:09:04,628 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: application/javascript
2017-08-01 16:09:04,628 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.apache.wicket.ajax.AbstractDefaultAjaxBehavior/res/js/wicket-ajax-jquery-ver-F7B616A06388D870481A2120080172D3.js]
2017-08-01 16:09:04,628 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:06,879 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/help.png, QueryString: null'; against '/web/**'
2017-08-01 16:09:06,879 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/help.png, QueryString: null with /web/**
2017-08-01 16:09:06,879 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:06,879 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:06,879 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:06,879 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/help.png]
2017-08-01 16:09:06,879 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:09:06,879 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:06,926 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/delete.png, QueryString: null'; against '/web/**'
2017-08-01 16:09:06,926 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/delete.png, QueryString: null with /web/**
2017-08-01 16:09:06,926 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:06,926 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:06,926 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:06,926 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/delete.png]
2017-08-01 16:09:06,926 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:09:06,926 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:06,989 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/magnifier.png, QueryString: null'; against '/web/**'
2017-08-01 16:09:06,989 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/magnifier.png, QueryString: null with /web/**
2017-08-01 16:09:06,989 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:06,989 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:06,989 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:06,989 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/magnifier.png]
2017-08-01 16:09:06,989 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:09:06,989 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:36,431 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1ecb3f0b] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 19c6e9f7]]
2017-08-01 16:09:44,707 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 5-1.ILinkListener-panel-tabs~container-tabs-2-link'; against '/web/**'
2017-08-01 16:09:44,707 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 5-1.ILinkListener-panel-tabs~container-tabs-2-link with /web/**
2017-08-01 16:09:44,707 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:44,707 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:44,707 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:44,707 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:44,707 DEBUG [org.geoserver] - Thread 265 locking in mode WRITE
2017-08-01 16:09:44,707 DEBUG [org.geoserver] - Thread 265 got the lock in mode WRITE
2017-08-01 16:09:44,941 DEBUG [org.geoserver] - Thread 265 locking in mode WRITE
2017-08-01 16:09:44,941 DEBUG [org.geoserver] - Thread 265 releasing the lock in mode WRITE
2017-08-01 16:09:44,957 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:44,957 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 6'; against '/web/**'
2017-08-01 16:09:44,957 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 6 with /web/**
2017-08-01 16:09:44,957 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:44,957 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:44,957 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:44,957 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:44,957 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:09:45,004 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/bullet_arrow_down.png, QueryString: null'; against '/web/**'
2017-08-01 16:09:45,004 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/bullet_arrow_down.png, QueryString: null with /web/**
2017-08-01 16:09:45,004 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:45,004 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:45,004 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:45,004 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/bullet_arrow_down.png]
2017-08-01 16:09:45,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/pencil.png, QueryString: null'; against '/web/**'
2017-08-01 16:09:45,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/pencil.png, QueryString: null with /web/**
2017-08-01 16:09:45,019 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:45,019 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:45,019 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:45,019 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/pencil.png]
2017-08-01 16:09:45,019 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:09:45,019 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:45,035 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/bullet_arrow_right.png, QueryString: null'; against '/web/**'
2017-08-01 16:09:45,035 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/resource/org.geoserver.web.geoserverbasepage/img/icons/silk/bullet_arrow_right.png, QueryString: null with /web/**
2017-08-01 16:09:45,035 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:45,035 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:45,035 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:45,035 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/resource/org.geoserver.web.GeoServerBasePage/img/icons/silk/bullet_arrow_right.png]
2017-08-01 16:09:45,035 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/png
2017-08-01 16:09:45,035 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:48,121 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 6-2.ILinkListener-panel-tabs~container-tabs-1-link'; against '/web/**'
2017-08-01 16:09:48,121 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 6-2.ILinkListener-panel-tabs~container-tabs-1-link with /web/**
