[GeoNode-users] default workspace for geosites
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jan 18 02:23:51 PST 2017
yes you can use
https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/templates/search
2017-01-18 11:01 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Ok, thank you for this further explanation Simone.
> Currently I have only the master site and the gemex site, so I tested:
>    - a layer uploaded in the master it is not seen in the gemex site, I
>    think this is correct
>    - a layer uploaded in the gemex site is seen in gemex of course but
>    also in the master site, this is correct too
>    - (I should test with a new geosite to upload a layer, in that case I
>    have to see it in the new geosite and of course in the master)
> Just a curiosity, is it possible to see only the layers uploaded in a
> geosite in the layer filter named 'type', since currently I see
> the total number of layer I have.
> thanks
> E.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* mercoledì 18 gennaio 2017 10.00
> *A:* Eugenio Trumpy
> *Cc:* Alessio Fabiani; geonode-users at lists.osgeo.org
> *Oggetto:* Re: [GeoNode-users] default workspace for geosites
> Eugenio,
> not sure about the workspace, probably the default one is used and the doc
> must be update, I'll find some time to check it.
> Anyway geosites already separates the layers, docs, maps and users by
> site. A layer uploaded by a normal user in a site will be visible only in
> that site. The normal use itself is visible in the specific site. Only
> administrators have access to all sites and resources. Geoserver
> getCapabilities also respect this so you don't have to worry. You as
> administrator can do other operations such as share resources or people
> across more sites.
> 2017-01-18 9:42 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Dear Simone,
>> I understood there is not the possibility to upload layers from sites in
>> different geoserver workspaces (is that definitely true or there is a way
>> to setup that by hand?) as described in the documentation, the only way is
>> to load all the layers from sites in the same geoserver workspace (geonode
>> is the default), then to yield layers visible to different sites the
>> administrator should setup the security data for each layer to a role
>> specially created, am I correct?
>> In this way I guess the administrator has to check always if a user
>> uploaded a layer in order to setup then the security on the uploaded
>> layers, am I right?
>> Currently in my site I have no layers uploaded, however, I see a certain
>> number of vector and raster layers uploaded (actually in 'geonode'
>> geoserver workspace), that's why those layer are set *.*.r in geoserver?
>> ciao
>> Eugenio
>> *Da:* Eugenio Trumpy <frippe12573 at hotmail.com>
>> *Inviato:* venerdì 13 gennaio 2017 12.04
>> *A:* Simone Dalmasso; Alessio Fabiani
>> *Cc:* geonode-users at lists.osgeo.org
>> The suggested way to store the layers belonging different geosites in
>> geoserver It seemed nice to me.
>> I read it here: https://geonode.readthedocs.io/en/2.0/tutorials/admin/
>> multi-tenancy.html
>> I wondered how I should create the workspace in geoserver.
>> I presume by hand from geoserver interface, then second question was
>> where I have to
>> set the workspace for the geosite since in the global setting.py I have:
>> DEFAULT_WORKSPACE
>> and
>> CASCADE_WORKSPACE (what does it means? What is it?)
>> I suppose the master site has to have DEFAULT_WORKSPACE = 'geonode'
>> whereas the site DEFAULT_WORKSPACE = 'geosite', so loading a layer from
>> the site it should use such workspace, is that right?
>> Why it does not work?
>> I understand that could be a second way (i.e. the way suggested by
>> Simone), could you give me an example? I guess you act layer by layer
>> adding new rules in geoserver 'Data security'.
>> ciao
>> Eugenio
>> *Inviato:* venerdì 13 gennaio 2017 11.45
>> *A:* Alessio Fabiani
>> *Cc:* Eugenio Trumpy; geonode-users at lists.osgeo.org
>> Not sure about the default workspace it might be a geonode bug. But I
>> leave the layers in the "geonode" one and it works well. Layers are managed
>> respecting permissions, and it works well in the instances I have.
>> 2017-01-13 10:59 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> Not sure but I'm afraid geonode has currently a lot of hardcoded stuff.
>>> It is quite premature speaking about multi-tenancy on GeoNode.
>>> Best Regards,
>>> Alessio Fabiani.
>>> GeoServer Professional Services from the experts!
>>> Visit http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> information in this message that has been received in error. The sender
>>> does not give any warranty or accept liability as the content, accuracy or
>>> completeness of sent messages and accepts no responsibility  for changes
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Fri, Jan 13, 2017 at 10:44 AM, Eugenio Trumpy <
>>> frippe12573 at hotmail.com> wrote:
>>>> Dear all,
>>>> I setup geosites in my geonode instance.
>>>> I'm now testing the geosite I created. I tried to upload a SHP from my
>>>> new geosite and the procedure went well.
>>>> However in geoserver, I see the new layer under the workspace named
>>>> 'geonode', which was created by the master site (for master site I
>>>> mean the one we have with the default installation of geonode). Since
>>>> i inserted the variable DEFAULT_WORKSPACE='mynewgeosite' in the
>>>> settings.py placed in the folder of my new geosite, I was expected to
>>>> have the new SHP in the new geoserver workspace.
>>>> Where am I wrong?
>>>> Moreover, after the layer upload I can see it in the layer list, but in
>>>> the 'type' filter I see the vector layer loaded over all the others
>>>> layers loaded in the master site.
>>>> I was expected to have only 1 layer. Is that correct or it is due to a
>>>> somehow miss-configuration?
>>>> Thanks in advance
>>>> Eugenio
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170118/1518ffa4/attachment-0001.html>
More information about the geonode-users mailing list
