[GeoNode-users] FW: Cannot upload layers
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Dec 20 06:00:05 PST 2017
ah very nice, thanks Francesco this is a very good news!
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Dec 20, 2017 at 2:42 PM, francesco bartoli <xbartolone at gmail.com>
wrote:
> Hi Alessio,
> just to let you know the documentation here and all the sections related
> to CentOS 7 have been recently updated and there is al least one
> installation which is currently working with this setup.
> Francesco
> 2017-12-20 9:56 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> Hi Stefano,
>> I kindly suggest you to follow the steps of this tutorial (which will be
>> - hopefully - backported soon on official GeoNode docs - as soon as I have
>> some spare time to do it and test everything from scratch).
>> http://training.geonode.geo-solutions.it/002_install_and_adm
>> in/002_geonode_install/index.html
>> Unfortunately we don't have updated documentation for CentOS.
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Wed, Dec 20, 2017 at 9:31 AM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
>>> Hi Ariel,
>>> unfortunately, this is not my case, as tomcat is already the owner of
>>> GeoServer data directory.
>>> Anyway, thanks for your contribution.
>>> @Alessio: thank you very much for your support. At this point I'm lost
>>> and I think I'll try again with a fresh machine. Just let me know if you
>>> think that I could have missed some other steps setting up Tomcat and
>>> Apache services, starting from a development installation (regular
>>> installation with geonode 2.6 is not an option for me).
>>> Stefano
>>> *From:* Ariel Neri [ariel.neriw at gmail.com]
>>> *Sent:* 20 December 2017 00:02
>>> *To:* Alessio Fabiani; LUONI Stefano (JRC-ISPRA-EXT)
>>> *Cc:* geonode-users
>>> *Subject:* Re: [GeoNode-users] FW: Cannot upload layers
>>> Hi, just in case it helps you, i had a similar problem some time ago
>>> after migrating GeoNode 2.6 to another server, probably not exactly the
>>> same. When I did the migration, some files in the new server where with
>>> owner: "root" instead of "Tomcat". Particularly after changing the
>>> ownership of: /usr/share/geoserver/data/data/geonode, the problem
>>> desapeared and all users were able to upload layers again.
>>> Probably is not your issue, but check the ownership of your files to
>>> make sure they´re right.
>>> Cheers
>>> 2017-12-19 13:57 GMT-03:00 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>:
>>>> [image: Inline image 1]
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>> 55054
>>>>  Massarosa
>>>> (LU)
>>>> Italy
>>>> phone: +39 0584 962313 <0584%20962313>
>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>> On Tue, Dec 19, 2017 at 5:56 PM, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>> So,
>>>>> I did some tests with your datasets and GeoNode is able to import them
>>>>> correctly
>>>>> I'm currently using the GeoNode master with GeoServer 2.12.x, but I
>>>>> don't think that your issue is related to the versions actually.
>>>>> I am pretty sure that something is wrong with your overall
>>>>> configuration, but it's hard to say without looking into the server config.
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054
>>>>>  Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> On Tue, Dec 19, 2017 at 4:46 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>>> wrote:
>>>>>> The machine is not reachable from outside JRC network at this time,
>>>>>> unfortunately.
>>>>>> If it can be of help, I can send you the GeoServer data directory,
>>>>>> Apache virtual host, Geonode settings file and the GeoTiff layer we were
>>>>>> testing before.
>>>>>> *From:* Alessio Fabiani [alessio.fabiani at geo-solutions.it]
>>>>>> *Sent:* 19 December 2017 16:01
>>>>>> *To:* LUONI Stefano (JRC-ISPRA-EXT)
>>>>>> *Cc:* GeoSolutions - JAI; geonode-users
>>>>>> That is very strange. Do you have a sample that I can test locally?
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054
>>>>>>  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Tue, Dec 19, 2017 at 3:41 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>>>> wrote:
>>>>>>> Yes, I already checked that this file could be processed by
>>>>>>> GeoServer. If I try to load it directly from GeoServer, SRS are detected
>>>>>>> (EPSG:21892), as well as bounds and the layer can be published.
>>>>>>> I don't understand why GeoServer should not be able to read the file.
>>>>>>> This file is just an example, but I get an upload error from Tomcat
>>>>>>> for shape files too.
>>>>>>> *Sent:* 19 December 2017 15:18
>>>>>>> Ah but "bogota" is a GeoTIFF or something? Is it gridded data or
>>>>>>> vectorial data?
>>>>>>> From the logs it looks like GeoNode tries to create a Coverage Store
>>>>>>> and GeoServer somehow is not able to read the file.
>>>>>>> It could be worth trying to ingest the file directly on GeoServer in
>>>>>>> order to understand if the server is able to recognize it or not. Maybe it
>>>>>>> needs some GDAL pre-processing in order to be correctly managed by
>>>>>>> GeoServer.
>>>>>>> Regards,
>>>>>>> Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> 55054
>>>>>>>  Massarosa
>>>>>>> (LU)
>>>>>>> Italy
>>>>>>> On Tue, Dec 19, 2017 at 3:02 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>>>>> wrote:
>>>>>>>> Please, find the log attached to this email.