2017-08-01 16:09:48,121 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:48,121 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:48,121 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:48,136 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:48,136 DEBUG [org.geoserver] - Thread 269 locking in mode WRITE
2017-08-01 16:09:48,136 DEBUG [org.geoserver] - Thread 269 got the lock in mode WRITE
2017-08-01 16:09:48,386 DEBUG [org.geoserver] - Thread 269 locking in mode WRITE
2017-08-01 16:09:48,386 DEBUG [org.geoserver] - Thread 269 releasing the lock in mode WRITE
2017-08-01 16:09:48,402 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:48,417 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 7'; against '/web/**'
2017-08-01 16:09:48,417 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 7 with /web/**
2017-08-01 16:09:48,417 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:48,417 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:48,417 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:48,417 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:48,417 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:09:48,417 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:49,839 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 7-3.ILinkListener-panel-tabs~container-tabs-0-link'; against '/web/**'
2017-08-01 16:09:49,839 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 7-3.ILinkListener-panel-tabs~container-tabs-0-link with /web/**
2017-08-01 16:09:49,839 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:49,855 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:49,855 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:49,855 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:49,855 DEBUG [org.geoserver] - Thread 63 locking in mode WRITE
2017-08-01 16:09:49,855 DEBUG [org.geoserver] - Thread 63 got the lock in mode WRITE
2017-08-01 16:09:49,902 DEBUG [org.geoserver] - Thread 63 locking in mode WRITE
2017-08-01 16:09:49,902 DEBUG [org.geoserver] - Thread 63 releasing the lock in mode WRITE
2017-08-01 16:09:49,902 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:09:49,917 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8'; against '/web/**'
2017-08-01 16:09:49,917 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8 with /web/**
2017-08-01 16:09:49,917 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:09:49,917 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:09:49,917 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:09:49,917 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:09:49,917 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:09:49,917 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:08,987 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8-4.IBehaviorListener.0-panel-panel-roleServices-table-listContainer-items-2-itemProperties-0-component-link&_=1501603789945'; against '/web/**'
2017-08-01 16:10:08,987 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8-4.IBehaviorListener.0-panel-panel-roleServices-table-listContainer-items-2-itemProperties-0-component-link&_=1501603789945 with /web/**
2017-08-01 16:10:08,987 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:08,987 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:08,987 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:08,987 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:10:08,987 DEBUG [org.geoserver] - Thread 55 locking in mode WRITE
2017-08-01 16:10:08,987 DEBUG [org.geoserver] - Thread 55 got the lock in mode WRITE
2017-08-01 16:10:09,222 DEBUG [org.geoserver] - Thread 55 locking in mode WRITE
2017-08-01 16:10:09,222 DEBUG [org.geoserver] - Thread 55 releasing the lock in mode WRITE
2017-08-01 16:10:09,237 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2017-08-01 16:10:09,237 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:09,347 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 9'; against '/web/**'
2017-08-01 16:10:09,347 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 9 with /web/**
2017-08-01 16:10:09,347 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:09,347 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:09,347 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:09,347 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:09,347 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:09,347 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:09,440 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/resource/org.geoserver.web.geoserverbasepage/favicon-ver-cd7c91844a87fe589c62dfe238a2aca7.ico, QueryString: null'; against '/web/**'
2017-08-01 16:10:09,440 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/resource/org.geoserver.web.geoserverbasepage/favicon-ver-cd7c91844a87fe589c62dfe238a2aca7.ico, QueryString: null with /web/**
2017-08-01 16:10:09,440 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:09,440 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:09,440 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:09,440 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/resource/org.geoserver.web.GeoServerBasePage/favicon-ver-CD7C91844A87FE589C62DFE238A2ACA7.ico]
2017-08-01 16:10:09,440 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:26,267 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 9-1.IFormSubmitListener-panel-panel-panel-form'; against '/web/**'
2017-08-01 16:10:26,267 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 9-1.IFormSubmitListener-panel-panel-panel-form with /web/**
2017-08-01 16:10:26,267 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:26,267 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:26,267 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:26,267 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:26,282 DEBUG [org.geoserver] - Thread 56 locking in mode WRITE
2017-08-01 16:10:26,282 DEBUG [org.geoserver] - Thread 56 got the lock in mode WRITE
2017-08-01 16:10:26,423 DEBUG [org.geoserver] - Thread 56 locking in mode WRITE
2017-08-01 16:10:26,423 DEBUG [org.geoserver] - Thread 56 releasing the lock in mode WRITE
2017-08-01 16:10:26,439 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:26,439 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8'; against '/web/**'
2017-08-01 16:10:26,439 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8 with /web/**
