[GeoNode-users] Running Geonode development build on another ip (!= localhost)
Daniel Victoria daniel.victoria at gmail.com
Wed Jan 11 05:03:25 PST 2017
I get an error that it's not possible to connect to the address
http://192.168.67.103/ or http://192.168.67.103:8000/
But if I go to geoserver page on http://192.168.67.103:8080/geoserver and
click on the geonode Icon, I get redirected to localhost:8000 (which does
not work).
I tryed both `paver start` and `paver start -b 192.168.67.103:8000`
What did work was to issue `python manage.py runserver 192.168.67.103:8000`.
With that I can get to GeoNode at the address but the link to Geoserver
does not work because it looks for geoserver under localhost:8080
Will changing the geoserver address in settings.py fix this?
My setup is a bit strange because my virtualbox connects to the internet
via a NAT interface and connetcs to my host computer using a host-only net
interface
Thanks
On Wed, Jan 11, 2017 at 10:29 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Sure you can, what error do you get, 404 or something else? You may need
> to add the forward rule in virtualbox to port 8000.
> 2017-01-11 12:45 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> I'm trying to setup the GeoNode development build following the
>> instructions in https://github.com/GeoNode/geonode (using the ubuntu
>> instructions - virtualevn; pip; paver). The catch is that I have a windows
>> machine so I installed a Ubuntu server on a Virtualbox (just the server, no
>> GUI).
>> I can access the server running on the virtualbox through the IP
>> 192.168.67.103
>> After doing paver stat, I can get to geoserver through the IP
>> However, I cannot get to geonode through the IP 192.168.67.103:8000
>> Is it possible to run the GeoNode development build this way? With just a
>> Ubuntu server install and access through an IP other than localhost?
>> Cheers
>> Daniel
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170111/8924580c/attachment.html>
More information about the geonode-users mailing list
