[GeoNode-users] installing geonode 2.5.6
Dave Kennewell davekennewell at gmail.com
Mon Jan 2 23:48:12 PST 2017
Ah, thanks Simone... I had been trying on Ubuntu 14.04 and not getting
anywhere with the /testing repo.
On 16.04 I'm now getting the same packaging problems as Jeff mentioned in
his recent email (subject: "GeoNode 2.5.6 is out"). But at least I'm now on
the same page as everyone else :)
On 3 January 2017 at 11:08, Simo D [via OSGeo.org] <
ml-node+s1560n5301802h77 at n6.nabble.com> wrote:
> Hi, the fastest is to install geonode on xenial using the normal geonode
> installation guide but just use:
> sudo add-apt-repository ppa:geonode/testing
> instead of
> sudo add-apt-repository ppa:geonode/stable.
> hope this helps
> 2017-01-03 7:38 GMT+01:00 David Kennewell <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5301802&i=0>>:
>> Hi list,
>> I'd like to try out the new react viewer, and use django 1.8, not 1.6.
>> As of today, what's the easiest way to get this up and running on a clean
>> server?
>> regards
>> Dave
>> geonode-users mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301802&i=1>
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301802&i=2>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/installing-geonode-
> 2-5-6-tp5301801p5301802.html
> To unsubscribe from GeoNode users, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185389&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OXwtOTI1NjEyMTk0>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170103/4f4a3d08/attachment.html>
More information about the geonode-users mailing list
