[GeoNode-users] RHEL 7
Francesco Bartoli xbartolone at gmail.com
Thu Jan 12 03:04:30 PST 2017
Then which manage.py command are you running from there? What error are you
facing?
Sent from [Nylas N1](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-60fab480-58a3/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vv
bm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the extensible, open source mail
client.
![](https://link.nylas.com/open/43o9gzlmd58gqwkxv3di3wjcc/local-
60fab480-58a3?r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
On gen 12 2017, at 11:43 am, Vázquez López, José Manuel (DGITIP-Serv.
Sist.Inf. Corporativos) <jm.vazquez.lopez at cfnavarra.es> wrote:
> No, I’m in the same directory:
> geonode at centjeedes12:geonode$ pwd
> /home/geonode/geonode
> geonode at centjeedes12:geonode$ ls -l
> total 132
> -rw-r--r--  1 root root  2687 ene 11 10:07 AUTHORS
> -rw-r--r--  1 root root   120 ene 11 10:07 CONTRIBUTING
> -rw-r--r--  1 root root   758 ene 11 10:07 dev_config.yml
> -rw-r--r--  1 root root   547 ene 11 10:07 docker-compose.override.yml
> -rw-r--r--  1 root root  1127 ene 11 10:07 docker-compose.yml
> -rw-r--r--  1 root root   199 ene 11 10:07 Dockerfile
> drwxr-xr-x  7 root root  4096 ene 11 10:07 docs
> drwxr-xr-x 22 root root  4096 ene 12 09:54 geonode
> drwxr-xr-x  2 root root   124 ene 11 10:10 GeoNode.egg-info
> -rw-r--r--  1 root root 35147 ene 11 10:07 license.txt
> -rw-r--r--  1 root root  1448 ene 11 10:07 Makefile
> -rwxr-xr-x  1 root root  1064 ene 11 10:07 manage.py
> -rw-r--r--  1 root root   325 ene 11 10:07 MANIFEST.in
> drwxr-xr-x  8 root root   116 ene 11 10:07 package
> -rw-r--r--  1 root root 22331 ene 11 10:07 pavement.py
> -rw-r--r--  1 root root 10190 ene 11 10:07 README
> lrwxrwxrwx  1 root root     6 ene 11 10:07 README.rst -> README
> -rw-r--r--  1 root root  1569 ene 11 10:07 requirements.txt
> drwxr-xr-x  8 root root    90 ene 11 10:07 scripts
> -rw-r--r--  1 root root    62 ene 11 10:07 setup.cfg
> -rw-r--r--  1 root root  4712 ene 11 10:07 setup.py
> **De:** Francesco Bartoli [mailto:xbartolone at gmail.com]
**Enviado el:** jueves, 12 de enero de 2017 11:28
**Para:** Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos)
**CC:** geonode-users at lists.osgeo.org
**Asunto:** Re: [GeoNode-users] RHEL 7
> So now is or isn't the error related to not being able to find the manage.py
script? Is something else?
/local-3ac7d7af-88ee/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=am0u
dmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc
client.![](https://link.nylas.com/open/43o9gzlmd58gqwkxv3di3wjcc/local-
3ac7d7af-88ee?r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=)
On gen 12 2017, at 10:38 am, Vázquez López, José Manuel (DGITIP-Serv.
<[jm.vazquez.lopez at cfnavarra.es](mailto:jm.vazquez.lopez at cfnavarra.es)> wrote:
> I think the script can’t find somewhat…
> This is my current PATH:
> /usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/java/bin:/home/geonod
e/.local/bin:/home/geonode/bin
> If I type python, the  interpreter starts correctly
> But, if I type python manage.py or python manage.py migrate or python
manage.py tururu… I obtain the error.
> Thanks
> Jose
> **De:** geonode-users [[mailto:geonode-users-bounces at lists.osgeo.org](mailto
:geonode-users-bounces at lists.osgeo.org)] **En nombre de **Francesco Bartoli
**Enviado el:** miércoles, 11 de enero de 2017 15:36
**CC:** [geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)
> Yes it is but you don’t need to move any file. Please make sure to have
python and pip commands in your PATH before running:
> $ pip install -e .
> and
> $ python manage.py <something>
> Again each of them has to be executed from /home/geonode/geonode
> Francesco
> Il giorno 11/gen/2017, alle ore 10:55, Vázquez López, José Manuel (DGITIP-
<[jm.vazquez.lopez at cfnavarra.es](mailto:jm.vazquez.lopez at cfnavarra.es)> ha
scritto:
> Yes, this repo works.
> Continuing the manual, I should modify the _local_settings.py.sample_ file
and save it _as local_settings.py_, but that file doesn’t exist.
> I can see two other: _local_settings.py.geoserver.sample_ and
_local_settings.py.qgis.sample, _ so I modified the geoserver one and save it
as _local_settings.py_
> Is this correct?
> Then, _the manage.py_ is not _in /home/geonode/geonode/genode_ directory,
instead it is in _/home/geonode/geonode_, so I have copied it to
_/home/geonode/geonode/genode_ in order to execute it (and obtain the same
error as above)
> Is this correct?
