[GeoNode-users] Overwrite Core Model in geonode project
Toni Schönbuchner toni.schoenbuchner at csgis.de
Thu Feb 2 03:15:34 PST 2017
Hi Simone,
thanks!
>  as said, creating you own fork of GeoNode may be a better solution!
mh mh mh geonode instance has been installed from apt. Also there is already
2.5 branch at github. I haven´t done before but keeping the fork in sync seems to
bring a lot of work as well. I´ll evalute the work of your first suggestion and
decide after words.
thanks & cheers,
Toni
> Am 02.02.2017 um 12:04 schrieb Simone Dalmasso <simone.dalmasso at gmail.com>:
> correct but is a big and heavy work. as said, creating you own fork of GeoNode may be a better solution!
> 2017-02-02 12:02 GMT+01:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>>:
> Dear Simone,
> thanks for your fast reply! Would you kindly check if I understood your advise correctly and picked the right places?
>> You have to define your own url, views etc.
> The metadata page is managed in first instance of layers app.
> layers/urls.py points to layers/views.py
> layers/views.py uses layers/models.py
> layers/model.py inherits from base/models.py
> This means it could work like this:
> copy apps: /base and /layers to /var/www/my_project
> Routing views: change  my_project/layers/urls.py to use  my_project/layers/views.py
>  https://github.com/GeoNode/geonode/blob/2.4.x/geonode/layers/urls.py#L30 <https://github.com/GeoNode/geonode/blob/2.4.x/geonode/layers/urls.py#L30>
> models: change my_project/layers/views.py to use my_project/layers/models.py
> https://github.com/GeoNode/geonode/blob/2.4.x/geonode/layers/views.py#L47 <https://github.com/GeoNode/geonode/blob/2.4.x/geonode/layers/views.py#L47>
> change my_project/models.py to use my_project/base/models.py
> https://github.com/GeoNode/geonode/blob/2.4.x/geonode/layers/models.py#L33 <https://github.com/GeoNode/geonode/blob/2.4.x/geonode/layers/models.py#L33>
> Correct?
> Thanks a lot,
> Toni
>> Am 02.02.2017 um 10:53 schrieb Simone Dalmasso <simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>>:
>> Hi, the way to use your own models instead of the default ones is quite tricky.
>> You have to define your own url, views etc. This is one of the cases where a fork could be an option to consider.
>> 2017-02-02 10:26 GMT+01:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>>:
>> Dear List,
>> on Geonode 2.4 (Ubuntu 14.04) I´d like to extend the metadata details page (route /metadata).
>> This works perfectly by extending the base model which lives under:
>> /usr/local/lib/python2.7/dist-packages/geonode/base/models.py
>> To not hack the core we created a new project under /var/www/my_project
>> and copied the base app there (/var/www/my_project/base).
>> Template overrides work as expected but unfortunately it seems project models are ignored
>> (and still the core model is utilized).
>> What is the recommended way to customize models without changing the core?
>> Thanks,
>> Toni
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170202/d3f00b68/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170202/d3f00b68/attachment.sig>
More information about the geonode-users mailing list
