[GeoNode-users] Custom Installation
Paolo Corti pcorti at gmail.com
Fri Feb 17 07:59:47 PST 2017
No problem, is fine if you are not using git but the zip file.
I see that gsconfig is the correct version for 2.6.0+alpha1, so I
believe it could be a problem of Python paths of the wsgi
configuration. Moreover you are not getting the error using the dev
server, as far as I understand.
p
On Fri, Feb 17, 2017 at 10:56 AM, Giovani Fronza
<giovanifronza at gmail.com> wrote:
> $ pip freeze | grep gsconfig
> gsconfig==1.0.6
> $ git rev-parse HEAD
> fatal: Not a git repository (or any of the parent directories): .git
> I get a zip file from github sugested on first reply
> (https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1), unziped and
> copied content for my /home/geonode path.
> What is the correct way to get .git from 2.6? Sorry, I'm newbie on this.
> 2017-02-17 13:44 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> That seems fine, though I don't see gsconfig being downgraded as it
>> should according to Simone's suggestion.
>> Could you check what is the output of: pip freeze | grep gsconfig
>> Also please let me know what is the output of this: git rev-parse HEAD
>> p
>> On Fri, Feb 17, 2017 at 10:35 AM, Giovani Fronza
>> > Wen run ($ sudo pip isntall -e .) returns a warning...
>> > Installing collected packages: GeoNode
>> >   Running setup.py develop for GeoNode
>> >     warning: manifest_maker: MANIFEST.in, line 2: 'recursive-exclude'
>> > expects <dir> <pattern1> <pattern2> ...
>> >     Creating /usr/local/lib/python2.7/dist-packages/GeoNode.egg-link
>> > (link
>> > to .)
>> >     GeoNode 2.5.16 is already the active version in easy-install.pth
>> >     Installed /home/geonode
>> > Successfully installed GeoNode
>> > Cleaning up...
>> > 2017-02-17 13:19 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> Yes, after checking out the git tag, you should reinstall resources
>> >> (with sudo pip install -e .) as there could be differences.
>> >> p
>> >> On Fri, Feb 17, 2017 at 10:09 AM, Simone Dalmasso
>> >> <simone.dalmasso at gmail.com> wrote:
>> >> > Hi, seems that you may have a wrong version of gsconfig. pls check
>> >> > that.
>> >> > 2017-02-17 16:05 GMT+01:00 Giovani Fronza <giovanifronza at gmail.com>:
>> >> >> I think so. DonĀ“t tried to start paver before, but now, it retuns
>> >> >> this
>> >> >> messanges:
>> >> >> ---> pavement.start_django
>> >> >> python manage.py runserver  &
>> >> >> GeoNode is now available.
>> >> >> root at vmgeo:/home/geonode# Performing system checks...
>> >> >> System check identified some issues:
>> >> >> WARNINGS:
>> >> >> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>> >> >> ManyToManyField.
>> >> >> System check identified 1 issue (0 silenced).
>> >> >> February 17, 2017 - 08:54:03
>> >> >> Django version 1.8.17, using settings 'geonode.settings'
>> >> >> Starting development server at http://127.0.0.1:8000/
>> >> >> Quit the server with CONTROL-C.
>> >> >> 2017-02-17 12:17 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> >>> Before starting using httpd and mod_wsgi: does your GeoNode
>> >> >>> instance
>> >> >>> work correctly with the development server? You can start it with
>> >> >>> paver start, as suggested in the documentation page you have linked
>> >> >>> p
>> >> >>> On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza
>> >> >>> wrote:
>> >> >>> > Thankyou very much Paolo!
>> >> >>> > After installation I faced problem with wsgi. Something related
>> >> >>> > to
>> >> >>> > geoserver.catalog.
>> >> >>> > I found this on apache error.log
>> >> >>> >  mod_wsgi (pid=22240): Target WSGI script
>> >> >>> > '/home/geonode/geonode/wsgi.py'
>> >> >>> > cannot be loaded as Python module.
>> >> >>> >  mod_wsgi (pid=22240): Exception occurred processing WSGI script
>> >> >>> > '/home/geonode/geonode/wsgi.py'.
>> >> >>> >  Traceback (most recent call last):
>> >> >>> >    File "/home/geonode/geonode/wsgi.py", line 30, in <module>
>> >> >>> >      application = get_wsgi_application()
>> >> >>> >    File
>> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py",
>> >> >>> > line
>> >> >>> > 14, in get_wsgi_application
>> >> >>> >      django.setup()
>> >> >>> >    File
>> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/__init__.py",
>> >> >>> > line
>> >> >>> > 18, in setup
>> >> >>> >      apps.populate(settings.INSTALLED_APPS)
>> >> >>> >    File
>> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/apps/registry.py",
>> >> >>> > line 108, in populate
>> >> >>> >      app_config.import_models(all_models)
>> >> >>> >    File
>> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/apps/config.py",
>> >> >>> > line
>> >> >>> > 198, in import_models
>> >> >>> >      self.models_module = import_module(models_module_name)
>> >> >>> >    File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>> >> >>> > import_module
>> >> >>> >      __import__(name)
>> >> >>> >    File "/home/geonode/geonode/services/models.py", line 24, in
>> >> >>> > <module>
>> >> >>> >      from geoserver.catalog import FailedRequestError, Catalog
>> >> >>> >  ImportError: No module named catalog
>> >> >>> > How to resolv that?
>> >> >>> > 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> >>> >> Hi Giovani
>> >> >>> >> you should be able to get the 2.6 (note that it is still not
>> >> >>> >> released)
>> >> >>> >> by
>> >> >>> >> checking out the 2.6 tag from git:
>> >> >>> >> hope it helps
>> >> >>> >> p
>> >> >>> >> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza
>> >> >>> >> wrote:
>> >> >>> >> > I've just installed the current geonode.git, according to the
>> >> >>> >> > instructions
>> >> >>> >> > presented on
>> >> >>> >> > http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html,
>> >> >>> >> > and for my surprise that was installed the 2.7.dev version.
>> >> >>> >> > I'm curious about 2.6 stable release. We have just started a
>> >> >>> >> > big
>> >> >>> >> > project
>> >> >>> >> > to
>> >> >>> >> > manage geospatial data and we would like to lead with a
>> >> >>> >> > solution
>> >> >>> >> > newest
>> >> >>> >> > as
>> >> >>> >> > possible.
>> >> >>> >> > Is there a realistic date for 2.6 version launch?
>> >> >>> >> > What are your recomendations for custom installation (for
>> >> >>> >> > debian),
>> >> >>> >> > considering this situation?
>> >> >>> >> > Giovani
>> >> >>> >> > _______________________________________________
>> >> >>> >> > geonode-users mailing list
>> >> >>> >> > geonode-users at lists.osgeo.org
>> >> >>> >> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> >> >>> >> Paolo Corti
>> >> >>> >> Geospatial software developer
>> >> >>> >> web: http://www.paolocorti.net
>> >> >>> >> twitter: @capooti
>> >> >>> >> skype: capooti
>> >> >>> Paolo Corti
>> >> >>> twitter: @capooti
>> >> >>> skype: capooti
>> >> > Simone
>> >> Paolo Corti
>> >> twitter: @capooti
>> >> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