2017-08-01 16:10:26,439 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:26,439 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:26,439 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:26,439 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:10:26,439 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:27,189 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task running
2017-08-01 16:10:27,189 DEBUG [org.geoserver.security] - Cache entries #: 1
2017-08-01 16:10:27,189 DEBUG [org.geoserver.security] - AuthenticationCache Eviction task completed
2017-08-01 16:10:27,189 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 16:10:30,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8-5.IBehaviorListener.0-panel-panel-roleServices-table-listContainer-items-3-itemProperties-0-component-link&_=1501603826503'; against '/web/**'
2017-08-01 16:10:30,705 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.usergrouproleservicespage, QueryString: 8-5.IBehaviorListener.0-panel-panel-roleServices-table-listContainer-items-3-itemProperties-0-component-link&_=1501603826503 with /web/**
2017-08-01 16:10:30,705 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:30,705 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:30,705 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:30,705 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.UserGroupRoleServicesPage]
2017-08-01 16:10:30,705 DEBUG [org.geoserver] - Thread 267 locking in mode WRITE
2017-08-01 16:10:30,705 DEBUG [org.geoserver] - Thread 267 got the lock in mode WRITE
2017-08-01 16:10:30,736 DEBUG [org.geoserver] - Thread 267 locking in mode WRITE
2017-08-01 16:10:30,736 DEBUG [org.geoserver] - Thread 267 releasing the lock in mode WRITE
2017-08-01 16:10:30,752 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2017-08-01 16:10:30,752 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:30,768 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 10'; against '/web/**'
2017-08-01 16:10:30,768 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 10 with /web/**
2017-08-01 16:10:30,768 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:30,768 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:30,768 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:30,768 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:30,768 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:30,768 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:35,803 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 10-1.ILinkListener-panel-panel-tabs~container-tabs-1-link'; against '/web/**'
2017-08-01 16:10:35,803 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 10-1.ILinkListener-panel-panel-tabs~container-tabs-1-link with /web/**
2017-08-01 16:10:35,803 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:35,803 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:35,803 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:35,803 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:35,803 DEBUG [org.geoserver] - Thread 64 locking in mode WRITE
2017-08-01 16:10:35,803 DEBUG [org.geoserver] - Thread 64 got the lock in mode WRITE
2017-08-01 16:10:35,865 DEBUG [org.geoserver] - Thread 64 locking in mode WRITE
2017-08-01 16:10:35,865 DEBUG [org.geoserver] - Thread 64 releasing the lock in mode WRITE
2017-08-01 16:10:35,865 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:35,865 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 11'; against '/web/**'
2017-08-01 16:10:35,865 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 11 with /web/**
2017-08-01 16:10:35,865 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:35,865 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:35,865 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:35,881 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:35,881 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:35,881 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:36,430 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 22f09326] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 1dec3e12]]
2017-08-01 16:10:39,469 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 11-2.IBehaviorListener.0-panel-panel-panel-table-listContainer-items-1-itemProperties-0-component-link&_=1501603835922'; against '/web/**'
2017-08-01 16:10:39,469 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 11-2.IBehaviorListener.0-panel-panel-panel-table-listContainer-items-1-itemProperties-0-component-link&_=1501603835922 with /web/**
2017-08-01 16:10:39,469 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:39,469 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:39,469 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:39,469 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:39,469 DEBUG [org.geoserver] - Thread 265 locking in mode WRITE
2017-08-01 16:10:39,469 DEBUG [org.geoserver] - Thread 265 got the lock in mode WRITE
2017-08-01 16:10:39,594 DEBUG [org.geoserver] - Thread 265 locking in mode WRITE
2017-08-01 16:10:39,594 DEBUG [org.geoserver] - Thread 265 releasing the lock in mode WRITE
2017-08-01 16:10:39,610 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2017-08-01 16:10:39,610 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:39,625 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 12'; against '/web/**'
2017-08-01 16:10:39,625 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 12 with /web/**
2017-08-01 16:10:39,625 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:39,625 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:39,625 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:39,625 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:39,625 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:39,625 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:47,445 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 11'; against '/web/**'
2017-08-01 16:10:47,445 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 11 with /web/**
2017-08-01 16:10:47,445 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:47,445 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:47,445 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:47,445 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:47,461 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:47,461 DEBUG [org.geoserver] - Thread 62 locking in mode WRITE
2017-08-01 16:10:47,461 DEBUG [org.geoserver] - Thread 62 got the lock in mode WRITE
