[GeoNode-users] Custom Installation
Giovani Fronza giovanifronza at gmail.com
Fri Feb 17 07:05:17 PST 2017
I think so. DonĀ“t tried to start paver before, but now, it retuns this
messanges:
---> pavement.start_django
python manage.py runserver  &
GeoNode is now available.
root at vmgeo:/home/geonode# Performing system checks...
System check identified some issues:
WARNINGS:
base.ResourceBase.tkeywords: (fields.W340) null has no effect on
ManyToManyField.
System check identified 1 issue (0 silenced).
February 17, 2017 - 08:54:03
Django version 1.8.17, using settings 'geonode.settings'
Starting development server at http://127.0.0.1:8000/
Quit the server with CONTROL-C.
2017-02-17 12:17 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
> Before starting using httpd and mod_wsgi: does your GeoNode instance
> work correctly with the development server? You can start it with
> paver start, as suggested in the documentation page you have linked
> p
> On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza <giovanifronza at gmail.com>
> wrote:
> > Thankyou very much Paolo!
> > After installation I faced problem with wsgi. Something related to
> > geoserver.catalog.
> > I found this on apache error.log
> >  mod_wsgi (pid=22240): Target WSGI script '/home/geonode/geonode/wsgi.
> py'
> > cannot be loaded as Python module.
> >  mod_wsgi (pid=22240): Exception occurred processing WSGI script
> > '/home/geonode/geonode/wsgi.py'.
> >  Traceback (most recent call last):
> >    File "/home/geonode/geonode/wsgi.py", line 30, in <module>
> >      application = get_wsgi_application()
> >    File "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py",
> line
> > 14, in get_wsgi_application
> >      django.setup()
> >    File "/usr/local/lib/python2.7/dist-packages/django/__init__.py",
> line
> > 18, in setup
> >      apps.populate(settings.INSTALLED_APPS)
> >    File "/usr/local/lib/python2.7/dist-packages/django/apps/
> registry.py",
> > line 108, in populate
> >      app_config.import_models(all_models)
> >    File "/usr/local/lib/python2.7/dist-packages/django/apps/config.py",
> line
> > 198, in import_models
> >      self.models_module = import_module(models_module_name)
> >    File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
> > import_module
> >      __import__(name)
> >    File "/home/geonode/geonode/services/models.py", line 24, in <module>
> >      from geoserver.catalog import FailedRequestError, Catalog
> >  ImportError: No module named catalog
> > How to resolv that?
> > 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
> >> Hi Giovani
> >> you should be able to get the 2.6 (note that it is still not released)
> by
> >> checking out the 2.6 tag from git:
> >> https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1
> >> hope it helps
> >> p
> >> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza <
> >> wrote:
> >> > I've just installed the current geonode.git, according to the
> >> > instructions
> >> > presented on
> >> > http://docs.geonode.org/en/master/tutorials/admin/
> install/custom_install.html,
> >> > and for my surprise that was installed the 2.7.dev version.
> >> > I'm curious about 2.6 stable release. We have just started a big
> project
> >> > to
> >> > manage geospatial data and we would like to lead with a solution
> newest
> >> > as
> >> > possible.
> >> > Is there a realistic date for 2.6 version launch?
> >> > What are your recomendations for custom installation (for debian),
> >> > considering this situation?
> >> > Giovani
> >> > _______________________________________________
> >> > geonode-users mailing list
> >> > geonode-users at lists.osgeo.org
> >> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> >> Paolo Corti
> >> Geospatial software developer
> >> web: http://www.paolocorti.net
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170217/dd62d7a9/attachment.html>
More information about the geonode-users mailing list
