[GeoNode-users] geonode loads with IP not with URL/domain name
Simone Dalmasso simone.dalmasso at gmail.com
Sun Aug 20 12:39:26 PDT 2017
Hi, make sure the domain you have set is correct, for example
Http://xxx.example.com will be only "xxx.example .com"
That is the only error I see from the logs.
ps please always keep the list in copy.
2017-08-19 11:57 GMT-04:00 Mehdi Ahmadi <mehmadi at gmail.com>:
> Thanks again! The *latest error message* in error.log file is as
> >> Invalid HTTP_HOST header: '<hostname>'. You may need to add u'
> <hostname>' to ALLOWED_HOSTS.
> My hostname is already in the ALLOWED_HOSTS. Is there any other place I
> can check for this?
> there is also an error in processing WSGI in my_geonode (where I did my
> customization):
> >> mod_wsgi (pid=28575): Exception occurred processing WSGI script '/admin/
> my_geonode/my_geonode/wsgi.py'.
> I have modified wsgi.py in my_geonode according to the documentation (
> http://docs.geonode.org/en/master/tutorials/admin/customize
> _lookfeel/customize/setup_admin.html)
> Is there any other settings I need to add in wsgi.py when I use hostname
> instead of localhost?
> Here is the entire error.log file (after removing pid and tid and
> datetime) for reference:
> [wsgi:warn] mod_wsgi: Compiled for Python/2.7.11.
> [wsgi:warn] mod_wsgi: Runtime using Python/2.7.12.
> [mpm_event:notice] AH00489: Apache/2.4.18 (Ubuntu) mod_wsgi/4.3.0
> Python/2.7.12 configured -- resuming normal operations
> [core:notice] AH00094: Command line: '/usr/sbin/apache2'
> [wsgi:error]  Invalid HTTP_HOST header: '<hostname>'. You may need to add
> u'<hostname>' to ALLOWED_HOSTS.
> [wsgi:error]  Internal Server Error: /
> [wsgi:error]  Traceback (most recent call last):
> [wsgi:error]    File "/usr/lib/python2.7/dist-
> packages/django/core/handlers/base.py", line 87, in get_exception_response
> [wsgi:error]      response = callback(request, **param_dict)
> [wsgi:error]    File "/usr/lib/python2.7/dist-packages/django/utils/decorators.py",
> line 110, in _wrapped_view
> [wsgi:error]      response = view_func(request, *args, **kwargs)
> [wsgi:error]    File "/usr/lib/python2.7/dist-packages/django/views/defaults.py",
> line 60, in bad_request
> [wsgi:error]      return http.HttpResponseBadRequest(template.render())
> [wsgi:error]    File "/usr/lib/python2.7/dist-packages/django/template/backends/django.py",
> line 74, in render
> [wsgi:error]      return self.template.render(context)
> packages/django/template/base.py", line 210, in render
> [wsgi:error]      return self._render(context)
> packages/django/template/base.py", line 202, in _render
> [wsgi:error]      return self.nodelist.render(context)
> packages/django/template/base.py", line 905, in render
> [wsgi:error]      bit = self.render_node(node, context)
> [wsgi:error]    File "/usr/lib/python2.7/dist-packages/django/template/debug.py",
> line 79, in render_node
> [wsgi:error]      return node.render(context)
> [wsgi:error]    File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py",
> line 135, in render
> [wsgi:error]      return compiled_parent._render(context)
> line 135, in render
> line 65, in render
> [wsgi:error]      result = block.nodelist.render(context)
> line 159, in render
> [wsgi:error]      return template.render(context)
> packages/django/template/base.py", line 212, in render
> [wsgi:error]    File "/usr/lib/python2.7/dist-packages/announcements/
> templatetags/announcements_tags.py", line 24, in render
> [wsgi:error]      request = context["request"]
> [wsgi:error]    File "/usr/lib/python2.7/dist-packages/django/template/context.py",
> line 71, in __getitem__
> [wsgi:error]      raise KeyError(key)
> [wsgi:error]  KeyError: 'request'
> [wsgi:error]  mod_wsgi (pid=28574): Exception occurred processing WSGI
> script '/path/to/my_geonode/my_geonode/wsgi.py'.
> packages/django/core/handlers/wsgi.py", line 189, in __call__
> [wsgi:error]      response = self.get_response(request)
> packages/django/core/handlers/base.py", line 209, in get_response
> [wsgi:error]      response = self.get_exception_response(request,
> resolver, 400)
> packages/django/core/handlers/base.py", line 90, in get_exception_response
> [wsgi:error]      response = self.handle_uncaught_exception(request,
> resolver, sys.exc_info())
> packages/django/core/handlers/base.py", line 268, in
> [wsgi:error]      return callback(request, **param_dict)
> line 45, in server_error
> [wsgi:error]      return http.HttpResponseServerError(template.render())
> line 74, in render
> line 56, in render
> [wsgi:error]      result = self.nodelist.render(context)
> line 159, in render
> [wsgi:error] Internal Server Error: /favicon.ico
> line 74, in render
> line 135, in render
> line 135, in render
> line 65, in render
> line 159, in render
> [wsgi:error] mod_wsgi (pid=28575): Exception occurred processing WSGI
> resolver, 400)
> line 74, in render
> line 56, in render
> line 159, in render
> On Sat, Aug 19, 2017 at 7:26 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Yeah, take a look at the apache logs /var/logs/apache2/error.log. It'll
>> give you more info
>> 2017-08-19 10:55 GMT-04:00 Mehdi Ahmadi <mehmadi at gmail.com>:
>>> Thanks Simone. I just run (sudo geonode-updateip XXXXXX; replacing
>>> XXXXX with hostname) and restarted apache, but still the same problem shows
>>> up.
>>> It seems that the command updates geoserver layers and adds the
>>> <hostname> to the allowed hosts. I already did this local_settings.py file.
>>> I can confirm that the ALLOWED_HOSTS in /etc/geonode and my_geonode
>>> (for customization) contains both my IP and Hostname.
>>> Any other advice?
>>> On Sat, Aug 19, 2017 at 7:06 PM, Simone Dalmasso <
>>>> Hi, if you change the hostname then you have to run "geonode updateip
>>>> XXXXXX", this is because of security checks in django.
>>>> Hope this helps
>>>> 2017-08-19 9:32 GMT-04:00 Mehdi Ahmadi <mehmadi at gmail.com>:
>>>>> I have successfully installed geonode on a remote server made some
>>>>> customization. Now, it loads with IP address with no problem; however, I
>>>>> get the following apache error when I try to load the website using
>>>>> URL/host name. Strange enough, geoserver works fine when I try both
>>>>> /geoserver and /geoserver. Pinging the host name shows my ip address and my
>>>>> nameservers seem to be set appropriately.
>>>>> Do you guys have any idea what is the likely reason for this problem?
>>>>> Error message:
>>>>> The server encountered an internal error or misconfiguration and was
>>>>> unable to complete your request.
>>>>> Please contact the server administrator at webmaster at localhost to
>>>>> inform them of the time this error occurred, and the actions you performed
>>>>> just before this error.
>>>>> More information about this error may be available in the server error
>>>>> log.
>>>>> Apache/2.4.18 (Ubuntu) Server at ulsdi.ir Port 80
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>>> Thanks,
>>> Mehdi
>> Simone
> Thanks,
> Mehdi
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170820/5328ef0f/attachment-0001.html>
More information about the geonode-users mailing list