2017-08-01 16:10:47,476 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:47,476 DEBUG [org.geoserver] - Thread 62 locking in mode WRITE
2017-08-01 16:10:47,476 DEBUG [org.geoserver] - Thread 62 releasing the lock in mode WRITE
2017-08-01 16:10:47,492 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:48,556 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 11-3.IBehaviorListener.0-panel-panel-panel-table-listContainer-items-4-itemProperties-0-component-link&_=1501603847550'; against '/web/**'
2017-08-01 16:10:48,556 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 11-3.IBehaviorListener.0-panel-panel-panel-table-listContainer-items-4-itemProperties-0-component-link&_=1501603847550 with /web/**
2017-08-01 16:10:48,556 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:48,556 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:48,556 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:48,556 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:48,556 DEBUG [org.geoserver] - Thread 56 locking in mode WRITE
2017-08-01 16:10:48,556 DEBUG [org.geoserver] - Thread 56 got the lock in mode WRITE
2017-08-01 16:10:48,587 DEBUG [org.geoserver] - Thread 56 locking in mode WRITE
2017-08-01 16:10:48,587 DEBUG [org.geoserver] - Thread 56 releasing the lock in mode WRITE
2017-08-01 16:10:48,587 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/xml;charset=UTF-8
2017-08-01 16:10:48,587 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:48,603 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 13'; against '/web/**'
2017-08-01 16:10:48,603 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 13 with /web/**
2017-08-01 16:10:48,603 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:48,603 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:48,603 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:48,603 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:48,603 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:48,603 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:10:50,774 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/page, QueryString: 11'; against '/web/**'
2017-08-01 16:10:50,774 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/page, QueryString: 11 with /web/**
2017-08-01 16:10:50,774 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:10:50,774 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:10:50,774 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:10:50,790 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/page]
2017-08-01 16:10:50,790 DEBUG [org.geoserver] - Thread 267 locking in mode WRITE
2017-08-01 16:10:50,790 DEBUG [org.geoserver] - Thread 267 got the lock in mode WRITE
2017-08-01 16:10:50,805 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:10:50,805 DEBUG [org.geoserver] - Thread 267 locking in mode WRITE
2017-08-01 16:10:50,805 DEBUG [org.geoserver] - Thread 267 releasing the lock in mode WRITE
2017-08-01 16:10:50,821 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:11:36,426 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 270ac132] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 22066c1e]]
2017-08-01 16:12:13,696 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.securitysettingspage, QueryString: null'; against '/web/**'
2017-08-01 16:12:13,696 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.securitysettingspage, QueryString: null with /web/**
2017-08-01 16:12:13,696 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:12:13,696 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:12:13,696 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:12:13,696 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.SecuritySettingsPage]
2017-08-01 16:12:13,696 DEBUG [org.geoserver] - Thread 64 locking in mode WRITE
2017-08-01 16:12:13,696 DEBUG [org.geoserver] - Thread 64 got the lock in mode WRITE
2017-08-01 16:12:13,759 DEBUG [org.geoserver] - Thread 64 locking in mode WRITE
2017-08-01 16:12:13,759 DEBUG [org.geoserver] - Thread 64 releasing the lock in mode WRITE
2017-08-01 16:12:13,759 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:12:13,775 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.securitysettingspage, QueryString: 14'; against '/web/**'
2017-08-01 16:12:13,775 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.securitysettingspage, QueryString: 14 with /web/**
2017-08-01 16:12:13,775 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:12:13,775 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:12:13,775 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:12:13,775 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.SecuritySettingsPage]
2017-08-01 16:12:13,775 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:12:13,775 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:12:29,629 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.securitysettingspage, QueryString: 14-1.IFormSubmitListener-form'; against '/web/**'
2017-08-01 16:12:29,629 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.securitysettingspage, QueryString: 14-1.IFormSubmitListener-form with /web/**
2017-08-01 16:12:29,629 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:12:29,629 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:12:29,629 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:12:29,629 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.SecuritySettingsPage]
2017-08-01 16:12:29,629 DEBUG [org.geoserver] - Thread 265 locking in mode WRITE
2017-08-01 16:12:29,629 DEBUG [org.geoserver] - Thread 265 got the lock in mode WRITE
2017-08-01 16:12:29,675 WARN [org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider] - INIT FROM CONFIG
2017-08-01 16:12:29,707 DEBUG [org.geoserver.security] - AuthenticationCache removing all entries
2017-08-01 16:12:29,707 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 16:12:29,707 DEBUG [org.geoserver.security] - AuthenticationCache removed all entries
2017-08-01 16:12:29,707 DEBUG [org.geoserver] - Thread 265 locking in mode WRITE
2017-08-01 16:12:29,707 DEBUG [org.geoserver] - Thread 265 releasing the lock in mode WRITE
2017-08-01 16:12:29,707 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:12:29,722 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: null'; against '/web/**'
