[GeoNode-users] unable to login
Gi Petrak gkpetrak at gmail.com
Wed Feb 15 02:14:59 PST 2017
Good morning,
After installation you have to run in your terminal the following command:
geonode createsuperuser
or navigate to the geonode folder (cd path/to/geonode) where manage.py
lives and run:
python manage.py createsuperuser
In both cases geonode system will prompt you to insert a username and a
password. These credentials
are the username and password of admin user (super user). Then if you
insert them to the sign in form
of geonode, you will be connected as admin user.
I hope this will help.
George
2017-02-15 6:26 GMT+02:00 Yogini Jalidar Sonawane <
yoginij.sonawane at st.niituniversity.in>:
> Good Morning Sir,
> No Sir..
> What should I do now? Should i reinstall the setup? Can you give proper
> link t install or set a proper path for GeoNode on Windows?
> Thanks and regards,
> Yogini
> On Wed, Feb 15, 2017 at 12:17 AM, Gi Petrak <gkpetrak at gmail.com> wrote:
>> Hello,
>> What installation guide did you follow ?
>> Did you run the command: geonode createsuperuser or python manage.py
>> createsuperuser in order to create a super user ?
>> Regards,
>> George
>> 2017-02-14 12:39 GMT+02:00 Yogini Jalidar Sonawane <
>>> Dear sir/madam,
>>>  First i want to say thanks a lot for installation web site. I installed
>>> GeoNode with having an error. But now facing a problem with user name and
>>> password. I am not able to log in now.
>>> Thanks and Regards,
>>> Yogini
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170215/e039cea5/attachment.html>
More information about the geonode-users mailing list
