[GeoNode-users] installing geonode 2.5.6
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Jan 5 16:07:24 PST 2017
Hi Dave,
It looks like this error is specific to ansible 2.x
The ansible role works fine with ansible 1.9.x for now.
We will try to fix this issue soon.
Thanks,
Angelos
On 01/05/2017 01:16 PM, Dave Kennewell wrote:
> Hi Angelos,
> Thanks for this - I've tried the geonode-ansible installer. It seems to be
> working well, until I get to the "makemigrations" command, when I get this
> permissions error:
> [image: Inline images 1]
> If I ssh into the server, activate the venv and execute the makemigrations
> command manually, it works fine... but the rest of the playbook won't run.
> My playbook looks like this
> - hosts: webserver
>    remote_user: ubuntu
>    vars:
>      app_name: my_test_app
>      github_user: GeoNode
>    roles:
>      - geonode
> Both my ansible controlling machine & the geonode server are running
> Xenial.
> It's my first time using ansible, so I might be doing something not quite
> right, or it might the the scripts?
> Thanks
> Dave Kennewell
> On 3 January 2017 at 18:29, Angelos Tzotsos [via OSGeo.org] <
> ml-node+s1560n5301842h17 at n6.nabble.com> wrote:
>> Hi all,
>> I just completed updating the ansible installer for Ubuntu Xenial:
>> https://github.com/GeoNode/ansible-geonode
>> Please test and let me know how this works out.
>> I am going to work on the ppa issues next.
>> Best,
>> Angelos
>> On 01/03/2017 10:01 AM, David Kennewell wrote:
>> Ah, thanks Simone... I had been trying on Ubuntu 14.04 and not getting
>> anywhere with the /testing repo.
>> On 16.04 I'm now getting the same packaging problems as Jeff mentioned in
>> his recent email (subject: "GeoNode 2.5.6 is out"). But at least I'm now on
>> the same page as everyone else :)
>> (and apologies for any cross-posting with this reply, I've been getting
>> confused with my email lists)
>> David Kennewell
>> Water Resources Engineer
>> Hydrata.com
>> +971 55 409 7378[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=0>
>> On Tue, Jan 3, 2017 at 11:08 AM, Simone Dalmasso [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=1>
>> wrote:
>> Hi, the fastest is to install geonode on xenial using the normal geonode
>> installation guide but just use:
>> sudo add-apt-repository ppa:geonode/testing
>> instead of
>> sudo add-apt-repository ppa:geonode/stable.
>> hope this helps
>> 2017-01-03 7:38 GMT+01:00 David Kennewell [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=2>:
>> Hi list,
>> I'd like to try out the new react viewer, and use django 1.8, not 1.6.
>> As of today, what's the easiest way to get this up and running on a clean
>> server?
>> regards
>> Dave
>> geonode-users mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=3>http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
>> geonode-users mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=4>http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Angelos Tzotsos, PhD
>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
>> geonode-devel mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=5>
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Re-GeoNode-users-install
>> ing-geonode-2-5-6-tp5301842.html
>> To unsubscribe from GeoNode devel, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185388&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OHwtOTI1NjEyMTk0>
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> geonode-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170106/a2119745/attachment-0001.html>
More information about the geonode-users mailing list