> Thanks
> Jose
[[mailto:xbartolone at gmail.com](mailto:xbartolone at gmail.com)]
**Enviado el:** lunes, 09 de enero de 2017 16:14
> Have you already tried with this repo
[http://rpm.pbone.net/index.php3?stat=3&search=libxslt-
python&srodzaj=3&dist[]=94](http://rpm.pbone.net/index.php3?stat=3&search
=libxslt-python&srodzaj=3&dist%5B%5D=94&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEu
ZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)?
> Il giorno 09/gen/2017, alle ore 13:10, Vázquez López, José Manuel (DGITIP-
scritto:
> Hi, Francesco.
> Sorry about _Christmas long break_.
> First, I Can’t find the proper libxslt-python package,
> After do  sudo yum install -y git gdal gdal-python geos python-pip python-
imaging \
> python-virtualenv python-devel gcc-c++ python-psycopg2 libxml2 \
> libxml2-devel libxml2-python libxslt libxslt-devel libxslt-python,
> I get this:
> No existe disponible ningún paquete libxslt-python
> The rest of packages seem to be installed.
> Continuing the manual, I arrive at this point:
> python manage.py migrate with this result:
> Instrucción ilegal
> And, I can see this message in /var/log/messages:
> Jan  9 13:06:24 centjeedes12 kernel: traps: python[62459] trap invalid
opcode ip:7f938dbbabee sp:7fff2b18c058 error:0 in
etree.so[7f938d99c000+4b7000]
> Thanks
> Jose
> **De:** "[xbartolone at gmail.com](mailto:xbartolone at gmail.com)"
**Enviado el:** jueves, 22 de diciembre de 2016 17:06
**CC:** "[geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)"
> Hi Josè,
What kind of issues are you facing?
Francesco
Inviato da [ TypeApp](http://www.typeapp.com/r&r=am0udmF6cXVlei5sb3BlekBjZm5hd
mFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) per iPhone
> On 22 dic 2016 [ at 16:29](x-apple-data-detectors://1&r=am0udmF6cXVlei5sb3Bl
ekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), Vázquez
> Hi,
> Has anyone installed geonode over RHEL 7?
I'm having trouble installing it, following the guide [ http://docs.geonode.or
g/en/master/tutorials/install_and_admin/setup_on_centos/setup_centos.html](htt
p://docs.geonode.org/en/master/tutorials/install_and_admin/setup_on_centos/set
up_centos.html&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0
> Thanks
> **José Manuel Vázquez**
> Lurraldeko Informazio Sistemen Atala / Sección de Sistemas de Información
Territorial
> Informazio Sistema Korporatiboen Zerbitzua / Servicio de Sistemas de
Información Corporativos
> Informatika, Telekomunikazio eta Berrikuntza Publikoaren Zuzendaritza
Nagusia / Dirección General de Informática, Telecomunicaciones e Innovación
Pública
> Lehendakaritzako, Funtzio Publikoko, Barneko eta Justiziako Departamentua /
Departamento de Presidencia, Función Pública, Interior y Justicia
> **Nafarroako Gobernua** **Gobierno de Navarra**
> [C/ Cabárceno, 6](x-apple-data-detectors://5&r=am0udmF6cXVlei5sb3BlekBjZm5hd
mFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) \- 3ª planta
31621 Sarriguren (Navarra)
> e-mail:
teléfono:   +34 848 426 169
> Lantokiaren kokalekua / Localízame en
> [ ](https://administracionelectronica.navarra.es/ApiSitnaIFrames/VisorPunto.
aspx?x=614672&y=4741153&detalles=Informatika%2C%20Telekomunikazio%20eta%20Berr
ikuntza%20Publikoaren%20Zuzendaritza%20Nagusia%20%2F%20Direcci%C3%B3n%20Genera
l%20de%20Inform%C3%A1tica%2C%20Telecomunicaciones%20e%20Innovaci%C3%B3n%20P%C3
%BAblica&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0
cy5vc2dlby5vcmc=)
> [Antes de imprimir este mensaje, asegúrate de que es necesario. Proteger el
medio ambiente está también en tu mano. Mesedez, gogoan izan ingurumenaren-
inpaktua e-posta hau inprimatu baino lehen. Please consider your environmental
responsibility before printing this e-mail.](https://administracionelectronica
.navarra.es/ApiSitnaIFrames/VisorPunto.aspx?x=614672&y=4741153&detalles=Inform
atika%2C%20Telekomunikazio%20eta%20Berrikuntza%20Publikoaren%20Zuzendaritza%20
Nagusia%20%2F%20Direcci%C3%B3n%20General%20de%20Inform%C3%A1tica%2C%20Telecomu
nicaciones%20e%20Innovaci%C3%B3n%20P%C3%BAblica&r=am0udmF6cXVlei5sb3BlekBjZm5h
cy5vc2dlby5vcmc=)
> [_______________________________________________
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users](https://administracione
lectronica.navarra.es/ApiSitnaIFrames/VisorPunto.aspx?x=614672&y=4741153&detal
les=Informatika%2C%20Telekomunikazio%20eta%20Berrikuntza%20Publikoaren%20Zuzen
daritza%20Nagusia%20%2F%20Direcci%C3%B3n%20General%20de%20Inform%C3%A1tica%2C%
20Telecomunicaciones%20e%20Innovaci%C3%B3n%20P%C3%BAblica&r=am0udmF6cXVlei5sb3
BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170112/1a42c505/attachment-0001.html>
More information about the geonode-users mailing list
