[GeoNode-users] Running Geonode development build on another ip (!= localhost)
Daniel Victoria daniel.victoria at gmail.com
Thu Jan 12 04:14:40 PST 2017
Thanks all for the help. I believe I've got it working now!
Cheers
Daniel
On Wed, Jan 11, 2017 at 12:03 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Ah yes, don't use paver otherwise will be only in localhost. And yes,
> adapt the geoserver PUBLIC_LOCATION to your needs in settings and will be
> fine.
> 2017-01-11 14:03 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> I get an error that it's not possible to connect to the address
>> http://192.168.67.103/ or http://192.168.67.103:8000/
>> But if I go to geoserver page on http://192.168.67.103:8080/geoserver
>> and click on the geonode Icon, I get redirected to localhost:8000 (which
>> does not work).
>> I tryed both `paver start` and `paver start -b 192.168.67.103:8000`
>> What did work was to issue `python manage.py runserver 192.168.67.103:8000`.
>> With that I can get to GeoNode at the address but the link to Geoserver
>> does not work because it looks for geoserver under localhost:8080
>> Will changing the geoserver address in settings.py fix this?
>> My setup is a bit strange because my virtualbox connects to the internet
>> via a NAT interface and connetcs to my host computer using a host-only net
>> interface
>> Thanks
>> On Wed, Jan 11, 2017 at 10:29 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Sure you can, what error do you get, 404 or something else? You may need
>>> to add the forward rule in virtualbox to port 8000.
>>> 2017-01-11 12:45 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>> I'm trying to setup the GeoNode development build following the
>>>> instructions in https://github.com/GeoNode/geonode (using the ubuntu
>>>> instructions - virtualevn; pip; paver). The catch is that I have a windows
>>>> machine so I installed a Ubuntu server on a Virtualbox (just the server, no
>>>> GUI).
>>>> I can access the server running on the virtualbox through the IP
>>>> 192.168.67.103
>>>> After doing paver stat, I can get to geoserver through the IP
>>>> However, I cannot get to geonode through the IP 192.168.67.103:8000
>>>> Is it possible to run the GeoNode development build this way? With just
>>>> a Ubuntu server install and access through an IP other than localhost?
>>>> Cheers
>>>> Daniel
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170112/6a91c874/attachment.html>
More information about the geonode-users mailing list
