[GeoNode-users] Error on running geonode using docker
Jeffrey Johnson ortelius at gmail.com
Wed Jan 4 07:57:15 PST 2017
Run it on your host _after_ docker-compose up. It will run the migrations
remotely in the right container.
https://github.com/GeoNode/geonode/blob/master/Makefile#L12
On Wed, Jan 4, 2017 at 7:55 AM, Sindile Bidla <
sindile.bidla at geoilocate.co.za> wrote:
> Hi Jeffrey,
> In which container must i execute `make sync`
> I was using the following workflow as per the notes:
> If you want to use Docker you can now:
> # build the docker container
> docker-compose build
> # run the docker container
> docker-compose up
> # turn it off
> docker-compose down
> Regards,
> Sindile
> On 04/01/2017 17:37, Jeffrey Johnson wrote:
> You need to execute `make sync` to run the migrations.
> On Wed, Jan 4, 2017 at 6:49 AM, Sindile Bidla <
>> I am trying to run geonode via the docker on Ubuntu 16.04, but have been
>> faced with the following error message:
>> running docker ps -a
>> CONTAINER ID        IMAGE                     COMMAND
>> CREATED             STATUS                    PORTS
>> NAMES
>> 543b85dfd393        geonode/nginx:geoserver   "nginx -g 'daemon off"   22
>> hours ago        Up 22 hours               0.0.0.0:80->80/tcp,
>> 443/tcp          geonode_nginx_1
>> 9a327ceeba10        geonode/django            "django-admin.py runs"   22
>> hours ago        Up 22 hours               8000/tcp
>> geonode_django_1
>> d25966950b90        geonode/django            "celery worker --app="   22
>> hours ago        Exited (0) 22 hours ago
>> geonode_celery_1
>> 1501d708bca9        geonode/geoserver         "/usr/local/tomcat/tm"   22
>> hours ago        Up 22 hours               0.0.0.0:32769->8080/tcp
>> geonode_geoserver_1
>> 1978155ef4f4        rabbitmq                  "docker-entrypoint.sh"   22
>> hours ago        Up 22 hours               4369/tcp, 5671-5672/tcp,
>> 25672/tcp   geonode_rabbitmq_1
>> 95324b25309d        postgres                  "/docker-entrypoint.s"   22
>> hours ago        Up 22 hours               5432/tcp
>> geonode_postgres_1
>> 63b5746192f9        geonode/geoserver_data    "/bin/true"              22
>> geoserver_data_dir
>> b6567923df39        elasticsearch             "/docker-entrypoint.s"   22
>> hours ago        Up 22 hours               9200/tcp,
>> 9300/tcp                   geonode_elasticsearch_1
>> geonode_celery_1 - Is this an expected behavior, if not what could I be
>> doing wrong?
>> Also going to http://localhost, I get the following error message:
>> ProgrammingError at /
>> relation "django_site" does not exist
>> LINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
>> Request Method: GET
>> Request URL: <http://localhost/>http://localhost/
>> Django Version: 1.8.7
>> Exception Type: ProgrammingError
>> Exception Value:
>> Exception Location: /usr/local/lib/python2.7/site-
>> packages/django/db/backends/utils.py in execute, line 64
>> Python Executable: /usr/local/bin/python2
>> Python Version: 2.7.9
>> Python Path:
>> ['/usr/local/bin',
>>  '/usr/src/app',
>>  '/usr/local/lib/python27.zip',
>>  '/usr/local/lib/python2.7',
>>  '/usr/local/lib/python2.7/plat-linux2',
>>  '/usr/local/lib/python2.7/lib-tk',
>>  '/usr/local/lib/python2.7/lib-old',
>>  '/usr/local/lib/python2.7/lib-dynload',
>>  '/usr/local/lib/python2.7/site-packages',
>>  '/usr/src/app']
>> Server time: Wed, 4 Jan 2017 08:38:38 -0600
>> I am able to access geoserver web interface though.
>> Will greatly appreciate any pointers.
>> Regards,
>> Sindile
>> _______________________________________________ geonode-users mailing
>> list geonode-users at lists.osgeo.org http://lists.osgeo.org/mailman
>> /listinfo/geonode-users
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170104/d5410022/attachment.html>
More information about the geonode-users mailing list
