[GeoNode-users] Running Geonode development build on another ip (!= localhost)
Daniel Victoria daniel.victoria at gmail.com
Thu Jan 12 10:58:12 PST 2017
I changed that but apparently it did not work. However, I got tired of
trying to fix the connection issues caused by running geonode development
in a ubuntu server from a virtualbox windows. So I installed a full
Ubuntu-desktop and I'm now running GeoNode from localhost. Things are
looking almost right now. Except for this message when I try to upload a
layer.
"GET /api/featured/ HTTP/1.1" 200 68
java.lang.UnsatisfiedLinkError: /tmp/
spatialite-3.7.22.4-libspatialitejdbc.so: libproj.so.0: cannot open shared
object file: No such file or directory
On Thu, Jan 12, 2017 at 2:56 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> I guess the issue is related to the "importlayers" command. I would have
> to debug it in order to understand. At a first glance it looks like the
> command does not make use of the geoserver usernamen/password defined on
> the setttings.
> Anyway. In order to make a test, try to update the "rest.properties" file
> under the GEOSERVER_DATA_DIR/security/rest.properties
> like follows:
> /rest/process/batchdownload/download/*;GET=IS_AUTHENTICATED_ANONYMOUSLY
> /rest/printing/*;GET,POST=IS_AUTHENTICATED_ANONYMOUSLY
> /**;GET=IS_AUTHENTICATED_ANONYMOUSLY
> /**;POST,DELETE,PUT=IS_AUTHENTICATED_ANONYMOUSLY
> NOTE: this is dangerous on a public instance. Until we improve the
> "importlayers" management command I suggest to revert this change once the
> import has finished.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Jan 12, 2017 at 5:45 PM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> same error as before (attached). I'm also attaching the geoserver oauth2
>> screen
>> On Thu, Jan 12, 2017 at 2:21 PM, Alessio Fabiani <
>>> Can you please try to run the following command?
>>> `python manage.py imporlayers -v 3 --user=admin some_shape_file`
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Thu, Jan 12, 2017 at 5:10 PM, Daniel Victoria <
>>>> I installed GeoNode following the development installation instructions
>>>> for Ubuntu, found on GitHub.
>>>> That gives me GeoNode *versão 2.5.7.dev20170111233058 and GeoServer *
>>>> 2.9-SNAPSHOT
>>>> I also changed the scope to 'write' in the OAuth2 geonode-oauth2
>>>> filter, following the email you sent today to the list
>>>> Cheers
>>>> Daniel
>>>> On Thu, Jan 12, 2017 at 11:59 AM, Alessio Fabiani <
>>>>> It might depend on a geoserver configuration that needs authentication
>>>>> to access REST APIs.
>>>>> Which version of GeoNode / GeoServer you installed exactly?
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Thu, Jan 12, 2017 at 1:59 PM, Daniel Victoria <
>>>>>> Well, sort off. Spoke too soon.
>>>>>> I can load geonode. I can get from geonode to geoserver and it
>>>>>> recognizes my user. I can upload data to GeoServer using the geoserver Data
>>>>>> importer. I can upload documents to Geonode. But, when I try to load a
>>>>>> shapefile using geonode I get a 403-forbiden
>>>>>> attached is the output from the command:
>>>>>> `python manage.py imporlayers -v 3 some_shape_file`
>>>>>> Cheers
>>>>>> Daniel
>>>>>> On Thu, Jan 12, 2017 at 10:14 AM, Daniel Victoria <
>>>>>>> Thanks all for the help. I believe I've got it working now!
>>>>>>> Cheers
>>>>>>> Daniel
>>>>>>> On Wed, Jan 11, 2017 at 12:03 PM, Simone Dalmasso <
>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>> Ah yes, don't use paver otherwise will be only in localhost. And
>>>>>>>> yes, adapt the geoserver PUBLIC_LOCATION to your needs in settings and will
>>>>>>>> be fine.
>>>>>>>> 2017-01-11 14:03 GMT+01:00 Daniel Victoria <
>>>>>>>> daniel.victoria at gmail.com>:
>>>>>>>>> I get an error that it's not possible to connect to the address
>>>>>>>>> http://192.168.67.103/ or http://192.168.67.103:8000/
>>>>>>>>> But if I go to geoserver page on http://192.168.67.103:8080/geo
>>>>>>>>> server and click on the geonode Icon, I get redirected to
>>>>>>>>> localhost:8000 (which does not work).
>>>>>>>>> I tryed both `paver start` and `paver start -b 192.168.67.103:8000
>>>>>>>>> What did work was to issue `python manage.py runserver
>>>>>>>>> 192.168.67.103:8000`. With that I can get to GeoNode at the
>>>>>>>>> address but the link to Geoserver does not work because it looks for
>>>>>>>>> geoserver under localhost:8080
>>>>>>>>> Will changing the geoserver address in settings.py fix this?
>>>>>>>>> My setup is a bit strange because my virtualbox connects to the
>>>>>>>>> internet via a NAT interface and connetcs to my host computer using a
>>>>>>>>> host-only net interface
>>>>>>>>> Thanks
>>>>>>>>> On Wed, Jan 11, 2017 at 10:29 AM, Simone Dalmasso <
>>>>>>>>>> Sure you can, what error do you get, 404 or something else? You
>>>>>>>>>> may need to add the forward rule in virtualbox to port 8000.
>>>>>>>>>> 2017-01-11 12:45 GMT+01:00 Daniel Victoria <
>>>>>>>>>>> I'm trying to setup the GeoNode development build following the
>>>>>>>>>>> instructions in https://github.com/GeoNode/geonode (using the
>>>>>>>>>>> ubuntu instructions - virtualevn; pip; paver). The catch is that I have a
>>>>>>>>>>> windows machine so I installed a Ubuntu server on a Virtualbox (just the
>>>>>>>>>>> server, no GUI).
>>>>>>>>>>> I can access the server running on the virtualbox through the IP
>>>>>>>>>>> 192.168.67.103
>>>>>>>>>>> After doing paver stat, I can get to geoserver through the IP
>>>>>>>>>>> 192.168.67.103:8080/geoserver
>>>>>>>>>>> However, I cannot get to geonode through the IP
>>>>>>>>>>> 192.168.67.103:8000
>>>>>>>>>>> Is it possible to run the GeoNode development build this way?
>>>>>>>>>>> With just a Ubuntu server install and access through an IP other than
>>>>>>>>>>> localhost?
>>>>>>>>>>> Cheers
>>>>>>>>>>> Daniel
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>> Simone
>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170112/af24b942/attachment-0001.html>
More information about the geonode-users mailing list
