[GeoNode-users] Migrating large number of layers to Geonode
Sacha Black sacha.black at gmail.com
Wed Dec 20 06:34:35 PST 2017
Thank you - I will try it.
If I prepare metadata and cartography (SLD) in advance, will the script
import them also?
If yes, what format should the metadata be? I have the old metadata in a
GeoNetwork, and can export and transform however is necessary.
If no, I will just edit the metadata afterwards as advised.
- Sacha
On Wed, Dec 20, 2017 at 12:46 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> You can try to use the following module
> http://docs.geonode.org/en/master/tutorials/admin/
> loading_data_into_geonode/importlayers.html?highlight=importlayers
> This management command should walk through a spatialdata set of files
> (either raster and vector) and import them on GeoNode and GeoServer with a
> default initial configuration.
> You still have to edit the metadata manually on a later step.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
> (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Dec 19, 2017 at 11:32 PM, Sacha Black <sacha.black at gmail.com>
> wrote:
>> hi list,
>> I am new to GeoNode and interested in migrating a large number of layers
>> (> 3000)  from an old Mapserver 6.x WMS server. They are mostly shapefiles
>> and some rasters.
>> I know I can connect to the existing WMS service to use the layers in
>> GeoNode, but since eventually the old server will be turned off, I would
>> like to know the best option to import the layers into GeoNode permanently.
>> I set up a basic GeoNode in a clean Ubuntu 16.04 install using the Quick
>> Guide (http://geonode.org/#install). But I didn't find any specific
>> instructions for setting up a bulk import.
>> Is there any examples of using a script to do this kind of task? Is this
>> a reasonable expectation? What warnings/best practices should I be aware of?
>> - Sacha
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/2103eaaf/attachment.html>
More information about the geonode-users mailing list