2017-08-01 16:12:29,722 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: null with /web/**
2017-08-01 16:12:29,722 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:12:29,722 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:12:29,722 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:12:29,722 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 16:12:29,879 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:12:29,925 DEBUG [org.geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
java.lang.Exception: Full stack trace for the session creation path
	at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:92)
	at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:229)
	at org.apache.wicket.session.HttpSessionStore.getHttpSession(HttpSessionStore.java:95)
	at org.apache.wicket.session.HttpSessionStore.getSessionId(HttpSessionStore.java:166)
	at org.apache.wicket.Session.bind(Session.java:267)
	at org.apache.wicket.Session.replaceSession(Session.java:519)
	at org.geoserver.web.GeoServerApplication.onApplicationEvent(GeoServerApplication.java:417)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:163)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:136)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:381)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:335)
	at org.springframework.security.authentication.DefaultAuthenticationEventPublisher.publishAuthenticationSuccess(DefaultAuthenticationEventPublisher.java:84)
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:213)
	at org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1492)
	at org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.<init>(SecurityHomePageContentProvider.java:105)
	at org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:47)
	at org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:129)
	at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
	at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
	at org.apache.wicket.Component.internalBeforeRender(Component.java:949)
	at org.apache.wicket.Component.beforeRender(Component.java:1017)
	at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1568)
	at org.apache.wicket.Component.onBeforeRender(Component.java:3877)
	at org.apache.wicket.Page.onBeforeRender(Page.java:801)
	at org.apache.wicket.Component.internalPrepareForRender(Component.java:2215)
	at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
	at org.apache.wicket.Component.render(Component.java:2304)
	at org.apache.wicket.Page.renderPage(Page.java:1018)
	at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
	at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
	at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
	at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
	at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
	at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2522)
	at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2511)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
2017-08-01 16:12:29,988 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:12:30,019 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:12:30,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/, QueryString: 16'; against '/web/**'
2017-08-01 16:12:30,019 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/, QueryString: 16 with /web/**
2017-08-01 16:12:30,035 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:12:30,035 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:12:30,035 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:12:30,035 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2017-08-01 16:12:30,035 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2017-08-01 16:12:30,035 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:12:36,435 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2b22777f] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 261e226b]]
2017-08-01 16:13:36,433 DEBUG [org.geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2f3394a9] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at 2a2f3f95]]
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 16:13:47,213 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:14:17,223 WARN [org.geoserver.security] -
org.springframework.security.authentication.InternalAuthenticationServiceException
	at org.springframework.security.authentication.dao.DaoAuthenticationProvider.retrieveUser(DaoAuthenticationProvider.java:126)
	at org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:143)
	at org.geoserver.security.auth.UsernamePasswordAuthenticationProvider.authenticate(UsernamePasswordAuthenticationProvider.java:82)
	at org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
	at org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:323)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:178)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
Caused by: java.lang.NullPointerException
	at java.util.AbstractCollection.addAll(Unknown Source)
	at org.geoserver.security.impl.RoleCalculator.calculateRoles(RoleCalculator.java:124)
	at org.geoserver.security.impl.AbstractUserGroupService.loadUserByUsername(AbstractUserGroupService.java:197)
	at org.geoserver.security.concurrent.LockingUserGroupService.loadUserByUsername(LockingUserGroupService.java:243)
	at org.springframework.security.authentication.dao.DaoAuthenticationProvider.retrieveUser(DaoAuthenticationProvider.java:114)
	... 56 more
2017-08-01 16:14:17,223 DEBUG [org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider] - Auth request with org.springframework.security.authentication.UsernamePasswordAuthenticationToken at 58b3abfa: Principal: admin; Credentials: [PROTECTED]; Authenticated: false; Details: org.geoserver.security.filter.GeoServerWebAuthenticationDetails at 957e: RemoteIpAddress: 127.0.0.1; SessionId: null; Not granted any authorities
2017-08-01 16:14:17,270 DEBUG [org.geoserver.geofence.cache] - Loading user 'admin'
2017-08-01 16:14:17,285 WARN [org.geoserver.geofence.cache] - org.geoserver.geofence.cache.CachedRuleReader$NoAuthException: Can't auth user [admin]
2017-08-01 16:14:17,285 DEBUG [org.geoserver.geoserver.authentication.auth.GeoFenceAuthenticationProvider] - Default admin credentials NOT authenticated -- probably a frontend check
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Interactive login attempt was unsuccessful.
