[GeoNode-users] Custom Installation
Giovani Fronza giovanifronza at gmail.com
Fri Feb 17 09:01:19 PST 2017
Solved!
Corrected to:
WSGIDaemonProcess geonode
python-path=/home/geonode:/home/geonode/.venvs/geonode/lib/python2.7/site-packages
user=www-data threads=15 processes=2
After Apache restart everything is good!
Many, many thanks Paolo and Simone!
2017-02-17 14:40 GMT-02:00 Giovani Fronza <giovanifronza at gmail.com>:
> The instructions says to write a file geonode.conf with this on first line:
> WSGIDaemonProcess geonode python-path=/home/user/geonode:/home/user/.venvs/geonode/lib/python2.7/site-packages user=www-data threads=15 processes=2
> But I changed to this:
> WSGIDaemonProcess geonode python-path=/home/geonode:/usr/local/lib/python2.7/site-packages user=www-data threads=15 processes=2
> Site-packages are currently empty on this location. What would be the correct information for this line?
> 2017-02-17 13:59 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> No problem, is fine if you are not using git but the zip file.
>> I see that gsconfig is the correct version for 2.6.0+alpha1, so I
>> believe it could be a problem of Python paths of the wsgi
>> configuration. Moreover you are not getting the error using the dev
>> server, as far as I understand.
>> p
>> On Fri, Feb 17, 2017 at 10:56 AM, Giovani Fronza
>> <giovanifronza at gmail.com> wrote:
>> > $ pip freeze | grep gsconfig
>> > gsconfig==1.0.6
>> > $ git rev-parse HEAD
>> > fatal: Not a git repository (or any of the parent directories): .git
>> > I get a zip file from github sugested on first reply
>> > (https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1), unziped
>> and
>> > copied content for my /home/geonode path.
>> > What is the correct way to get .git from 2.6? Sorry, I'm newbie on this.
>> > 2017-02-17 13:44 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> That seems fine, though I don't see gsconfig being downgraded as it
>> >> should according to Simone's suggestion.
>> >> Could you check what is the output of: pip freeze | grep gsconfig
>> >> Also please let me know what is the output of this: git rev-parse HEAD
>> >> p
>> >> On Fri, Feb 17, 2017 at 10:35 AM, Giovani Fronza
>> >> > Wen run ($ sudo pip isntall -e .) returns a warning...
>> >> > Installing collected packages: GeoNode
>> >> >   Running setup.py develop for GeoNode
>> >> >     warning: manifest_maker: MANIFEST.in, line 2: 'recursive-exclude'
>> >> > expects <dir> <pattern1> <pattern2> ...
>> >> >     Creating /usr/local/lib/python2.7/dist-packages/GeoNode.egg-link
>> >> > (link
>> >> > to .)
>> >> >     GeoNode 2.5.16 is already the active version in easy-install.pth
>> >> >     Installed /home/geonode
>> >> > Successfully installed GeoNode
>> >> > Cleaning up...
>> >> > 2017-02-17 13:19 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> >> Yes, after checking out the git tag, you should reinstall resources
>> >> >> (with sudo pip install -e .) as there could be differences.
>> >> >> p
>> >> >> On Fri, Feb 17, 2017 at 10:09 AM, Simone Dalmasso
>> >> >> <simone.dalmasso at gmail.com> wrote:
>> >> >> > Hi, seems that you may have a wrong version of gsconfig. pls check
>> >> >> > that.
>> >> >> > 2017-02-17 16:05 GMT+01:00 Giovani Fronza <
>> >> >> >> I think so. DonĀ“t tried to start paver before, but now, it retuns
>> >> >> >> this
>> >> >> >> messanges:
>> >> >> >> ---> pavement.start_django
>> >> >> >> python manage.py runserver  &
>> >> >> >> GeoNode is now available.
>> >> >> >> root at vmgeo:/home/geonode# Performing system checks...
>> >> >> >> System check identified some issues:
>> >> >> >> WARNINGS:
>> >> >> >> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>> >> >> >> ManyToManyField.
>> >> >> >> System check identified 1 issue (0 silenced).
>> >> >> >> February 17, 2017 - 08:54:03
>> >> >> >> Django version 1.8.17, using settings 'geonode.settings'
>> >> >> >> Starting development server at http://127.0.0.1:8000/
>> >> >> >> Quit the server with CONTROL-C.
>> >> >> >> 2017-02-17 12:17 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> >> >>> Before starting using httpd and mod_wsgi: does your GeoNode
>> >> >> >>> instance
>> >> >> >>> work correctly with the development server? You can start it
>> with
>> >> >> >>> paver start, as suggested in the documentation page you have
>> linked
>> >> >> >>> p
>> >> >> >>> On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza
>> >> >> >>> wrote:
>> >> >> >>> > Thankyou very much Paolo!
