[GeoNode-users] RHEL 7
Francesco Bartoli xbartolone at gmail.com
Wed Jan 11 06:36:29 PST 2017
Yes it is but you don’t need to move any file. Please make sure to have python and pip commands in your PATH before running:
$ pip install -e .
and
$ python manage.py <something>
Again each of them has to be executed from /home/geonode/geonode
Francesco
Il giorno 11/gen/2017, alle ore 10:55, Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos) <jm.vazquez.lopez at cfnavarra.es> ha scritto:
> Yes, this repo works.
> Continuing the manual, I should modify the local_settings.py.sample file and save it as local_settings.py, but that file doesn’t exist.
> I can see two other: local_settings.py.geoserver.sample and local_settings.py.qgis.sample, so I modified the geoserver one and save it as local_settings.py
> Is this correct?
> Then, the manage.py is not in /home/geonode/geonode/genode directory, instead it is in /home/geonode/geonode, so I have copied it to /home/geonode/geonode/genode in order to execute it (and obtain the same error as above)
> Is this correct?
> Thanks
> Jose
> De: Francesco Bartoli [mailto:xbartolone at gmail.com]
> Enviado el: lunes, 09 de enero de 2017 16:14
> Para: Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos)
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] RHEL 7
> Have you already tried with this repo http://rpm.pbone.net/index.php3?stat=3&search=libxslt-python&srodzaj=3&dist[]=94?
> Il giorno 09/gen/2017, alle ore 13:10, Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos) <jm.vazquez.lopez at cfnavarra.es> ha scritto:
> Hi, Francesco.
> Sorry about Christmas long break.
> First, I Can’t find the proper libxslt-python package,
> After do  sudo yum install -y git gdal gdal-python geos python-pip python-imaging \
> python-virtualenv python-devel gcc-c++ python-psycopg2 libxml2 \
> libxml2-devel libxml2-python libxslt libxslt-devel libxslt-python,
> I get this:
> No existe disponible ningún paquete libxslt-python
> The rest of packages seem to be installed.
> Continuing the manual, I arrive at this point:
> python manage.py migrate with this result:
> Instrucción ilegal
> And, I can see this message in /var/log/messages:
> Jan  9 13:06:24 centjeedes12 kernel: traps: python[62459] trap invalid opcode ip:7f938dbbabee sp:7fff2b18c058 error:0 in etree.so[7f938d99c000+4b7000]
> Thanks
> Jose
> De: "xbartolone at gmail.com" [mailto:xbartolone at gmail.com]
> Enviado el: jueves, 22 de diciembre de 2016 17:06
> CC: "geonode-users at lists.osgeo.org"
> Hi Josè,
> What kind of issues are you facing?
> Francesco
> Inviato da TypeApp per iPhone
> On 22 dic 2016 at 16:29, Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos) <jm.vazquez.lopez at cfnavarra.es> wrote:
> Hi,
> Has anyone installed geonode over RHEL 7?
> I'm having trouble installing it, following the guide http://docs.geonode.org/en/master/tutorials/install_and_admin/setup_on_centos/setup_centos.html
> Thanks
> José Manuel Vázquez
> Lurraldeko Informazio Sistemen Atala / Sección de Sistemas de Información Territorial
> Informazio Sistema Korporatiboen Zerbitzua / Servicio de Sistemas de Información Corporativos
> Informatika, Telekomunikazio eta Berrikuntza Publikoaren Zuzendaritza Nagusia / Dirección General de Informática, Telecomunicaciones e Innovación Pública
> Lehendakaritzako, Funtzio Publikoko, Barneko eta Justiziako Departamentua / Departamento de Presidencia, Función Pública, Interior y Justicia
> Nafarroako Gobernua Gobierno de Navarra
> C/ Cabárceno, 6 - 3ª planta
> 31621 Sarriguren (Navarra)
> e-mail:        jm.vazquez.lopez at cfnavarra.es
> teléfono:   +34 848 426 169
> Lantokiaren kokalekua / Localízame en
> Antes de imprimir este mensaje, asegúrate de que es necesario. Proteger el medio ambiente está también en tu mano. Mesedez, gogoan izan ingurumenaren-inpaktua e-posta hau inprimatu baino lehen. Please consider your environmental responsibility before printing this e-mail.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170111/ff45985e/attachment.html>
More information about the geonode-users mailing list
