[GeoNode-users] Error on running geonode using docker
Sindile Bidla sindile.bidla at geoilocate.co.za
Wed Jan 4 07:52:04 PST 2017
Hi Jeffrey,
Where should I run 'make sync'?
I followed the following instructions:
If you want to use Docker you can now:
# build the docker container
docker-compose build
# run the docker container
docker-compose up
# turn it off
docker-compose down
On 04/01/2017 17:37, Jeffrey Johnson wrote:
> You need to execute `make sync` to run the migrations.
> On Wed, Jan 4, 2017 at 6:49 AM, Sindile Bidla
> <sindile.bidla at geoilocate.co.za
> <mailto:sindile.bidla at geoilocate.co.za>> wrote:
>     I am trying to run geonode via the docker on Ubuntu 16.04, but
>     have been faced with the following error message:
>     running docker ps -a
>     CONTAINER ID        IMAGE COMMAND                  CREATED
>     STATUS                    PORTS NAMES
>     543b85dfd393        geonode/nginx:geoserver   "nginx -g 'daemon
>     off"   22 hours ago        Up 22 hours
>     0.0.0.0:80->80/tcp, 443/tcp          geonode_nginx_1
>     9a327ceeba10        geonode/django "django-admin.py runs"   22
>     hours ago        Up 22 hours               8000/tcp geonode_django_1
>     d25966950b90        geonode/django            "celery worker
>     --app="   22 hours ago        Exited (0) 22 hours ago geonode_celery_1
>     1501d708bca9        geonode/geoserver "/usr/local/tomcat/tm"   22
>     hours ago        Up 22 hours               0.0.0.0:32769->8080/tcp
>     geonode_geoserver_1
>     1978155ef4f4        rabbitmq "docker-entrypoint.sh"   22 hours
>     ago        Up 22 hours               4369/tcp, 5671-5672/tcp,
>     25672/tcp geonode_rabbitmq_1
>     95324b25309d        postgres "/docker-entrypoint.s"   22 hours
>     ago        Up 22 hours               5432/tcp geonode_postgres_1
>     63b5746192f9        geonode/geoserver_data
>     "/bin/true"              22 hours ago        Exited (0) 22 hours
>     ago geoserver_data_dir
>     b6567923df39        elasticsearch "/docker-entrypoint.s"   22
>     hours ago        Up 22 hours               9200/tcp, 9300/tcp
>     geonode_elasticsearch_1
>     geonode_celery_1 - Is this an expected behavior, if not what could
>     I be doing wrong?
>     Also going to http://localhost, I get the following error message:
>       ProgrammingError at /
>     relation "django_site" does not exist
>     LINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
>     Request Method: 	GET
>     Request URL: 	http://localhost/
>     Django Version: 	1.8.7
>     Exception Type: 	ProgrammingError
>     Exception Value:
>     Exception Location:
>     /usr/local/lib/python2.7/site-packages/django/db/backends/utils.py
>     in execute, line 64
>     Python Executable: 	/usr/local/bin/python2
>     Python Version: 	2.7.9
>     Python Path:
>     ['/usr/local/bin',
>       '/usr/src/app',
>       '/usr/local/lib/python27.zip',
>       '/usr/local/lib/python2.7',
>       '/usr/local/lib/python2.7/plat-linux2',
>       '/usr/local/lib/python2.7/lib-tk',
>       '/usr/local/lib/python2.7/lib-old',
>       '/usr/local/lib/python2.7/lib-dynload',
>       '/usr/local/lib/python2.7/site-packages',
>       '/usr/src/app']
>     Server time: 	Wed, 4 Jan 2017 08:38:38 -0600
>     I am able to access geoserver web interface though.
>     Will greatly appreciate any pointers.
>     Regards,
>     Sindile
>     _______________________________________________ geonode-users
>     mailing list geonode-users at lists.osgeo.org
>     <mailto:geonode-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geonode-users
>     <http://lists.osgeo.org/mailman/listinfo/geonode-users>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170104/53ba4da4/attachment-0001.html>
More information about the geonode-users mailing list