>> >> >> >>> > After installation I faced problem with wsgi. Something
>> related
>> >> >> >>> > to
>> >> >> >>> > geoserver.catalog.
>> >> >> >>> > I found this on apache error.log
>> >> >> >>> >  mod_wsgi (pid=22240): Target WSGI script
>> >> >> >>> > '/home/geonode/geonode/wsgi.py'
>> >> >> >>> > cannot be loaded as Python module.
>> >> >> >>> >  mod_wsgi (pid=22240): Exception occurred processing WSGI
>> script
>> >> >> >>> > '/home/geonode/geonode/wsgi.py'.
>> >> >> >>> >  Traceback (most recent call last):
>> >> >> >>> >    File "/home/geonode/geonode/wsgi.py", line 30, in <module>
>> >> >> >>> >      application = get_wsgi_application()
>> >> >> >>> >    File
>> >> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py",
>> >> >> >>> > line
>> >> >> >>> > 14, in get_wsgi_application
>> >> >> >>> >      django.setup()
>> >> >> >>> >    File
>> >> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/__init__.py",
>> >> >> >>> > line
>> >> >> >>> > 18, in setup
>> >> >> >>> >      apps.populate(settings.INSTALLED_APPS)
>> >> >> >>> >    File
>> >> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/apps/registry
>> .py",
>> >> >> >>> > line 108, in populate
>> >> >> >>> >      app_config.import_models(all_models)
>> >> >> >>> >    File
>> >> >> >>> > "/usr/local/lib/python2.7/dist-packages/django/apps/config.
>> py",
>> >> >> >>> > line
>> >> >> >>> > 198, in import_models
>> >> >> >>> >      self.models_module = import_module(models_module_name)
>> >> >> >>> >    File "/usr/lib/python2.7/importlib/__init__.py", line 37,
>> in
>> >> >> >>> > import_module
>> >> >> >>> >      __import__(name)
>> >> >> >>> >    File "/home/geonode/geonode/services/models.py", line 24,
>> in
>> >> >> >>> > <module>
>> >> >> >>> >      from geoserver.catalog import FailedRequestError, Catalog
>> >> >> >>> >  ImportError: No module named catalog
>> >> >> >>> > How to resolv that?
>> >> >> >>> > 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> >> >>> >> Hi Giovani
>> >> >> >>> >> you should be able to get the 2.6 (note that it is still not
>> >> >> >>> >> released)
>> >> >> >>> >> by
>> >> >> >>> >> checking out the 2.6 tag from git:
>> >> >> >>> >> hope it helps
>> >> >> >>> >> p
>> >> >> >>> >> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza
>> >> >> >>> >> wrote:
>> >> >> >>> >> > I've just installed the current geonode.git, according to
>> the
>> >> >> >>> >> > instructions
>> >> >> >>> >> > presented on
>> >> >> >>> >> > http://docs.geonode.org/en/master/tutorials/admin/install/
>> custom_install.html,
>> >> >> >>> >> > and for my surprise that was installed the 2.7.dev version.
>> >> >> >>> >> > I'm curious about 2.6 stable release. We have just started
>> a
>> >> >> >>> >> > big
>> >> >> >>> >> > project
>> >> >> >>> >> > to
>> >> >> >>> >> > manage geospatial data and we would like to lead with a
>> >> >> >>> >> > solution
>> >> >> >>> >> > newest
>> >> >> >>> >> > as
>> >> >> >>> >> > possible.
>> >> >> >>> >> > Is there a realistic date for 2.6 version launch?
>> >> >> >>> >> > What are your recomendations for custom installation (for
>> >> >> >>> >> > debian),
>> >> >> >>> >> > considering this situation?
>> >> >> >>> >> > Giovani
>> >> >> >>> >> > _______________________________________________
>> >> >> >>> >> > geonode-users mailing list
>> >> >> >>> >> > geonode-users at lists.osgeo.org
>> >> >> >>> >> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> >> >> >>> >> Paolo Corti
>> >> >> >>> >> Geospatial software developer
>> >> >> >>> >> web: http://www.paolocorti.net
>> >> >> >>> >> twitter: @capooti
>> >> >> >>> >> skype: capooti
>> >> >> >>> Paolo Corti
>> >> >> >>> twitter: @capooti
>> >> >> >>> skype: capooti
>> >> >> > Simone
>> >> >> Paolo Corti
>> >> >> twitter: @capooti
>> >> >> skype: capooti
>> >> Paolo Corti
>> >> twitter: @capooti
>> >> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170217/3a9adb8f/attachment-0001.html>
More information about the geonode-users mailing list
