[GeoNode-users] installing geonode 2.5.6
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Jan 5 05:14:07 PST 2017
BTW, this is the playbook I used:
- hosts: amazon
   remote_user: ubuntu
   gather_facts: no
   pre_tasks:
     - name: 'install python2'
       raw: apt -y update && apt install -y python-minimal
       sudo: yes
     - setup:
   vars:
     app_name: my_geonode
     github_user: GeoNode
     server_name: 35.162.6.33
     deploy_user: ubuntu
   roles:
      - { role: GeoNode.geonode }
On 01/05/2017 03:12 PM, Angelos Tzotsos wrote:
> Hi Dave,
> I have seen this error before, only when testing on Amazon.
> There are some new commits in the ansible script, can you please try
> again on a clean VM?
> Also, if you are pulling the role from ansible galaxy, can you please
> make sure to get the latest version?
> Please let me know how this goes.
> Cheers,
> Angelos
> On 01/05/2017 01:16 PM, Dave Kennewell wrote:
>> Hi Angelos,
>> Thanks for this - I've tried the geonode-ansible installer. It seems
>> to be
>> working well, until I get to the "makemigrations" command, when I get
>> this
>> permissions error:
>> [image: Inline images 1]
>> If I ssh into the server, activate the venv and execute the
>> makemigrations
>> command manually, it works fine... but the rest of the playbook won't
>> run.
>> My playbook looks like this
>> - hosts: webserver
>>    remote_user: ubuntu
>>    vars:
>>      app_name: my_test_app
>>    roles:
>>      - geonode
>> Both my ansible controlling machine & the geonode server are running
>> Xenial.
>> It's my first time using ansible, so I might be doing something not
>> quite
>> right, or it might the the scripts?
>> Thanks
>> Dave Kennewell
>> On 3 January 2017 at 18:29, Angelos Tzotsos [via OSGeo.org] <
>> ml-node+s1560n5301842h17 at n6.nabble.com> wrote:
>>> Hi all,
>>> I just completed updating the ansible installer for Ubuntu Xenial:
>>> https://github.com/GeoNode/ansible-geonode
>>> Please test and let me know how this works out.
>>> I am going to work on the ppa issues next.
>>> Best,
>>> Angelos
>>> On 01/03/2017 10:01 AM, David Kennewell wrote:
>>> Ah, thanks Simone... I had been trying on Ubuntu 14.04 and not getting
>>> anywhere with the /testing repo.
>>> On 16.04 I'm now getting the same packaging problems as Jeff
>>> mentioned in
>>> his recent email (subject: "GeoNode 2.5.6 is out"). But at least I'm
>>> now on
>>> the same page as everyone else :)
>>> (and apologies for any cross-posting with this reply, I've been getting
>>> confused with my email lists)
>>> David Kennewell
>>> Water Resources Engineer
>>> Hydrata.com
>>> +971 55 409 7378[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5301842&i=0>
>>> On Tue, Jan 3, 2017 at 11:08 AM, Simone Dalmasso [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5301842&i=1>
>>> wrote:
>>> Hi, the fastest is to install geonode on xenial using the normal
>>> geonode
>>> installation guide but just use:
>>> sudo add-apt-repository ppa:geonode/testing
>>> instead of
>>> sudo add-apt-repository ppa:geonode/stable.
>>> hope this helps
>>> 2017-01-03 7:38 GMT+01:00 David Kennewell [hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5301842&i=2>:
>>> Hi list,
>>> I'd like to try out the new react viewer, and use django 1.8, not 1.6.
>>> As of today, what's the easiest way to get this up and running on a
>>> clean
>>> server?
>>> regards
>>> Dave
>>> geonode-users mailing list[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5301842&i=3>http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>>> <http:///user/SendEmail.jtp?type=node&node=5301842&i=4>http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Angelos Tzotsos, PhD
>>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
>>> geonode-devel mailing list
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=5>
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> If you reply to this email, your message will be added to the
>>> discussion
>>> below:
>>> http://osgeo-org.1560.x6.nabble.com/Re-GeoNode-users-install
>>> ing-geonode-2-5-6-tp5301842.html
>>> To unsubscribe from GeoNode devel, click here
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185388&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OHwtOTI1NjEyMTk0>
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> geonode-users at lists.osgeo.org
More information about the geonode-users mailing list
