[GeoNode-users] default workspace for geosites
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jan 13 01:59:16 PST 2017
Not sure but I'm afraid geonode has currently a lot of hardcoded stuff. It
is quite premature speaking about multi-tenancy on GeoNode.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Jan 13, 2017 at 10:44 AM, Eugenio Trumpy <frippe12573 at hotmail.com>
wrote:
> Dear all,
> I setup geosites in my geonode instance.
> I'm now testing the geosite I created. I tried to upload a SHP from my new
> geosite and the procedure went well.
> However in geoserver, I see the new layer under the workspace named
> 'geonode', which was created by the master site (for master site I mean
> the one we have with the default installation of geonode). Since i
> inserted the variable DEFAULT_WORKSPACE='mynewgeosite' in the settings.py
> placed in the folder of my new geosite, I was expected to have the new
> SHP in the new geoserver workspace.
> Where am I wrong?
> Moreover, after the layer upload I can see it in the layer list, but in
> the 'type' filter I see the vector layer loaded over all the others
> layers loaded in the master site.
> I was expected to have only 1 layer. Is that correct or it is due to a
> somehow miss-configuration?
> Thanks in advance
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170113/7e29c342/attachment.html>
More information about the geonode-users mailing list