>>>>>>>> Thank you Alessio!
>>>>>>>> *Sent:* 19 December 2017 14:51
>>>>>>>> Yes it is really strange.
>>>>>>>> Can you try to configure the GeoServer log level to verbose and
>>>>>>>> send to me the "geoserver.log" file ?
>>>>>>>> Regards,
>>>>>>>> Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> 55054
>>>>>>>>  Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> On Tue, Dec 19, 2017 at 2:48 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>>>>>> wrote:
>>>>>>>>> Yes, all database configs are correct; I followed the guide in the
>>>>>>>>> link you posted and I also have a PostGIS store correctly enabled in
>>>>>>>>> GeoServer, using those credentials.
>>>>>>>>> I have the same versions of Geonode and Geoserver (and Postgre sql
>>>>>>>>> as well) on a local development machine and everything works fine there. I
>>>>>>>>> have issues on this other machine, where I'm using Apache (on port 80) with
>>>>>>>>> WSGI daemon and Tomcat, instead of server on port 8000 and Jetty that come
>>>>>>>>> with the basic development installation.
>>>>>>>>> I also moved the Geoserver data directory to a custom
>>>>>>>>> /data/geoserver-data, after copying all contents of the original folder
>>>>>>>>> into the new one.
>>>>>>>>> I also set 777 permissions on both uploaded/layers of Geonode and
>>>>>>>>> GeoServer data directory, just to be sure that the problem was not there.
>>>>>>>>> So, I guess something is wrong with Tomcat configurations, but I
>>>>>>>>> don't know what (I also followed all guides I found, by the way).
>>>>>>>>> *Sent:* 19 December 2017 14:31
>>>>>>>>> *Cc:* geonode-users
>>>>>>>>> Did you correctly configured the database passwords and connection
>>>>>>>>> params on settings.py or local_settings.py ?
>>>>>>>>> Try to give a look here also
>>>>>>>>> in/002_geonode_install/create_geonode_db.html
>>>>>>>>> Regards,
>>>>>>>>> Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> 55054
>>>>>>>>>  Massarosa
>>>>>>>>> (LU)
>>>>>>>>> Italy
>>>>>>>>> On Tue, Dec 19, 2017 at 2:20 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>>>>>>> wrote:
>>>>>>>>>> My issue is still unresolved and I don't know how to deeply debug
>>>>>>>>>> it.
>>>>>>>>>> I get errors while trying to upload both shape files and raster
>>>>>>>>>> files; the only difference is that the process blocks at different points,
>>>>>>>>>> since I already have a PostGIS data store in GeoServer that would be used
>>>>>>>>>> for shape files.
>>>>>>>>>> Apparently, Geonode is unable to create a store into GeoServer.
>>>>>>>>>> This is an extract of Apache error log.
>>>>>>>>>> [Tue Dec 19 07:04:02.118664 <02%20118664> 2017] [wsgi:error]
>>>>>>>>>> [pid 4932:tid 140059365070592]   File "/home/luonist/risk_data_hub/m
>>>>>>>>>> y_venv/local/lib/python2.7/site-packages/geoserver/catalog.py",
>>>>>>>>>> line 555, in _create_coveragestore
>>>>>>>>>> [Tue Dec 19 07:04:02.118685 <02%20118685> 2017] [wsgi:error]
>>>>>>>>>> [pid 4932:tid 140059365070592]     raise UploadError(response)
>>>>>>>>>> [Tue Dec 19 07:04:02.118707 <02%20118707> 2017] [wsgi:error]
>>>>>>>>>> [pid 4932:tid 140059365070592] UploadError: Could not save the layer
>>>>>>>>>> bogota, there was an upload error: <!DOCTYPE html><html><head><title>Apache
>>>>>>>>>> Tomcat/8.0.32 (Ubuntu) - Error report</title><style type="text/css">H1
>>>>>>>>>> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
>>>>>>>>>> H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
>>>>>>>>>> H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
>>>>>>>>>> BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;}
>>>>>>>>>> B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
>>>>>>>>>> P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A
>>>>>>>>>> {color : black;}A.name {color : black;}.line {height: 1px;
>>>>>>>>>> background-color: #525D76; border: none;}</style> </head><body><h1>HTTP
>>>>>>>>>> Status 403 - Access is denied</h1><div class="line"></div><p><b>type</b>
>>>>>>>>>> Status report</p><p><b>message</b> <u>Access is
>>>>>>>>>> denied</u></p><p><b>description</b> <u>Access to the specified
>>>>>>>>>> resource has been forbidden.</u></p><hr class="line"><h3>Apache
>>>>>>>>>> Tomcat/8.0.32 (Ubuntu)</h3></body></html>
