[GeoNode-users] Custom Installation
Paolo Corti pcorti at gmail.com
Fri Feb 17 07:19:58 PST 2017
Yes, after checking out the git tag, you should reinstall resources
(with sudo pip install -e .) as there could be differences.
p
On Fri, Feb 17, 2017 at 10:09 AM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> Hi, seems that you may have a wrong version of gsconfig. pls check that.
> 2017-02-17 16:05 GMT+01:00 Giovani Fronza <giovanifronza at gmail.com>:
>> I think so. DonĀ“t tried to start paver before, but now, it retuns this
>> messanges:
>> ---> pavement.start_django
>> python manage.py runserver  &
>> GeoNode is now available.
>> root at vmgeo:/home/geonode# Performing system checks...
>> System check identified some issues:
>> WARNINGS:
>> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>> ManyToManyField.
>> System check identified 1 issue (0 silenced).
>> February 17, 2017 - 08:54:03
>> Django version 1.8.17, using settings 'geonode.settings'
>> Starting development server at http://127.0.0.1:8000/
>> Quit the server with CONTROL-C.
>> 2017-02-17 12:17 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>>> Before starting using httpd and mod_wsgi: does your GeoNode instance
>>> work correctly with the development server? You can start it with
>>> paver start, as suggested in the documentation page you have linked
>>> p
>>> On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza <giovanifronza at gmail.com>
>>> wrote:
>>> > Thankyou very much Paolo!
>>> > After installation I faced problem with wsgi. Something related to
>>> > geoserver.catalog.
>>> > I found this on apache error.log
>>> >  mod_wsgi (pid=22240): Target WSGI script
>>> > '/home/geonode/geonode/wsgi.py'
>>> > cannot be loaded as Python module.
>>> >  mod_wsgi (pid=22240): Exception occurred processing WSGI script
>>> > '/home/geonode/geonode/wsgi.py'.
>>> >  Traceback (most recent call last):
>>> >    File "/home/geonode/geonode/wsgi.py", line 30, in <module>
>>> >      application = get_wsgi_application()
>>> >    File "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py",
>>> > line
>>> > 14, in get_wsgi_application
>>> >      django.setup()
>>> >    File "/usr/local/lib/python2.7/dist-packages/django/__init__.py",
>>> > line
>>> > 18, in setup
>>> >      apps.populate(settings.INSTALLED_APPS)
>>> >    File
>>> > "/usr/local/lib/python2.7/dist-packages/django/apps/registry.py",
>>> > line 108, in populate
>>> >      app_config.import_models(all_models)
>>> >    File "/usr/local/lib/python2.7/dist-packages/django/apps/config.py",
>>> > line
>>> > 198, in import_models
>>> >      self.models_module = import_module(models_module_name)
>>> >    File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>>> > import_module
>>> >      __import__(name)
>>> >    File "/home/geonode/geonode/services/models.py", line 24, in
>>> > <module>
>>> >      from geoserver.catalog import FailedRequestError, Catalog
>>> >  ImportError: No module named catalog
>>> > How to resolv that?
>>> > 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>>> >> Hi Giovani
>>> >> you should be able to get the 2.6 (note that it is still not released)
>>> >> by
>>> >> checking out the 2.6 tag from git:
>>> >> https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1
>>> >> hope it helps
>>> >> p
>>> >> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza
>>> >> wrote:
>>> >> > I've just installed the current geonode.git, according to the
>>> >> > instructions
>>> >> > presented on
>>> >> > http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html,
>>> >> > and for my surprise that was installed the 2.7.dev version.
>>> >> > I'm curious about 2.6 stable release. We have just started a big
>>> >> > project
>>> >> > to
>>> >> > manage geospatial data and we would like to lead with a solution
>>> >> > newest
>>> >> > as
>>> >> > possible.
>>> >> > Is there a realistic date for 2.6 version launch?
>>> >> > What are your recomendations for custom installation (for debian),
>>> >> > considering this situation?
>>> >> > Giovani
>>> >> > _______________________________________________
>>> >> > geonode-users mailing list
>>> >> > geonode-users at lists.osgeo.org
>>> >> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> >> Paolo Corti
>>> >> Geospatial software developer
>>> >> web: http://www.paolocorti.net
>>> >> twitter: @capooti
>>> >> skype: capooti
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
> Simone
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