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Cancelling cookie
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/web/**'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/gwc/rest/web/**'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_check/'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_login/'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_security_logout/'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/j_spring_oauth2_geonode_logout/'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null'; against '/rest/**'
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /rest/layergroups/les-zones-inondables_26.xml, QueryString: null with /rest/**
2017-08-01 16:14:17,285 DEBUG [org.geoserver.security] - AuthenticationCache has no entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:14:17,692 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web/wicket/bookmarkable/org.geoserver.security.web.auth.authenticationpage, QueryString: null'; against '/web/**'
2017-08-01 16:14:17,692 DEBUG [org.geoserver.security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web/wicket/bookmarkable/org.geoserver.security.web.auth.authenticationpage, QueryString: null with /web/**
2017-08-01 16:14:17,692 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:14:17,692 DEBUG [org.geoserver.security] - Found 4 cookies!
2017-08-01 16:14:17,692 DEBUG [org.geoserver.security] - Found GeoNode cookie: ep9j00s8pnfh6wc5l7jdbhbyib8bfpkf
2017-08-01 16:14:17,707 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/web/wicket/bookmarkable/org.geoserver.security.web.auth.AuthenticationPage]
2017-08-01 16:14:17,707 DEBUG [org.geoserver] - Thread 269 locking in mode WRITE
2017-08-01 16:14:17,707 DEBUG [org.geoserver] - Thread 269 got the lock in mode WRITE
2017-08-01 16:14:17,754 DEBUG [org.geoserver.security] - Setting ROLES for User [admin] to [ROLE_ADMINISTRATOR]
2017-08-01 16:14:17,801 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Did not send remember-me cookie (principal did not set parameter '_spring_security_remember_me')
2017-08-01 16:14:17,801 DEBUG [org.geoserver.security.rememberme.GeoServerTokenBasedRememberMeServices] - Remember-me login not requested.
2017-08-01 16:14:17,801 DEBUG [org.geoserver.security] - AuthenticationCache adding new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:14:17,801 DEBUG [org.geoserver.security] - Cache entries #: 0
2017-08-01 16:14:17,801 DEBUG [org.geoserver.security] - AuthenticationCache added new entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
2017-08-01 16:14:17,801 DEBUG [org.geoserver.security] - Cache entries #: 1
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security] - Inspecting the http request looking for the GeoNode Session ID.
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security] - Found no cookies!
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: '/rest/layergroups/les-zones-inondables_26.xml'; to: '/rest/layergroups/les-zones-inondables_26.xml'  and httpMethod= GET
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/process/batchdownload/download/* methodList= [GET]
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/process/batchdownload/download/*; matchedPath=false; matchedMethods=true
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /rest/printing/* methodList= [GET, POST]
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /rest/printing/*; matchedPath=false; matchedMethods=true
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: '/rest/layergroups/les-zones-inondables_26.xml'; antPath is /**; matchedPath=true; matchedMethods=true
2017-08-01 16:14:17,817 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning IS_AUTHENTICATED_ANONYMOUSLY
2017-08-01 16:14:17,817 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups/les-zones-inondables_26.xml]
2017-08-01 16:14:17,817 DEBUG [org.geoserver] - Thread 266 locking in mode READ
2017-08-01 16:14:18,254 DEBUG [org.geoserver] - Thread 269 locking in mode WRITE
2017-08-01 16:14:18,254 DEBUG [org.geoserver] - Thread 269 releasing the lock in mode WRITE
2017-08-01 16:14:18,254 DEBUG [org.geoserver] - Thread 266 got the lock in mode READ
2017-08-01 16:14:18,254 DEBUG [org.geoserver] - Thread 266 locking in mode READ
2017-08-01 16:14:18,254 DEBUG [org.geoserver] - Thread 266 releasing the lock in mode READ
2017-08-01 16:14:18,254 ERROR [org.geoserver.rest] - No such layer group les-zones-inondables_26
2017-08-01 16:14:18,254 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
org.geoserver.rest.RestletException
	at org.geoserver.catalog.rest.LayerGroupFinder.findTarget(LayerGroupFinder.java:49)
	at org.restlet.Finder.handle(Finder.java:268)
	at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
	at org.restlet.Filter.doHandle(Filter.java:105)
	at org.restlet.Filter.handle(Filter.java:134)
	at org.restlet.Router.handle(Router.java:444)
	at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
	at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
	at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
	at org.springfram