>>>>>>>>>> From GeoServer logs, I only find an error that comes later, when
>>>>>>>>>> it looks for a store that should have been created before (if I understand
>>>>>>>>>> correctly):
>>>>>>>>>> 2017-12-19 13:04:02,014 ERROR [geoserver.rest] - No such
>>>>>>>>>> datastore: geonode,bogota
>>>>>>>>>> 2017-12-19 13:04:02,016 ERROR [geoserver.rest] -
>>>>>>>>>> org.geoserver.rest.RestletException
>>>>>>>>>> 2017-12-19 13:04:02,050 ERROR [geoserver.rest] - No such coverage
>>>>>>>>>> 2017-12-19 13:04:02,051 ERROR [geoserver.rest] -
>>>>>>>>>> 2017-12-19 13:04:02,080 ERROR [geoserver.rest] - No such wms
>>>>>>>>>> I'm using Geonode 2.7.4, GeoServer 2.10 (taken from
>>>>>>>>>> http://build.geonode.org/geoserver/latest/), Apache 2.4, Tomcat
>>>>>>>>>> 8, OpenJDK 1.8.0_151
>>>>>>>>>> Thank you very much,
>>>>>>>>>> Stefano
>>>>>>>>>> *From:* geonode-users [geonode-users-bounces at lists.osgeo.org] on
>>>>>>>>>> behalf of Stefano.LUONI at ext.ec.europa.eu [
>>>>>>>>>> Stefano.LUONI at ext.ec.europa.eu]
>>>>>>>>>> *Sent:* 18 December 2017 09:50
>>>>>>>>>> *To:* alessio.fabiani at geo-solutions.it
>>>>>>>>>> *Cc:* geonode-users at lists.osgeo.org
>>>>>>>>>> *Subject:* Re: [GeoNode-users] Cannot upload layers
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> yes, the GeoServer WAR file came with the development
>>>>>>>>>> installation (paver setup); I then moved the WAR file into Tomcat
>>>>>>>>>> directory, in order to replace Jetty with Tomcat as container for
>>>>>>>>>> GeoServer. I'm already using the Geonode authentication on GeoServer,
>>>>>>>>>> though.
>>>>>>>>>> *Sent:* 13 December 2017 18:16
>>>>>>>>>> *Cc:* geonode-users
>>>>>>>>>> Are you using one of the GeoServer WARs and DataDir prepared for
>>>>>>>>>> GeoNode?
>>>>>>>>>> Regards,
>>>>>>>>>> Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> 55054
>>>>>>>>>>  Massarosa
>>>>>>>>>> (LU)
>>>>>>>>>> Italy
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> On Wed, Dec 13, 2017 at 6:04 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>>>>>>>> wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> I'm facing this issue: whenever I try to upload a layer (both
>>>>>>>>>>> shape file or raster), I receive a 403 error (Access is denied) from
>>>>>>>>>>> Tomcat.
>>>>>>>>>>> Error code (403) from GeoServer:
>>>>>>>>>>> HTTP Status 403 - Access is denied
>>>>>>>>>>> *type* Status report
>>>>>>>>>>> *message* *Access is denied*
>>>>>>>>>>> *description* *Access to the specified resource has been
>>>>>>>>>>> forbidden.*
>>>>>>>>>>> Apache Tomcat/8.0.32 (Ubuntu)
>>>>>>>>>>> I'm working on a custom installation of Geonode v.2.7.4 on
>>>>>>>>>>> Ubuntu 16.04. I replaced Jetty with Tomcat8 as container for Geoserver,
>>>>>>>>>>> which is 2.10-SNAPSHOT.
>>>>>>>>>>> In Geoserver logs, I can find these errors:
>>>>>>>>>>> ERROR [org.geoserver.rest] - No such coverage store:
>>>>>>>>>>> geonode,geonode_data
>>>>>>>>>>> ERROR [org.geoserver.rest] - No such wms store:
>>>>>>>>>>> From Apache logs, I see that there is an exception thrown by
>>>>>>>>>>> my_venv/local/lib/python2.7/site-packages/geoserver/catalog.py",
>>>>>>>>>>> line 249, in save
>>>>>>>>>>> (headers['status'], body))
>>>>>>>>>>> FailedRequestError: Error code (403) from GeoServer
>>>>>>>>>>> Postgre sql is working correctly and I already configured and
>>>>>>>>>>> enabled a "datastore" PostGIS store in Geoserver.
>>>>>>>>>>> I followed all instructions about custom installation of Geonode
>>>>>>>>>>> (http://docs.geonode.org/en/master/tutorials/admin/install/c
>>>>>>>>>>> ustom_install.html) and advanced security (
>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver
>>>>>>>>>>> _geonode_security/).
>>>>>>>>>>> I checked that files exist in the "uploaded" directory under
>>>>>>>>>>> Geonode folder.
>>>>>>>>>>> I don't know what to do further to debug this issue.
>>>>>>>>>>> Can you help me?
>>>>>>>>>>> Stefano
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/ef73e801/attachment-0001.html>
Name: 2017-12-19 17_56_37-GeoNode.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/ef73e801/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/ef73e801/attachment-0003.png>
More information about the geonode-users mailing list
