[GeoNode-users] apt-get geonode 2.5.4
Giovani Fronza giovanifronza at gmail.com
Mon Jan 16 04:24:27 PST 2017
There is some prevision for the 2.6 version launch?
2017-01-05 22:05 GMT-02:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> Hi,
> The debian packaging is not completed yet.
> Please use the stable ppa for GeoNode 2.4.x or use the ansible script to
> install 2.5.x
> https://github.com/GeoNode/ansible-geonode
> Cheers,
> Angelos
> On 01/05/2017 04:07 PM, Finnegan Pope-Carter wrote:
> Hi, I’m running into an error when trying to install geonode 2.5.4 on a fresh copy of Ubuntu 16.04. I’ve added the ppa:geonode/testing repository and run apt-get update but when I try to install geonode I get the following error:
> @geonode2:~$ sudo apt-get install geonode
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> geonode : Depends: geoserver-geonode but it is not installable or
>                     geoserver but it is not installable
>            Depends: postgresql-9.1-postgis but it is not installable or
>                     postgresql-9.3-postgis-2.1 but it is not installable
>            Depends: python-geonode-agon-ratings but it is not installable
>            Depends: python-dialogos but it is not installable
>            Depends: python-django-geoexplorer but it is not installable
>            Depends: python-geonode-notification but it is not installable
>            Depends: python-django-taggit-templatetags but it is not installable
>            Depends: python-geonode-user-accounts but it is not installable
>            Depends: python-geonode-avatar but it is not installable
>            Depends: python-gsconfig but it is not installable
>            Depends: python-geonode-announcements but it is not installable
>            Depends: python-pinax-theme-bootstrap but it is not going to be installed
>            Depends: python-tastypie but it is not installable
>            Depends: python-django-modeltranslation but it is not installable
>            Depends: python-gsimporter but it is not installable
>            Depends: python-geonode-arcrest but it is not installable
>            Recommends: python-gisdata but it is not installable
>            Recommends: transifex-client but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> Can anyone tell me what I’m doing wrong?
> Kind regards
> Finn
> geonode-users mailing listgeonode-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geonode-users
> Angelos Tzotsos, PhD
> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170116/7a6046f6/attachment.html>
More information about the geonode-users mailing list
